Results 1 to 4 of 4
Thread: 2016 Seat Ibiza 6P 1.4 TDI DSG7 (CUSB)
    Unverified
    Jun 2017
    Admaps:
    01
    	SW:04B-906-027-D   HW:04B-907-445 ---  Engine
    	Component:R3 1.4l TDI   H08 9153, Coding:01254032422401080000
    	EV_ECM14TDI03004B906027D,003029,EV_ECM14TDI03004B906027D_SK26.rod
    	Monday,19,June,2017,21:16:59:46934
    	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
    	VCID: 2237AC420F0E8DBFF5-8076
    IDE00001-Production mode,00 00 00
    IDE00259-Idle RPM correction,0 /min
    IDE00263-Injector 1 correction value,X72Y4BRHJ9Z3G77W60TZ
    IDE00264-Injector 2 correction value,AP328B8JDY13H7R45YYX
    IDE00265-Injector 3 correction value,TP724B81EE54HP9CJ0YZ
    IDE01096-Particulate Filter Statistics,0
    IDE01711-Blocking of particle filter regeneration,not active
    IDE01945-Engine run-in oil pressure,not active
    IDE02248-Individually adjustable maximum speed limit,300.0 km/h
    IDE02332-Deactivate production mode,00 00 00
    IDE04158-Activation of start-stop function,active
    IDE04617-Protective function,Enabled
    IDE06425-Roller test bench mode: functional,not activated
    IDE07232-Initialization of NOx catalyst accumulator,357760 s
    IDE07903-Adaptation of ash mass,6.70 g
    IDE08287-Bleeding of coolant circuit,not active
    ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping,Not blocked
    ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor,Not blocked
    Elapsed Time: 00:05
    02
    	SW:0CW-300-049   HW:0AM-927-769-K ---  Auto Trans
    	Component:GSG DQ200-MQB H43 6501, Coding:0014
    	EV_TCMDQ200021,001001,EV_TCMDQ200021.rod
    	Wednesday,14,June,2017,20:34:03:46934
    	VCDS Version: Release 17.1.3  Data version: 20170203 DS267.2
    	VCID: 7A0784C2F75E359FBD-802E
    IDE00001-Production mode,not activated
    Elapsed Time: 00:01
    	Monday,19,June,2017,21:17:24:46934
    	VCID: 7A8FFC4A6FC6BD2735-802E
    Elapsed Time: 00:01
    03
    	SW:6C0-907-379-K   HW:6R0-907-379-BA ---  ABS Brakes
    	Component:ESP9.0i       H03 0004, Coding:11DD287D892B33C0091B106B0057881491CC90080007C9098F00
    	EV_Brake1ESP90iBOSCHPQ26,100020,EV_Brake1ESP90iBOSCHPQ26.rod
    	Monday,19,June,2017,21:17:41:46934
    	VCID: 3740828373950FD22D-8062
    IDE00820-ENG114920-Activating and deactivating all development messages-BOSCH Botschaften,not activated
    IDE00820-ENG114177-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 1,not activated
    IDE00820-ENG114178-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 2,not activated
    IDE00820-ENG114179-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 3,not activated
    IDE00820-ENG114919-Activating and deactivating all development messages-VW Botschaften,not activated
    IDE03659-Roller test bench mode,activated
    IDE04456-Brake disk drying,Medium
    IDE04643-Overboost in brake system,120BAR
    IDE04939-Tire pressure monitoring display,2
    IDE04949-Engine drag torque control,activated
    IDE05055-Hydraulic brake assistant,normal
    IDE05161-Straight ahead brake stabilization,activated
    IDE05286-Expanded electronic differential lock,Strong
    IDE05498-Rear axle hard braking,activated
    IDE07006-Tire pressure monitoring display: tire selection,1
    IDE07565-ABS in lower speed range,activated
    MAS00120-Anti-slip regulation (ASR),activated
    MAS00121-Electronic Differential Lock,activated
    MAS00122-Electronic Stability Program,activated
    MAS02080-XCP calibration protocol,not activated
    MAS02138-Hill-start assistant,normal
    MAS08145-Hill-start assistant: increase threshold,Three Percent
    ENG125053-Developer_Function_120,No Warning/Errro(Default)
    ENG130301-Developer_Function_121,not activated
    ENG118192-Tyre_pressure_control_monitoring_datalogging,0
    Elapsed Time: 00:07
    Unverified
    Jun 2017
    5F
    	SW:5QA-035-824   HW:5QA-035-824 ---  Information Electr.
    	Component:MU-S--ER      H24 0245, Coding:04520000BE02000011110001000808002F0201D40120010002
    	EV_MUStd6C3TSAT,001015,EV_MUStd6C3TSAT_SE26.rod
    	Monday,19,June,2017,21:27:56:46934
    	VCID: 7D8AF6B19B37AB381D-8028
    IDE00346-Summertime-automatic,Europe
    IDE00758-Base volume of telephone,50 %
    IDE00759-Base volume of speech output,50 %
    IDE00760-Microphone sensitivity,0 dB
    IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
    IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
    IDE02121-CD eject button,Enabled
    IDE02122-Developer mode,not activated
    IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic
    IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36
    IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36
    IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36
    IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36
    IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36
    IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36
    IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36
    IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36
    IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36
    IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36
    IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36
    IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36
    IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36
    IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36
    IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36
    IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36
    IDE02502-Confirmation of installation change,A7 36
    IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
    IDE04550-Bluetooth: Sniff mode,On
    IDE05113-Infotainment Recorder,activated
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
    IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128
    IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128
    IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128
    IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
    IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128
    IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128
    IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128
    IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128
    IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128
    IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128
    IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128
    IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128
    IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
    IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128
    IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
    IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128
    IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128
    IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128
    IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128
    IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128
    IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128
    IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated
    IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated
    IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated
    IDE10604-Menu entries for mobile online services,not activated
    IDE11122-Country identification: country of sale HMI,--
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked
    IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked
    IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked
    IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked
    IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked
    IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked
    IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked
    IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked
    IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked
    IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked
    IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked
    IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked
    IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked
    IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked
    IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked
    IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked
    IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked
    IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked
    IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked
    IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked
    IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked
    IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked
    IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked
    IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked
    IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked
    IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked
    IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked
    IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked
    IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked
    IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked
    IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked
    IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked
    IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked
    IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked
    IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked
    IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked
    IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked
    IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked
    IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked
    IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked
    IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked
    IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked
    IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked
    IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked
    IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked
    IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked
    IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked
    IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked
    IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked
    IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked
    IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked
    IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked
    IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked
    IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked
    IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked
    IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked
    IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked
    IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked
    IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked
    IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked
    IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked
    IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked
    IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked
    IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked
    IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked
    IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked
    IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked
    IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked
    IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked
    IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked
    IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked
    IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked
    IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked
    IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked
    IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked
    IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked
    IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked
    IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked
    IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked
    IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked
    IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked
    IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked
    IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked
    IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked
    IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked
    IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked
    IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked
    IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked
    IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked
    IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked
    IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked
    IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked
    IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked
    IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked
    IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked
    IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked
    IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked
    IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked
    IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked
    IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked
    IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked
    IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked
    IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked
    IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked
    IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked
    IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked
    IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked
    IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked
    IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked
    IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked
    IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked
    IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked
    IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked
    IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked
    MAS00951-Bluetooth,On
    MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz
    MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz
    MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz
    MAS03782-WLAN,On
    ENG117917-BAP_Debug_Mode_Release,not_released
    ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP
    ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
    ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
    ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated
    ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
    ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
    ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
    ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
    ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated
    ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
    ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
    ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
    ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
    ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
    ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
    ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
    ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
    ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
    ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
    ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
    ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
    ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
    ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
    ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
    ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated
    ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
    ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
    ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
    ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated
    ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
    ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
    ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
    ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
    ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated
    ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
    ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
    ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
    ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated
    ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated
    ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
    ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated
    ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
    ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
    ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
    ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
    ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
    ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
    ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
    ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
    ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
    ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
    ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
    ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
    ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
    ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
    ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
    ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated
    ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
    ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated
    ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated
    ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
    ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated
    ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated
    ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
    ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
    ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
    ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
    ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated
    ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
    ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
    ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
    ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
    ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
    ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated
    ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated
    ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated
    ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated
    ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
    ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
    ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated
    ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
    ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
    ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
    ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
    ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
    ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
    ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
    ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
    ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
    ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
    ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
    ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
    ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
    ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
    ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
    ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated
    ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
    ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
    ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
    ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated
    ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
    ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
    ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
    ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
    ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
    ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated
    ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
    ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
    ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
    ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
    ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
    ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated
    ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
    ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
    ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
    ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
    ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
    ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated
    ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
    ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
    ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated
    ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
    ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
    ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated
    ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
    ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
    ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
    ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated
    ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated
    ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
    ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
    ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
    ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
    ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
    ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
    ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
    ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
    ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
    ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated
    ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
    ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated
    ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated
    ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated
    ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated
    ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated
    ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,activated
    ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,activated
    ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,activated
    ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,activated
    ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,activated
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
    ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
    ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
    ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
    ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
    ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
    ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated
    ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
    ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
    ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
    ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
    ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
    ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
    ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
    ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated
    ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
    ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
    ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated
    ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
    ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated
    ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated
    ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
    ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
    ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
    ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
    ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
    ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
    ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated
    ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated
    ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated
    ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated
    ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Comfort data bus
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Comfort data bus
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Comfort data bus
    ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus
    ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Comfort data bus
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
    ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Comfort data bus
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Comfort data bus
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,Comfort data bus
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus
    ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Comfort data bus
    ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus
    ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus
    ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
    ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated
    ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus
    ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated
    ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus
    ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,Comfort data bus
    ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Comfort data bus
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Comfort data bus
    ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus
    ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Comfort data bus
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Comfort data bus
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Terminal 15
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Comfort data bus
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
    ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
    ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
    ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0
    ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50
    ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100
    ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0
    ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50
    ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,11 %
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,25 %
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 90 01 58 02 2C 01 2C 01 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 C5
    ENG117809-p_damping_Display,5 ms
    ENG117808-p_HMI_Display,13 %
    ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
    ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
    ENG117919-Startup_Screen_Sticker_HMI,09 00
    ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF
    ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On
    ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,OFF
    ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On
    ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF
    ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF
    ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF
    ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF
    ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present
    ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present
    ENG109862-ENG127492-Vehicle_configuration-LGI,OFF
    ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated
    ENG109862-ENG07590-Vehicle_configuration-Mirror_link,function_off_hmi_off
    ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF
    ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF
    ENG109862-ENG127495-Vehicle_configuration-online_media,OFF
    ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF
    ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF
    ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF
    ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF
    ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF
    ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF
    ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active
    ENG109862-ENG117844-Vehicle_configuration-picture_navi,OFF
    ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF
    ENG109862-ENG06574-Vehicle_configuration-ProbeCar_vzo,OFF
    ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5
    ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF
    ENG109862-ENG07589-Vehicle_configuration-RSE_software_component,activated
    ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS
    ENG109862-ENG11009-Vehicle_configuration-sd_slot_deactivation,no restriction
    ENG109862-ENG07588-Vehicle_configuration-SDS_Region_Flag,no_region
    ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present
    ENG109862-ENG07591-Vehicle_configuration-Smartphone_interface_for_rhmi,activated
    ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1
    ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF
    ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF
    ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,OFF
    ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF
    ENG109862-ENG06575-Vehicle_configuration-UOTA,OFF
    ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF
    ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF
    ENG109862-ENG127494-Vehicle_configuration-VZO,OFF
    ENG109862-ENG06576-Vehicle_configuration-WiFi_Client_HMI,OFF
    ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,OFF
    Elapsed Time: 00:33
    08
    	SW:6P0-907-044-B   HW:6P0-907-044-B ---  Auto HVAC
    	Component:Climatronic   H02 0202, Coding:001000001001200001
    	EV_ACClimaValeoPQ26,003001,EV_ACClimaValeoPQ26_SK25.rod
    	Monday,19,June,2017,21:23:37:46934
    	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
    	VCID: 303990A85748791D65-8064
    IDE00001-Production mode,Deactivating
    IDE01503-Runtime for compressor run-in basic setting,120 s
    IDE02332-Deactivate production mode,0
    IDE03176-Duration of compressor run in,60 s
    IDE04159-Deactivation of start-stop function,not active
    IDE06425-Roller test bench mode: functional,not activated
    IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min
    IDE06545-Blower voltage for production routines,6 V
    IDE06546-Interior target temperature for production routines,22 °C
    IDE06547-Air distribution for production routines,No effect
    IDE06593-Recirculation air for production routines,No effect
    IDE80006-Analysis 6,not activated
    IDE80007-Analysis 7,00 00
    ENG123031-ENG101574-dimming_characteristic_curve_display_illumination-X1,0
    ENG123031-ENG99557-dimming_characteristic_curve_display_illumination-X2,10
    ENG123031-ENG102140-dimming_characteristic_curve_display_illumination-X3,100
    ENG123031-ENG102936-dimming_characteristic_curve_display_illumination-X4,150
    ENG123031-ENG103548-dimming_characteristic_curve_display_illumination-X5,220
    ENG123031-ENG113992-dimming_characteristic_curve_display_illumination-X6,253
    ENG123031-ENG99777-dimming_characteristic_curve_display_illumination-Y1,1 %
    ENG123031-ENG100480-dimming_characteristic_curve_display_illumination-Y2,1 %
    ENG123031-ENG100773-dimming_characteristic_curve_display_illumination-Y3,10 %
    ENG123031-ENG100631-dimming_characteristic_curve_display_illumination-Y4,40 %
    ENG123031-ENG102174-dimming_characteristic_curve_display_illumination-Y5,82 %
    ENG123031-ENG113993-dimming_characteristic_curve_display_illumination-Y6,100 %
    ENG123032-ENG101574-dimming_characteristic_curve_function_illumination_general-X1,0
    ENG123032-ENG99557-dimming_characteristic_curve_function_illumination_general-X2,10
    ENG123032-ENG102140-dimming_characteristic_curve_function_illumination_general-X3,100
    ENG123032-ENG102936-dimming_characteristic_curve_function_illumination_general-X4,150
    ENG123032-ENG103548-dimming_characteristic_curve_function_illumination_general-X5,220
    ENG123032-ENG113992-dimming_characteristic_curve_function_illumination_general-X6,253
    ENG123032-ENG99777-dimming_characteristic_curve_function_illumination_general-Y1,2 %
    ENG123032-ENG100480-dimming_characteristic_curve_function_illumination_general-Y2,2 %
    ENG123032-ENG100773-dimming_characteristic_curve_function_illumination_general-Y3,7 %
    ENG123032-ENG100631-dimming_characteristic_curve_function_illumination_general-Y4,36 %
    ENG123032-ENG102174-dimming_characteristic_curve_function_illumination_general-Y5,74 %
    ENG123032-ENG113993-dimming_characteristic_curve_function_illumination_general-Y6,90 %
    ENG123030-ENG101574-dimming_characteristic_curve_search_illumination-X1,0
    ENG123030-ENG99557-dimming_characteristic_curve_search_illumination-X2,6
    ENG123030-ENG102140-dimming_characteristic_curve_search_illumination-X3,40
    ENG123030-ENG102936-dimming_characteristic_curve_search_illumination-X4,60
    ENG123030-ENG103548-dimming_characteristic_curve_search_illumination-X5,80
    ENG123030-ENG113992-dimming_characteristic_curve_search_illumination-X6,100
    ENG123030-ENG99777-dimming_characteristic_curve_search_illumination-Y1,0 %
    ENG123030-ENG100480-dimming_characteristic_curve_search_illumination-Y2,6 %
    ENG123030-ENG100773-dimming_characteristic_curve_search_illumination-Y3,40 %
    ENG123030-ENG100631-dimming_characteristic_curve_search_illumination-Y4,60 %
    ENG123030-ENG102174-dimming_characteristic_curve_search_illumination-Y5,80 %
    ENG123030-ENG113993-dimming_characteristic_curve_search_illumination-Y6,100 %
    Elapsed Time: 00:06
    09
    	SW:6C0-937-089-C   HW:6C0-937-089 ---  Cent. Elect.
