Results 1 to 8 of 8
Thread: 2012 Audi A7 3.0 TFSI No Communication with most modules
    New User
    Jul 2017
    Philippines
    I have a A7 with Air suspension problem. The front strut drop down, and the air pump won't turn on. To eliminate the pump is bad, I gave the pump 12v, and the pump run. Then, I started checking on the adaptive suspension control unit (J197) and Convenience system central control unit (J393). I remove all the sockets of both module to check for continuity. After I put back all the socket of both module, I tried to start the car. First thing, I notice, gauge cluster has no light / display, the shifter lights up and its in P. I still tried to start the car, the car started for about 1 sec. and dies.
    I have the first scan log when ever thing was working except the front air suspension
    Chassis Type: 4G (4G0)
    Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 20 28 34 36 3B 42 44 46
    47 52 53 55 5F 62 6D 72
    VIN: WAUZZZ4G6CN019259 Mileage: 16326km-10144miles
    This scan is after the car starts and dies immediately
    Thursday,06,July,2017,14:17:18:62610
    VCDS Version: 17.1.3.0 (x64)
    VIN: License Plate: POP677
    Chassis Type: 4G0
    01-Engine -- Status: Cannot be reached 0100
    02-Auto Trans -- Status: Cannot be reached 0100
    03-ABS Brakes -- Status: Malfunction 0110
    04-Steering Angle -- Status: Cannot be reached 0100
    05-Acc/Start Auth. -- Status: Cannot be reached 0100
    08-Auto HVAC -- Status: Cannot be reached 0100
    09-Cent. Elect. -- Status: Cannot be reached 0100
    10-Park/Steer Assist -- Status: Cannot be reached 0100
    16-Steering wheel -- Status: Cannot be reached 0100
    17-Instruments -- Status: Cannot be reached 0100
    20-High Beam Assist. -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: Cannot be reached 0100
    36-Seat Mem. Drvr -- Status: Cannot be reached 0100
    3B-Sensor Elect. -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Cannot be reached 0100
    46-Central Conv. -- Status: Cannot be reached 0100
    52-Door Elect, Pass. -- Status: Cannot be reached 0100
    53-Parking Brake -- Status: Cannot be reached 0100
    62-Door, Rear Left -- Status: Cannot be reached 0100
    6D-Trunk Elect. -- Status: Cannot be reached 0100
    72-Door, Rear Right -- Status: Cannot be reached 0100
    Do you think is more an electrical issue or immobilizer?
    idea or opinion would be have much appreciated.
    The above are not scans, they are only the Gateway Installation List headers of the scans..
    My gut says: Electrical issue.
    New User
    Jul 2017
    Philippines
    Attach is the complete scan when the car has suspension problem only.
    Address 01: Engine (J623-CGWB)       Labels: 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551     HW: 4H0 907 551
       Component: 3.0l V6 TFSI  H07 0007
       Revision: --H07---
       Coding: 1A251034052E00000000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551 002010
       ROD: EV_ECM30TFS0214G0907551_002.rod
       VCID: 66C9A1A899935F7173-8032
    Readiness: N/A
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 4G1 927 156 K    HW: 0B5 927 156 K
       Component: 0B5 30TFSIRdW H03 0008
       Revision: --H03---
       Coding: 000001
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDL501021_VW51.rod
       VCID: 356B36E494B5E4E90A-8060
    Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 44A647032265E2C0CB00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 346D0BE09FCFFDE13D-8060
    0702 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 72
                        Mileage: 16267 km
                        Date: 2017.06.26
                        Time: 17:46:37
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 10
                        Uz: B5
    0705 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 72
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 10:52:32
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 13
                        Uz: 9A
    0706 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 32
                        Mileage: 16273 km
                        Date: 2017.06.26
                        Time: 20:32:08
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 14
                        Uz: B1
    0707 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 70
                        Mileage: 16273 km
                        Date: 2017.06.26
                        Time: 20:30:47
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 15
                        Uz: 9B
       Part No SW: 4H0 907 064 BT    HW: 4H0 907 064 BT
       Component: BCM2 2.0      H31 0330
       Coding: 058A2F00000000000000
       VCID: 7CFDE3C0FF1FF5A1B5-8028
       Part No SW: 4G0 820 043 J    HW: 4G0 820 043 J
       Component: KLIMA 4 ZONEN H11 0056
       Serial number: 17061100040695
