2016 Seat Ibiza 6P 1.4 TDI DSG7 (CUSB) maps
kickdown
Unverified
Admaps:
01
	SW:04B-906-027-D   HW:04B-907-445 ---  Engine
	Component:R3 1.4l TDI   H08 9153, Coding:01254032422401080000
	EV_ECM14TDI03004B906027D,003029,EV_ECM14TDI03004B906027D_SK26.rod
	Monday,19,June,2017,21:16:59:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 2237AC420F0E8DBFF5-8076
IDE00001-Production mode,00 00 00
IDE00259-Idle RPM correction,0 /min
IDE00263-Injector 1 correction value,X72Y4BRHJ9Z3G77W60TZ
IDE00264-Injector 2 correction value,AP328B8JDY13H7R45YYX
IDE00265-Injector 3 correction value,TP724B81EE54HP9CJ0YZ
IDE01096-Particulate Filter Statistics,0
IDE01711-Blocking of particle filter regeneration,not active
IDE01945-Engine run-in oil pressure,not active
IDE02248-Individually adjustable maximum speed limit,300.0 km/h
IDE02332-Deactivate production mode,00 00 00
IDE04158-Activation of start-stop function,active
IDE04617-Protective function,Enabled
IDE06425-Roller test bench mode: functional,not activated
IDE07232-Initialization of NOx catalyst accumulator,357760 s
IDE07903-Adaptation of ash mass,6.70 g
IDE08287-Bleeding of coolant circuit,not active
ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping,Not blocked
ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor,Not blocked
Elapsed Time: 00:05
02
	SW:0CW-300-049   HW:0AM-927-769-K ---  Auto Trans
	Component:GSG DQ200-MQB H43 6501, Coding:0014
	EV_TCMDQ200021,001001,EV_TCMDQ200021.rod
	Wednesday,14,June,2017,20:34:03:46934
	VCDS Version: Release 17.1.3  Data version: 20170203 DS267.2
	VCID: 7A0784C2F75E359FBD-802E
IDE00001-Production mode,not activated
Elapsed Time: 00:01
	Monday,19,June,2017,21:17:24:46934
	VCID: 7A8FFC4A6FC6BD2735-802E
Elapsed Time: 00:01
03
	SW:6C0-907-379-K   HW:6R0-907-379-BA ---  ABS Brakes
	Component:ESP9.0i       H03 0004, Coding:11DD287D892B33C0091B106B0057881491CC90080007C9098F00
	EV_Brake1ESP90iBOSCHPQ26,100020,EV_Brake1ESP90iBOSCHPQ26.rod
	Monday,19,June,2017,21:17:41:46934
	VCID: 3740828373950FD22D-8062
IDE00820-ENG114920-Activating and deactivating all development messages-BOSCH Botschaften,not activated
IDE00820-ENG114177-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 1,not activated
IDE00820-ENG114178-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 2,not activated
IDE00820-ENG114179-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 3,not activated
IDE00820-ENG114919-Activating and deactivating all development messages-VW Botschaften,not activated
IDE03659-Roller test bench mode,activated
IDE04456-Brake disk drying,Medium
IDE04643-Overboost in brake system,120BAR
IDE04939-Tire pressure monitoring display,2
IDE04949-Engine drag torque control,activated
IDE05055-Hydraulic brake assistant,normal
IDE05161-Straight ahead brake stabilization,activated
IDE05286-Expanded electronic differential lock,Strong
IDE05498-Rear axle hard braking,activated
IDE07006-Tire pressure monitoring display: tire selection,1
IDE07565-ABS in lower speed range,activated
MAS00120-Anti-slip regulation (ASR),activated
MAS00121-Electronic Differential Lock,activated
MAS00122-Electronic Stability Program,activated
MAS02080-XCP calibration protocol,not activated
MAS02138-Hill-start assistant,normal
MAS08145-Hill-start assistant: increase threshold,Three Percent
ENG125053-Developer_Function_120,No Warning/Errro(Default)
ENG130301-Developer_Function_121,not activated
ENG118192-Tyre_pressure_control_monitoring_datalogging,0
Elapsed Time: 00:07
kickdown
Unverified
5F
	SW:5QA-035-824   HW:5QA-035-824 ---  Information Electr.
