Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: 2005 MK4 Jetta 2.0 BBW creeping lean condition
    Jul 2014
    Check for exhaust leaks usually the flex. Check for cam correlation should be mvb 93. Usually BBW they don't set the cam timing properly. Also oil pressure dictates cam correlation. Check cam correlation while the engine is cold and after you've been on the freeway about 10 miles check it again actual vs specified.
  2. Likes brooklynt3ch11214 liked this post
  3. #12
    OP
    Also verify that there is sufficient fuel flow and volume by checking the filter that likes to plug up in the tank of these BBW cars.
    I am not liking what you posted for a MAF though...........put a genuine one in.
  4. Likes brooklynt3ch11214, ivagp liked this post
  5. #13
    Jun 2017
    Quote Originally Posted by ivagp View Post
    The timing belt has never been replaced on this car. Last I checked it was in good shape. Are they known to jump a tooth?
  6. #14
    Jun 2017
    OP
    Should I grab a Bosch MAF? I'll see about grabbing a filter. I need to grab a few tools to start checking fuel pressure and pull vacuum.
    Also, is it wise to grab a Bentley manual for my Jetta? Are they worth the price?
  7. #15
    I think a real Bosch MAF is a good idea or genuine from dealer.........lots of china garbage clones out there.
    Make sure this part #06A-906-461T
    Erwin and print to PDF after buying a day is the cheapest route for RTFB.
  8. Likes brooklynt3ch11214, ivagp liked this post
  9. #16
    Jul 2014
    Timing belt is a 60000 mile service on that car. You should change it if it's never been replaced
  10. Likes brooklynt3ch11214 liked this post
  11. #17
    Jul 2014
    No they're not known to jump they're known to be off because there is no timing mark on the cam gear you have to remove the valve cover and install some kind of a tool or make your own Gadget and loosen the cam sprocket. But lots of times people are just marking the cam gear and putting the belt back on it might be fine but you must check cam correlation on MVB 93 to verify
  12. Likes brooklynt3ch11214 liked this post
  13. #18
    Jun 2017
    Yes I've heard many horror stories dealing with timing on the BBW. As far as I know there's nothing timing related wrong with the car, but I'll double check cam and crank correlation again.
  14. #19
    Jun 2017
    What's MVB 93?
    *update* Was on phone and couldn't mouse over to determine is was Measuring Value Block.
  15. #20
    Jun 2017
    Okay I'll look up that part number. What's RTFB?
    *update* Was on phone and couldn't mouse over to determine is was Read The Fine Book lol