       Coding: 6603607808
       ASAM Dataset: EV_AirCondiComfoUDS 002029
       VCID: 2649E1A859139F71B3-8072
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0100
       Revision: 11012002    Serial number: 00000001110122
       Coding: 0D07E01009769FE00981008480001800CF9CC3082A090101800308452F01
       VCID: 6ED9D988B96397310B-803A
       Component: WWS57X 110526  H35 0051
       Serial number:         110601020649
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11505845
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 14 06 2011  00000832
       Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A31 LED Mod1L  H02 0001
       Serial number: 00000000001105290369
       Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A27 LED Mod1R  H02 0001
       Serial number: 00000000001105290203
       Subsystem 6 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA101511000000330991
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: FF2881B5000000000001
       Subsystem 8 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A32 LED Mod2L  H02 0001
       Serial number: 00000000001106102449
       Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A28 LED Mod2R  H02 0001
       Serial number: 00000000001106102522
    Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
       Part No SW: 8X0 035 110 B    HW: 8X0 035 110
       Component: CDC-MP3-Pana  H41 0480
       Revision: 00000007
       VCID: 2C5D13804FFFA52165-8078
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901117301145
       Coding: 080103
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3B7F20DCB2913299FC-806E
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG002X9XT
       Coding: 30314530323130303037554A304C34473853
       VCID: 366931E889B3EFF103-8062
       Serial number: 3575HRB40550INGSCO72
       Serial number: 3585HRB40550INGS9P2$
       Serial number: 3515JRB404T0IAMEH83S
       Serial number: 3525JRB404T0JE3GD84E
       Serial number: 3554VRB404T0II4KEGLJ
       Serial number: 3564VRB404T0II4KA9B%
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Revision: 00000000    Serial number: 20110622000392
       Coding: 000034
       VCID: 306507F063D7C1C159-8064
       Component: E221 - MFL  H07 0009
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 931 C    HW: 4G8 920 931 C
       Component: TBenRdw       H71 0375
       Revision: 26181114    Serial number: 658290611593051
       Coding: 13A601021B030008010100
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: 2E59198871E3D7314B-807A
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000180321
       Coding: 00C1033000
       ROD: EV_GatewUDS_AU57.rod
       VCID: 32610DF865DBF3D12F-8066
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650764228
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 04018E64747464545425363E
       VCID: 336F08FC92C1FAD924-8066
    Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0056
       Serial number: 23061100040272
       Coding: 00
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
       VCID: 2F67048C76E9DE3940-807A
    Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
       Part No SW: 4G0 907 553 C    HW: 4G0 907 553
       Component: LUFE-DAEMPFER H17 0779
       Coding: 008000
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2B5F109C42F1A2196C-807E
    677384 - Ride-Height System; Plausibility Error
              C1046 00 [009] -  -
                        Reset counter: 32
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 11:02:14
    677385 - Ride-Height System; Plausibility Error
              C1046 00 [009] -  -
                        Reset counter: 32
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 11:02:14
    115968 - Functional Limitation due to Excessive Temperature
              P178E 00 [008] - -
                        Fault Frequency: 11
                        Reset counter: 72
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 11:05:48
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000006205630
       Coding: 00581B0000002001000001010101102030303232203232
       VCID: 77F7FCECC639D6F9D8-8022
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA42016A3K0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D5B1E847CE5AC2972-8078
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F56225E00620002080402
       VCID: 42815D38DD7B4351BF-8016
    Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
       Component: RCEPS         H33 0010
       Revision: 00001000    Serial number: 0005093238
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0152057225
       Coding: 013A0E2020B9B48583300A00000100000000000000000000000000000000
       Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO1233770/
       Coding: 001E00
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA101512000000337486
       Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0130