	Component:MU-S--ER      H24 0245, Coding:04520000BE02000011110001000808002F0201D40120010002
	EV_MUStd6C3TSAT,001015,EV_MUStd6C3TSAT_SE26.rod
	Monday,19,June,2017,21:27:56:46934
	VCID: 7D8AF6B19B37AB381D-8028
IDE00346-Summertime-automatic,Europe
IDE00758-Base volume of telephone,50 %
IDE00759-Base volume of speech output,50 %
IDE00760-Microphone sensitivity,0 dB
IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
IDE02121-CD eject button,Enabled
IDE02122-Developer mode,not activated
IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36
IDE02502-Confirmation of installation change,A7 36
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
IDE04550-Bluetooth: Sniff mode,On
IDE05113-Infotainment Recorder,activated
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128
IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated
IDE10604-Menu entries for mobile online services,not activated
IDE11122-Country identification: country of sale HMI,--
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked
MAS00951-Bluetooth,On
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz
MAS03782-WLAN,On
ENG117917-BAP_Debug_Mode_Release,not_released
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated
ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated
ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated
ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated
ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated
ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated
ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated
ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated
ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,activated
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,activated
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,activated
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,activated
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,activated
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated
ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated
ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated
ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated
ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Comfort data bus
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Comfort data bus
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Comfort data bus
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Comfort data bus
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Comfort data bus
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Comfort data bus
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,Comfort data bus
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Comfort data bus
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Comfort data bus
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated
ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus
ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated
ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,Comfort data bus
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Comfort data bus
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Comfort data bus
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Comfort data bus
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Comfort data bus
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Terminal 15
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Comfort data bus
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,11 %
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,25 %
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 90 01 58 02 2C 01 2C 01 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 C5
ENG117809-p_damping_Display,5 ms
ENG117808-p_HMI_Display,13 %
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
ENG117919-Startup_Screen_Sticker_HMI,09 00
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,OFF
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated
ENG109862-ENG07590-Vehicle_configuration-Mirror_link,function_off_hmi_off
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active
ENG109862-ENG117844-Vehicle_configuration-picture_navi,OFF
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF
ENG109862-ENG06574-Vehicle_configuration-ProbeCar_vzo,OFF
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF
ENG109862-ENG07589-Vehicle_configuration-RSE_software_component,activated
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS
ENG109862-ENG11009-Vehicle_configuration-sd_slot_deactivation,no restriction
ENG109862-ENG07588-Vehicle_configuration-SDS_Region_Flag,no_region
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present
ENG109862-ENG07591-Vehicle_configuration-Smartphone_interface_for_rhmi,activated
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,OFF
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF
ENG109862-ENG06575-Vehicle_configuration-UOTA,OFF
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF
ENG109862-ENG06576-Vehicle_configuration-WiFi_Client_HMI,OFF
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,OFF
Elapsed Time: 00:33
08
	SW:6P0-907-044-B   HW:6P0-907-044-B ---  Auto HVAC
	Component:Climatronic   H02 0202, Coding:001000001001200001
	EV_ACClimaValeoPQ26,003001,EV_ACClimaValeoPQ26_SK25.rod
	Monday,19,June,2017,21:23:37:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 303990A85748791D65-8064
IDE00001-Production mode,Deactivating
IDE01503-Runtime for compressor run-in basic setting,120 s
IDE02332-Deactivate production mode,0
IDE03176-Duration of compressor run in,60 s
IDE04159-Deactivation of start-stop function,not active
IDE06425-Roller test bench mode: functional,not activated
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min
IDE06545-Blower voltage for production routines,6 V
IDE06546-Interior target temperature for production routines,22 °C
IDE06547-Air distribution for production routines,No effect
IDE06593-Recirculation air for production routines,No effect
IDE80006-Analysis 6,not activated
IDE80007-Analysis 7,00 00
ENG123031-ENG101574-dimming_characteristic_curve_display_illumination-X1,0
ENG123031-ENG99557-dimming_characteristic_curve_display_illumination-X2,10
ENG123031-ENG102140-dimming_characteristic_curve_display_illumination-X3,100
ENG123031-ENG102936-dimming_characteristic_curve_display_illumination-X4,150
ENG123031-ENG103548-dimming_characteristic_curve_display_illumination-X5,220
ENG123031-ENG113992-dimming_characteristic_curve_display_illumination-X6,253
ENG123031-ENG99777-dimming_characteristic_curve_display_illumination-Y1,1 %
ENG123031-ENG100480-dimming_characteristic_curve_display_illumination-Y2,1 %
ENG123031-ENG100773-dimming_characteristic_curve_display_illumination-Y3,10 %
ENG123031-ENG100631-dimming_characteristic_curve_display_illumination-Y4,40 %
ENG123031-ENG102174-dimming_characteristic_curve_display_illumination-Y5,82 %
ENG123031-ENG113993-dimming_characteristic_curve_display_illumination-Y6,100 %
ENG123032-ENG101574-dimming_characteristic_curve_function_illumination_general-X1,0
ENG123032-ENG99557-dimming_characteristic_curve_function_illumination_general-X2,10
ENG123032-ENG102140-dimming_characteristic_curve_function_illumination_general-X3,100
ENG123032-ENG102936-dimming_characteristic_curve_function_illumination_general-X4,150
ENG123032-ENG103548-dimming_characteristic_curve_function_illumination_general-X5,220
ENG123032-ENG113992-dimming_characteristic_curve_function_illumination_general-X6,253
ENG123032-ENG99777-dimming_characteristic_curve_function_illumination_general-Y1,2 %
ENG123032-ENG100480-dimming_characteristic_curve_function_illumination_general-Y2,2 %
ENG123032-ENG100773-dimming_characteristic_curve_function_illumination_general-Y3,7 %
ENG123032-ENG100631-dimming_characteristic_curve_function_illumination_general-Y4,36 %
ENG123032-ENG102174-dimming_characteristic_curve_function_illumination_general-Y5,74 %
ENG123032-ENG113993-dimming_characteristic_curve_function_illumination_general-Y6,90 %
ENG123030-ENG101574-dimming_characteristic_curve_search_illumination-X1,0
ENG123030-ENG99557-dimming_characteristic_curve_search_illumination-X2,6
ENG123030-ENG102140-dimming_characteristic_curve_search_illumination-X3,40
ENG123030-ENG102936-dimming_characteristic_curve_search_illumination-X4,60
ENG123030-ENG103548-dimming_characteristic_curve_search_illumination-X5,80
ENG123030-ENG113992-dimming_characteristic_curve_search_illumination-X6,100
ENG123030-ENG99777-dimming_characteristic_curve_search_illumination-Y1,0 %
ENG123030-ENG100480-dimming_characteristic_curve_search_illumination-Y2,6 %
ENG123030-ENG100773-dimming_characteristic_curve_search_illumination-Y3,40 %
ENG123030-ENG100631-dimming_characteristic_curve_search_illumination-Y4,60 %
ENG123030-ENG102174-dimming_characteristic_curve_search_illumination-Y5,80 %
ENG123030-ENG113993-dimming_characteristic_curve_search_illumination-Y6,100 %
Elapsed Time: 00:06
09
	SW:6C0-937-089-C   HW:6C0-937-089 ---  Cent. Elect.
