Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: 2010 Audi S4 B8- Alarm Keeps Going Off
    Aug 2014
    Afternoon All,
    I have an issue with my alarm, which goes off randomly, usually at night. I'm hoping someone has had a similar problem.
    Car: 2010MY B8 S4 Avant (without keyless entry)
    Problem: Alarm goes off randomly at night (3 times last night, hasn't done it for 6 weeks or so prior to this)
    Containment: Unlock car with fob, lock again.
    Info: All door locks work fine, no other issues with car. (data logs below)
    My question is what is the root cause of the alarm going off, at the moment I have two thoughts:
    - Door handle sensors (known fault)
    - Vehicle energy management system (thinks 12v Battery is low, possibly reset current battery adaptions)
    So, first a log from this morning:
    Chassis Type: 8K (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 30 42 46 47 52 53 55 56 5F
    62 72
    VIN: WAUZZZ8K1AA126187 Mileage: 123910km/76994miles
    Address 01: Engine (J623-CAKA) Labels: 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 HW: 8K0 907 551
    Component: 3.0T SIMOS84 H06 0005
    Revision: --------
    Coding: 010C000C240F0128
    Shop #: WSC 06335 000 00000
    ASAM Dataset: EV_ECM30TFS8K0907551 A01007
    ROD: EV_ECM30TFS8K0907551.rod
    VCID: EED9625C3182496EF9B-80BB
    Readiness: 0000 0001
    Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
    Part No SW: 8K1 927 156 B HW: 0B5 927 156 E
    Component: 0B5 30TFSIRdW H03 0003
    Revision: --H03--- Serial number: 0000000395
    Coding: 000001
    ASAM Dataset: EV_TCMDL501 A02043
    ROD: EV_TCMDL501.rod
    VCID: 346D30349F2EA3BE4FF-8061
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BC HW: 8K0 907 379 BC
    Component: ESP8 quattro H04 0020
    Coding: 290500
    VCID: 7BFFDB08FAF0ACC6CE5-802E
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0327
    Coding: 011200
    VCID: 810329E0181C4616149-80D4
    Subsystem 1 - Part No SW: 8T0 959 754 AG HW: 8T0 959 754 AG
    Component: FBSAUDIB8 IDG H37 0060
    Component: J764 ELV MLB H37 0042
    Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
    Component: KLIMA 3 ZONEN H08 0171
    Revision: D1000000 Serial number: 01260120100875
    Coding: 66140000
    VCID: 77F7C738C6D888A6AAD-8022
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H25 0380
    Revision: 10025001 Serial number: 00000000448446
    Coding: 260050914034AF010001000300001D0D0F1D470A00010141000000
    VCID: 3C7D1814BF7E6BFE87F-8069
    Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 180110 H05 0070
    Coding: 00FD11
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
    Component: PARKHILFE 8K H06 0070
    Revision: 11001001 Serial number: 50941003401763
    Coding: 10010D
    VCID: 489574C4FBA6375E137-801D
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
    Component: AirbagVW-AU10 H39 0560
    Serial number: 003EFD0BCMKO
    Coding: 30363435363030303030554A3052384B3053
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 418369E0D09C0616D49-8014
    Serial number: 6334MSME50010B550
    Serial number: 6344MSME4E426D52O
    Serial number: 6352QSME6C4D2D04V
    Serial number: 6362QSME6E4D3408U
    Serial number: 63732SME364E1A0C6
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME684E3C0EI
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90315JAR0007T
    Coding: 000037
    VCID: 3D7B1510A46462F6B01-8068
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 980 P HW: 8K0 920 980 P
    Component: KOMBIINSTR. H05 0255
    Revision: 00200000 Serial number: CJ123MW1A
    Coding: 2F07110002002600010000
    VCID: 3F876F18AE6870E6A2D-806A
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
    Component: GW-BEM 4CAN-M H09 0105
    Revision: EB800053 Serial number: 5300E101180091
    Coding: 00C303
    VCID: 52A156AC0DFA8D8E7D3-8007
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H07 0170
    Fault Frequency: 11
    Reset counter: 57
    Mileage: 122598 km
    Date: 2014.07.30
    Time: 05:50:00
    Bin. Bits: 00000
    Voltage: 12.30 V
    Count: 17
    Last edited by Uwe; 08-20-2014 at 09:56 AM. Reason: Wrapped CODE tags around scan data
    Aug 2014
    Address 30: Special Function II (J843)  Labels: 8K0-907-440.clb
      Part No SW: 8K0 907 440 B  HW: 8K0 907 440
      Component: STS  H04 0020
      Revision: S0H04000  Serial number: 00000000013976
      Coding: 01010101000000000000000102
      VCID: 2D5B25507404F276001-8078
    Address 42: Door Elect, Driver (J386)  Labels: 8K0-959-793.clb
      Part No SW: 8K0 959 793 H  HW: 8K0 959 793 D
      Component: TSG FA  H11 0306
      Revision:  Serial number: 0000009962160
      Coding: 011C02204021410001
      VCID: 458B7DF0CCB42A36E81-8010
    Address 46: Central Conv. (J393)  Labels: 8K0-907-064-46.clb
      Revision: 00002001  Serial number: 0126104558
      Coding: 013B062220390C000030023280000000
    Address 47: Sound System (J525)  Labels: 8T0-035-223-BOM.clb
      Part No SW: 8T0 035 223 AN  HW: 8T0 035 223 AK
      Component: DSP Prem  H10 0190
      Revision: 00010001  Serial number: 34882001151201
      VCID: 7AF1DE0CF5CA95CED53-802F
    Address 52: Door Elect, Pass. (J387)  Labels: 8K0-959-792.clb
      Part No SW: 8K0 959 792 H  HW: 8K0 959 792 D
      Component: TSG BF  H11 0306
      Revision:  Serial number: 0000009948537
      VCID: 448D60F4C78E133EFFF-8011
    Address 53: Parking Brake (J540)  Labels: 8K0-907-801-V1.clb
      Part No SW: 8K0 907 801 H  HW: 8K0 907 801 H
      Component: EPB Audi B8  H09 0100
      Revision: 00000003  Serial number: 10000000423999
      VCID: 346D3034972EA3BE4FF-8061
    Address 55: Xenon Range  Labels: 8K0-907-357.clb
      Part No: 8K5 907 357
      Revision: 00000001  Serial number:
      Coding: 0000004
      Shop #: WSC 06334 000 00000
      VCID: F7F7473886D808A62AD-80A2
    Address 56: Radio (R)  Labels: Redir Fail!
