Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Audi A8 D3 fault codes. Repairs ideas.
    Jul 2017
    Hello all,
    I have recently bought an A8 d3 2005 (UK) year, and have been experiencing issues with the MMI, it is currently stuck up and blank. Boot screen will load then it shuts down. I have intermittent success by removing the battery, charging and reinstalling. This has worked to return the MMI to operational order a couple of times. But it is not solving the problem, so I have had someone perform a VCDS scan on the full system and the Optical bus.
    There appears to be an issue with the battery regulation management system and some of the MMI components.
    The dealer I bought the car from (non specialist) has offered to repair the car and I would welcome anyone's thoughts on what a repair/component strategy might be.
    From my own research I am thinking, replace battery, battery management module, boss amp.
    Full VCDS scan results:
    Monday,10,July,2017,13:29:47:06319
    VCDS Version: 17.1.3.0 (x64)
    VIN: WAUZZZ4E46N002270 License Plate: DHA
    Mileage: 238400km-148134mi Repair Order:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38
    42 46 47 4F 52 53 55 56 61 62 67 72 76 77
    VIN: WAUZZZ4E46N002270 Mileage: 238400km-148134miles
    05-Acc/Start Auth. -- Status: Sporadic communication error 1000
    07-Control Head -- Status: Cannot be reached 1100
    18-Aux. Heat -- Status: Malfunction 1010
    1E-Media Player 2 -- Status: Cannot be reached 1100
    67-Voice Control -- Status: Cannot be reached 1100
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H01--- Serial number: AUX3Z0E3363322
    Coding: 0011973
    Shop #: WSC 02313 785 00200
    VCID: 2959ED1C80E18D099E-807C
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 - - Intermittent
    Mileage: 238122 km
    Date: 2017.07.04
    Time: 00:00:00
    Torque: 167.7 Nm
    Duty Cycle: 1.0 %
    Voltage: 10.56 V
    Bin. Bits: 00101111
    Torque: 89.7 Nm
    006249 - Transmission Mount Valve 1 (N262)
    P1869 - 001 - Short to Ground
    Mileage: 238122 km
    Date: 2017.07.04
    Time: 00:00:00
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 001 - Open Circuit
    Fault Status: 01110001
    Mileage: 238128 km
    Date: 2017.07.06
    Time: 01:05:55
    RPM: 882 /min
    Torque: 93.6 Nm
    Duty Cycle: 1.0 %
    Voltage: 11.70 V
    Duty Cycle: 24.1 %
    Temperature: 10.8°C
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4E0 910 156 F HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0090
    Revision: --H01--- Serial number: 4022977
    VCID: 2541E12CECF9A969BA-8070
    Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
    Component: ESP 5.7 allrad H44 0510
    Coding: 0008357
    Shop #: WSC 02313 000 00000
    VCID: 224BFA30FDD75E51DF-8076
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 909 131 C
    Component: FBS AUDID3 H04 0140
    Revision: 01404004 Serial number: AUX3Z0E3363322
    Coding: 0412672
    Shop #: WSC 02311 785 00200
    VCID: 58BF98D8EB0BC481F1-800C
    Component: ELV XXXX
    Address 06: Seat Mem. Pass Labels: None
    Part No SW: 4E0 910 760 C HW: 4E0 959 760
    Component: Sitzmemory BFS H08 0060
    Revision: 00000000 Serial number: 5DS 008 795-03
    Coding: 4063328
    Shop #: WSC 00000 785 00200
    VCID: 2345FF34E2CD5759D4-8076
    00456 - Control Module for Access and Start Control (J518)
    Reset counter: 161
    Mileage: 238160 km
    Date: 2017.07.06
    Time: 18:00:30
    Address 07: Control Head
    Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
    Component: KLIMAAUTOMAT 016 0400
    Revision: 00000030 Serial number: 00000000065950
    Coding: 1394705
    VCID: 1C37C4C8DFB368A115-8048
    00065 - Rear Left Footwell Heater (Z42)
    Reset counter: 119
    Mileage: 238128 km
    Date: 2017.07.04
    Time: 00:18:00
    Voltage: 13.20 V
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
    Component: ILM Fahrer H12 0210
    Coding: 0143121
    VCID: 3169057CA831F5C956-8064
    Subsystem 1 - Part No: 4E2 910 113 B
    Component: Wischer WWS D3 H50 0420
    Coding: 00000036
    Shop #: WSC 02313
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Coding: 00139548
    Shop #: WSC 02313
    Reset counter: 167
    00455 - Control Module for Access and Start Control; Comfort CAN (J518)
    Reset counter: 167
    Address 15: Airbags Labels: 4E0-910-655-84.lbl
    Part No SW: 4E0 910 655 HW: 4E0 959 655 G
    Component: Airbag 8.4E+ H10 0940
    Coding: 0431707
    VCID: 63C5BF34A24D175994-8036
    Address 16: Steering wheel Labels: 4E0-910-549.lbl
    Part No SW: 4E0 910 549 HW: 4E0 953 549
    Coding: 0112141
    VCID: 65C1A12CAC7969697A-8030
    Component: Lenkradmodul H07 0080
    Reset counter: 167
    Mileage: 238161 km
    Date: 2017.07.06
    Time: 18:00:28
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