	Component:BCM PQ26 Hi4R H08 0086, Coding:08001A5042532AFB0BA44000B12707481001690257010000000000000000
	EV_BCMA0,005005,EV_BCMA0_005_VW26.rod
	Monday,19,June,2017,21:18:40:46934
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG130235-Production mode-Entry_control,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,3
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,activated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1100 ms
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
IDE02152-Characteristics in production mode,2000 ms
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active
IDE02488-DWA Interior monitoring,100 %
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.00 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.200 %
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,0.0 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Fog light
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,72.0
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,active
IDE04926-ENG126570-Comfort illumination-lho_zeit,10 s
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
IDE04927-IDE01446-Window heater-Running time of heated front window,0 s
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,-50.0 °C
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,420.0 s
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,400 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,Default
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,delay_driver_door_contact_thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock NAR,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,not active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05143-MAS02985-Writing parameter-Value,130
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
IDE05144-Read parameter address,FE 00 00
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,38
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,42
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,39
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,43
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,48
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,00
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,00
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,00
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,00
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,00
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,28
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,4C
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,0C
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,48
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,4C
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100
IDE05145-ENG114999-Light configuration-Dimming_AB_10,100
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100
IDE05145-ENG115212-Light configuration-Dimming_AB_12,100
IDE05145-ENG114958-Light configuration-Dimming_AB_13,100
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100
IDE05145-ENG115404-Light configuration-Dimming_AB_23,100
IDE05145-ENG115423-Light configuration-Dimming_AB_24,100
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100
IDE05145-ENG115556-Light configuration-Dimming_AB_31,100
IDE05145-ENG115575-Light configuration-Dimming_AB_32,100
IDE05145-ENG115594-Light configuration-Dimming_AB_33,100
IDE05145-ENG115613-Light configuration-Dimming_AB_34,108
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0
IDE05145-ENG115060-Light configuration-Dimming_CD_2,28
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0
IDE05145-ENG115408-Light configuration-Dimming_CD_23,100
IDE05145-ENG115427-Light configuration-Dimming_CD_24,100
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0
IDE05145-ENG115079-Light configuration-Dimming_CD_3,28
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0
IDE05145-ENG115617-Light configuration-Dimming_CD_34,3
IDE05145-ENG115098-Light configuration-Dimming_CD_4,100
IDE05145-ENG114981-Light configuration-Dimming_CD_5,100
IDE05145-ENG115119-Light configuration-Dimming_CD_6,100
IDE05145-ENG115138-Light configuration-Dimming_CD_7,100
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,minimize
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,minimize
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0
IDE05145-ENG115064-Light configuration-Dimming_EF_2,28
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0
IDE05145-ENG115083-Light configuration-Dimming_EF_3,28
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,03
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,22
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,23
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,17
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,19
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,4A
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,00
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,00
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,00
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,00
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,30
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,4C
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,01
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,49
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,4B
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,only_if_closed
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4
IDE05145-ENG114997-Light configuration-Light_Function_A_10,45
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62
IDE05145-ENG115210-Light configuration-Light_Function_A_12,18
IDE05145-ENG114956-Light configuration-Light_Function_A_13,19
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4
IDE05145-ENG115054-Light configuration-Light_Function_A_2,20
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8
IDE05145-ENG115459-Light configuration-Light_Function_A_26,26
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37
IDE05145-ENG115073-Light configuration-Light_Function_A_3,20
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0
IDE05145-ENG115611-Light configuration-Light_Function_A_34,229
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0
IDE05145-ENG115211-Light configuration-Light_Function_B_12,22
IDE05145-ENG114957-Light configuration-Light_Function_B_13,23
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0
IDE05145-ENG115055-Light configuration-Light_Function_B_2,0
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10
IDE05145-ENG115441-Light configuration-Light_Function_B_25,30
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0
IDE05145-ENG115074-Light configuration-Light_Function_B_3,0
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0
IDE05145-ENG115612-Light configuration-Light_Function_B_34,246
IDE05145-ENG115093-Light configuration-Light_Function_B_4,8
IDE05145-ENG114976-Light configuration-Light_Function_B_5,8
IDE05145-ENG115114-Light configuration-Light_Function_B_6,0
IDE05145-ENG115133-Light configuration-Light_Function_B_7,0
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0
IDE05145-ENG115058-Light configuration-Light_Function_C_2,8
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0
IDE05145-ENG115406-Light configuration-Light_Function_C_23,30
IDE05145-ENG115425-Light configuration-Light_Function_C_24,30
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0
IDE05145-ENG115077-Light configuration-Light_Function_C_3,8
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0
IDE05145-ENG115615-Light configuration-Light_Function_C_34,173
IDE05145-ENG115096-Light configuration-Light_Function_C_4,9
IDE05145-ENG114979-Light configuration-Light_Function_C_5,10
IDE05145-ENG115117-Light configuration-Light_Function_C_6,13
IDE05145-ENG115136-Light configuration-Light_Function_C_7,14
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0
IDE05145-ENG115059-Light configuration-Light_Function_D_2,9
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0
IDE05145-ENG115078-Light configuration-Light_Function_D_3,10
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0
IDE05145-ENG115616-Light configuration-Light_Function_D_34,78
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0
IDE05145-ENG115118-Light configuration-Light_Function_D_6,15
IDE05145-ENG115137-Light configuration-Light_Function_D_7,15
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0
IDE05145-ENG115062-Light configuration-Light_Function_E_2,18
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0
IDE05145-ENG115081-Light configuration-Light_Function_E_3,19
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0
IDE05145-ENG115619-Light configuration-Light_Function_E_34,88
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0
IDE05145-ENG115624-Light configuration-Light_Function_H_34,99
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,allgemeine Scheinwerfer
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,allgemeine Scheinwerfer
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,LED Bremsleuchten
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,LED Bremsleuchten
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe12W
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeine Scheinwerfer
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Xenon Abblendlicht
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Xenon Abblendlicht
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,Shutter
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,Shutter
IDE05822-DWA Vehicle inclination sensor,100 %
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 64 23 65 42 57 9B 25 44 3F 3A 69 35 95 2D 09 A3 02 07 06 56 00 0F 12 00 89 09 31 F3 6E 0F C3 42 87 1B 05 34 3F 3A 69 7A 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 67 23 65 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 91 30 61 27 2D
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
IDE06425-Roller test bench mode: functional,not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,not active
IDE08542-ENG115671-Access control 2-Regenschließen,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Time
IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung,Energy management
IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung,Energy management
IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,0 min
IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit,24 s
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,not active
MAS01490-IDE07474-Energy management-Adapting for energy management,Energy management active
MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement,not active
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed
MAS08233-ENG126575-other-mute_mode_aktiv,not active
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed
ENG05956-Adaptation_theft_protection_2,not active
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.0 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.0 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.0 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.0 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.0 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.0 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.0 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.0 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.0 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,104 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,6
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,6
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,5.0 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,5.0 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,15.0 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,40.0 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,82.0 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,10.0