       Revision: CJ007000    Serial number: 00000000008095
       Coding: 030000
       VCID: 1C3DC3401F5F55A115-8048
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 41835234D87D5849A6-8014
       Revision: --------    Serial number: 00000000092859
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2A5115984D0BBB1197-807E
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
       Serial number: 110622-0004-114
       Coding: 11236F601002A200
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C5D138047FFA52165-8078
    120589 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                        Fault Frequency: 7
                        Reset counter: 32
                        Mileage: 16302 km
                        Date: 2017.06.28
                        Time: 09:53:03
       Part No SW: 4G0 035 182 H    HW: 4G0 035 182 H
       Component: RMC Cnct Plus H51 0717
       Coding: 0100040001E1DB47002B060303020100000000
       VCID: 2649E1A851139F71B3-8072
       Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464E.0B0039929
       Subsystem 2 - Part No SW: 4G1 919 610     HW: 4G1 919 610
       Component: E380 BDT C7  H08 0203
       Serial number: 90349KFH000JF
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14224000620002080002
       VCID: 448D5B20C76F4D618D-8010
    Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
       Part No SW: 4G8 959 107 L    HW: 4G8 959 107 F
       Component: HDSG-Modul    H13 0039
       Revision: 11013001    Serial number: 165100249
       Coding: 0A3305C002
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       VCID: 3E7929C8A18327B1DB-806A
       Component: TSG HR        H04 0212
    End-------------------------(Elapsed Time: 05:53)--------------------------
    Scan after inspection of wires on J197 and J393
    Address 01: Engine
    12 Faults Found:
    0051 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: B3
                        Uz: 9F
    0058 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BB
                        Uz: 9B
    0060 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BE
                        Uz: 9B
    0061 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C8
                        Uz: 97
    0668 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: CB
                        Uz: 99
    0069 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E0
                        Uz: 9B
    0071 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: ED
                        Uz: 9B
    0073 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F2
                        Uz: 9B
    0075 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F5
                        Uz: 9B
    0091 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 09
                        Uz: 9B
    0478 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: F6
                        Uz: 9A
    0479 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: F7
                        Uz: 9A
       Revision: 00000007
    1048576 - Databus
                        Reset counter: 32
    1049600 - Databus
              U1121 00 [137] - Missing Message
                        Reset counter: 32
    1050112 - Databus
                        Reset counter: 32
    1051136 - Databus
                        Reset counter: 32
       Coding: 00C1033000
    16 Faults Found:
    4226 - No Communication with Transmission Control Module
              U0101 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 12.1 V
                        Control Module temperature: 28 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: On
                        Datenfeld: 0
    4224 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    4356 - No Communications with Parking Brake Control Module
              U0128 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    4230 - No Communications with Steering Angle Sender (G85)
              U0126 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    4228 - No Communication with ABS Brake Control Module
              U0121 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    5014 - Ride Level Control Module
              U0132 00 [008] - No Communications
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 11:34:22
                        Voltage terminal 30: 12.5 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 33 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
    6655 - Sensor electronics control module
              U1077 00 [008] - No communication
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 11:34:22
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    6673 - Generator
              P1B00 00 [009] - Mechanical Malfunction
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:23:03
                        Voltage terminal 30: 12.1 V