    	Component:BCM PQ26 Hi4R H08 0086, Coding:08001A5042532AFB0BA44000B12707481001690257010000000000000000
    	EV_BCMA0,005005,EV_BCMA0_005_VW26.rod
    	Monday,19,June,2017,21:18:40:46934
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
    IDE00001-ENG130235-Production mode-Entry_control,not active
    IDE00001-ENG112304-Production mode-Heckwischer,not active
    IDE00001-ENG98647-Production mode-Interior lighting,not active
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
    IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active
    IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active
    IDE00002-Transport mode,active
    IDE00820-Activating and deactivating all development messages,not active
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,3
    IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active
    IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,activated
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1100 ms
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
    IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
    IDE02152-Characteristics in production mode,2000 ms
    IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
    IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active
    IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active
    IDE02488-DWA Interior monitoring,100 %
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
    IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
    IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.00 °
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
    IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active
    IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined
    IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active
    IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5
    IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS
    IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled
    IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active
    IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active
    IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.200 %
    IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,0.0 %
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h
    IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
    IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
    IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,active
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Fog light
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,72.0
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
    IDE04926-ENG126569-Comfort illumination-lho_aktiviert,active
    IDE04926-ENG126570-Comfort illumination-lho_zeit,10 s
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
    IDE04927-IDE01446-Window heater-Running time of heated front window,0 s
    IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,-50.0 °C
    IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C
    IDE04927-ENG126613-Window heater-Aussenspiegelheizung,420.0 s
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,400 s
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,Default
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,delay_driver_door_contact_thatcham
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
    IDE05142-ENG116706-Access control-Autounlock NAR,not active
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,active
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,not active
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
    IDE05142-ENG115755-Access control-Notschließfunktion,active
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
    IDE05142-ENG115758-Access control-Valet Parking,not active
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
    IDE05143-MAS02985-Writing parameter-Value,130
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
    IDE05144-Read parameter address,FE 00 00
    IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34
    IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E
    IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00
    IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00
    IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,38
    IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,42
    IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00
    IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00
    IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,39
    IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,43
    IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08
    IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18
    IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,48
    IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,00
    IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,00
    IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,00
    IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,00
    IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,00
    IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,28
    IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C
    IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00
    IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B
    IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00
    IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,4C
    IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00
    IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00
    IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00
    IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00
    IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,0C
    IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,48
    IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,4C
    IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36
    IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40
    IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37
    IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41
    IDE05145-ENG115018-Light configuration-Dimming_AB_0,100
    IDE05145-ENG115037-Light configuration-Dimming_AB_1,100
    IDE05145-ENG114999-Light configuration-Dimming_AB_10,100
    IDE05145-ENG115193-Light configuration-Dimming_AB_11,100
    IDE05145-ENG115212-Light configuration-Dimming_AB_12,100
    IDE05145-ENG114958-Light configuration-Dimming_AB_13,100
    IDE05145-ENG115233-Light configuration-Dimming_AB_14,100
    IDE05145-ENG115252-Light configuration-Dimming_AB_15,100
    IDE05145-ENG115271-Light configuration-Dimming_AB_16,100
    IDE05145-ENG115290-Light configuration-Dimming_AB_17,100
    IDE05145-ENG115309-Light configuration-Dimming_AB_18,100
    IDE05145-ENG115328-Light configuration-Dimming_AB_19,100
    IDE05145-ENG115056-Light configuration-Dimming_AB_2,100
    IDE05145-ENG115347-Light configuration-Dimming_AB_20,100
    IDE05145-ENG115366-Light configuration-Dimming_AB_21,100
    IDE05145-ENG115385-Light configuration-Dimming_AB_22,100
    IDE05145-ENG115404-Light configuration-Dimming_AB_23,100
    IDE05145-ENG115423-Light configuration-Dimming_AB_24,100
    IDE05145-ENG115442-Light configuration-Dimming_AB_25,100
    IDE05145-ENG115461-Light configuration-Dimming_AB_26,100
    IDE05145-ENG115480-Light configuration-Dimming_AB_27,100
    IDE05145-ENG115499-Light configuration-Dimming_AB_28,100
    IDE05145-ENG115518-Light configuration-Dimming_AB_29,100
    IDE05145-ENG115075-Light configuration-Dimming_AB_3,100
    IDE05145-ENG115537-Light configuration-Dimming_AB_30,100
    IDE05145-ENG115556-Light configuration-Dimming_AB_31,100
    IDE05145-ENG115575-Light configuration-Dimming_AB_32,100
    IDE05145-ENG115594-Light configuration-Dimming_AB_33,100
    IDE05145-ENG115613-Light configuration-Dimming_AB_34,108
    IDE05145-ENG115094-Light configuration-Dimming_AB_4,100
    IDE05145-ENG114977-Light configuration-Dimming_AB_5,100
    IDE05145-ENG115115-Light configuration-Dimming_AB_6,100
    IDE05145-ENG115134-Light configuration-Dimming_AB_7,100
    IDE05145-ENG115153-Light configuration-Dimming_AB_8,100
    IDE05145-ENG115172-Light configuration-Dimming_AB_9,100
    IDE05145-ENG115022-Light configuration-Dimming_CD_0,0
    IDE05145-ENG115041-Light configuration-Dimming_CD_1,0
    IDE05145-ENG115003-Light configuration-Dimming_CD_10,0
    IDE05145-ENG115197-Light configuration-Dimming_CD_11,0
    IDE05145-ENG115216-Light configuration-Dimming_CD_12,0
    IDE05145-ENG114962-Light configuration-Dimming_CD_13,0
    IDE05145-ENG115237-Light configuration-Dimming_CD_14,0
    IDE05145-ENG115256-Light configuration-Dimming_CD_15,0
    IDE05145-ENG115275-Light configuration-Dimming_CD_16,0
    IDE05145-ENG115294-Light configuration-Dimming_CD_17,0
    IDE05145-ENG115313-Light configuration-Dimming_CD_18,0
    IDE05145-ENG115332-Light configuration-Dimming_CD_19,0
    IDE05145-ENG115060-Light configuration-Dimming_CD_2,28
    IDE05145-ENG115351-Light configuration-Dimming_CD_20,0
    IDE05145-ENG115370-Light configuration-Dimming_CD_21,0
    IDE05145-ENG115389-Light configuration-Dimming_CD_22,0
    IDE05145-ENG115408-Light configuration-Dimming_CD_23,100
    IDE05145-ENG115427-Light configuration-Dimming_CD_24,100
    IDE05145-ENG115446-Light configuration-Dimming_CD_25,0
    IDE05145-ENG115465-Light configuration-Dimming_CD_26,0
    IDE05145-ENG115484-Light configuration-Dimming_CD_27,0
    IDE05145-ENG115503-Light configuration-Dimming_CD_28,0
    IDE05145-ENG115522-Light configuration-Dimming_CD_29,0
    IDE05145-ENG115079-Light configuration-Dimming_CD_3,28
    IDE05145-ENG115541-Light configuration-Dimming_CD_30,0
    IDE05145-ENG115560-Light configuration-Dimming_CD_31,0
    IDE05145-ENG115579-Light configuration-Dimming_CD_32,0
    IDE05145-ENG115598-Light configuration-Dimming_CD_33,0
    IDE05145-ENG115617-Light configuration-Dimming_CD_34,3
    IDE05145-ENG115098-Light configuration-Dimming_CD_4,100
    IDE05145-ENG114981-Light configuration-Dimming_CD_5,100
    IDE05145-ENG115119-Light configuration-Dimming_CD_6,100
    IDE05145-ENG115138-Light configuration-Dimming_CD_7,100
    IDE05145-ENG115157-Light configuration-Dimming_CD_8,0
    IDE05145-ENG115176-Light configuration-Dimming_CD_9,0
    IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize
    IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize
    IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize
    IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize
    IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize
    IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize
    IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize
    IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize
    IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize
    IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize
    IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize
    IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize
    IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize
    IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize
    IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize
    IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize
    IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize
    IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize
    IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize
    IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize
    IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize
    IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize
    IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize
    IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize
    IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize
    IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize
    IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize
    IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize
    IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize
    IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize
    IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize
    IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize
    IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize
    IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize
    IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize
    IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize
    IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize
    IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize
    IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize
    IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize
    IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize
    IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize
    IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize
    IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize
    IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize
    IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize
    IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize
    IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,minimize
    IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize
    IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize
    IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize
    IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize
    IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize
    IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize
    IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize
    IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize
    IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize
    IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize
    IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,minimize
    IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize
    IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize
    IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize
    IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize
    IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize
    IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize
    IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize
    IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize
    IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize
    IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize
    IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize
    IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize
    IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize
    IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize
    IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize
    IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize
    IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize
    IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize
    IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize
    IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize
    IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize
    IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize
    IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize
    IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize
    IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize
    IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize
    IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize
    IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize
    IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize
    IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize
    IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize
    IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize
    IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize
    IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize
    IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize
    IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize
    IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize
    IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize
    IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize
    IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize
    IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize
    IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize
    IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize
    IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize
    IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize
    IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize
    IDE05145-ENG115026-Light configuration-Dimming_EF_0,0
    IDE05145-ENG115045-Light configuration-Dimming_EF_1,0
    IDE05145-ENG115007-Light configuration-Dimming_EF_10,0
    IDE05145-ENG115201-Light configuration-Dimming_EF_11,0
    IDE05145-ENG115220-Light configuration-Dimming_EF_12,0
    IDE05145-ENG114966-Light configuration-Dimming_EF_13,0
    IDE05145-ENG115241-Light configuration-Dimming_EF_14,0
    IDE05145-ENG115260-Light configuration-Dimming_EF_15,0
    IDE05145-ENG115279-Light configuration-Dimming_EF_16,0
    IDE05145-ENG115298-Light configuration-Dimming_EF_17,0
    IDE05145-ENG115317-Light configuration-Dimming_EF_18,0
    IDE05145-ENG115336-Light configuration-Dimming_EF_19,0
    IDE05145-ENG115064-Light configuration-Dimming_EF_2,28
    IDE05145-ENG115355-Light configuration-Dimming_EF_20,0
    IDE05145-ENG115374-Light configuration-Dimming_EF_21,0
    IDE05145-ENG115393-Light configuration-Dimming_EF_22,0
    IDE05145-ENG115412-Light configuration-Dimming_EF_23,0
    IDE05145-ENG115431-Light configuration-Dimming_EF_24,0
    IDE05145-ENG115450-Light configuration-Dimming_EF_25,0
    IDE05145-ENG115469-Light configuration-Dimming_EF_26,0
    IDE05145-ENG115488-Light configuration-Dimming_EF_27,0
    IDE05145-ENG115507-Light configuration-Dimming_EF_28,0
    IDE05145-ENG115526-Light configuration-Dimming_EF_29,0
    IDE05145-ENG115083-Light configuration-Dimming_EF_3,28
    IDE05145-ENG115545-Light configuration-Dimming_EF_30,0
    IDE05145-ENG115564-Light configuration-Dimming_EF_31,0
    IDE05145-ENG115583-Light configuration-Dimming_EF_32,0
    IDE05145-ENG115602-Light configuration-Dimming_EF_33,0
    IDE05145-ENG115621-Light configuration-Dimming_EF_34,0
    IDE05145-ENG115102-Light configuration-Dimming_EF_4,0
    IDE05145-ENG114985-Light configuration-Dimming_EF_5,0
    IDE05145-ENG115123-Light configuration-Dimming_EF_6,0
    IDE05145-ENG115142-Light configuration-Dimming_EF_7,0
    IDE05145-ENG115161-Light configuration-Dimming_EF_8,0
    IDE05145-ENG115180-Light configuration-Dimming_EF_9,0
    IDE05145-ENG115030-Light configuration-Dimming_GH_0,0
    IDE05145-ENG115049-Light configuration-Dimming_GH_1,0
    IDE05145-ENG115011-Light configuration-Dimming_GH_10,0
    IDE05145-ENG115205-Light configuration-Dimming_GH_11,0
    IDE05145-ENG115224-Light configuration-Dimming_GH_12,0
    IDE05145-ENG114970-Light configuration-Dimming_GH_13,0
    IDE05145-ENG115245-Light configuration-Dimming_GH_14,0
    IDE05145-ENG115264-Light configuration-Dimming_GH_15,0
    IDE05145-ENG115283-Light configuration-Dimming_GH_16,0
    IDE05145-ENG115302-Light configuration-Dimming_GH_17,0
    IDE05145-ENG115321-Light configuration-Dimming_GH_18,0
    IDE05145-ENG115340-Light configuration-Dimming_GH_19,0
    IDE05145-ENG115068-Light configuration-Dimming_GH_2,0
    IDE05145-ENG115359-Light configuration-Dimming_GH_20,0
    IDE05145-ENG115378-Light configuration-Dimming_GH_21,0
    IDE05145-ENG115397-Light configuration-Dimming_GH_22,0
    IDE05145-ENG115416-Light configuration-Dimming_GH_23,0
    IDE05145-ENG115435-Light configuration-Dimming_GH_24,0
    IDE05145-ENG115454-Light configuration-Dimming_GH_25,0
    IDE05145-ENG115473-Light configuration-Dimming_GH_26,0
    IDE05145-ENG115492-Light configuration-Dimming_GH_27,0
    IDE05145-ENG115511-Light configuration-Dimming_GH_28,0
    IDE05145-ENG115530-Light configuration-Dimming_GH_29,0
    IDE05145-ENG115087-Light configuration-Dimming_GH_3,0
    IDE05145-ENG115549-Light configuration-Dimming_GH_30,0
    IDE05145-ENG115568-Light configuration-Dimming_GH_31,0
    IDE05145-ENG115587-Light configuration-Dimming_GH_32,0
    IDE05145-ENG115606-Light configuration-Dimming_GH_33,0
    IDE05145-ENG115625-Light configuration-Dimming_GH_34,0
    IDE05145-ENG115106-Light configuration-Dimming_GH_4,0
    IDE05145-ENG114989-Light configuration-Dimming_GH_5,0
    IDE05145-ENG115127-Light configuration-Dimming_GH_6,0
    IDE05145-ENG115146-Light configuration-Dimming_GH_7,0
    IDE05145-ENG115165-Light configuration-Dimming_GH_8,0
    IDE05145-ENG115184-Light configuration-Dimming_GH_9,0
    IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14
    IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15
    IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,03
    IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00
    IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,22
    IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,23
    IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00
    IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00
    IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,17
    IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,19
    IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16
    IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18
    IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,4A
    IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,00
    IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,00
    IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C
    IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,00
    IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,00
    IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,30
    IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E
    IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08
    IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32
    IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01
    IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,4C
    IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07
    IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00
    IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00
    IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00
    IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,01
    IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,49
    IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,4B
    IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A
    IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B
    IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C
    IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D
    IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always
    IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always
    IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always
    IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always
    IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always
    IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always
    IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always
    IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always
    IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always
    IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always
    IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always
    IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always
    IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always
    IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always
    IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always
    IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always
    IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always
    IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always
    IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always
    IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always
    IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always
    IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always
    IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always
    IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always
    IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always
    IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always
    IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always
    IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always
    IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,only_if_closed
    IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always
    IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always
    IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always
    IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always
    IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always
    IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always
    IDE05145-ENG115016-Light configuration-Light_Function_A_0,2
    IDE05145-ENG115035-Light configuration-Light_Function_A_1,4
    IDE05145-ENG114997-Light configuration-Light_Function_A_10,45
    IDE05145-ENG115191-Light configuration-Light_Function_A_11,62
    IDE05145-ENG115210-Light configuration-Light_Function_A_12,18
    IDE05145-ENG114956-Light configuration-Light_Function_A_13,19
    IDE05145-ENG115231-Light configuration-Light_Function_A_14,63
    IDE05145-ENG115250-Light configuration-Light_Function_A_15,64
    IDE05145-ENG115269-Light configuration-Light_Function_A_16,2
    IDE05145-ENG115288-Light configuration-Light_Function_A_17,4
    IDE05145-ENG115307-Light configuration-Light_Function_A_18,2
    IDE05145-ENG115326-Light configuration-Light_Function_A_19,4
    IDE05145-ENG115054-Light configuration-Light_Function_A_2,20
    IDE05145-ENG115345-Light configuration-Light_Function_A_20,24
    IDE05145-ENG115364-Light configuration-Light_Function_A_21,24
    IDE05145-ENG115383-Light configuration-Light_Function_A_22,24
    IDE05145-ENG115402-Light configuration-Light_Function_A_23,8
    IDE05145-ENG115421-Light configuration-Light_Function_A_24,8
    IDE05145-ENG115440-Light configuration-Light_Function_A_25,8
    IDE05145-ENG115459-Light configuration-Light_Function_A_26,26
    IDE05145-ENG115478-Light configuration-Light_Function_A_27,38
    IDE05145-ENG115497-Light configuration-Light_Function_A_28,25
    IDE05145-ENG115516-Light configuration-Light_Function_A_29,37
    IDE05145-ENG115073-Light configuration-Light_Function_A_3,20
    IDE05145-ENG115535-Light configuration-Light_Function_A_30,41
    IDE05145-ENG115554-Light configuration-Light_Function_A_31,0
    IDE05145-ENG115573-Light configuration-Light_Function_A_32,0
    IDE05145-ENG115592-Light configuration-Light_Function_A_33,0
    IDE05145-ENG115611-Light configuration-Light_Function_A_34,229
    IDE05145-ENG115092-Light configuration-Light_Function_A_4,20
    IDE05145-ENG114975-Light configuration-Light_Function_A_5,20
    IDE05145-ENG115113-Light configuration-Light_Function_A_6,11
    IDE05145-ENG115132-Light configuration-Light_Function_A_7,12
    IDE05145-ENG115151-Light configuration-Light_Function_A_8,13
    IDE05145-ENG115170-Light configuration-Light_Function_A_9,14
    IDE05145-ENG115017-Light configuration-Light_Function_B_0,0
    IDE05145-ENG115036-Light configuration-Light_Function_B_1,0
    IDE05145-ENG114998-Light configuration-Light_Function_B_10,0
    IDE05145-ENG115192-Light configuration-Light_Function_B_11,0
    IDE05145-ENG115211-Light configuration-Light_Function_B_12,22
    IDE05145-ENG114957-Light configuration-Light_Function_B_13,23
    IDE05145-ENG115232-Light configuration-Light_Function_B_14,0
    IDE05145-ENG115251-Light configuration-Light_Function_B_15,0
    IDE05145-ENG115270-Light configuration-Light_Function_B_16,0
    IDE05145-ENG115289-Light configuration-Light_Function_B_17,0
    IDE05145-ENG115308-Light configuration-Light_Function_B_18,0
    IDE05145-ENG115327-Light configuration-Light_Function_B_19,0
    IDE05145-ENG115055-Light configuration-Light_Function_B_2,0
    IDE05145-ENG115346-Light configuration-Light_Function_B_20,0
    IDE05145-ENG115365-Light configuration-Light_Function_B_21,0
    IDE05145-ENG115384-Light configuration-Light_Function_B_22,0
    IDE05145-ENG115403-Light configuration-Light_Function_B_23,9
    IDE05145-ENG115422-Light configuration-Light_Function_B_24,10
    IDE05145-ENG115441-Light configuration-Light_Function_B_25,30
    IDE05145-ENG115460-Light configuration-Light_Function_B_26,0
    IDE05145-ENG115479-Light configuration-Light_Function_B_27,0
    IDE05145-ENG115498-Light configuration-Light_Function_B_28,0
    IDE05145-ENG115517-Light configuration-Light_Function_B_29,0
    IDE05145-ENG115074-Light configuration-Light_Function_B_3,0
    IDE05145-ENG115536-Light configuration-Light_Function_B_30,0
    IDE05145-ENG115555-Light configuration-Light_Function_B_31,0
    IDE05145-ENG115574-Light configuration-Light_Function_B_32,0
    IDE05145-ENG115593-Light configuration-Light_Function_B_33,0
    IDE05145-ENG115612-Light configuration-Light_Function_B_34,246
    IDE05145-ENG115093-Light configuration-Light_Function_B_4,8
    IDE05145-ENG114976-Light configuration-Light_Function_B_5,8
    IDE05145-ENG115114-Light configuration-Light_Function_B_6,0
    IDE05145-ENG115133-Light configuration-Light_Function_B_7,0
    IDE05145-ENG115152-Light configuration-Light_Function_B_8,15
    IDE05145-ENG115171-Light configuration-Light_Function_B_9,15
    IDE05145-ENG115020-Light configuration-Light_Function_C_0,0
    IDE05145-ENG115039-Light configuration-Light_Function_C_1,0
    IDE05145-ENG115001-Light configuration-Light_Function_C_10,0
    IDE05145-ENG115195-Light configuration-Light_Function_C_11,0
    IDE05145-ENG115214-Light configuration-Light_Function_C_12,0
    IDE05145-ENG114960-Light configuration-Light_Function_C_13,0
    IDE05145-ENG115235-Light configuration-Light_Function_C_14,0
    IDE05145-ENG115254-Light configuration-Light_Function_C_15,0
    IDE05145-ENG115273-Light configuration-Light_Function_C_16,0
    IDE05145-ENG115292-Light configuration-Light_Function_C_17,0
    IDE05145-ENG115311-Light configuration-Light_Function_C_18,0
    IDE05145-ENG115330-Light configuration-Light_Function_C_19,0
    IDE05145-ENG115058-Light configuration-Light_Function_C_2,8
    IDE05145-ENG115349-Light configuration-Light_Function_C_20,0
    IDE05145-ENG115368-Light configuration-Light_Function_C_21,0
    IDE05145-ENG115387-Light configuration-Light_Function_C_22,0
    IDE05145-ENG115406-Light configuration-Light_Function_C_23,30
    IDE05145-ENG115425-Light configuration-Light_Function_C_24,30
    IDE05145-ENG115444-Light configuration-Light_Function_C_25,0
    IDE05145-ENG115463-Light configuration-Light_Function_C_26,0
    IDE05145-ENG115482-Light configuration-Light_Function_C_27,0
    IDE05145-ENG115501-Light configuration-Light_Function_C_28,0
    IDE05145-ENG115519-Light configuration-Light_Function_C_29,0
    IDE05145-ENG115077-Light configuration-Light_Function_C_3,8
    IDE05145-ENG115539-Light configuration-Light_Function_C_30,0
    IDE05145-ENG115558-Light configuration-Light_Function_C_31,0
    IDE05145-ENG115577-Light configuration-Light_Function_C_32,0
    IDE05145-ENG115596-Light configuration-Light_Function_C_33,0
    IDE05145-ENG115615-Light configuration-Light_Function_C_34,173
    IDE05145-ENG115096-Light configuration-Light_Function_C_4,9
    IDE05145-ENG114979-Light configuration-Light_Function_C_5,10
    IDE05145-ENG115117-Light configuration-Light_Function_C_6,13
    IDE05145-ENG115136-Light configuration-Light_Function_C_7,14