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,10.0
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,50.0
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,50.0
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,10.0
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,10.0
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.0
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,100
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,03
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,Ambientelicht 1
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,17
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,39
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,19
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,43
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19,100
ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19,0
ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19,maximize
ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19,maximize
ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19,maximize
ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19,0
ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19,0
ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19,18
ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19,18
ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19,Always
ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19,Blinken rechts Hellphase
ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19,not active
ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19,not active
ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19,not active
ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19,not active
ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19,not active
ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19,not active
ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19,not active
ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,00
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,00
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,LED Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,00
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,00
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,LED Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,00
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,100
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,100
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,00
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,00
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,ComingHome LeavingHome
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,100
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,100
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,00
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,00
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,ComingHome LeavingHome
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,30
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,28
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,ComingHome LeavingHome
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergesteckt
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe12W
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine Scheinwerfer
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,28
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,28
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,4A
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,48
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Daytime running lights
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,not active
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Parking light
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parking light left
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Nebellicht links
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,100
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,100
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,100
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,108
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,3
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,01
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,0C
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,only_if_closed
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,28
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,28
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,4C
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,4C
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Daytime running lights
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not active
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Parking light
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,Parking light right
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Nebellicht rechts
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,100
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,49
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,48
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,Parking light
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Parking light left
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,100
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,4B
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,4C
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,Parking light
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Parking light right
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,100
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,not active
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,Left high beam
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,Headlamp flasher
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Xenon Abblendlicht
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,100
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,not active
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,Right high beam
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,Headlamp flasher
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Xenon Abblendlicht
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,Shutter
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,Shutter
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
ENG122927-RLS_close_glazing,2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,9 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 s
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
ENG122929-RLS_LIN_Communication,4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
ENG122930-RLS_tunel_gateway_recognize,5 s
ENG122935-RLS_Washer_Front,15 s
ENG122926-RLS_wiper_position_parking,15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Elapsed Time: 01:37
	SW:6C0-937-089-C   HW:6C0-937-089 ---  Cent. Elect.
	Component:BCM PQ26 Hi4R H08 0086, Coding:08001A5042532AFB0BA44000B12707481001690257010000000000000000
	EV_BCMA0,005005,EV_BCMA0_005_VW26.rod
	Monday,19,June,2017,21:20:49:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 303990A85748791D65-8064
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG130235-Production mode-Entry_control,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,3
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,activated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1100 ms
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
IDE02152-Characteristics in production mode,2000 ms
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active
IDE02332-Deactivate production mode,0
IDE02488-DWA Interior monitoring,100 %
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.00 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.200 %
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,0.0 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Fog light
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,72.0
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,active
IDE04926-ENG126570-Comfort illumination-lho_zeit,10 s
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
IDE04927-IDE01446-Window heater-Running time of heated front window,0 s
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,-50.0 °C
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,420.0 s
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,400 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,Default
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,delay_driver_door_contact_thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock NAR,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,not active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05143-MAS02985-Writing parameter-Value,130
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
IDE05144-Read parameter address,FE 00 00
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,38
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,42
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,39
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,43
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,48
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,00
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,00
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,00
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,00
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,00
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,28
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,4C
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,0C
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,48
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,4C
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100
IDE05145-ENG114999-Light configuration-Dimming_AB_10,100
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100
IDE05145-ENG115212-Light configuration-Dimming_AB_12,100
IDE05145-ENG114958-Light configuration-Dimming_AB_13,100
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100
IDE05145-ENG115404-Light configuration-Dimming_AB_23,100
IDE05145-ENG115423-Light configuration-Dimming_AB_24,100
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100
IDE05145-ENG115556-Light configuration-Dimming_AB_31,100
IDE05145-ENG115575-Light configuration-Dimming_AB_32,100
IDE05145-ENG115594-Light configuration-Dimming_AB_33,100
IDE05145-ENG115613-Light configuration-Dimming_AB_34,108
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0
IDE05145-ENG115060-Light configuration-Dimming_CD_2,28
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0
IDE05145-ENG115408-Light configuration-Dimming_CD_23,100
IDE05145-ENG115427-Light configuration-Dimming_CD_24,100
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0
IDE05145-ENG115079-Light configuration-Dimming_CD_3,28
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0
IDE05145-ENG115617-Light configuration-Dimming_CD_34,3
IDE05145-ENG115098-Light configuration-Dimming_CD_4,100
IDE05145-ENG114981-Light configuration-Dimming_CD_5,100
IDE05145-ENG115119-Light configuration-Dimming_CD_6,100
IDE05145-ENG115138-Light configuration-Dimming_CD_7,100
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,minimize
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,minimize
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0
IDE05145-ENG115064-Light configuration-Dimming_EF_2,28
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0
IDE05145-ENG115083-Light configuration-Dimming_EF_3,28
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,03
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,22
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,23
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,17
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,19