    Component: KOMBIINSTR. VDO H71 0400
    Revision: D02 Serial number: AUDID3E3000050
    Coding: 0000413
    Shop #: WSC 59921 067 57207
    Address 18: Aux. Heat Labels: None
    Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
    Component: Heizgeraet H07 0100
    Revision: 0000000B Serial number: 00000009006406
    VCID: 1A3BC2D0D587169107-804E
    02251 - Heater Unit Locked
    Address 19: CAN Gateway Labels: 4E0-910-468.clb
    Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
    Component: Gateway H10 0080
    Revision: 10 Serial number: 19003054148122
    Coding: FCFE7FDE2B7104
    VCID: 275DEB2496F5BB7988-8072
    00384 - Optical Databus
    Fault Frequency: 59
    Reset counter: 127
    Mileage: 238128 km
    Date: 2017.07.04
    Time: 00:34:31
    01207 - Control Module for Auxiliary Heater (J364)
    Fault Frequency: 59
    Reset counter: 127
    Mileage: 238128 km
    Date: 2017.07.04
    Time: 00:34:31
    Reset counter: 161
    Mileage: 238161 km
    Date: 2017.07.06
    Time: 18:00:28
    Reset counter: 161
    Mileage: 238161 km
    Date: 2017.07.06
    Time: 18:00:28
    Address 1E: Media Player 2
    Address 25: Immobilizer Labels: 4E0-910-131.lbl
    Coding: 0412672
    Component: ELV XXXX
    XXXXXXXXXXX ELV XXXX
    Address 28: HVAC, Rear Labels: None
    Part No SW: 4E0 910 158 HW: 4E0 919 158 A
    Component: KLIMA-STG. FOND 015 0220
    Revision: 00000018 Serial number: 00000000026754
    Coding: 0000000
    VCID: 61C9B53CB851054986-8034
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
    Component: LUFTFDR.-CDC H06 4480
    Coding: 0015510
    VCID: 285FE8189BEBB40181-807C
    Component: Sitzmemory FS H08 0060
    Coding: 4063338
    Address 37: Navigation
    Address 38: Roof Electronics Labels: 4E0-910-135.lbl
    Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
    Component: Dachknoten D3 H02 0090
    Serial number: 00000502500025
    Coding: 0035972
    VCID: 1D31C9CCC4A961A9E2-8048
    Reset counter: 161
    Mileage: 238160 km
    Date: 2017.07.06
    Time: 18:00:00
    Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
    Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
    Component: Türsteuer.FS BRM003 0060
    Coding: 0028462
    VCID: 204FF038F3DB4C41C9-8074
    Fault Frequency: 14
    Reset counter: 127
    Mileage: 237456 km
    Date: 2017.06.20
    Time: 18:32:22
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 A HW: 4E0 907 289
    Component: Komfortgeraet H04 0040
    Revision: 00400004 Serial number: W040504090194
    Coding: 0004317
    Subsystem 1 - Part No: 4E0 907 719
    Component: Neigungssensor H03 0020
    00985 - Right Tail Light (M2)
    014 - Defective
    Fault Status: 01101110
    Reset counter: 127
    Mileage: 220112 km
    Date: 2016.08.27
    Time: 18:17:24
    Reset counter: 127
    Mileage: 220112 km
    Date: 2016.08.27
    Time: 18:17:24
    Reset counter: 161
    Mileage: 238161 km
    Date: 2017.07.06
    Time: 18:00:33
    Address 47: Sound System
    Address 4F: Centr. Electr. II Labels: None
    Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
    Component: ILM Beifahrer H09 0040
    Revision: Serial number: 00000000059824
    Coding: 0010101
    VCID: 1E33CEC0C9AF7AB1FB-804A
    Reset counter: 161
    Date: 2023.06.06
    Time: 00:00:00
    Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
    Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
    Component: Türsteuer.BF BRM003 0060
    Coding: 0028462
    Fault Frequency: 0
    Reset counter: 146
    Mileage: 237680 km
    Date: 2017.07.01
    Time: 09:49:40
    Address 53: Parking Brake Labels: 4E0-910-801.clb
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000221
    Shop #: WSC 00443 210 90890
    Part No: 8P0 907 357 D
    Coding: 0000006
    VCID: 3B7527547A7D0F99FC-806E
    Address 56: Radio
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
    Component: ENERGIEMANAGER H12 0480
    Revision: 00000000 Serial number: 00000000006661
    Shop #: WSC 00579 210 58584
    Subsystem 1 - Part No: 4E0 915 105 A
    Component: von VA0 1504150050
    Coding: 344530393135313035412056413031353034313530303530
    Shop #: WSC 00000 128 00289
    Mileage: 238128 km
    Date: 2017.07.04
    Time: 00:37:04
    02276 - Quiescent Current Stage 5
    Mileage: 238128 km
    Date: 2017.07.04
    Time: 00:37:04
    Mileage: 238396 km
    Date: 2017.07.08
    Time: 00:48:58
    Mileage: 238396 km
    Date: 2017.07.08
    Time: 00:48:58
    02255 - Voltage Measuring Lead from Vbat
    Fault Status: 00101001
    Fault Frequency: 7
    Reset counter: 167
    Mileage: 238132 km
    Date: 2017.07.06
    Time: 01:16:00
    Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
    Component: Türsteuer.HL BRM003 0060
    Coding: 0028462
    Fault Frequency: 0
    Reset counter: 146
    Mileage: 237680 km
    Date: 2017.07.01