    IDE05145-ENG115155-Light configuration-Light_Function_C_8,0
    IDE05145-ENG115174-Light configuration-Light_Function_C_9,0
    IDE05145-ENG115021-Light configuration-Light_Function_D_0,0
    IDE05145-ENG115040-Light configuration-Light_Function_D_1,0
    IDE05145-ENG115002-Light configuration-Light_Function_D_10,0
    IDE05145-ENG115196-Light configuration-Light_Function_D_11,0
    IDE05145-ENG115215-Light configuration-Light_Function_D_12,0
    IDE05145-ENG114961-Light configuration-Light_Function_D_13,0
    IDE05145-ENG115236-Light configuration-Light_Function_D_14,0
    IDE05145-ENG115255-Light configuration-Light_Function_D_15,0
    IDE05145-ENG115274-Light configuration-Light_Function_D_16,0
    IDE05145-ENG115293-Light configuration-Light_Function_D_17,0
    IDE05145-ENG115312-Light configuration-Light_Function_D_18,0
    IDE05145-ENG115331-Light configuration-Light_Function_D_19,0
    IDE05145-ENG115059-Light configuration-Light_Function_D_2,9
    IDE05145-ENG115350-Light configuration-Light_Function_D_20,0
    IDE05145-ENG115369-Light configuration-Light_Function_D_21,0
    IDE05145-ENG115388-Light configuration-Light_Function_D_22,0
    IDE05145-ENG115407-Light configuration-Light_Function_D_23,0
    IDE05145-ENG115426-Light configuration-Light_Function_D_24,0
    IDE05145-ENG115445-Light configuration-Light_Function_D_25,0
    IDE05145-ENG115464-Light configuration-Light_Function_D_26,0
    IDE05145-ENG115483-Light configuration-Light_Function_D_27,0
    IDE05145-ENG115502-Light configuration-Light_Function_D_28,0
    IDE05145-ENG115521-Light configuration-Light_Function_D_29,0
    IDE05145-ENG115078-Light configuration-Light_Function_D_3,10
    IDE05145-ENG115540-Light configuration-Light_Function_D_30,0
    IDE05145-ENG115559-Light configuration-Light_Function_D_31,0
    IDE05145-ENG115578-Light configuration-Light_Function_D_32,0
    IDE05145-ENG115597-Light configuration-Light_Function_D_33,0
    IDE05145-ENG115616-Light configuration-Light_Function_D_34,78
    IDE05145-ENG115097-Light configuration-Light_Function_D_4,0
    IDE05145-ENG114980-Light configuration-Light_Function_D_5,0
    IDE05145-ENG115118-Light configuration-Light_Function_D_6,15
    IDE05145-ENG115137-Light configuration-Light_Function_D_7,15
    IDE05145-ENG115156-Light configuration-Light_Function_D_8,0
    IDE05145-ENG115175-Light configuration-Light_Function_D_9,0
    IDE05145-ENG115024-Light configuration-Light_Function_E_0,0
    IDE05145-ENG115043-Light configuration-Light_Function_E_1,0
    IDE05145-ENG115005-Light configuration-Light_Function_E_10,0
    IDE05145-ENG115199-Light configuration-Light_Function_E_11,0
    IDE05145-ENG115218-Light configuration-Light_Function_E_12,0
    IDE05145-ENG114964-Light configuration-Light_Function_E_13,0
    IDE05145-ENG115239-Light configuration-Light_Function_E_14,0
    IDE05145-ENG115258-Light configuration-Light_Function_E_15,0
    IDE05145-ENG115277-Light configuration-Light_Function_E_16,0
    IDE05145-ENG115296-Light configuration-Light_Function_E_17,0
    IDE05145-ENG115315-Light configuration-Light_Function_E_18,0
    IDE05145-ENG115334-Light configuration-Light_Function_E_19,0
    IDE05145-ENG115062-Light configuration-Light_Function_E_2,18
    IDE05145-ENG115353-Light configuration-Light_Function_E_20,0
    IDE05145-ENG115372-Light configuration-Light_Function_E_21,0
    IDE05145-ENG115391-Light configuration-Light_Function_E_22,0
    IDE05145-ENG115410-Light configuration-Light_Function_E_23,0
    IDE05145-ENG115429-Light configuration-Light_Function_E_24,0
    IDE05145-ENG115448-Light configuration-Light_Function_E_25,0
    IDE05145-ENG115467-Light configuration-Light_Function_E_26,0
    IDE05145-ENG115486-Light configuration-Light_Function_E_27,0
    IDE05145-ENG115505-Light configuration-Light_Function_E_28,0
    IDE05145-ENG115524-Light configuration-Light_Function_E_29,0
    IDE05145-ENG115081-Light configuration-Light_Function_E_3,19
    IDE05145-ENG115543-Light configuration-Light_Function_E_30,0
    IDE05145-ENG115562-Light configuration-Light_Function_E_31,0
    IDE05145-ENG115581-Light configuration-Light_Function_E_32,0
    IDE05145-ENG115600-Light configuration-Light_Function_E_33,0
    IDE05145-ENG115619-Light configuration-Light_Function_E_34,88
    IDE05145-ENG115100-Light configuration-Light_Function_E_4,0
    IDE05145-ENG114983-Light configuration-Light_Function_E_5,0
    IDE05145-ENG115121-Light configuration-Light_Function_E_6,0
    IDE05145-ENG115140-Light configuration-Light_Function_E_7,0
    IDE05145-ENG115159-Light configuration-Light_Function_E_8,0
    IDE05145-ENG115178-Light configuration-Light_Function_E_9,0
    IDE05145-ENG115025-Light configuration-Light_Function_F_0,0
    IDE05145-ENG115044-Light configuration-Light_Function_F_1,0
    IDE05145-ENG115006-Light configuration-Light_Function_F_10,0
    IDE05145-ENG115200-Light configuration-Light_Function_F_11,0
    IDE05145-ENG115219-Light configuration-Light_Function_F_12,0
    IDE05145-ENG114965-Light configuration-Light_Function_F_13,0
    IDE05145-ENG115240-Light configuration-Light_Function_F_14,0
    IDE05145-ENG115259-Light configuration-Light_Function_F_15,0
    IDE05145-ENG115278-Light configuration-Light_Function_F_16,0
    IDE05145-ENG115297-Light configuration-Light_Function_F_17,0
    IDE05145-ENG115316-Light configuration-Light_Function_F_18,0
    IDE05145-ENG115335-Light configuration-Light_Function_F_19,0
    IDE05145-ENG115063-Light configuration-Light_Function_F_2,0
    IDE05145-ENG115354-Light configuration-Light_Function_F_20,0
    IDE05145-ENG115373-Light configuration-Light_Function_F_21,0
    IDE05145-ENG115392-Light configuration-Light_Function_F_22,0
    IDE05145-ENG115411-Light configuration-Light_Function_F_23,0
    IDE05145-ENG115430-Light configuration-Light_Function_F_24,0
    IDE05145-ENG115449-Light configuration-Light_Function_F_25,0
    IDE05145-ENG115468-Light configuration-Light_Function_F_26,0
    IDE05145-ENG115487-Light configuration-Light_Function_F_27,0
    IDE05145-ENG115506-Light configuration-Light_Function_F_28,0
    IDE05145-ENG115525-Light configuration-Light_Function_F_29,0
    IDE05145-ENG115082-Light configuration-Light_Function_F_3,0
    IDE05145-ENG115544-Light configuration-Light_Function_F_30,0
    IDE05145-ENG115563-Light configuration-Light_Function_F_31,0
    IDE05145-ENG115582-Light configuration-Light_Function_F_32,0
    IDE05145-ENG115601-Light configuration-Light_Function_F_33,0
    IDE05145-ENG115620-Light configuration-Light_Function_F_34,0
    IDE05145-ENG115101-Light configuration-Light_Function_F_4,0
    IDE05145-ENG114984-Light configuration-Light_Function_F_5,0
    IDE05145-ENG115122-Light configuration-Light_Function_F_6,0
    IDE05145-ENG115141-Light configuration-Light_Function_F_7,0
    IDE05145-ENG115160-Light configuration-Light_Function_F_8,0
    IDE05145-ENG115179-Light configuration-Light_Function_F_9,0
    IDE05145-ENG115028-Light configuration-Light_Function_G_0,0
    IDE05145-ENG115047-Light configuration-Light_Function_G_1,0
    IDE05145-ENG115009-Light configuration-Light_Function_G_10,0
    IDE05145-ENG115203-Light configuration-Light_Function_G_11,0
    IDE05145-ENG115222-Light configuration-Light_Function_G_12,0
    IDE05145-ENG114968-Light configuration-Light_Function_G_13,0
    IDE05145-ENG115243-Light configuration-Light_Function_G_14,0
    IDE05145-ENG115262-Light configuration-Light_Function_G_15,0
    IDE05145-ENG115281-Light configuration-Light_Function_G_16,0
    IDE05145-ENG115300-Light configuration-Light_Function_G_17,0
    IDE05145-ENG115319-Light configuration-Light_Function_G_18,0
    IDE05145-ENG115338-Light configuration-Light_Function_G_19,0
    IDE05145-ENG115066-Light configuration-Light_Function_G_2,0
    IDE05145-ENG115357-Light configuration-Light_Function_G_20,0
    IDE05145-ENG115376-Light configuration-Light_Function_G_21,0
    IDE05145-ENG115395-Light configuration-Light_Function_G_22,0
    IDE05145-ENG115414-Light configuration-Light_Function_G_23,0
    IDE05145-ENG115433-Light configuration-Light_Function_G_24,0
    IDE05145-ENG115452-Light configuration-Light_Function_G_25,0
    IDE05145-ENG115471-Light configuration-Light_Function_G_26,0
    IDE05145-ENG115490-Light configuration-Light_Function_G_27,0
    IDE05145-ENG115509-Light configuration-Light_Function_G_28,0
    IDE05145-ENG115528-Light configuration-Light_Function_G_29,0
    IDE05145-ENG115085-Light configuration-Light_Function_G_3,0
    IDE05145-ENG115547-Light configuration-Light_Function_G_30,0
    IDE05145-ENG115566-Light configuration-Light_Function_G_31,0
    IDE05145-ENG115585-Light configuration-Light_Function_G_32,0
    IDE05145-ENG115604-Light configuration-Light_Function_G_33,0
    IDE05145-ENG115623-Light configuration-Light_Function_G_34,0
    IDE05145-ENG115104-Light configuration-Light_Function_G_4,0
    IDE05145-ENG114987-Light configuration-Light_Function_G_5,0
    IDE05145-ENG115125-Light configuration-Light_Function_G_6,0
    IDE05145-ENG115144-Light configuration-Light_Function_G_7,0
    IDE05145-ENG115163-Light configuration-Light_Function_G_8,0
    IDE05145-ENG115182-Light configuration-Light_Function_G_9,0
    IDE05145-ENG115029-Light configuration-Light_Function_H_0,0
    IDE05145-ENG115048-Light configuration-Light_Function_H_1,0
    IDE05145-ENG115010-Light configuration-Light_Function_H_10,0
    IDE05145-ENG115204-Light configuration-Light_Function_H_11,0
    IDE05145-ENG115223-Light configuration-Light_Function_H_12,0
    IDE05145-ENG114969-Light configuration-Light_Function_H_13,0
    IDE05145-ENG115244-Light configuration-Light_Function_H_14,0
    IDE05145-ENG115263-Light configuration-Light_Function_H_15,0
    IDE05145-ENG115282-Light configuration-Light_Function_H_16,0
    IDE05145-ENG115301-Light configuration-Light_Function_H_17,0
    IDE05145-ENG115320-Light configuration-Light_Function_H_18,0
    IDE05145-ENG115339-Light configuration-Light_Function_H_19,0
    IDE05145-ENG115067-Light configuration-Light_Function_H_2,0
    IDE05145-ENG115358-Light configuration-Light_Function_H_20,0
    IDE05145-ENG115377-Light configuration-Light_Function_H_21,0
    IDE05145-ENG115396-Light configuration-Light_Function_H_22,0
    IDE05145-ENG115415-Light configuration-Light_Function_H_23,0
    IDE05145-ENG115434-Light configuration-Light_Function_H_24,0
    IDE05145-ENG115453-Light configuration-Light_Function_H_25,0
    IDE05145-ENG115472-Light configuration-Light_Function_H_26,0
    IDE05145-ENG115491-Light configuration-Light_Function_H_27,0
    IDE05145-ENG115510-Light configuration-Light_Function_H_28,0
    IDE05145-ENG115529-Light configuration-Light_Function_H_29,0
    IDE05145-ENG115086-Light configuration-Light_Function_H_3,0
    IDE05145-ENG115548-Light configuration-Light_Function_H_30,0
    IDE05145-ENG115567-Light configuration-Light_Function_H_31,0
    IDE05145-ENG115586-Light configuration-Light_Function_H_32,0
    IDE05145-ENG115605-Light configuration-Light_Function_H_33,0
    IDE05145-ENG115624-Light configuration-Light_Function_H_34,99
    IDE05145-ENG115105-Light configuration-Light_Function_H_4,0
    IDE05145-ENG114988-Light configuration-Light_Function_H_5,0
    IDE05145-ENG115126-Light configuration-Light_Function_H_6,0
    IDE05145-ENG115145-Light configuration-Light_Function_H_7,0
    IDE05145-ENG115164-Light configuration-Light_Function_H_8,0
    IDE05145-ENG115183-Light configuration-Light_Function_H_9,0
    IDE05145-ENG115013-Light configuration-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115032-Light configuration-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG114995-Light configuration-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115207-Light configuration-Type_Of_Load_12,allgemeine Scheinwerfer
    IDE05145-ENG114954-Light configuration-Type_Of_Load_13,allgemeine Scheinwerfer
    IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115266-Light configuration-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
    IDE05145-ENG115285-Light configuration-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115304-Light configuration-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115323-Light configuration-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115051-Light configuration-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
    IDE05145-ENG115342-Light configuration-Type_Of_Load_20,LED Bremsleuchten
    IDE05145-ENG115361-Light configuration-Type_Of_Load_21,LED Bremsleuchten
    IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte
    IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115437-Light configuration-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
    IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe12W
    IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeine Scheinwerfer
    IDE05145-ENG115070-Light configuration-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
    IDE05145-ENG115532-Light configuration-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active
    IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active
    IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active
    IDE05145-ENG115089-Light configuration-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG114973-Light configuration-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Xenon Abblendlicht
    IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Xenon Abblendlicht
    IDE05145-ENG115148-Light configuration-Type_Of_Load_8,Shutter
    IDE05145-ENG115167-Light configuration-Type_Of_Load_9,Shutter
    IDE05822-DWA Vehicle inclination sensor,100 %
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 64 23 65 42 57 9B 25 44 3F 3A 69 35 95 2D 09 A3 02 07 06 56 00 0F 12 00 89 09 31 F3 6E 0F C3 42 87 1B 05 34 3F 3A 69 7A 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 67 23 65 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 91 30 61 27 2D
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
    IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
    IDE06425-Roller test bench mode: functional,not active
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
    IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min
    IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0
    IDE08542-IDE02021-Access control 2-Comfort closing,active
    IDE08542-IDE02022-Access control 2-Comfort opening,active
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
    IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
    IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,not active
    IDE08542-ENG115671-Access control 2-Regenschließen,not active
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
    IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,active
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
    IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
    IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5
    IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36
    IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active
    IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active
    IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active
    IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active
    IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active
    IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active
    IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active
    IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active
    IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active
    IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active
    IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active
    IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active
    IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active
    IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active
    IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active
    IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active
    IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active
    IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active
    IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active
    IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active
    IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active
    IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active
    IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active
    IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active
    IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active
    IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active
    IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active
    IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active
    IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active
    IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active
    IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active
    IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active
    IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active
    IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active
    IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active
    IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm
    IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5
    IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40
    IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active
    IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active
    IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active
    IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active
    IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active
    IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active
    IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active
    IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active
    IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active
    IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active
    IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active
    IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active
    IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active
    IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active
    IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active
    IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active
    IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active
    IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active
    IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active
    IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active
    IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active
    IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active
    IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active
    IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active
    IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active
    IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active
    IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active
    IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active
    IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active
    IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active
    IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active
    IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active
    IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active
    IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active
    IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active
    IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm
    IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Time
    IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung,Energy management
    IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung,Energy management
    IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten
    IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,0 min
    IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit,24 s
    IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,not active
    MAS01490-IDE07474-Energy management-Adapting for energy management,Energy management active
    MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement,not active
    MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed
    MAS08233-ENG126575-other-mute_mode_aktiv,not active
    MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed
    ENG05956-Adaptation_theft_protection_2,not active
    ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.0 %
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.0 %
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.0 %
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.0 %
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.0 %
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.0 %
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.0 %
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.0 %
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.0 %
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,104 lx
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,6
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,6
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,5.0 %
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,5.0 %
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,15.0 %
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,40.0 %
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,82.0 %
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,10.0
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,10.0
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,50.0
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,50.0
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,10.0
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,10.0
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.0
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0
    ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100
    ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0
    ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize
    ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize
    ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize
    ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0
    ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0
    ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14
    ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34
    ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always
    ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase
    ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active
    ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active
    ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active
    ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active
    ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active
    ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active
    ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active
    ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
    ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,100
    ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0
    ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize
    ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize
    ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize
    ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0
    ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0
    ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,03
    ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00
    ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always
    ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,Ambientelicht 1
    ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active
    ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active
    ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active
    ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active
    ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active
    ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active
    ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active
    ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
    ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100
    ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0
    ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize
    ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize
    ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize
    ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0
    ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0
    ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00
    ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00
    ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always
    ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster
    ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active
    ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active
    ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active
    ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active
    ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active
    ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active
    ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active
    ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
    ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100
    ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0
    ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize
    ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize
    ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize
    ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0
    ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0
    ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22
    ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38
    ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always
    ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links
    ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links
    ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active
    ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active
    ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active
    ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active
    ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active
    ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active
    ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer
    ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100
    ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0
    ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize
    ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize
    ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize
    ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0
    ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0
    ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23
    ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42
    ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always
    ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts
    ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts
    ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active
    ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active
    ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active
    ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active
    ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active
    ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active
    ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer
    ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100
    ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0
    ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize
    ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize
    ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize
    ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0
    ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0
    ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00
    ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00
    ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always
    ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED
    ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active
    ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active
    ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active
    ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active
    ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active
    ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active
    ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active
    ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
    ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100
    ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0
    ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize
    ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize
    ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize
    ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0
    ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0
    ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,17
    ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,39
    ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always
    ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase
    ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active
    ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active
    ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active
    ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active
    ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active
    ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active
    ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active
    ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
    ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100
    ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0
    ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize
    ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize
    ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize
    ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0
    ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0
    ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,19
    ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,43
    ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always
    ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase
    ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active
    ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active
    ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active
    ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active
    ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active
    ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active
    ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active
    ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
    ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100
    ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0
    ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize
    ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize
    ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize
    ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0
    ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0
    ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16
    ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08
    ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always
    ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase
    ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active
    ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active
    ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active
    ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active
    ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active
    ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active
    ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active
    ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
    ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19,100
    ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19,0
    ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19,maximize
    ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19,maximize
    ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19,maximize
    ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19,0
    ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19,0
    ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19,18
    ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19,18
    ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19,Always
    ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19,Blinken rechts Hellphase
    ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19,not active
    ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19,not active
    ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19,not active
    ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19,not active
    ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19,not active
    ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19,not active
    ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19,not active
    ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
    ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100
    ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0
    ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize
    ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize
    ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize
    ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0
    ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0
    ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15
    ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E
    ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always
    ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase
    ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active
    ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active
    ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active
    ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active
    ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active
    ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active
    ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active
    ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
    ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100
    ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0
    ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize
    ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize
    ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize
    ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0
    ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0
    ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,00
    ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,00
    ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always
    ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light
    ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active
    ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active
    ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active
    ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active
    ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active
    ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active
    ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active
    ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,LED Bremsleuchten
    ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100
    ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0
    ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize
    ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize
    ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize
    ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0
    ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0
    ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,00
    ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,00
    ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always
    ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light
    ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active
    ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active
    ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active
    ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active
    ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active
    ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active
    ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active
    ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,LED Bremsleuchten
    ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100
    ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0
    ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize
    ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize
    ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize
    ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0
    ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0
    ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C
    ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,00
    ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always
    ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light
    ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active
    ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active
    ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active
    ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active
    ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active
    ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active
    ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active
    ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte
    ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,100
    ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,100
    ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize
    ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize
    ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize
    ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0
    ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0
    ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,00
    ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,00
    ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always
    ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light
    ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left
    ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,ComingHome LeavingHome
    ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active
    ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active
    ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active
    ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active
    ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active
    ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
    ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,100
    ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,100
    ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize
    ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize
    ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize
    ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0
    ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0
    ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,00
    ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,00
    ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always
    ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light
    ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right
    ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,ComingHome LeavingHome
    ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active
    ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active
    ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active
    ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active
    ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active
    ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
    ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100
    ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0
    ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize
    ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize
    ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize
    ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0
    ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0
    ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,30
    ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,28
    ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always
    ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light
    ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,ComingHome LeavingHome
    ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active
    ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active
    ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active
    ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active
    ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active
    ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active
    ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
    ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100
    ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0
    ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize
    ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize
    ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize
    ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0
    ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0
    ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E
    ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C
    ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always
    ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergesteckt
    ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active
    ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active
    ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active
    ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active
    ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active
    ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active
    ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active
    ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
    ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100
    ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0
    ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize
    ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize
    ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
    ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0
    ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0
    ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08
    ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00
    ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always
    ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer
    ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active
    ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active
    ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active
    ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active
    ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active
    ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active
    ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active
    ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
    ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100
    ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0
    ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
    ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
    ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
    ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0
    ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0
    ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32
    ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B
    ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
    ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
    ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active
    ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active
    ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active
    ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active
    ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active
    ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active
    ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active
    ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe12W
    ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100
    ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0
    ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
    ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
    ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
    ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0
    ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0
    ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
    ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
    ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
    ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
    ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active
    ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active
    ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active
    ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active
    ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active
    ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active
    ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active
    ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine Scheinwerfer
    ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100
    ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,28
    ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize
    ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize
    ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize
    ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,28
    ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0
    ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,4A
    ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,48
    ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always
    ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Daytime running lights
    ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,not active
    ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Parking light
    ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parking light left
    ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Nebellicht links
    ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active
    ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active
    ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active
    ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
    ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100
    ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0
    ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize
    ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize
    ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize
    ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0
    ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0
    ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07
    ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00
    ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always
    ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light
    ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active
    ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active
    ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active
    ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active
    ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active
    ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active
    ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active
    ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
    ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,100
    ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0
    ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize
    ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize
    ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize
    ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0
    ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0
    ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00
    ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00
    ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always
    ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active
    ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active
    ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active
    ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active
    ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active
    ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active
    ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active
    ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active
    ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active
    ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,100
    ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0
    ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize
    ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize
    ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize
    ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0
    ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0
    ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00
    ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00
    ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always
    ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active
    ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active
    ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active
    ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active
    ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active
    ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active
    ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active
    ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active
    ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active
    ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,100
    ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0
    ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize
    ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize
    ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize
    ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0
    ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0
    ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00
    ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00
    ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always
    ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active
    ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active
    ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active
    ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active
    ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active
    ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active
    ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active
    ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active
    ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active
    ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,108
    ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,3
    ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize
    ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize
    ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize
    ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0
    ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0
    ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,01
    ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,0C
    ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,only_if_closed
    ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active
    ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active
    ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100
    ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,28
    ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize
    ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize
    ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize
    ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,28
    ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0
    ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,4C
    ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,4C
    ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always
    ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Daytime running lights
    ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not active
    ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Parking light
    ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,Parking light right
    ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Nebellicht rechts
    ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active
    ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active
    ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active
    ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
    ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100
    ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,100
    ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize
    ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize
    ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize
    ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0
    ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0
    ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,49
    ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,48
    ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always
    ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights
    ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,Parking light
    ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Parking light left
    ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active
    ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active
    ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active
    ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active
    ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active
    ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
    ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100
    ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,100
    ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize
    ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize
    ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize
    ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0
    ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0
    ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,4B
    ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,4C
    ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always
    ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights
    ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,Parking light
    ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Parking light right
    ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active
    ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active
    ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active
    ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active
    ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active
    ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
    ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100
    ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,100
    ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize
    ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize
    ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize
    ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0
    ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0
    ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A
    ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36
    ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always
    ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links
    ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,not active
    ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,Left high beam
    ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,Headlamp flasher
    ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active
    ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active
    ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active
    ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active
    ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Xenon Abblendlicht
    ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100
    ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,100
    ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize
    ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize
    ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize
    ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0
    ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0
    ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B
    ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40
    ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always
    ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts
    ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,not active
    ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,Right high beam
    ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,Headlamp flasher
    ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active
    ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active
    ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active
    ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active
    ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Xenon Abblendlicht
    ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100
    ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0
    ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize
    ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize
    ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize
    ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0
    ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0
    ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C
    ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37
    ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always
    ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam
    ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher
    ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active
    ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active
    ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active
    ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active
    ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active
    ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active
    ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,Shutter
    ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100
    ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0
    ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize
    ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize
    ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize
    ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0
    ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0
    ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D
    ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41
    ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always
    ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam
    ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher
    ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active
    ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active
    ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active
    ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active
    ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active
    ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active
    ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,Shutter
    ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100
    ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0
    ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize
    ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize
    ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize
    ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0
    ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0
    ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00
    ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00
    ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always
    ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED
    ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active
    ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active
    ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active
    ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active
    ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active
    ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active
    ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active
    ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
    ENG126648-MAS02526-LIN-Mirrormode-Activation,not active
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,not active
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,not active
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,not active
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
    ENG122927-RLS_close_glazing,2.0 s
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,9 s
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 s
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
    ENG122929-RLS_LIN_Communication,4 s
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
    ENG122930-RLS_tunel_gateway_recognize,5 s
    ENG122935-RLS_Washer_Front,15 s
    ENG122926-RLS_wiper_position_parking,15 s
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
    ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Elapsed Time: 01:37
    	SW:6C0-937-089-C   HW:6C0-937-089 ---  Cent. Elect.