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,4A
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,00
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,00
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,00
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,00
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,30
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,4C
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,01
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,49
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,4B
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,only_if_closed
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4
IDE05145-ENG114997-Light configuration-Light_Function_A_10,45
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62
IDE05145-ENG115210-Light configuration-Light_Function_A_12,18
IDE05145-ENG114956-Light configuration-Light_Function_A_13,19
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4
IDE05145-ENG115054-Light configuration-Light_Function_A_2,20
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8
IDE05145-ENG115459-Light configuration-Light_Function_A_26,26
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37
IDE05145-ENG115073-Light configuration-Light_Function_A_3,20
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0
IDE05145-ENG115611-Light configuration-Light_Function_A_34,229
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0
IDE05145-ENG115211-Light configuration-Light_Function_B_12,22
IDE05145-ENG114957-Light configuration-Light_Function_B_13,23
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0
IDE05145-ENG115055-Light configuration-Light_Function_B_2,0
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10
IDE05145-ENG115441-Light configuration-Light_Function_B_25,30
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0
IDE05145-ENG115074-Light configuration-Light_Function_B_3,0
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0
IDE05145-ENG115612-Light configuration-Light_Function_B_34,246
IDE05145-ENG115093-Light configuration-Light_Function_B_4,8
IDE05145-ENG114976-Light configuration-Light_Function_B_5,8
IDE05145-ENG115114-Light configuration-Light_Function_B_6,0
IDE05145-ENG115133-Light configuration-Light_Function_B_7,0
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0
IDE05145-ENG115058-Light configuration-Light_Function_C_2,8
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0
IDE05145-ENG115406-Light configuration-Light_Function_C_23,30
IDE05145-ENG115425-Light configuration-Light_Function_C_24,30
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0
IDE05145-ENG115077-Light configuration-Light_Function_C_3,8
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0
IDE05145-ENG115615-Light configuration-Light_Function_C_34,173
IDE05145-ENG115096-Light configuration-Light_Function_C_4,9
IDE05145-ENG114979-Light configuration-Light_Function_C_5,10
IDE05145-ENG115117-Light configuration-Light_Function_C_6,13
IDE05145-ENG115136-Light configuration-Light_Function_C_7,14
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0
IDE05145-ENG115059-Light configuration-Light_Function_D_2,9
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0
IDE05145-ENG115078-Light configuration-Light_Function_D_3,10
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0
IDE05145-ENG115616-Light configuration-Light_Function_D_34,78
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0
IDE05145-ENG115118-Light configuration-Light_Function_D_6,15
IDE05145-ENG115137-Light configuration-Light_Function_D_7,15
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0
IDE05145-ENG115062-Light configuration-Light_Function_E_2,18
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0
IDE05145-ENG115081-Light configuration-Light_Function_E_3,19
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0
IDE05145-ENG115619-Light configuration-Light_Function_E_34,88
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0
IDE05145-ENG115624-Light configuration-Light_Function_H_34,99
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,allgemeine Scheinwerfer
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,allgemeine Scheinwerfer
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,LED Bremsleuchten
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,LED Bremsleuchten
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe12W
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeine Scheinwerfer
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Xenon Abblendlicht
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Xenon Abblendlicht
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,Shutter
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,Shutter
IDE05822-DWA Vehicle inclination sensor,100 %
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 39 F7 64 23 65 42 57 9B 25 44 3F 3A 69 35 95 2D 09 A3 02 07 06 56 00 0F 12 00 89 09 31 F3 6E 0F C3 42 87 1B 05 34 3F 3A 69 7A 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 67 23 65 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 91 30 61 27 2D
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %
IDE06425-Roller test bench mode: functional,not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,not active
IDE08542-ENG115671-Access control 2-Regenschließen,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Time
IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung,Energy management
IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung,Energy management
IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit,0 min
IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit,24 s
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein,not active
MAS01490-IDE07474-Energy management-Adapting for energy management,Energy management active
MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement,not active
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed
MAS08233-ENG126575-other-mute_mode_aktiv,not active
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed
ENG05956-Adaptation_theft_protection_2,not active
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.0 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.0 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.0 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.0 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.0 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.0 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.0 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.0 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.0 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,104 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,6
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,6
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,5.0 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,5.0 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,15.0 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,40.0 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,82.0 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,10.0
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,10.0
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,50.0
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,50.0
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,10.0
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,10.0
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.0
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,allgemeineLEDmitOpenLoadDiagnose
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,100
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,03
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,Ambientelicht 1
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,LED Kleinleistung ohne Open Load Diagnose
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,17
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,39
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,allgemeine LED mit Open Load Diagnose
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,19
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,43
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,allgemeineLEDmitOpenLoadDiagnose
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,allgemeineLEDmitOpenLoadDiagnose
ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19,100
ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19,0
ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19,maximize
ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19,maximize
ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19,maximize
ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19,0
ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19,0
ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19,18
ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19,18
ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19,Always
ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19,Blinken rechts Hellphase
ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19,not active
ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19,not active
ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19,not active
ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19,not active
ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19,not active
ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19,not active
ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19,not active
ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19,allgemeineLEDmitOpenLoadDiagnose
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,allgemeineLEDmitOpenLoadDiagnose
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,00
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,00
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,LED Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,00
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,00
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,LED Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,00
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,100
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,100
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,00
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,00
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,ComingHome LeavingHome
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineLEDmitOpenLoadDiagnose
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,100
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,100
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,00
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,00
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,ComingHome LeavingHome
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineLEDmitOpenLoadDiagnose
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,30
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,28
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,ComingHome LeavingHome
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,allgemeine LED mit Open Load Diagnose
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergesteckt
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineLEDmitOpenLoadDiagnose
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe12W
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeine Scheinwerfer
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,28
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,minimize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,28
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,4A
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,48
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Daytime running lights
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,not active