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 31 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
    0257 - Powertrain Databus
              U0002 00 [008] - No Communications
                        Fault Frequency: 33
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Voltage terminal 30: 12.3 V
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    0261 - Data Bus for Control/Display
              U10AD 00 [009] - No Communications
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    0263 - Comfort System CAN Bus (SAE Medium Speed Bus)
              U0011 00 [009] - Performance
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    0264 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
              U0009 00 [008] - -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    0265 - Data Bus for Control/Display
              U10AF 00 [008] - 1-Wire Mode
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    0266 - Comfort System Databus (VAG Wingle-Wire Mode) (SAE L Shorted H)
              U0018 00 [008] - -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    12290 - Quiescent Current
              U1406 00 [008] - Too High
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 16:45:57
                        Voltage terminal 30: 12.4 V
                        System status: LIN_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Control Module temperature: 30 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
       Revision: AA001002
                        Reset counter: 32
                        Reset counter: 32
                        Reset counter: 32
       Coding: 008000
    12 Faults Found:
    453639 - Pressure Sensor for Ride-Height
              C1031 11 [008] - Short to Ground
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:10
    206091 - Valve for Air-Spring Front Left
              C103C 13 [008] - Open Circuit
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:11
    206347 - Valve for Air-Spring Front Right
              C103D 13 [008] - Open Circuit
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:11
    206603 - Valve for Air-Spring Rear Left
              C103E 13 [008] - Open Circuit
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:11
    206859 - Valve for Air-Spring Rear Right
              C103F 13 [008] - Open Circuit
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:15:43
    357643 - Bleed Valve for Ride-Height
              C103B 13 [008] - Open Circuit
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 10:35:18
    453899 - Valve for Ride-Height Pressure Accumulator
              C103A 13 [008] - Open Circuit
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:15:43
    677387 - Ride-Height System; Plausibility Error
              C1046 00 [008] -  -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 10:57:23
    0022 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
    0016 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
    0005 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
    358155 - Relay for Ride-Height Compressor
              C1038 12 [008] - Short to Plus
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 10:35:17
    3801344 - Function Restricted due to Missing Message(s)
              U1111 00 [047] - -
                        Fault Frequency: 23
                        Reset counter: 32
                        DCU Temperature: 29 °C
                        Voltage Clamp 15: 12.4 V
                        Voltage Clamp 30: 12.0 V
                        Ignition Cycle Count: 53563
                        00000000000000000
    3158274 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
    3158276 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
    4208000 - Steering Angle Sensor
              B1168 F1 [137] - Synchronization Failed
                        Fault Frequency: 26
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
    3161616 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
       Coding: 030000
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 32
                        Bin. Bits: 00000110
    6 Faults Found:
              U1111 00 [009] - -
                        Reset counter: 32
    0052 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 32
    0053 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 32
    336388 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 32
    337165 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 32
    340484 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 32
    End-------------------------(Elapsed Time: 04:51)--------------------------
    Thanks UWE for your reply..
    Nothing jumps out at me as an obvious cause for all that, sorry.
    Verified VCDS User sasha's Avatar
    Oct 2016
    Australia
    @titawgo
    what was the issue with the car in the end, did you get it sorted?