    	Component:BCM PQ26 Hi4R H08 0086, Coding:08001A5042532AFB0BA44000B12707481001690257010000000000000000
    	EV_BCMA0,005005,EV_BCMA0_005_VW26.rod
    	Monday,19,June,2017,21:20:49:46934
    	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
    	VCID: 303990A85748791D65-8064
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
    IDE00001-ENG130235-Production mode-Entry_control,not active
    IDE00001-ENG112304-Production mode-Heckwischer,not active
    IDE00001-ENG98647-Production mode-Interior lighting,not active
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
    IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active
    IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active
    IDE00002-Transport mode,active
    IDE00820-Activating and deactivating all development messages,not active
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,3
    IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active
    IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,activated
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1100 ms
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
    IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
    IDE02152-Characteristics in production mode,2000 ms
    IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
    IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active
    IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active
    IDE02332-Deactivate production mode,0
    IDE02488-DWA Interior monitoring,100 %
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
    IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
    IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.00 °
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
    IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active
    IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined
    IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active
    IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5
    IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS
    IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled
    IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active
    IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active
    IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.200 %
    IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,0.0 %
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h
    IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
    IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
    IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,active
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Fog light
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,72.0
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
    IDE04926-ENG126569-Comfort illumination-lho_aktiviert,active
    IDE04926-ENG126570-Comfort illumination-lho_zeit,10 s
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
    IDE04927-IDE01446-Window heater-Running time of heated front window,0 s
    IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,-50.0 °C
    IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C
    IDE04927-ENG126613-Window heater-Aussenspiegelheizung,420.0 s
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,400 s
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,Default
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,delay_driver_door_contact_thatcham
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
    IDE05142-ENG116706-Access control-Autounlock NAR,not active
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,active
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,not active
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
    IDE05142-ENG115755-Access control-Notschließfunktion,active
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
    IDE05142-ENG115758-Access control-Valet Parking,not active
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
    IDE05143-MAS02985-Writing parameter-Value,130
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
    IDE05144-Read parameter address,FE 00 00
    IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34
    IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E
    IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00
    IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00
    IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,38
    IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,42
    IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00
    IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00
    IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,39
    IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,43
    IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08
    IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18
    IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,48
    IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,00
    IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,00
    IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,00
    IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,00
    IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,00
    IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,28
    IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C
    IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00
    IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B
    IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00
    IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,4C
    IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00
    IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00
    IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00
    IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00
    IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,0C
    IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,48
    IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,4C
    IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36
    IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40
    IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37
    IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41
    IDE05145-ENG115018-Light configuration-Dimming_AB_0,100
    IDE05145-ENG115037-Light configuration-Dimming_AB_1,100
    IDE05145-ENG114999-Light configuration-Dimming_AB_10,100
    IDE05145-ENG115193-Light configuration-Dimming_AB_11,100
    IDE05145-ENG115212-Light configuration-Dimming_AB_12,100
    IDE05145-ENG114958-Light configuration-Dimming_AB_13,100
    IDE05145-ENG115233-Light configuration-Dimming_AB_14,100
    IDE05145-ENG115252-Light configuration-Dimming_AB_15,100
    IDE05145-ENG115271-Light configuration-Dimming_AB_16,100
    IDE05145-ENG115290-Light configuration-Dimming_AB_17,100
    IDE05145-ENG115309-Light configuration-Dimming_AB_18,100
    IDE05145-ENG115328-Light configuration-Dimming_AB_19,100
    IDE05145-ENG115056-Light configuration-Dimming_AB_2,100
    IDE05145-ENG115347-Light configuration-Dimming_AB_20,100
    IDE05145-ENG115366-Light configuration-Dimming_AB_21,100
    IDE05145-ENG115385-Light configuration-Dimming_AB_22,100
    IDE05145-ENG115404-Light configuration-Dimming_AB_23,100
    IDE05145-ENG115423-Light configuration-Dimming_AB_24,100
    IDE05145-ENG115442-Light configuration-Dimming_AB_25,100
    IDE05145-ENG115461-Light configuration-Dimming_AB_26,100
    IDE05145-ENG115480-Light configuration-Dimming_AB_27,100
    IDE05145-ENG115499-Light configuration-Dimming_AB_28,100
    IDE05145-ENG115518-Light configuration-Dimming_AB_29,100
    IDE05145-ENG115075-Light configuration-Dimming_AB_3,100
    IDE05145-ENG115537-Light configuration-Dimming_AB_30,100
    IDE05145-ENG115556-Light configuration-Dimming_AB_31,100
    IDE05145-ENG115575-Light configuration-Dimming_AB_32,100
    IDE05145-ENG115594-Light configuration-Dimming_AB_33,100
    IDE05145-ENG115613-Light configuration-Dimming_AB_34,108
    IDE05145-ENG115094-Light configuration-Dimming_AB_4,100
    IDE05145-ENG114977-Light configuration-Dimming_AB_5,100
    IDE05145-ENG115115-Light configuration-Dimming_AB_6,100
    IDE05145-ENG115134-Light configuration-Dimming_AB_7,100
    IDE05145-ENG115153-Light configuration-Dimming_AB_8,100
    IDE05145-ENG115172-Light configuration-Dimming_AB_9,100
    IDE05145-ENG115022-Light configuration-Dimming_CD_0,0
    IDE05145-ENG115041-Light configuration-Dimming_CD_1,0
    IDE05145-ENG115003-Light configuration-Dimming_CD_10,0
    IDE05145-ENG115197-Light configuration-Dimming_CD_11,0
    IDE05145-ENG115216-Light configuration-Dimming_CD_12,0
    IDE05145-ENG114962-Light configuration-Dimming_CD_13,0
    IDE05145-ENG115237-Light configuration-Dimming_CD_14,0
    IDE05145-ENG115256-Light configuration-Dimming_CD_15,0
    IDE05145-ENG115275-Light configuration-Dimming_CD_16,0
    IDE05145-ENG115294-Light configuration-Dimming_CD_17,0
    IDE05145-ENG115313-Light configuration-Dimming_CD_18,0
    IDE05145-ENG115332-Light configuration-Dimming_CD_19,0
    IDE05145-ENG115060-Light configuration-Dimming_CD_2,28
    IDE05145-ENG115351-Light configuration-Dimming_CD_20,0
    IDE05145-ENG115370-Light configuration-Dimming_CD_21,0
    IDE05145-ENG115389-Light configuration-Dimming_CD_22,0
    IDE05145-ENG115408-Light configuration-Dimming_CD_23,100
    IDE05145-ENG115427-Light configuration-Dimming_CD_24,100
    IDE05145-ENG115446-Light configuration-Dimming_CD_25,0
    IDE05145-ENG115465-Light configuration-Dimming_CD_26,0
    IDE05145-ENG115484-Light configuration-Dimming_CD_27,0
    IDE05145-ENG115503-Light configuration-Dimming_CD_28,0
    IDE05145-ENG115522-Light configuration-Dimming_CD_29,0
    IDE05145-ENG115079-Light configuration-Dimming_CD_3,28
    IDE05145-ENG115541-Light configuration-Dimming_CD_30,0
    IDE05145-ENG115560-Light configuration-Dimming_CD_31,0
    IDE05145-ENG115579-Light configuration-Dimming_CD_32,0
    IDE05145-ENG115598-Light configuration-Dimming_CD_33,0
    IDE05145-ENG115617-Light configuration-Dimming_CD_34,3
    IDE05145-ENG115098-Light configuration-Dimming_CD_4,100
    IDE05145-ENG114981-Light configuration-Dimming_CD_5,100
    IDE05145-ENG115119-Light configuration-Dimming_CD_6,100
    IDE05145-ENG115138-Light configuration-Dimming_CD_7,100
    IDE05145-ENG115157-Light configuration-Dimming_CD_8,0
    IDE05145-ENG115176-Light configuration-Dimming_CD_9,0
    IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize
    IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize
    IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize
    IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize
    IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize
    IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize
    IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize
    IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize
    IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize
    IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize
    IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize
    IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize
    IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize
    IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize
    IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize
    IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize
    IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize
    IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize
    IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize
    IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize
    IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize
    IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize
    IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize
    IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize
    IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize
    IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize
    IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize
    IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize
    IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize
    IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize
    IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize
    IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize
    IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize
    IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize
    IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize
    IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize
    IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize
    IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize
    IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize
    IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize
    IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize
    IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize
    IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize
    IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize
    IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize
    IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize
    IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize
    IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,minimize
    IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize
    IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize
    IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize
    IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize
    IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize
    IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize
    IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize
    IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize
    IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize
    IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize
    IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,minimize
    IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize
    IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize
    IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize
    IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize
    IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize
    IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize
    IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize
    IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize
    IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize
    IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize
    IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize
    IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize
    IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize
    IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize
    IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize
    IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize
    IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize
    IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize
    IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize
    IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize
    IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize
    IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize
    IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize
    IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize
    IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize
    IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize
    IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize
    IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize
    IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize
    IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize
    IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize
    IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize
    IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize
    IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize
    IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize
    IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize
    IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize
    IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize
    IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize
    IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize
    IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize
    IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize
    IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize
    IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize
    IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize
    IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize
    IDE05145-ENG115026-Light configuration-Dimming_EF_0,0
    IDE05145-ENG115045-Light configuration-Dimming_EF_1,0
    IDE05145-ENG115007-Light configuration-Dimming_EF_10,0
    IDE05145-ENG115201-Light configuration-Dimming_EF_11,0
    IDE05145-ENG115220-Light configuration-Dimming_EF_12,0
    IDE05145-ENG114966-Light configuration-Dimming_EF_13,0
    IDE05145-ENG115241-Light configuration-Dimming_EF_14,0
    IDE05145-ENG115260-Light configuration-Dimming_EF_15,0
    IDE05145-ENG115279-Light configuration-Dimming_EF_16,0
    IDE05145-ENG115298-Light configuration-Dimming_EF_17,0
    IDE05145-ENG115317-Light configuration-Dimming_EF_18,0
    IDE05145-ENG115336-Light configuration-Dimming_EF_19,0
    IDE05145-ENG115064-Light configuration-Dimming_EF_2,28
    IDE05145-ENG115355-Light configuration-Dimming_EF_20,0
    IDE05145-ENG115374-Light configuration-Dimming_EF_21,0
    IDE05145-ENG115393-Light configuration-Dimming_EF_22,0
    IDE05145-ENG115412-Light configuration-Dimming_EF_23,0
    IDE05145-ENG115431-Light configuration-Dimming_EF_24,0
    IDE05145-ENG115450-Light configuration-Dimming_EF_25,0
    IDE05145-ENG115469-Light configuration-Dimming_EF_26,0
    IDE05145-ENG115488-Light configuration-Dimming_EF_27,0
    IDE05145-ENG115507-Light configuration-Dimming_EF_28,0
    IDE05145-ENG115526-Light configuration-Dimming_EF_29,0
    IDE05145-ENG115083-Light configuration-Dimming_EF_3,28
    IDE05145-ENG115545-Light configuration-Dimming_EF_30,0
    IDE05145-ENG115564-Light configuration-Dimming_EF_31,0
    IDE05145-ENG115583-Light configuration-Dimming_EF_32,0
    IDE05145-ENG115602-Light configuration-Dimming_EF_33,0
    IDE05145-ENG115621-Light configuration-Dimming_EF_34,0
    IDE05145-ENG115102-Light configuration-Dimming_EF_4,0
    IDE05145-ENG114985-Light configuration-Dimming_EF_5,0
    IDE05145-ENG115123-Light configuration-Dimming_EF_6,0
    IDE05145-ENG115142-Light configuration-Dimming_EF_7,0
    IDE05145-ENG115161-Light configuration-Dimming_EF_8,0
    IDE05145-ENG115180-Light configuration-Dimming_EF_9,0
    IDE05145-ENG115030-Light configuration-Dimming_GH_0,0
    IDE05145-ENG115049-Light configuration-Dimming_GH_1,0
    IDE05145-ENG115011-Light configuration-Dimming_GH_10,0
    IDE05145-ENG115205-Light configuration-Dimming_GH_11,0
    IDE05145-ENG115224-Light configuration-Dimming_GH_12,0
    IDE05145-ENG114970-Light configuration-Dimming_GH_13,0
    IDE05145-ENG115245-Light configuration-Dimming_GH_14,0
    IDE05145-ENG115264-Light configuration-Dimming_GH_15,0
    IDE05145-ENG115283-Light configuration-Dimming_GH_16,0
    IDE05145-ENG115302-Light configuration-Dimming_GH_17,0
    IDE05145-ENG115321-Light configuration-Dimming_GH_18,0
    IDE05145-ENG115340-Light configuration-Dimming_GH_19,0
    IDE05145-ENG115068-Light configuration-Dimming_GH_2,0
    IDE05145-ENG115359-Light configuration-Dimming_GH_20,0
    IDE05145-ENG115378-Light configuration-Dimming_GH_21,0
    IDE05145-ENG115397-Light configuration-Dimming_GH_22,0
    IDE05145-ENG115416-Light configuration-Dimming_GH_23,0
    IDE05145-ENG115435-Light configuration-Dimming_GH_24,0
    IDE05145-ENG115454-Light configuration-Dimming_GH_25,0
    IDE05145-ENG115473-Light configuration-Dimming_GH_26,0
    IDE05145-ENG115492-Light configuration-Dimming_GH_27,0
    IDE05145-ENG115511-Light configuration-Dimming_GH_28,0
    IDE05145-ENG115530-Light configuration-Dimming_GH_29,0
    IDE05145-ENG115087-Light configuration-Dimming_GH_3,0
    IDE05145-ENG115549-Light configuration-Dimming_GH_30,0
    IDE05145-ENG115568-Light configuration-Dimming_GH_31,0
    IDE05145-ENG115587-Light configuration-Dimming_GH_32,0
    IDE05145-ENG115606-Light configuration-Dimming_GH_33,0
    IDE05145-ENG115625-Light configuration-Dimming_GH_34,0
    IDE05145-ENG115106-Light configuration-Dimming_GH_4,0
    IDE05145-ENG114989-Light configuration-Dimming_GH_5,0
    IDE05145-ENG115127-Light configuration-Dimming_GH_6,0
    IDE05145-ENG115146-Light configuration-Dimming_GH_7,0
    IDE05145-ENG115165-Light configuration-Dimming_GH_8,0
    IDE05145-ENG115184-Light configuration-Dimming_GH_9,0
    IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14
    IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15
    IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,03
    IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00
    IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,22
    IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,23
    IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00
    IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00
    IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,17
    IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,19
    IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16
    IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18
    IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,4A
    IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,00
    IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,00
    IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C
    IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,00
    IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,00
    IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,30
    IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E
    IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08
    IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32
    IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01
    IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,4C
    IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07
    IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00
    IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00
    IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00
    IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,01
    IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,49
    IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,4B
    IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A
    IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B
    IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C
    IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D
    IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always
    IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always
    IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always
    IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always
    IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always
    IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always
    IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always
    IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always
    IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always
    IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always
    IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always
    IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always
    IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always
    IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always
    IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always
    IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always
    IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always
    IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always
    IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always
    IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always
    IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always
    IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always
    IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always
    IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always
    IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always
    IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always
    IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always
    IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always
    IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,only_if_closed
    IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always
    IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always
    IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always
    IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always
    IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always
    IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always
    IDE05145-ENG115016-Light configuration-Light_Function_A_0,2
    IDE05145-ENG115035-Light configuration-Light_Function_A_1,4
    IDE05145-ENG114997-Light configuration-Light_Function_A_10,45
    IDE05145-ENG115191-Light configuration-Light_Function_A_11,62
    IDE05145-ENG115210-Light configuration-Light_Function_A_12,18
    IDE05145-ENG114956-Light configuration-Light_Function_A_13,19
    IDE05145-ENG115231-Light configuration-Light_Function_A_14,63
    IDE05145-ENG115250-Light configuration-Light_Function_A_15,64
    IDE05145-ENG115269-Light configuration-Light_Function_A_16,2
    IDE05145-ENG115288-Light configuration-Light_Function_A_17,4
    IDE05145-ENG115307-Light configuration-Light_Function_A_18,2
    IDE05145-ENG115326-Light configuration-Light_Function_A_19,4
    IDE05145-ENG115054-Light configuration-Light_Function_A_2,20
    IDE05145-ENG115345-Light configuration-Light_Function_A_20,24
    IDE05145-ENG115364-Light configuration-Light_Function_A_21,24
    IDE05145-ENG115383-Light configuration-Light_Function_A_22,24
    IDE05145-ENG115402-Light configuration-Light_Function_A_23,8
    IDE05145-ENG115421-Light configuration-Light_Function_A_24,8
    IDE05145-ENG115440-Light configuration-Light_Function_A_25,8
    IDE05145-ENG115459-Light configuration-Light_Function_A_26,26
    IDE05145-ENG115478-Light configuration-Light_Function_A_27,38
    IDE05145-ENG115497-Light configuration-Light_Function_A_28,25
    IDE05145-ENG115516-Light configuration-Light_Function_A_29,37
    IDE05145-ENG115073-Light configuration-Light_Function_A_3,20
    IDE05145-ENG115535-Light configuration-Light_Function_A_30,41
    IDE05145-ENG115554-Light configuration-Light_Function_A_31,0
    IDE05145-ENG115573-Light configuration-Light_Function_A_32,0
    IDE05145-ENG115592-Light configuration-Light_Function_A_33,0
    IDE05145-ENG115611-Light configuration-Light_Function_A_34,229
    IDE05145-ENG115092-Light configuration-Light_Function_A_4,20
    IDE05145-ENG114975-Light configuration-Light_Function_A_5,20
    IDE05145-ENG115113-Light configuration-Light_Function_A_6,11
    IDE05145-ENG115132-Light configuration-Light_Function_A_7,12
    IDE05145-ENG115151-Light configuration-Light_Function_A_8,13
    IDE05145-ENG115170-Light configuration-Light_Function_A_9,14
    IDE05145-ENG115017-Light configuration-Light_Function_B_0,0
    IDE05145-ENG115036-Light configuration-Light_Function_B_1,0
    IDE05145-ENG114998-Light configuration-Light_Function_B_10,0
    IDE05145-ENG115192-Light configuration-Light_Function_B_11,0
    IDE05145-ENG115211-Light configuration-Light_Function_B_12,22
    IDE05145-ENG114957-Light configuration-Light_Function_B_13,23
    IDE05145-ENG115232-Light configuration-Light_Function_B_14,0
    IDE05145-ENG115251-Light configuration-Light_Function_B_15,0
    IDE05145-ENG115270-Light configuration-Light_Function_B_16,0
    IDE05145-ENG115289-Light configuration-Light_Function_B_17,0
    IDE05145-ENG115308-Light configuration-Light_Function_B_18,0
    IDE05145-ENG115327-Light configuration-Light_Function_B_19,0
    IDE05145-ENG115055-Light configuration-Light_Function_B_2,0
    IDE05145-ENG115346-Light configuration-Light_Function_B_20,0
    IDE05145-ENG115365-Light configuration-Light_Function_B_21,0
    IDE05145-ENG115384-Light configuration-Light_Function_B_22,0
    IDE05145-ENG115403-Light configuration-Light_Function_B_23,9
    IDE05145-ENG115422-Light configuration-Light_Function_B_24,10
    IDE05145-ENG115441-Light configuration-Light_Function_B_25,30
    IDE05145-ENG115460-Light configuration-Light_Function_B_26,0
    IDE05145-ENG115479-Light configuration-Light_Function_B_27,0
    IDE05145-ENG115498-Light configuration-Light_Function_B_28,0
    IDE05145-ENG115517-Light configuration-Light_Function_B_29,0
    IDE05145-ENG115074-Light configuration-Light_Function_B_3,0
    IDE05145-ENG115536-Light configuration-Light_Function_B_30,0
    IDE05145-ENG115555-Light configuration-Light_Function_B_31,0
    IDE05145-ENG115574-Light configuration-Light_Function_B_32,0
    IDE05145-ENG115593-Light configuration-Light_Function_B_33,0
    IDE05145-ENG115612-Light configuration-Light_Function_B_34,246
    IDE05145-ENG115093-Light configuration-Light_Function_B_4,8
    IDE05145-ENG114976-Light configuration-Light_Function_B_5,8
    IDE05145-ENG115114-Light configuration-Light_Function_B_6,0
    IDE05145-ENG115133-Light configuration-Light_Function_B_7,0
    IDE05145-ENG115152-Light configuration-Light_Function_B_8,15
    IDE05145-ENG115171-Light configuration-Light_Function_B_9,15
    IDE05145-ENG115020-Light configuration-Light_Function_C_0,0
    IDE05145-ENG115039-Light configuration-Light_Function_C_1,0
    IDE05145-ENG115001-Light configuration-Light_Function_C_10,0
    IDE05145-ENG115195-Light configuration-Light_Function_C_11,0
    IDE05145-ENG115214-Light configuration-Light_Function_C_12,0
    IDE05145-ENG114960-Light configuration-Light_Function_C_13,0
    IDE05145-ENG115235-Light configuration-Light_Function_C_14,0
    IDE05145-ENG115254-Light configuration-Light_Function_C_15,0
    IDE05145-ENG115273-Light configuration-Light_Function_C_16,0
    IDE05145-ENG115292-Light configuration-Light_Function_C_17,0
    IDE05145-ENG115311-Light configuration-Light_Function_C_18,0
    IDE05145-ENG115330-Light configuration-Light_Function_C_19,0
    IDE05145-ENG115058-Light configuration-Light_Function_C_2,8
    IDE05145-ENG115349-Light configuration-Light_Function_C_20,0
    IDE05145-ENG115368-Light configuration-Light_Function_C_21,0
    IDE05145-ENG115387-Light configuration-Light_Function_C_22,0
    IDE05145-ENG115406-Light configuration-Light_Function_C_23,30
    IDE05145-ENG115425-Light configuration-Light_Function_C_24,30
    IDE05145-ENG115444-Light configuration-Light_Function_C_25,0
    IDE05145-ENG115463-Light configuration-Light_Function_C_26,0
    IDE05145-ENG115482-Light configuration-Light_Function_C_27,0
    IDE05145-ENG115501-Light configuration-Light_Function_C_28,0
    IDE05145-ENG115519-Light configuration-Light_Function_C_29,0
    IDE05145-ENG115077-Light configuration-Light_Function_C_3,8
    IDE05145-ENG115539-Light configuration-Light_Function_C_30,0
    IDE05145-ENG115558-Light configuration-Light_Function_C_31,0
    IDE05145-ENG115577-Light configuration-Light_Function_C_32,0
    IDE05145-ENG115596-Light configuration-Light_Function_C_33,0
    IDE05145-ENG115615-Light configuration-Light_Function_C_34,173
    IDE05145-ENG115096-Light configuration-Light_Function_C_4,9
    IDE05145-ENG114979-Light configuration-Light_Function_C_5,10
    IDE05145-ENG115117-Light configuration-Light_Function_C_6,13
    IDE05145-ENG115136-Light configuration-Light_Function_C_7,14
    IDE05145-ENG115155-Light configuration-Light_Function_C_8,0
    IDE05145-ENG115174-Light configuration-Light_Function_C_9,0
    IDE05145-ENG115021-Light configuration-Light_Function_D_0,0
    IDE05145-ENG115040-Light configuration-Light_Function_D_1,0
    IDE05145-ENG115002-Light configuration-Light_Function_D_10,0
    IDE05145-ENG115196-Light configuration-Light_Function_D_11,0
    IDE05145-ENG115215-Light configuration-Light_Function_D_12,0
    IDE05145-ENG114961-Light configuration-Light_Function_D_13,0
    IDE05145-ENG115236-Light configuration-Light_Function_D_14,0
    IDE05145-ENG115255-Light configuration-Light_Function_D_15,0
    IDE05145-ENG115274-Light configuration-Light_Function_D_16,0
    IDE05145-ENG115293-Light configuration-Light_Function_D_17,0
    IDE05145-ENG115312-Light configuration-Light_Function_D_18,0
    IDE05145-ENG115331-Light configuration-Light_Function_D_19,0
    IDE05145-ENG115059-Light configuration-Light_Function_D_2,9
    IDE05145-ENG115350-Light configuration-Light_Function_D_20,0
    IDE05145-ENG115369-Light configuration-Light_Function_D_21,0
    IDE05145-ENG115388-Light configuration-Light_Function_D_22,0
    IDE05145-ENG115407-Light configuration-Light_Function_D_23,0
    IDE05145-ENG115426-Light configuration-Light_Function_D_24,0
    IDE05145-ENG115445-Light configuration-Light_Function_D_25,0
    IDE05145-ENG115464-Light configuration-Light_Function_D_26,0
    IDE05145-ENG115483-Light configuration-Light_Function_D_27,0
    IDE05145-ENG115502-Light configuration-Light_Function_D_28,0
    IDE05145-ENG115521-Light configuration-Light_Function_D_29,0
    IDE05145-ENG115078-Light configuration-Light_Function_D_3,10
    IDE05145-ENG115540-Light configuration-Light_Function_D_30,0
    IDE05145-ENG115559-Light configuration-Light_Function_D_31,0
    IDE05145-ENG115578-Light configuration-Light_Function_D_32,0
    IDE05145-ENG115597-Light configuration-Light_Function_D_33,0
    IDE05145-ENG115616-Light configuration-Light_Function_D_34,78
    IDE05145-ENG115097-Light configuration-Light_Function_D_4,0
    IDE05145-ENG114980-Light configuration-Light_Function_D_5,0
    IDE05145-ENG115118-Light configuration-Light_Function_D_6,15
    IDE05145-ENG115137-Light configuration-Light_Function_D_7,15
    IDE05145-ENG115156-Light configuration-Light_Function_D_8,0
    IDE05145-ENG115175-Light configuration-Light_Function_D_9,0
    IDE05145-ENG115024-Light configuration-Light_Function_E_0,0
    IDE05145-ENG115043-Light configuration-Light_Function_E_1,0
    IDE05145-ENG115005-Light configuration-Light_Function_E_10,0
    IDE05145-ENG115199-Light configuration-Light_Function_E_11,0
    IDE05145-ENG115218-Light configuration-Light_Function_E_12,0
    IDE05145-ENG114964-Light configuration-Light_Function_E_13,0
    IDE05145-ENG115239-Light configuration-Light_Function_E_14,0
    IDE05145-ENG115258-Light configuration-Light_Function_E_15,0
    IDE05145-ENG115277-Light configuration-Light_Function_E_16,0
    IDE05145-ENG115296-Light configuration-Light_Function_E_17,0
    IDE05145-ENG115315-Light configuration-Light_Function_E_18,0
    IDE05145-ENG115334-Light configuration-Light_Function_E_19,0
    IDE05145-ENG115062-Light configuration-Light_Function_E_2,18
    IDE05145-ENG115353-Light configuration-Light_Function_E_20,0
    IDE05145-ENG115372-Light configuration-Light_Function_E_21,0
    IDE05145-ENG115391-Light configuration-Light_Function_E_22,0
    IDE05145-ENG115410-Light configuration-Light_Function_E_23,0
    IDE05145-ENG115429-Light configuration-Light_Function_E_24,0
    IDE05145-ENG115448-Light configuration-Light_Function_E_25,0
    IDE05145-ENG115467-Light configuration-Light_Function_E_26,0
    IDE05145-ENG115486-Light configuration-Light_Function_E_27,0
    IDE05145-ENG115505-Light configuration-Light_Function_E_28,0
    IDE05145-ENG115524-Light configuration-Light_Function_E_29,0
    IDE05145-ENG115081-Light configuration-Light_Function_E_3,19
    IDE05145-ENG115543-Light configuration-Light_Function_E_30,0
    IDE05145-ENG115562-Light configuration-Light_Function_E_31,0
    IDE05145-ENG115581-Light configuration-Light_Function_E_32,0
    IDE05145-ENG115600-Light configuration-Light_Function_E_33,0
    IDE05145-ENG115619-Light configuration-Light_Function_E_34,88
    IDE05145-ENG115100-Light configuration-Light_Function_E_4,0
    IDE05145-ENG114983-Light configuration-Light_Function_E_5,0
    IDE05145-ENG115121-Light configuration-Light_Function_E_6,0
    IDE05145-ENG115140-Light configuration-Light_Function_E_7,0
    IDE05145-ENG115159-Light configuration-Light_Function_E_8,0
    IDE05145-ENG115178-Light configuration-Light_Function_E_9,0
    IDE05145-ENG115025-Light configuration-Light_Function_F_0,0
    IDE05145-ENG115044-Light configuration-Light_Function_F_1,0
    IDE05145-ENG115006-Light configuration-Light_Function_F_10,0
    IDE05145-ENG115200-Light configuration-Light_Function_F_11,0
    IDE05145-ENG115219-Light configuration-Light_Function_F_12,0
    IDE05145-ENG114965-Light configuration-Light_Function_F_13,0
    IDE05145-ENG115240-Light configuration-Light_Function_F_14,0
    IDE05145-ENG115259-Light configuration-Light_Function_F_15,0
    IDE05145-ENG115278-Light configuration-Light_Function_F_16,0
    IDE05145-ENG115297-Light configuration-Light_Function_F_17,0
    IDE05145-ENG115316-Light configuration-Light_Function_F_18,0
    IDE05145-ENG115335-Light configuration-Light_Function_F_19,0
    IDE05145-ENG115063-Light configuration-Light_Function_F_2,0
    IDE05145-ENG115354-Light configuration-Light_Function_F_20,0