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,Parking light
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,Parking light left
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,Nebellicht links
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,LED Kleinleistung ohne Open Load Diagnose
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,100
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,100
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,100
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,108
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,3
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,01
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,0C
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,only_if_closed
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,28
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,minimize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,28
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,4C
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,4C
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Daytime running lights
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,not active
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,Parking light
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,Parking light right
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,Nebellicht rechts
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,LED Tagfahrlichtmodul Signal
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,100
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,49
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,48
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,Parking light
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,Parking light left
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,LED Tagfahrlichtmodul Versorgung
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,100
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,4B
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,4C
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,Parking light
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,Parking light right
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,LED Tagfahrlichtmodul Versorgung
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,100
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,not active
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,Left high beam
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,Headlamp flasher
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Xenon Abblendlicht
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,100
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,not active
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,Right high beam
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,Headlamp flasher
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Xenon Abblendlicht
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,Shutter
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,Shutter
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
ENG126648-MAS02526-LIN-Mirrormode-Activation,not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
ENG122927-RLS_close_glazing,2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,9 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 s
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s
ENG122929-RLS_LIN_Communication,4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx
ENG122930-RLS_tunel_gateway_recognize,5 s
ENG122935-RLS_Washer_Front,15 s
ENG122926-RLS_wiper_position_parking,15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Elapsed Time: 01:37
kickdown
Unverified
10
	SW:5Q0-919-294-K   HW:5Q0-919-294-A ---  Park/Steer Assist
	Component:PARKHILFE 8K  H03 0054, Coding:0031151011
	EV_EPHVA18AU3700000,002026,EV_EPHVA18AU3700000_VW37.rod
	Monday,19,June,2017,21:24:12:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 43546AEF83E9F7A6CD-8016
IDE00001-Production mode,Deactivating
IDE01165-Park assist activation tone,On
IDE01169-Audio reduction request,On
IDE02332-Deactivate production mode,0
IDE03782-Switch-off speed for parking assist,10 km/h
MAS01426-Speaker volume for rear park assist,Stage 4
MAS01427-Speaker frequency for rear park assist,Stage 4
MAS01428-Speaker volume for front park assist,Stage 4
MAS01429-Speaker frequency for front park assist,Stage 6
Elapsed Time: 00:07
15
	SW:6C0-959-655-K   HW:6C0-959-655-K ---  Airbags
	Component:VW20Airbag002 002 0380, Coding:88CCC000000000005C0000CA000800000000
	EV_AirbaVW20BPAVW26X,001001,EV_AirbaVW20BPAVW26X.rod
	Monday,19,June,2017,21:24:46:46934
	VCID: 3B4C7AF7638127EE0D-806E
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed
Elapsed Time: 00:01
17
	SW:6P0-920-741-A   HW:6P0-920-741-A ---  Instruments
	Component:KOMBI         208 1422, Coding:072D09082980000800083A001000000000000000
	EV_DashBoardVDDMQBAB,009046,EV_DashBoardVDDMQBAB_009_SK37.rod
	Monday,19,June,2017,21:25:04:46934
	VCID: 2E3B94AE5F42751395-807A
IDE00295-Oil temperature display,On
IDE00301-Distance,23499 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,English
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
IDE00345-MAS12879-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,21 H
IDE00501-Minute,25 min
IDE00502-Year,2017 yr
IDE00503-Month,6 mon
IDE00504-Day,19 d
IDE00510-ESI: distance driven from inspection,5643 km
IDE00511-ESI: time from inspection,111 d
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,17700 km
IDE00518-ESI: thermal load,10200 km
IDE00711-Trip recorder,not installed
IDE00819-Day counter,507 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,365 d
IDE01153-SIA: maximum value of distance to service,15000 km
IDE01154-SIA: maximum value of time to service,365 d
IDE02489-Display depiction,Not available
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
IDE03329-Driving profiled for range remaining,6.3 l/100km
IDE03346-IDE00301-Units adjusted-Distance,Kilometers
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius
IDE03346-MAS02957-Units adjusted-Time,24h
IDE03346-MAS03032-Units adjusted-Volume,Liter
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km
IDE03346-MAS13665-Units adjusted-Anhänge-/Stützlast Masse,Kilogramm (kg)
IDE03348-MAS01456-Speed warning-Speed,190
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour
IDE03348-IDE03348-Speed warning-,active
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,19900 km
IDE03352-FIX: Time since last time-dependent inspection,462 d
IDE03372-Source for synchronization of time,internal clock
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE04169-Display correction of consumption and operating range: gas,100 %
IDE05930-Service notification in days,30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km
IDE05932-FIX: Reset value for next time-dependent inspections,365 d
IDE05971-Vehicle Positioning System Interface Control Module,not installed
IDE06425-Roller test bench mode: functional,not activated
IDE06588-Ignition active message: actuator,Driver door
IDE06922-No-voltage display,Display
IDE07221-Cylinder shut-off,Display
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km
IDE08247-Driving profile for range remaining LPG,10.0 l/100km
IDE11086-Service notification,30 d
MAS03555-Lap counter,Display
MAS03685-Digital speedometer,Display
ENG117917-BAP_Debug_Mode_Release,not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
ENG119875-defuel_threshold,35 l
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,22
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,3C
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,64
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,30
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,04
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,04
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,22
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,34
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,50
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,64
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,96
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,0A
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,0A
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,3C
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,3C
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,3C
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,3C
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,64
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,96
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0F
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0F
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,2D
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,3E
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,57
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 15
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 70
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,0E
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,21
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
ENG119874-Gas_functionality,not active
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light
ENG119882-init_fuel_algorithm,No
ENG130585-Leaving_warning_delay,1.6 s
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0
ENG119825-Picture_Upload_Download,not active
ENG119876-Service_Key_Clear_All_Counter,Yes
ENG130584-Statistic_phev_mileage,5 km
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.6
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.0
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.0
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN
ENG112418-ENG99298-total_range_gas-State,not active
Elapsed Time: 00:32
19
	SW:6C0-909-901   HW:6C0-937-089 ---  CAN Gateway
	Component:GW MQB A0     H08 0086, Coding:030100044F0859007B000000040300010001000000000000000000000000
	EV_GatewA0Lear,013020,EV_GatewA0Lear_VW26.rod
	Monday,19,June,2017,21:26:11:46934
	VCID: 657226093BBF3B90DD-8030
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating
IDE00002-Transport mode,not active
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V
IDE01211-Static current measuring mode,not activated
IDE01457-Energy management deactivation stage,Mode not active
IDE01459-Energy management heat output control status,Mode not active
IDE01844-Increase idle speed request,Mode not active
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,--
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active
IDE01860-Generator specified voltage value variable,10.6 V
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway,1
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,Not coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,Not coded
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,coded
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded
IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1,Not coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded
IDE01996-ENG118234-Installation list: specified installations-Node_0x09,Not coded
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded
IDE02200-Component protection showroom mode,not active
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,VAO
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,660114E08N
IDE03903-Production process data 1,00 B7
IDE04159-Deactivation of start-stop function,Mode not active
IDE04186-Battery terminal recognition,connected
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error
IDE06530-Distance left for deactivation of static current measuring mode,2
IDE06541-Distance left for deactivation of transport mode,50
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,not activated
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,not activated