    Time: 09:49:40
    Address 67: Voice Control
    Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
    Component: Türsteuer.HR BRM003 0060
    Coding: 0028462
    Fault Frequency: 0
    Reset counter: 146
    Mileage: 237680 km
    Date: 2017.07.01
    Time: 09:49:40
    Address 76: Park Assist Labels: 4E0-910-283.lbl
    Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
    Component: Parkhilfe 8-Kan H12 0020
    Revision: 06.00.55 Serial number: 00067808720507
    Coding: 0001108
    VCID: 2149F53CF8D14549C6-8074
    Reset counter: 161
    Address 77: Telephone
    End-------------------------(Elapsed Time: 03:27)--------------------------
    Jul 2017
    Optical scan results :
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(High/D3) OK OK
    1E-Media Player 2 OK OK
    77-Telephone OK OK
    47-Sound System ERROR ERROR
    67-Voice Control OK OK
    56-Radio OK OK
    37-Navigation OK ERROR
    First thing I would do is check voltage supply to the amp.
    How old is the battery?
    Jul 2017
    Battery is 2 years old. From the looks of the history that came with the car, it has had a new battery every 2 years since 2013.
    I have had the battery tested at 3 auto shops, with the battery on the car. Two readers displayed a 'excessive noise' message and didn't give any useful data. The third, gave a reading of 'battey unserviceable', 100% charged and 60% capacity.
    When I have had the battery in charge overnight, my charger says 'full' and I measure 12.8volts at the battery after charging.
    I tried a brand new battery on the car today at the shop and the MMI remained the same.
    I cannot figure out if the majority of the faults are battery/power management related or component failure.
    Can I check the voltage going to the amp using a multimeter? How?
    A new battery every two years seems excessive. Given that this car has almost 150,000 miles on it, it's not like it was only driven around the block.
    I wonder if the Battery Manager was ever told that the battery has been replaced?
    Have you tried the Battery History function available in our current Beta version? Take a look here:
    http://www.ross-tech.com/vcds/download/beta/17-5.php
    Sure you can check the voltage to the amp using a multi-meter. Wiring diagrams will tell you which pins should have power. The following threads may be useful:
    http://forums.ross-tech.com/showthread.php?5999
    http://forums.ross-tech.com/showthread.php?2884
    Jul 2017
    Thanks for the reply.
    I don't have the VCDS software, I paid to have a scan done so I can't check the battey history.
    Thanks for the links, I'm away from the car for a few days but will check at the weekend.
    I opened the car this morning and as I was putting bags in the boot (trunk) the MMI screen stowed itself away, having been up and blank previously. I started the car and turned the MMI on, I got maybe 20 seconds of music playing via CD then it all went blank and non responsive again.
    Do you think I have multiple issues here? (Amp, access system, battery manager, battery). Or could all these faults be traced to a single source of failure?
    The used car dealer I bought it from has offered to repair the car, but I know they are not VAG specialists so I'm trying to get the diagnosis myself so i know what needs to be done.
  7. #7
    Quote Originally Posted by Davekes View Post
    Well, if you're going to own a 12 year old A8, I'm going to suggest that getting VCDS yourself would probably be a good investment.
    I think there are multiple issues here. If it were me, I'd work on the most obvious one first, and that's the MMI. Trouble with these cars is that when some things don't communicate, other things may not properly go to sleep, and then your battery gets drained..
    If they are not VAG specialists, I'm not sure they're qualified to work on this car. The systems in a D3 A8 are rather more complex than those in a typical Golf or Skoda.
  8. #8
    Jul 2017
    Yes, I agree that a VCDS is a much needed investment and it's on my list.
    I am more inclined to carry out the repairs myself as I believe that with the research I am doing I will be better equipped to do so.
    I do need to agree this with the dealer first.
    What are your thoughts on the battery management unit scan results? Does it need to be replaced?
  9. #9
    What makes you think it should be replaced?
  10. #10
    Jul 2017
    The 5 faults found during the scan.
    Mileage: 238128 km
    Date: 2017.07.04
    Time: 00:37:04
    Mileage: 238128 km
    Date: 2017.07.04
    Time: 00:37:04
    Mileage: 238396 km
    Date: 2017.07.08
    Time: 00:48:58
    Mileage: 238396 km
    Date: 2017.07.08
    Time: 00:48:58
    Fault Frequency: 7
    Reset counter: 167
    Mileage: 238132 km
    Date: 2017.07.06
    Time: 01:16:00