    IDE05145-ENG115373-Light configuration-Light_Function_F_21,0
    IDE05145-ENG115392-Light configuration-Light_Function_F_22,0
    IDE05145-ENG115411-Light configuration-Light_Function_F_23,0
    IDE05145-ENG115430-Light configuration-Light_Function_F_24,0
    IDE05145-ENG115449-Light configuration-Light_Function_F_25,0
    IDE05145-ENG115468-Light configuration-Light_Function_F_26,0
    IDE05145-ENG115487-Light configuration-Light_Function_F_27,0
    IDE05145-ENG115506-Light configuration-Light_Function_F_28,0
    IDE05145-ENG115525-Light configuration-Light_Function_F_29,0
    IDE05145-ENG115082-Light configuration-Light_Function_F_3,0
    IDE05145-ENG115544-Light configuration-Light_Function_F_30,0
    IDE05145-ENG115563-Light configuration-Light_Function_F_31,0
    IDE05145-ENG115582-Light configuration-Light_Function_F_32,0
    IDE05145-ENG115601-Light configuration-Light_Function_F_33,0
    IDE05145-ENG115620-Light configuration-Light_Function_F_34,0
    IDE05145-ENG115101-Light configuration-Light_Function_F_4,0
    IDE05145-ENG114984-Light configuration-Light_Function_F_5,0
    IDE05145-ENG115122-Light configuration-Light_Function_F_6,0
    IDE05145-ENG115141-Light configuration-Light_Function_F_7,0
    IDE05145-ENG115160-Light configuration-Light_Function_F_8,0
    IDE05145-ENG115179-Light configuration-Light_Function_F_9,0
    IDE05145-ENG115028-Light configuration-Light_Function_G_0,0
    IDE05145-ENG115047-Light configuration-Light_Function_G_1,0
    IDE05145-ENG115009-Light configuration-Light_Function_G_10,0
    IDE05145-ENG115203-Light configuration-Light_Function_G_11,0
    IDE05145-ENG115222-Light configuration-Light_Function_G_12,0
    IDE05145-ENG114968-Light configuration-Light_Function_G_13,0
    IDE05145-ENG115243-Light configuration-Light_Function_G_14,0
    IDE05145-ENG115262-Light configuration-Light_Function_G_15,0
    IDE05145-ENG115281-Light configuration-Light_Function_G_16,0
    IDE05145-ENG115300-Light configuration-Light_Function_G_17,0
    IDE05145-ENG115319-Light configuration-Light_Function_G_18,0
    IDE05145-ENG115338-Light configuration-Light_Function_G_19,0
    IDE05145-ENG115066-Light configuration-Light_Function_G_2,0
    IDE05145-ENG115357-Light configuration-Light_Function_G_20,0
    IDE05145-ENG115376-Light configuration-Light_Function_G_21,0
    IDE05145-ENG115395-Light configuration-Light_Function_G_22,0
    IDE05145-ENG115414-Light configuration-Light_Function_G_23,0
    IDE05145-ENG115433-Light configuration-Light_Function_G_24,0
    IDE05145-ENG115452-Light configuration-Light_Function_G_25,0
    IDE05145-ENG115471-Light configuration-Light_Function_G_26,0
    IDE05145-ENG115490-Light configuration-Light_Function_G_27,0
    IDE05145-ENG115509-Light configuration-Light_Function_G_28,0
    IDE05145-ENG115528-Light configuration-Light_Function_G_29,0
    IDE05145-ENG115085-Light configuration-Light_Function_G_3,0
    IDE05145-ENG115547-Light configuration-Light_Function_G_30,0
    IDE05145-ENG115566-Light configuration-Light_Function_G_31,0
    IDE05145-ENG115585-Light configuration-Light_Function_G_32,0
    IDE05145-ENG115604-Light configuration-Light_Function_G_33,0
    IDE05145-ENG115623-Light configuration-Light_Function_G_34,0
    IDE05145-ENG115104-Light configuration-Light_Function_G_4,0
    IDE05145-ENG114987-Light configuration-Light_Function_G_5,0
    IDE05145-ENG115125-Light configuration-Light_Function_G_6,0
    IDE05145-ENG115144-Light configuration-Light_Function_G_7,0
    IDE05145-ENG115163-Light configuration-Light_Function_G_8,0
    IDE05145-ENG115182-Light configuration-Light_Function_G_9,0
    IDE05145-ENG115029-Light configuration-Light_Function_H_0,0
    IDE05145-ENG115048-Light configuration-Light_Function_H_1,0
    IDE05145-ENG115010-Light configuration-Light_Function_H_10,0
    IDE05145-ENG115204-Light configuration-Light_Function_H_11,0
    IDE05145-ENG115223-Light configuration-Light_Function_H_12,0
    IDE05145-ENG114969-Light configuration-Light_Function_H_13,0
    IDE05145-ENG115244-Light configuration-Light_Function_H_14,0
    IDE05145-ENG115263-Light configuration-Light_Function_H_15,0
    IDE05145-ENG115282-Light configuration-Light_Function_H_16,0
    IDE05145-ENG115301-Light configuration-Light_Function_H_17,0
    IDE05145-ENG115320-Light configuration-Light_Function_H_18,0
    IDE05145-ENG115339-Light configuration-Light_Function_H_19,0
    IDE05145-ENG115067-Light configuration-Light_Function_H_2,0
    IDE05145-ENG115358-Light configuration-Light_Function_H_20,0
    IDE05145-ENG115377-Light configuration-Light_Function_H_21,0
    IDE05145-ENG115396-Light configuration-Light_Function_H_22,0
    IDE05145-ENG115415-Light configuration-Light_Function_H_23,0
    IDE05145-ENG115434-Light configuration-Light_Function_H_24,0
    IDE05145-ENG115453-Light configuration-Light_Function_H_25,0
    IDE05145-ENG115472-Light configuration-Light_Function_H_26,0
    IDE05145-ENG115491-Light configuration-Light_Function_H_27,0
    IDE05145-ENG115510-Light configuration-Light_Function_H_28,0
    IDE05145-ENG115529-Light configuration-Light_Function_H_29,0
    IDE05145-ENG115086-Light configuration-Light_Function_H_3,0
    IDE05145-ENG115548-Light configuration-Light_Function_H_30,0
    IDE05145-ENG115567-Light configuration-Light_Function_H_31,0
    IDE05145-ENG115586-Light configuration-Light_Function_H_32,0
    IDE05145-ENG115605-Light configuration-Light_Function_H_33,0
    IDE05145-ENG115624-Light configuration-Light_Function_H_34,99
    IDE05145-ENG115105-Light configuration-Light_Function_H_4,0
    IDE05145-ENG114988-Light configuration-Light_Function_H_5,0
    IDE05145-ENG115126-Light configuration-Light_Function_H_6,0
    IDE05145-ENG115145-Light configuration-Light_Function_H_7,0
    IDE05145-ENG115164-Light configuration-Light_Function_H_8,0
    IDE05145-ENG115183-Light configuration-Light_Function_H_9,0
    IDE05145-ENG115013-Light configuration-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115032-Light configuration-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG114995-Light configuration-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115207-Light configuration-Type_Of_Load_12,allgemeine Scheinwerfer
    IDE05145-ENG114954-Light configuration-Type_Of_Load_13,allgemeine Scheinwerfer
    IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115266-Light configuration-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
    IDE05145-ENG115285-Light configuration-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115304-Light configuration-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115323-Light configuration-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115051-Light configuration-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
    IDE05145-ENG115342-Light configuration-Type_Of_Load_20,LED Bremsleuchten
    IDE05145-ENG115361-Light configuration-Type_Of_Load_21,LED Bremsleuchten
    IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte
    IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115437-Light configuration-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
    IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
    IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe12W
    IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeine Scheinwerfer
    IDE05145-ENG115070-Light configuration-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
    IDE05145-ENG115532-Light configuration-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
    IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active
    IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active
    IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active
    IDE05145-ENG115089-Light configuration-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG114973-Light configuration-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Xenon Abblendlicht
    IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Xenon Abblendlicht
    IDE05145-ENG115148-Light configuration-Type_Of_Load_8,Shutter
    IDE05145-ENG115167-Light configuration-Type_Of_Load_9,Shutter
    IDE05822-DWA Vehicle inclination sensor,100 %
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 64 23 65 42 57 9B 25 44 3F 3A 69 35 95 2D 09 A3 02 07 06 56 00 0F 12 00 89 09 31 F3 6E 0F C3 42 87 1B 05 34 3F 3A 69 7A 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 67 23 65 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 91 30 61 27 2D
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
    IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
    IDE06425-Roller test bench mode: functional,not active
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
    IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min
    IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0
    IDE08542-IDE02021-Access control 2-Comfort closing,active
    IDE08542-IDE02022-Access control 2-Comfort opening,active
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
    IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
    IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,not active
    IDE08542-ENG115671-Access control 2-Regenschließen,not active
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
    IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,active
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
    IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
    IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5
    IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36
    IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active
    IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active
    IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active
    IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active
    IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active
    IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active
    IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active
    IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active
    IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active
    IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active
    IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active
    IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active
    IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active
    IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active
    IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active
    IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active
    IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active
    IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active
    IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active
    IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active
    IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active
    IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active
    IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active
    IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active
    IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active
    IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active
    IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active
    IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active
    IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active
    IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active
    IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active
    IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active
    IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active
    IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active
    IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active
    IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm
    IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5
    IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40
    IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active
    IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active
    IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active
    IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active
    IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active
    IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active
    IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active
    IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active
    IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active
    IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active
    IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active
    IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active
    IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active
    IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active
    IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active
    IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active
    IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active
    IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active
    IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active
    IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active
    IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active
    IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active
    IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active
    IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active
    IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active
    IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active
    IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active
    IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active
    IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active
    IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active
    IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active
    IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active
    IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active
    IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active
    IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active
    IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm
    IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Time
    IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung,Energy management
    IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung,Energy management
    IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten
    IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,0 min
    IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit,24 s
    IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,not active
    MAS01490-IDE07474-Energy management-Adapting for energy management,Energy management active
    MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement,not active
    MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed
    MAS08233-ENG126575-other-mute_mode_aktiv,not active
    MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed
    ENG05956-Adaptation_theft_protection_2,not active
    ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.0 %
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.0 %
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.0 %
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.0 %
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.0 %
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.0 %
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.0 %
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.0 %
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.0 %
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,104 lx
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,6
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,6
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,5.0 %
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,5.0 %
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,15.0 %
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,40.0 %
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,82.0 %
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,10.0
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,10.0
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,50.0
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,50.0
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,10.0
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,10.0
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.0
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0
    ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100
    ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0
    ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize
    ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize
    ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize
    ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0
    ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0
    ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14
    ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34
    ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always
    ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase
    ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active
    ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active
    ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active
    ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active
    ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active
    ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active
    ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active
    ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
    ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,100
    ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0
    ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize
    ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize
    ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize
    ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0
    ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0
    ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,03
    ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00
    ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always
    ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,Ambientelicht 1
    ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active
    ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active
    ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active
    ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active
    ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active
    ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active
    ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active
    ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
    ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100
    ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0
    ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize
    ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize
    ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize
    ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0
    ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0
    ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00
    ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00
    ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always
    ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster
    ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active
    ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active
    ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active
    ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active
    ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active
    ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active
    ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active
    ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
    ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100
    ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0
    ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize
    ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize
    ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize
    ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0
    ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0
    ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22
    ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38
    ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always
    ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links
    ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links
    ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active
    ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active
    ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active
    ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active
    ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active
    ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active
    ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer
    ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100
    ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0
    ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize
    ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize
    ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize
    ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0
    ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0
    ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23
    ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42
    ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always
    ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts
    ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts
    ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active
    ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active
    ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active
    ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active
    ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active
    ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active
    ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer
    ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100
    ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0
    ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize
    ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize
    ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize
    ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0
    ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0
    ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00
    ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00
    ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always
    ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED
    ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active
    ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active
    ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active
    ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active
    ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active
    ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active
    ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active
    ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
    ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100
    ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0
    ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize
    ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize
    ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize
    ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0
    ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0
    ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,17
    ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,39
    ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always
    ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase
    ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active
    ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active
    ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active
    ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active
    ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active
    ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active
    ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active
    ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
    ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100
    ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0
    ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize
    ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize
    ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize
    ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0
    ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0
    ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,19
    ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,43
    ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always
    ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase
    ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active
    ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active
    ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active
    ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active
    ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active
    ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active
    ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active
    ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
    ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100
    ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0
    ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize
    ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize
    ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize
    ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0
    ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0
    ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16
    ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08
    ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always
    ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase
    ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active
    ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active
    ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active
    ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active
    ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active
    ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active
    ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active
    ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
    ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19,100
    ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19,0
    ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19,maximize
    ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19,maximize
    ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19,maximize
    ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19,0
    ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19,0
    ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19,18
    ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19,18
    ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19,Always
    ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19,Blinken rechts Hellphase
    ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19,not active
    ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19,not active
    ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19,not active
    ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19,not active
    ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19,not active
    ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19,not active
    ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19,not active
    ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
    ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100
    ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0
    ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize
    ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize
    ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize
    ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0
    ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0
    ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15
    ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E
    ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always
    ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase
    ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active
    ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active
    ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active
    ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active
    ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active
    ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active
    ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active
    ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
    ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100
    ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0
    ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize
    ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize
    ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize
    ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0
    ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0
    ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,00
    ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,00
    ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always
    ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light
    ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active
    ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active
    ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active
    ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active
    ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active
    ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active
    ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active
    ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,LED Bremsleuchten
    ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100
    ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0
    ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize
    ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize
    ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize
    ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0
    ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0
    ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,00
    ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,00
    ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always
    ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light
    ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active
    ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active
    ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active
    ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active
    ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active
    ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active
    ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active
    ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,LED Bremsleuchten
    ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100
    ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0
    ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize
    ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize
    ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize
    ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0
    ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0
    ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C
    ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,00
    ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always
    ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light
    ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active
    ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active
    ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active
    ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active
    ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active
    ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active
    ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active
    ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte
    ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,100
    ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,100
    ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize
    ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize
    ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize
    ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0
    ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0
    ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,00
    ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,00
    ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always
    ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light
    ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left
    ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,ComingHome LeavingHome
    ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active
    ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active
    ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active
    ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active
    ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active
    ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
    ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,100
    ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,100
    ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize
    ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize
    ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize
    ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0
    ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0
    ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,00
    ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,00
    ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always
    ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light
    ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right
    ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,ComingHome LeavingHome
    ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active
    ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active
    ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active
    ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active
    ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active
    ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
    ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100
    ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0
    ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize
    ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize
    ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize
    ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0
    ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0
    ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,30
    ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,28
    ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always
    ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light
    ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,ComingHome LeavingHome
    ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active
    ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active
    ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active
    ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active
    ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active
    ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active
    ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
    ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100
    ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0
    ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize
    ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize
    ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize
    ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0
    ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0
    ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E
    ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C
    ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always
    ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergesteckt
    ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active
    ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active
    ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active
    ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active
    ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active
    ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active
    ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active
    ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
    ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100
    ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0
    ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize
    ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize
    ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
    ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0
    ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0
    ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08
    ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00
    ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always
    ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer
    ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active
    ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active
    ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active
    ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active
    ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active
    ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active
    ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active
    ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
    ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100
    ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0
    ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
    ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
    ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
    ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0
    ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0
    ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32
    ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B
    ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
    ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
    ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active
    ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active
    ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active
    ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active
    ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active
    ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active
    ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active
    ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe12W
    ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100
    ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0
    ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
    ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
    ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
    ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0
    ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0
    ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
    ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
    ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
    ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
    ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active
    ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active
    ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active
    ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active
    ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active
    ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active
    ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active
    ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine Scheinwerfer
    ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100
    ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,28
    ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize
    ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize
    ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize
    ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,28
    ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0
    ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,4A
    ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,48
    ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always
    ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Daytime running lights
    ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,not active
    ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Parking light
    ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parking light left
    ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Nebellicht links
    ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active
    ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active
    ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active
    ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
    ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100
    ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0
    ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize
    ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize
    ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize
    ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0
    ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0
    ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07
    ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00
    ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always
    ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light
    ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active
    ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active
    ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active
    ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active
    ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active
    ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active
    ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active
    ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
    ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,100
    ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0
    ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize
    ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize
    ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize
    ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0
    ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0
    ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00
    ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00
    ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always
    ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active
    ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active
    ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active
    ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active
    ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active
    ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active
    ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active
    ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active
    ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active
    ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,100
    ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0
    ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize
    ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize
    ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize
    ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0
    ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0
    ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00
    ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00
    ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always
    ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active
    ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active
    ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active
    ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active
    ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active
    ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active
    ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active
    ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active
    ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active
    ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,100
    ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0
    ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize
    ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize
    ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize
    ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0
    ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0
    ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00
    ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00
    ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always
    ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active
    ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active
    ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active
    ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active
    ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active
    ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active
    ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active
    ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active
    ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active
    ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,108
    ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,3
    ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize
    ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize
    ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize
    ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0
    ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0
    ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,01
    ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,0C
    ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,only_if_closed
    ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active
    ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active
    ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100
    ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,28
    ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize
    ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize
    ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize
    ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,28
    ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0
    ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,4C
    ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,4C
    ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always
    ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Daytime running lights
    ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not active
    ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Parking light
    ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,Parking light right
    ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Nebellicht rechts
    ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active
    ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active
    ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active
    ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
    ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100
    ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,100
    ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize
    ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize
    ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize
    ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0
    ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0
    ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,49
    ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,48
    ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always
    ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights
    ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,Parking light
    ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Parking light left
    ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active
    ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active
    ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active
    ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active
    ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active
    ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
    ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100
    ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,100
    ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize
    ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize
    ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize
    ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0
    ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0
    ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,4B
    ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,4C
    ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always
    ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights
    ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,Parking light
    ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Parking light right
    ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active
    ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active
    ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active
    ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active
    ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active
    ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
    ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100
    ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,100
    ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize
    ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize
    ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize
    ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0
    ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0
    ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A
    ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36
    ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always
    ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links
    ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,not active
    ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,Left high beam
    ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,Headlamp flasher
    ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active
    ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active
    ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active
    ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active
    ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Xenon Abblendlicht
    ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100
    ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,100
    ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize
    ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize
    ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize
    ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0
    ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0
    ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B
    ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40
    ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always
    ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts
    ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,not active
    ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,Right high beam
    ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,Headlamp flasher
    ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active
    ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active
    ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active
    ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active
    ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Xenon Abblendlicht
    ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100
    ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0
    ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize
    ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize
    ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize
    ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0
    ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0
    ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C
    ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37
    ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always
    ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam
    ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher
    ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active
    ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active
    ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active
    ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active
    ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active
    ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active
    ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,Shutter
    ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100
    ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0
    ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize
    ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize
    ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize
    ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0
    ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0
    ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D
    ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41
    ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always
    ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam
    ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher
    ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active
    ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active
    ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active
    ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active
    ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active
    ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active
    ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,Shutter
    ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100
    ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0
    ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize
    ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize
    ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize
    ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0
    ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0
    ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00
    ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00
    ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always
    ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED
    ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active
    ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active
    ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active
    ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active
    ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active
    ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active
    ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active
    ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
    ENG126648-MAS02526-LIN-Mirrormode-Activation,not active
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,not active
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,not active
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,not active
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
    ENG122927-RLS_close_glazing,2.0 s
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,9 s
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 s
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
    ENG122929-RLS_LIN_Communication,4 s
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
    ENG122930-RLS_tunel_gateway_recognize,5 s
    ENG122935-RLS_Washer_Front,15 s
    ENG122926-RLS_wiper_position_parking,15 s
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
    ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Elapsed Time: 01:37
  3. Likes EduardJS liked this post
    Unverified
    Jun 2017
    	SW:5Q0-919-294-K   HW:5Q0-919-294-A ---  Park/Steer Assist
    	Component:PARKHILFE 8K  H03 0054, Coding:0031151011
    	EV_EPHVA18AU3700000,002026,EV_EPHVA18AU3700000_VW37.rod
    	Monday,19,June,2017,21:24:12:46934
    	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
    	VCID: 43546AEF83E9F7A6CD-8016
    IDE00001-Production mode,Deactivating
    IDE01165-Park assist activation tone,On
    IDE01169-Audio reduction request,On
    IDE02332-Deactivate production mode,0
    IDE03782-Switch-off speed for parking assist,10 km/h
    MAS01426-Speaker volume for rear park assist,Stage 4
    MAS01427-Speaker frequency for rear park assist,Stage 4
    MAS01428-Speaker volume for front park assist,Stage 4
    MAS01429-Speaker frequency for front park assist,Stage 6
    Elapsed Time: 00:07
    15
    	SW:6C0-959-655-K   HW:6C0-959-655-K ---  Airbags
    	Component:VW20Airbag002 002 0380, Coding:88CCC000000000005C0000CA000800000000
    	EV_AirbaVW20BPAVW26X,001001,EV_AirbaVW20BPAVW26X.rod
    	Monday,19,June,2017,21:24:46:46934
    	VCID: 3B4C7AF7638127EE0D-806E
    MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined
    MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated
    MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated
    MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated
    MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated
    MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated
    MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated
    MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated
    MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated
    MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined
    MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated
    MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed
    Elapsed Time: 00:01
    17
    	SW:6P0-920-741-A   HW:6P0-920-741-A ---  Instruments
    	Component:KOMBI         208 1422, Coding:072D09082980000800083A001000000000000000
    	EV_DashBoardVDDMQBAB,009046,EV_DashBoardVDDMQBAB_009_SK37.rod
    	Monday,19,June,2017,21:25:04:46934
    	VCID: 2E3B94AE5F42751395-807A
    IDE00295-Oil temperature display,On
    IDE00301-Distance,23499 km
    IDE00342-ESI: Resetting ESI,no warning
    IDE00343-Language version,English
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
    IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
    IDE00499-Display correction of consumptions and operating range,100 %
    IDE00500-Hour,21 H
    IDE00501-Minute,25 min
    IDE00502-Year,2017 yr
    IDE00503-Month,6 mon
    IDE00504-Day,19 d
    IDE00510-ESI: distance driven from inspection,5643 km
    IDE00511-ESI: time from inspection,111 d
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
    IDE00514-ESI: maximum value of time between inspections,730 d
    IDE00515-ESI: oil quality,good oil quality
    IDE00517-ESI: soot entry,17700 km
    IDE00518-ESI: thermal load,10200 km
    IDE00711-Trip recorder,not installed
    IDE00819-Day counter,507 d
    IDE00820-Activating and deactivating all development messages,not active
    IDE00827-ESI: minimum value of time between inspections,365 d
    IDE01153-SIA: maximum value of distance to service,15000 km
    IDE01154-SIA: maximum value of time to service,365 d
    IDE02489-Display depiction,Not available
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
    IDE03329-Driving profiled for range remaining,6.3 l/100km
    IDE03346-IDE00301-Units adjusted-Distance,Kilometers
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
    IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour
    IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius
    IDE03346-MAS02957-Units adjusted-Time,24h
    IDE03346-MAS03032-Units adjusted-Volume,Liter
    IDE03346-MAS03034-Units adjusted-Pressure,bar
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km
    IDE03346-MAS13665-Units adjusted-Anhänge-/Stützlast Masse,Kilogramm (kg)
    IDE03348-MAS01456-Speed warning-Speed,190
    IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour
    IDE03348-IDE03348-Speed warning-,active
    IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,19900 km
    IDE03352-FIX: Time since last time-dependent inspection,462 d
    IDE03372-Source for synchronization of time,internal clock
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
    IDE03867-Deactivate seat belt warning,No
    IDE04169-Display correction of consumption and operating range: gas,100 %
    IDE05930-Service notification in days,30 d
    IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km
    IDE05932-FIX: Reset value for next time-dependent inspections,365 d
    IDE05971-Vehicle Positioning System Interface Control Module,not installed
    IDE06425-Roller test bench mode: functional,not activated
    IDE06588-Ignition active message: actuator,Driver door
    IDE06922-No-voltage display,Display
    IDE07221-Cylinder shut-off,Display
    IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km
    IDE08247-Driving profile for range remaining LPG,10.0 l/100km
    IDE11086-Service notification,30 d
    MAS03555-Lap counter,Display
    MAS03685-Digital speedometer,Display
    ENG117917-BAP_Debug_Mode_Release,not_released
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
    ENG119875-defuel_threshold,35 l
    ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00
    ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A
    ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64
    ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96
    ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC
    ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD
    ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01
    ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01
    ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06
    ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A
    ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,22
    ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,3C
    ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,64
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
    ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,30
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
    ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
    ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64
    ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
    ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,04
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,04
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,22
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,34
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,50
    ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
    ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,64
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,96
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,0A
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,0A
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,3C
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,3C
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,3C
    ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,3C
    ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
    ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,64
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,96
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC
    ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0F
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0F
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,2D
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,3E
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,57
    ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 15
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 70
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
    ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
    ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
    ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,0E
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,21
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
    ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
    ENG119874-Gas_functionality,not active
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light
    ENG119882-init_fuel_algorithm,No
    ENG130585-Leaving_warning_delay,1.6 s
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
    ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
    ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0
    ENG119825-Picture_Upload_Download,not active
    ENG119876-Service_Key_Clear_All_Counter,Yes
    ENG130584-Statistic_phev_mileage,5 km
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.6
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.0
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.0
    ENG112418-ENG112412-total_range_gas-consumption_factor,0.000
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN
    ENG112418-ENG99298-total_range_gas-State,not active
    Elapsed Time: 00:32
    19
    	SW:6C0-909-901   HW:6C0-937-089 ---  CAN Gateway
    	Component:GW MQB A0     H08 0086, Coding:030100044F0859007B000000040300010001000000000000000000000000
    	EV_GatewA0Lear,013020,EV_GatewA0Lear_VW26.rod
    	Monday,19,June,2017,21:26:11:46934
    	VCID: 657226093BBF3B90DD-8030
    IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating
    IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating
    IDE00002-Transport mode,not active
    IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V
    IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V
    IDE01211-Static current measuring mode,not activated
    IDE01457-Energy management deactivation stage,Mode not active
    IDE01459-Energy management heat output control status,Mode not active
    IDE01844-Increase idle speed request,Mode not active
    IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,--
    IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active
    IDE01860-Generator specified voltage value variable,10.6 V
    IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded
    IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded
    IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded
    IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded
    IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded
    IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded
    IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded
    IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded
    IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded
    IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded
    IDE01996-SFT00021-Installation list: specified installations-Airbag,coded
    IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded
    IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded
    IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded
    IDE01996-SFT00025-Installation list: specified installations-Gateway,1
    IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded
    IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded
    IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded
    IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded
    IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded
    IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded
    IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded
    IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded
    IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded
    IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded
    IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded
    IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded
    IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,Not coded
    IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded
    IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded
    IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded
    IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded
    IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,Not coded
    IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,coded
    IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded
    IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded
    IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded
    IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded
    IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded
    IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded
    IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded
    IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded
    IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded
    IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded
    IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1,Not coded
    IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded
    IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded
    IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded
    IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded
    IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded
    IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded
    IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded
    IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded
    IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded
    IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded
    IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded
    IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded
    IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded
    IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded
    IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded
    IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded
    IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded
    IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded
    IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded
    IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded
    IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded
    IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded
    IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded
    IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded
    IDE01996-ENG118234-Installation list: specified installations-Node_0x09,Not coded
    IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded
    IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded
    IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded
    IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded
    IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded
    IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded
    IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded
    IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded
    IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded
    IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded
    IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded
    IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded
    IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded
    IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded
    IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded
    IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded
    IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded
    IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded
    IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded
    IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded
    IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded
    IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded
    IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded
    IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded
    IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded
    IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded
    IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded
    IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded
    IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded
    IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded
    IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded
    IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded
    IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded
    IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded
    IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded
    IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded
    IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded
    IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded
    IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded
    IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded
    IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded
    IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded
    IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded
    IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded
    IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded
    IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded
    IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded
    IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded
    IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded
    IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded
    IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded
    IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded
    IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded
    IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded
    IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded
    IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded
    IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded
    IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded
    IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded
    IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded
    IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded
    IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded
    IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded
    IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded
    IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded
    IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded
    IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded
    IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded
    IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded
    IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded
    IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded
    IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded
    IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded
    IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded
    IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded
    IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded
    IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded
    IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded
    IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded
    IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded
    IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded
    IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded
    IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded
    IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded
    IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded
    IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded
    IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded
    IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded
    IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded
    IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded
    IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded
    IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded
    IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded
    IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded
    IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded
    IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded
    IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded
    IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded
    IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded
    IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded
    IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded
    IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded
    IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded
    IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded
    IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded
    IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded
    IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded
    IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded
    IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded
    IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded
    IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded
    IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded
    IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded
    IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded
    IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded
    IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded
    IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded
    IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded
    IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded
    IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded
    IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded
    IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded
    IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded
    IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded
    IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded
    IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded
    IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded
    IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded
    IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded
    IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded
    IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded
    IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded
    IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded
    IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded
    IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded
    IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded
    IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded
    IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded
    IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded
    IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded
    IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded
    IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded
    IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded
    IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded
    IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded
    IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded
    IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded
    IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded
    IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded
    IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded
    IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded
    IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded
    IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded
    IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded
    IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded
    IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded
    IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded
    IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded
    IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded
    IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded
    IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded
    IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded
    IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded
    IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded
    IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded
    IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded
    IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded
    IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded
    IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded
    IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded
    IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded
    IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded
    IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded
    IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded
    IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded
    IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded
    IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded
    IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded
    IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded
    IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded
    IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded
    IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded
    IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded
    IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded
    IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded
    IDE02200-Component protection showroom mode,not active
    IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah
    IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece
    IDE03256-MAS06107-Battery adaptation-Battery manufacturer,VAO
    IDE03256-MAS06108-Battery adaptation-Battery Serial Number,660114E08N
    IDE03903-Production process data 1,00 B7
    IDE04159-Deactivation of start-stop function,Mode not active
    IDE04186-Battery terminal recognition,connected
    IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
    IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated
    IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error
    IDE06530-Distance left for deactivation of static current measuring mode,2
    IDE06541-Distance left for deactivation of transport mode,50
    IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated
    IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated
    IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated
    IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated
    IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated
    IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated
    IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated
    IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated
    IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated
    IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated
    IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated
    IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated
    IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,not activated
    IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,not activated
    IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,not activated
    IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,not activated
    IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,not activated
    IDE06753-MAS06295-Efficiency program display-Comfort use fog light,not activated
    IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated
    IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,not activated
    IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,not activated
    IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,not activated
    IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,not activated
    IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated
    IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,not activated
    IDE07838-Counter for inconsistent states,1095
    IDE08348-Start/stop start voltage limit,7.6 V
    IDE08624-MKE Check box,activated
    IDE10736-Cyclization limitation request battery service,0
    ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,not active
    ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,0
    ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,0 ms
    ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,0 ms
    ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,0 ms
    ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
    ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,0 ms
    ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,0 ms
    ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms
    ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,0 ms
    ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active
    ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active
    ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active
    ENG05988-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active
    ENG05989-EM_nominal_voltage_limitation_low_beams,12.1 V
    ENG05992-EM_requirement_cyclic_time_voltage_measurement,0 s
    ENG05991-EM_requirement_reduction_air_blowers,Mode not active
    ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C
    ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C
    ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled
    ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled
    ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled
    ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled
    ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled
    ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled
    ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled
    ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled
    ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled
    ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled
    ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled
    ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled
    ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled
    ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled
    ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled
    ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled
    ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled
    ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled
    ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled
    ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled
    ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled
    ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled
    ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled
    ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled
    ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled
    ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
    ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled
    ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled
    ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled
    ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled
    ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled
    ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled
    ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled
    ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled
    ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled
    ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled
    ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled
    ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled
    ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled
    ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled
    ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled
    ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled
    ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled
    ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled
    ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled
    ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
    ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled
    ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled
    ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled
    ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled
    ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled
    ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled
    ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
    ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled
    ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled
    ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled
    ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled
    ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled
    ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled
    ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled
    ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled
    ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled
    ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled
    ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled
    ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled
    ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled
    ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled
    ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled
    ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled
    ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled
    ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled
    ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled
    ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled
    ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled
    ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled
    ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled
    ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled
    ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled
    ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled
    ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled
    ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled
    ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled
    ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled
    ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled
    ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled
    ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled
    ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled
    ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled
    ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled
    ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled
    ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled
    ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled
    ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled
    ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled
    ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled
    ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled
    ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled
    ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled
    ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled
    ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled
    ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled
    ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled
    ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled
    ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled
    ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled
    ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled
    ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled
    ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled
    ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled
    ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled
    ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled
    ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled
    ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled
    ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled
    ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled
    ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled
    ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled
    ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled
    ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled
    ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled
    ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled
    ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled
    ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled
    ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled
    ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled
    ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled
    ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled
    ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled
    ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled
    ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled
    ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled
    ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled
    ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled
    ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled
    ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled
    ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled
    ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled
    ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled
    ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled
    ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled
    ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled
    ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled
    ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled
    ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled
    ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled
    ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled
    ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled
    ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled
    ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled
    ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled
    ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled
    ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled
    ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled
    ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled
    ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled
    ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled
    ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled
    ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled
    ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled
    ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled
    ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled
    ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled
    ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled
    ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled
    ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled
    ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled
    ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled
    ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled
    ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled
    ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled
    ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled
    ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled
    ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled
    ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled
    ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled
    ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled
    ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled
    ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled
    ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled
    ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled
    ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled
    ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled
    ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled
    ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled
    ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled
    ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled
    ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled
    ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled
    ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled
    ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled
    ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled
    ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled
    ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled
    ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled
    ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled
    ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled
    ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled
    ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled
    ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled
    ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled
    ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled
    ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled
    ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled
    ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled
    ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled
    ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled
    ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled
    ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled
    ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled
    ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled
    ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled
    ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled
    ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled
    ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled
    ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled
    ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled
    ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled
    ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled
    ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled
    ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled
    ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled
    ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled
    ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled
    ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled
    ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled
    ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled
    ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled
    ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled
    ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled
    ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled
    ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled
    ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled
    ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled
    ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled
    ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled
    ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled
    ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled
    ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled
    ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled
    ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled
    ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled
    ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled
    ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled
    ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled
    ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled
    ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled
    ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled
    ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled
    ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled
    ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled
    ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled
    ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled
    ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled
    ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled
    ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled
    ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled
    ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain
    ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ,not active
    ENG05993-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00
    ENG05994-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00
    ENG05995-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00
    ENG05996-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00
    ENG05997-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00
    ENG05998-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00
    ENG05999-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00
    ENG06000-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00
    ENG06001-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00
    ENG06002-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00
    ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,not active
    ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,not active
    ENG118779-ENG118723-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VW,not installed
    ENG118779-ENG118722-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor,not installed
    ENG118779-ENG109457-Multi_function_steering_wheel_control_module Coding Value-Tiptronic,not installed
    ENG118774-WakeUpMonitor_Activation,not activated
    ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
    ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
    ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
    Elapsed Time: 00:25
    44
    	SW:6C1-909-144-AG   HW:6C1-909-144-D ---  Steering Assist
    	Component:EPS_TRW_ALow  312 3232, Coding:000700
    	EV_SteerAssisUDSTRW,016026,EV_SteerAssisUDSTRW_SE26.rod
    	Monday,19,June,2017,21:27:11:46934
    	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
    	VCID: 6D7A16615B87CB489D-8038
    IDE00820-Activating and deactivating all development messages,not active
    IDE03724-Straight line running,active
    IDE03734-Support power,100%
    IDE04130-Characteristic curve of steering assistance,Driving profile selection button
    IDE04555-Activation of pwr steering asst without engine running,not active
    IDE05162-Software end stop,active
    IDE06419-Driving profile switchover,Incremental: controlled over time
    IDE07399-Engine type,large type 1
    IDE07540-Download without rest bus,not active
    MAS02080-XCP calibration protocol,active
    Elapsed Time: 00:04
    55
    	SW:7P6-907-357-D   HW:7P6-907-357-A ---  Headlight Range
    	Component:AFS-ECU       H07 0090, Coding:058A010003000000
    	EV_HeadlRegulVWAFSMQB,001120,EV_HeadlRegulVWAFSMQB.rod
    	Monday,19,June,2017,21:27:37:46934
    	VCID: 404970F897F8D98DE5-8014
    IDE03641-Presentation run dynamic AFS light,active
    IDE03642-Presentation mode,not active
    IDE03679-Adaptive light functions,not active
    IDE03787-Activate left/right hand drive switch-over,not active
    ENG100660-PWM to Level Scaling Factor Front,3.00 mm/%
    ENG103748-PWM to Level Scaling Factor Rear,-7.20 mm/%
    ENG103979-Reference_Run_Start_Condition,Engine start
    Elapsed Time: 00:02
    Unverified
    Jun 2017
    Auto Scan added:
    VCDS Version: 17.1.3.0
    VIN: VSSZZZ6JZGR080726   License Plate:
    Chassis Type: 6J (6C0)
    Scan: 01 02 03 08 09 10 15 17 19 44 55 5F
    Address 01: Engine (J000-CUSB)       Labels: 04B-907-445-V1.clb
       Part No SW: 04B 906 027 D    HW: 04B 907 445
       Component: R3 1.4l TDI   H08 9153
       Revision: 21006001
       Coding: 01254032422401080000
       Shop #: WSC 00049 770 00209
       ASAM Dataset: EV_ECM14TDI03004B906027D 003029
       ROD: EV_ECM14TDI03004B906027D_SK26.rod
       VCID: 224F94BA3766A557DD-8076
    Readiness: N/A
       Part No SW: 0CW 300 049     HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 6501
       Revision: 00043014    Serial number: CU501511247300
       ROD: EV_TCMDQ200021.rod
       VCID: 7AA7E4A2973E553F1D-802E
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
       Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0004
       Serial number: 08503581160109
       Coding: 11DD287D892B33C0091B106B0057881491CC90080007C9098F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 37586AFB9B8D27EA35-8062
    Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
       Part No SW: 6P0 907 044 B    HW: 6P0 907 044 B
       Component: Climatronic   H02 0202
       Serial number:  1512092A-1395
       Coding: 001000001001200001
       ASAM Dataset: EV_ACClimaValeoPQ26 003001
       ROD: EV_ACClimaValeoPQ26_SK25.rod
       VCID: 305178807FA011354D-8064
    Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 C    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H08 0086
       Serial number: 001588197593
       Coding: 08001A5042532AFB0BA44000B12707481001690257010000000000000000
       ASAM Dataset: EV_BCMA0 005005
       ROD: EV_BCMA0_005_VW26.rod
       Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
       Component: RLHS  037 0059
       Serial number: S5Y16M01D05H19M05S31
       Coding: 00984D
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 6R0 959 801 DT    HW: 6R0 959 801 DT  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  003 0630
       Serial number: KU0KU019111553234062
       Coding: 1400A5
       Subsystem 3 - Part No SW: 6R0 959 802 EE    HW: 6R0 959 802 EE  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  003 0630
       Serial number: KU0KU014121553481690
       Coding: 0400A5
       Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY153273DNY
       Serial number: 00000000000064436026
       Subsystem 7 - Part No SW: 6R0 959 811 R    HW: 6R0 959 811 R
       Component: J388__TSG_HL  019 1112
       Serial number: 13102719160118224844
       Subsystem 8 - Part No SW: 6R0 959 812 R    HW: 6R0 959 812 R
       Component: J389__TSG_HR  019 1112
       Serial number: 13202718160118204646
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Revision: --------    Serial number: 39391600402324
       Coding: 0031151011
       VCID: 436C52C7ABC1EFBED5-8016
    Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
       Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
       Component: VW20Airbag002 002 0380
       Revision: --------    Serial number: 003TJ0001HJ2
       Coding: 88CCC000000000005C0000CA000800000000
       Shop #: WSC 00049 770 00111
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3B6462EF8BF9DF8615-806E
       Subsystem 1 - Part No SW: -----------    HW: 410 271 001 16
       Component: SideSensor_Df  15B 0148
       Serial number: 3495R00C91D3F921C0D9
       Subsystem 2 - Part No SW: -----------    HW: 410 271 001 16
       Component: SideSensor_Pf  15B 0148
       Serial number: 3505R000C294C705538L
       Subsystem 3 - Part No SW: -----------    HW: 410 272 610 15
       Component: SideSensor_Dr  15B 0148
       Serial number: 3515R009D1D07263D3B-
       Subsystem 4 - Part No SW: -----------    HW: 410 272 610 15
       Component: SideSensor_Pr  15B 0148
       Serial number: 3525R009D1D07266214K
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 6P0 920 741 A    HW: 6P0 920 741 A
       Component: KOMBI         208 1422
       Coding: 072D09082980000800083A001000000000000000
       ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
       VCID: 2E537C8647BA6D2B7D-807A
    Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H08 0086
       Revision: --------    Serial number: 001588197593
       Coding: 030100044F0859007B000000040300010001000000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 013020
       ROD: EV_GatewA0Lear_VW26.rod
       VCID: 658A0E612397D3A8A5-8030
       Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
       Serial number: 000000000A0827041215
       Coding: 002000
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 53019K37552821416080
    Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
       Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  312 3232
       Serial number: CG190587
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016026
       ROD: EV_SteerAssisUDSTRW_SE26.rod
       VCID: 6D92FE5943FFE36065-8038
       Coding: 058A010003000000
       Shop #: WSC 00049 770 00137
       VCID: 406158D0BFD0F1A5CD-8014
       Subsystem 1 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 290000
       Subsystem 2 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 290000
    Address 5F: Information Electr. (J794)       Labels: Redir Fail!
       Part No SW: 5QA 035 824     HW: 5QA 035 824
       Component: MU-S--ER      H24 0245
       Serial number: SEZAZ2S0002083
       Coding: 04520000BE02000011110001000808002F0201D40120010002
       ASAM Dataset: EV_MUStd6C3TSAT 001015
       ROD: EV_MUStd6C3TSAT_SE26.rod
       VCID: 7DA2DEA9832F43D0E5-8028
       Subsystem 1 - Part No SW: 5F0 919 604     HW: 5F0 919 604
       Component: ABTm_Std2  H44 1031
       Serial number: SEZ8Z9RLL0014U
    End-------------------------(Elapsed Time: 03:11)--------------------------