      Part No SW: 4F0 035 053 J  HW: 4F0 035 053
      Component: Radio U Basic H45 0052
      Revision: AB001007  Serial number: 341B-0A7699532
      Coding: 010003010000000001
      VCID: 244DC07427CE333EDFF-8071
    Address 5F: Information Electr. (J794)  Labels: 4E0-035-6xx-5F.clb
      Part No SW: 8T2 035 666 F  HW: 8T2 035 666 E
      Component: H-BN-EU  H47 0143
      Revision: --------  Serial number: 475BV0A7544071
      Coding: 01010101020681ED01000B1E000000030000
      Shop #: WSC 00047 210 184061
      VCID: 3E79121CA96279EEA9B-806B
      Subsystem 1 - Part No: 8R0 060 884 J
      Component: EUR 2010  1005
      Subsystem 2 - Part No SW: 4F0 919 604  HW: 4F0 919 604
      Component: DU7 High  H43 0306
      Subsystem 3 - Part No SW: 8T0 919 609 F  HW: 8T0 919 609 F
      Component: E0380 Bedient  H08 0100
      Subsystem 4 - Part No: 8R0 906 961 A
      Component: CD-Database  1293
    Address 62: Door, Rear Left (J388)  Labels: 8K0-959-795.clb
      Part No SW: 8K0 959 795 C  HW: 8K0 959 795 C
      Component: TSG HL  H10 0306
      Revision:  Serial number: 0000102691423
      Coding: 010C02204021210001
      VCID: 428166ECDD9A1D0ECD3-8017
    Address 72: Door, Rear Right (J389)  Labels: 8K0-959-795.clb
      Component: TSG HR  H10 0306
      Revision:  Serial number: 0000102691442
    End  ---------------------------------------------------------------------
    I then did some further digging on VAG-COM, and interrogated the convenience module:
    After some digging on the internet I found the following, a TSB for A5/S5/A4/S4 regarding a similar issue- not my car does not have keyless entry.
    The symptoms are all very similar, but my information isn't sufficient to know what the codes are in Module 46 > Block 18 (i.e. what does a value of 2.0 mean?)
    - TSB suggests Value 2 (no communication)
    - VW 'Tech-Tips' suggests Value 2 (Front Passenger Rotary Latch Switch)
    So, where to go from here...?
    My other question is regarding handed faults (i.e. passenger side) is Ross-Tech mature enough to understand implications RHD/LHD regarding fault handling. I.e. I'm using a VW America Tech Tip to decipher a European fault code, I presume fault code descriptions change with RHD/LHD?
    Further information on supported codes my car has:
    Module 05: Nothing Stored
    Front Drivers Door: Nothing Stored
    Front Passenger Door: Nothing Stored
    Central Conv:
    CAN 19:
    Rear Left Door:
    Rear Right Door:
    Any help greatly appreciated!
    Many Thanks,
    Pete
    United States
    Please wrap those scans in [Code] as explained here: How to post an Auto-Scan
    We do not have all of the alarm sources for BCM2 documented so please run a control module map as explained in in this similar case so we can evaluate all of the applicable MVBs.
    You can either open that map with Notepad and wrap it in [code] to paste it here or email it to us and I'll paste the relevant information in this thread after we evaluate it.
    What's with the list of alarm sources for Touareg/Phaeton? I wouldn't count on those to apply to a B8 A4.
    We've only been doing this for 14 years now. But as for how mature we are, well..
    Generally, VW/Audi has used Driver and Passenger sides to designate things in the front (instead of Left and Right) for precisely this reason -- there's asymmetry in the way the stuff in the front row is designed. Since there are typically no such issues in he rear, they use Left and Right. Anyway, I think it's a safe assumption that Driver and Passenger sides mean what they say regardless whether the car is designed to be driven on the right or the wrong side of the road.
    Its battery replacement time................
  6. Likes jakematic, Sternfels, victor35ma liked this post
    Aug 2014
    Will do- apologies about the code!
    Aug 2014
    Uwe, for sure I shouldn't assume they're the same, I couldn't find any other reference (aside from the Audi TSB attached above) ref module 46 block 18...
    Thanks for the info on the handing too
  9. #8
    Aug 2014
    Jack- is that based on previous experience, or a best guess?
  10. #9
    NC USA
    Quote Originally Posted by Yoof View Post
    I've never known Jack to guess... he uses empirical data and experience.
    And he looked at this:
    Fault Frequency: 11
    Reset counter: 57
    Mileage: 122598 km
    Date: 2014.07.30
    Time: 05:50:00
    Bin. Bits: 00000
    Voltage: 12.30 V
    Count: 17
    And the vehicle is 5ish years old - almost exactly when all Audis need a new battery in my experience
  11. Likes Jack@European_Parts, Dana, Sternfels liked this post
  12. #10
  13. Likes jakematic liked this post