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,not activated
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,not activated
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,not activated
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,not activated
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,not activated
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,not activated
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,not activated
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,not activated
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,not activated
IDE07838-Counter for inconsistent states,1095
IDE08348-Start/stop start voltage limit,7.6 V
IDE08624-MKE Check box,activated
IDE10736-Cyclization limitation request battery service,0
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,not active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,0
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,0 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,0 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,0 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,0 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,0 ms
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,0 ms
ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active
ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active
ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active
ENG05988-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active
ENG05989-EM_nominal_voltage_limitation_low_beams,12.1 V
ENG05992-EM_requirement_cyclic_time_voltage_measurement,0 s
ENG05991-EM_requirement_reduction_air_blowers,Mode not active
ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C
ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C
ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled
ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled
ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled
ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled
ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled
ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled
ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled
ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled
ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled
ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled
ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled
ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled
ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled
ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled
ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled
ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled
ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled
ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled
ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled
ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled
ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled
ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled
ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled
ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled
ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled
ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled
ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled
ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled
ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled
ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled
ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled
ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled
ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled
ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled
ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled
ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled
ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled
ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled
ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled
ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled
ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled
ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled
ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled
ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled
ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled
ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled
ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled
ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled
ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled
ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled
ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled
ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled
ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled
ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled
ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled
ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled
ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled
ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled
ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled
ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled
ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled
ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled
ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled
ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled
ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled
ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled
ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled
ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled
ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled
ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled
ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled
ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled
ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled
ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled
ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled
ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled
ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled
ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled
ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled
ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled
ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled
ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled
ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled
ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled
ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled
ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled
ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled
ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled
ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled
ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled
ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled
ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled
ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled
ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled
ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled
ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled
ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled
ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled
ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled
ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled
ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled
ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled
ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled
ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled
ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled
ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled
ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled
ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled
ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled
ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled
ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled
ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled
ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled
ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled
ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled
ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled
ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled
ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled
ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled
ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled
ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled
ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled
ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled
ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled
ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled
ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled
ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled
ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled
ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled
ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled
ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled
ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled
ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled
ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled
ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled
ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled
ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled
ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled
ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled
ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled
ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled
ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled
ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled
ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled
ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled
ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled
ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled
ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled
ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled
ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled
ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled
ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled
ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled
ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled
ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled
ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled
ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled
ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled
ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled
ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled
ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled
ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled
ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled
ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled
ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled
ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled
ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled
ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled
ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled
ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled
ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled
ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled
ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled
ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled
ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled
ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled
ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled
ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled
ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled
ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled
ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled
ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled
ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled
ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled
ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled
ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled
ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled
ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled
ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled
ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled
ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled
ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled
ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled
ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled
ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled
ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled
ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled
ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled
ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled
ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled
ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled
ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled
ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled
ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled
ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled
ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled
ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled
ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled
ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled
ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled
ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled
ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled
ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled
ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled
ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled
ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled
ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled
ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled
ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled
ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled
ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled
ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled
ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled
ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled
ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled
ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled
ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled
ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled
ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled
ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled
ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled
ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled
ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled
ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled
ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled
ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled
ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled
ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled
ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled
ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled
ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled
ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled
ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled
ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled
ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled
ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled
ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled
ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled
ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled
ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled
ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled
ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled
ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain
ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ,not active
ENG05993-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00
ENG05994-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00
ENG05995-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00
ENG05996-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00
ENG05997-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00
ENG05998-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00
ENG05999-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00
ENG06000-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00
ENG06001-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00
ENG06002-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,not active
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,not active
ENG118779-ENG118723-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VW,not installed
ENG118779-ENG118722-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor,not installed
ENG118779-ENG109457-Multi_function_steering_wheel_control_module Coding Value-Tiptronic,not installed
ENG118774-WakeUpMonitor_Activation,not activated
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
Elapsed Time: 00:25
44
	SW:6C1-909-144-AG   HW:6C1-909-144-D ---  Steering Assist
	Component:EPS_TRW_ALow  312 3232, Coding:000700
	EV_SteerAssisUDSTRW,016026,EV_SteerAssisUDSTRW_SE26.rod
	Monday,19,June,2017,21:27:11:46934
	VCDS Version: Release 17.1.3  Data version: 20170602 DS267.2
	VCID: 6D7A16615B87CB489D-8038
IDE00820-Activating and deactivating all development messages,not active
IDE03724-Straight line running,active
IDE03734-Support power,100%
IDE04130-Characteristic curve of steering assistance,Driving profile selection button
IDE04555-Activation of pwr steering asst without engine running,not active
IDE05162-Software end stop,active
IDE06419-Driving profile switchover,Incremental: controlled over time
IDE07399-Engine type,large type 1
IDE07540-Download without rest bus,not active
MAS02080-XCP calibration protocol,active
Elapsed Time: 00:04
55
	SW:7P6-907-357-D   HW:7P6-907-357-A ---  Headlight Range
	Component:AFS-ECU       H07 0090, Coding:058A010003000000
	EV_HeadlRegulVWAFSMQB,001120,EV_HeadlRegulVWAFSMQB.rod
	Monday,19,June,2017,21:27:37:46934
	VCID: 404970F897F8D98DE5-8014
IDE03641-Presentation run dynamic AFS light,active
IDE03642-Presentation mode,not active
IDE03679-Adaptive light functions,not active
IDE03787-Activate left/right hand drive switch-over,not active
ENG100660-PWM to Level Scaling Factor Front,3.00 mm/%
ENG103748-PWM to Level Scaling Factor Rear,-7.20 mm/%
ENG103979-Reference_Run_Start_Condition,Engine start
Elapsed Time: 00:02
kickdown
Unverified
Auto Scan added:
VCDS Version: 17.1.3.0
VIN: VSSZZZ6JZGR080726   License Plate:
Chassis Type: 6J (6C0)
Scan: 01 02 03 08 09 10 15 17 19 44 55 5F
Address 01: Engine (J000-CUSB)       Labels: 04B-907-445-V1.clb
   Part No SW: 04B 906 027 D    HW: 04B 907 445
   Component: R3 1.4l TDI   H08 9153
   Revision: 21006001
   Coding: 01254032422401080000
   Shop #: WSC 00049 770 00209
   ASAM Dataset: EV_ECM14TDI03004B906027D 003029
   ROD: EV_ECM14TDI03004B906027D_SK26.rod
   VCID: 224F94BA3766A557DD-8076
Readiness: N/A
   Part No SW: 0CW 300 049     HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 6501
   Revision: 00043014    Serial number: CU501511247300
   ROD: EV_TCMDQ200021.rod
   VCID: 7AA7E4A2973E553F1D-802E
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08503581160109
   Coding: 11DD287D892B33C0091B106B0057881491CC90080007C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 37586AFB9B8D27EA35-8062
Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
   Part No SW: 6P0 907 044 B    HW: 6P0 907 044 B
   Component: Climatronic   H02 0202
   Serial number:  1512092A-1395
   Coding: 001000001001200001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_SK25.rod
   VCID: 305178807FA011354D-8064
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0086
   Serial number: 001588197593
   Coding: 08001A5042532AFB0BA44000B12707481001690257010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005_VW26.rod
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y16M01D05H19M05S31
   Coding: 00984D
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 801 DT    HW: 6R0 959 801 DT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0630
   Serial number: KU0KU019111553234062
   Coding: 1400A5
   Subsystem 3 - Part No SW: 6R0 959 802 EE    HW: 6R0 959 802 EE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0630
   Serial number: KU0KU014121553481690
   Coding: 0400A5
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY153273DNY
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064436026
   Subsystem 7 - Part No SW: 6R0 959 811 R    HW: 6R0 959 811 R
   Component: J388__TSG_HL  019 1112
   Serial number: 13102719160118224844
   Subsystem 8 - Part No SW: 6R0 959 812 R    HW: 6R0 959 812 R
   Component: J389__TSG_HR  019 1112
   Serial number: 13202718160118204646
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391600402324
   Coding: 0031151011
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 436C52C7ABC1EFBED5-8016
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag002 002 0380
   Revision: --------    Serial number: 003TJ0001HJ2
   Coding: 88CCC000000000005C0000CA000800000000
   Shop #: WSC 00049 770 00111
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B6462EF8BF9DF8615-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 271 001 16
   Component: SideSensor_Df  15B 0148
   Serial number: 3495R00C91D3F921C0D9
   Subsystem 2 - Part No SW: -----------    HW: 410 271 001 16
   Component: SideSensor_Pf  15B 0148
   Serial number: 3505R000C294C705538L
   Subsystem 3 - Part No SW: -----------    HW: 410 272 610 15
   Component: SideSensor_Dr  15B 0148
   Serial number: 3515R009D1D07263D3B-
   Subsystem 4 - Part No SW: -----------    HW: 410 272 610 15
   Component: SideSensor_Pr  15B 0148
   Serial number: 3525R009D1D07266214K
Address 17: Instruments (J285)       Labels: None
   Part No SW: 6P0 920 741 A    HW: 6P0 920 741 A
   Component: KOMBI         208 1422
   Coding: 072D09082980000800083A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 2E537C8647BA6D2B7D-807A
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001588197593
   Coding: 030100044F0859007B000000040300010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 658A0E612397D3A8A5-8030
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000A0827041215
   Coding: 002000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 53019K37552821416080
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CG190587
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW_SE26.rod
   VCID: 6D92FE5943FFE36065-8038
   Coding: 058A010003000000
   Shop #: WSC 00049 770 00137
   VCID: 406158D0BFD0F1A5CD-8014
   Subsystem 1 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 290000
   Subsystem 2 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 290000
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5QA 035 824     HW: 5QA 035 824
   Component: MU-S--ER      H24 0245
   Serial number: SEZAZ2S0002083
   Coding: 04520000BE02000011110001000808002F0201D40120010002
   ASAM Dataset: EV_MUStd6C3TSAT 001015
   ROD: EV_MUStd6C3TSAT_SE26.rod
   VCID: 7DA2DEA9832F43D0E5-8028
   Subsystem 1 - Part No SW: 5F0 919 604     HW: 5F0 919 604
   Component: ABTm_Std2  H44 1031
   Serial number: SEZ8Z9RLL0014U
End-------------------------(Elapsed Time: 03:11)--------------------------