    New User
    Mar 2020
    Ireland
    Same problem
    Hi mate, having the same issue you help me and tell me what was the issue? thanks
    Quote Originally Posted by titawgo View Post
       Revision: --H07---
    Readiness: N/A
       Revision: --H03---
       Coding: 000001
              U1113 00 [008] - -
                        Reset counter: 72
                        Mileage: 16267 km
                        Date: 2017.06.26
                        Time: 17:46:37
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 10
                        Uz: B5
              U1112 00 [008] - -
                        Reset counter: 72
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 10:52:32
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 13
                        Uz: 9A
              U1113 00 [009] - -
                        Reset counter: 32
                        Mileage: 16273 km
                        Date: 2017.06.26
                        Time: 20:32:08
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 14
                        Uz: B1
              U1112 00 [008] - -
                        Reset counter: 70
                        Mileage: 16273 km
                        Date: 2017.06.26
                        Time: 20:30:47
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 15
                        Uz: 9B
       Coding: 6603607808
       Coding: 0045F7
       Coding: 02562B
       Coding: 020300
       Revision: 00000007
       Coding: 080103
       Coding: 000034
       ROD: EV_RBD4K.rod
       Coding: 00C1033000
       Revision: AA001002
       Coding: 00
       Coding: 008000
              C1046 00 [009] -  -
                        Reset counter: 32
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 11:02:14
              C1046 00 [009] -  -
                        Reset counter: 32
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 11:02:14
              P178E 00 [008] - -
                        Fault Frequency: 11
                        Reset counter: 72
                        Mileage: 16314 km
                        Date: 2017.06.28
                        Time: 11:05:48
       Coding: 001E00
       Coding: 030000
              U1113 00 [137] - -
                        Fault Frequency: 7
                        Reset counter: 32
                        Mileage: 16302 km
                        Date: 2017.06.28
                        Time: 09:53:03
       Coding: 0A3305C002
    Address 01: Engine
    12 Faults Found:
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: B3
                        Uz: 9F
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BB
                        Uz: 9B
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BE
                        Uz: 9B
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C8
                        Uz: 97
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: CB
                        Uz: 99
              U1111 00 [137] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E0
                        Uz: 9B
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: ED
                        Uz: 9B
              U1111 00 [137] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F2
                        Uz: 9B
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: F5
                        Uz: 9B
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 09
                        Uz: 9B
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: F6
                        Uz: 9A
              U1111 00 [009] - -
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 2F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: F7
                        Uz: 9A
       Revision: 00000007
    1048576 - Databus
                        Reset counter: 32
    1049600 - Databus
                        Reset counter: 32
    1050112 - Databus
                        Reset counter: 32
    1051136 - Databus
                        Reset counter: 32
       Coding: 00C1033000
    16 Faults Found:
              U0101 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U0100 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U0128 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U0126 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U0121 00 [009] - -
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 11:34:22
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 11:34:22
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    6673 - Generator
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:23:03
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
                        Fault Frequency: 33
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
                        Reset counter: 32
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U0009 00 [008] - -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U0018 00 [008] - -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.06
                        Time: 10:21:39
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 16:45:57
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.07.05
                        Time: 19:49:12
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
       Revision: AA001002
                        Reset counter: 32
                        Reset counter: 32
                        Reset counter: 32
       Coding: 008000
    12 Faults Found:
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:10
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:11
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:11
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:08:11
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:15:43
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 10:35:18
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.28
                        Time: 17:15:43
              C1046 00 [008] -  -
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 10:57:23
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
              U1111 00 [009] - -
                        Reset counter: 32
                        Time: 00:00:00
                        Reset counter: 72
                        Mileage: 16326 km
                        Date: 2017.06.29
                        Time: 10:35:17
              U1111 00 [047] - -
                        Fault Frequency: 23
                        Reset counter: 32
                        00000000000000000
              U1111 00 [009] - -
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
              U1111 00 [009] - -
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
                        Fault Frequency: 26
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
              U1111 00 [009] - -
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 1048574 km
                        Time: 00:00:00
                        valid
       Coding: 030000
                        Reset counter: 32
                        Bin. Bits: 00000110
    6 Faults Found:
              U1111 00 [009] - -
                        Reset counter: 32
              U1111 00 [137] - -
                        Reset counter: 32
              U1111 00 [137] - -
                        Reset counter: 32
              U1111 00 [137] - -
                        Reset counter: 32
              U1111 00 [009] - -
                        Reset counter: 32
              U1111 00 [137] - -
                        Reset counter: 32
  7. #7
    Ignition switch?
    Post an auto-scan of what you have.....
  8. #8
    Jan 2020
    Germany (Auto-Intern)
    Hi, please check the gearbox cooling valve N509. Check if there is water in the electrical plug. If yes, replace it. The water goes from the valve through the cable to the plug of the gearbox.
    The Mechatronic connector is then full of cooling water. This results in a malfunction in the data bus.
    Attached Images Attached Images
  9. Likes PetrolDave, Uwe, Fredrick Awuor liked this post
