Results 1 to 9 of 9
Thread: A6 BMK resetting learned values DPF
    New User
    Jun 2017
    Sweden
    Hallo,
    greetings from Sweden.
    I have a problem to reset values for DPF after it was cleaned (oil ash value 51 when Audi limitation is 49). When going to Long adaptation Channel 081 I can only set as new value 1 (not recommended 0001) and confirm it by Test, then Test value appear as "0" but both Test and Save stay disabled. Only when I try to set "0" the option "Save" is available. No changes to MVB 104 (oil ash, soot calc/meas and distance) occur. Any idea what is wrong or what I do wrong?
    Wednesday,21,June,2017,15:07:28:52626
    VCDS Version: 17.1.3.0 (x64)
    VIN: WAUZZZ4F26N179134   License Plate: AJX
    Mileage: 365180km-226912mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
              56 61 62 72 76 77
    VIN: WAUZZZ4F26N179134   Mileage: 365180km-226912miles
    Address 01: Engine        Labels: User\059-907-401-ASB.clb
       Part No SW: 4F0 910 401 S    HW: 4F0 907 401 C
       Component: 3.0L V6TDI  G000AG  0040
       Revision: --H02---    Serial number:
       Coding: 0011372
       Shop #: WSC 66565 257 00032
       VCID: 2C5D15EA8FC6A52165-8078
    009263 - Diesel Particulate Filter (Bank 1)
                   P242F - 001 - Restricted/Clogged - MIL ON
                        Fault Status: 11100001
                        Mileage: 365180 km
                        Date: 2017.06.21
                        Time: 14:58:15
                        (no units): 0.0
                        (no units): 32.0
                        (no units): 22.0
                        Temperature: 17.7°C
                        Absolute Pres.: 0.0 mbar
                        Pressure: 0 mbar
    Readiness: 0 0 1 1 1
       Part No SW: 4F1 910 156 S    HW: 09L 927 156 A
       Component: AG6 09L 3,0 TDI RdW 0020
       Revision: --H01---    Serial number:        4168926
       Shop #: WSC 02325 785 00200
       VCID: 346D0D8A57F6FDE13D-8060
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H05 0090
       Coding: 0020872
       VCID: 2D5B18EEB4DCAC2972-8078
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601000398730
       Coding: 0000131
       Shop #: WSC 40970 222 87061
       VCID: 63CFBED6A2982A5994-8036
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4F0 910 730 F    HW: 4E0 035 729
       Component: Interfacebox    H43 2120
       Revision: 00000000    Serial number: 350DO067668313
       Coding: 0001001
       Shop #: WSC 40972 222 86801
       VCID: 244DFDCAE7166D61AD-8070
       Component: Bedienteil MMIC6H08 0050
       Subsystem 2 - Serial number: 00000000380511
       Subsystem 3 - Serial number: 0131.03.060000000100011186ÿ
       Subsystem 4 - Serial number: 011186ÿ
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0170
       Revision: 00000030    Serial number: 00000030113313
       Coding: 0000278
       VCID: 5BBF86369AE81299DC-800E
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0190
       Coding: 0012121
       Shop #: WSC 02335 785 00200
       VCID: 2A5113F28532BB1197-807E
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Component: REGENLICHTSENSORH12 0090
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBF8092263
       VCID: 1C3DC52ADF6655A115-8048
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 42 AIRBAG AUDI8RH29 0280
       Revision: 08H29000    Serial number: 0037LD0DZT91
       Coding: 0013362
       VCID: 2953ECFE8034B0099E-807C
       Subsystem 1 - Serial number: 6332CSME11332564T
       Subsystem 2 - Serial number: 6342CSME10430931Q
       Subsystem 3 - Serial number: 6352QSME0D0C3941J
       Subsystem 4 - Serial number: 6362QSME0D412F5BT
       Subsystem 5 - Serial number: 63734SME0C7C2113$
       Subsystem 6 - Serial number: 63834SME0C2D7A115
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90055060930026
       Coding: 0002042
       Shop #: WSC 02323 785 00200
       VCID: 66C9A7C251AA5F7173-8032
       Part No SW: 4F0 910 930 A    HW: 4F0 920 931 F
       Component: KOMBIINSTR. M73 H17 0660
       Revision: 00400000    Serial number: 4PV515746
       Coding: 2049043
       Shop #: WSC 38060 000 1048576
       VCID: 2143F4DEF8047849C6-8074
    Address 19: CAN Gateway        Labels: 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 13008063278236
       Coding: ECFE73C41B3104
       Shop #: WSC 02334 785 00200
       VCID: 2757EAC69620867988-8072
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 C
       Component: MNS ECE         H45 1060
       Revision: 00000000    Serial number: 305IX057637817
       Shop #: WSC 02327 785 00200
       VCID: 3B7F26B67AA83299FC-806E
       Component: TSG FA          H12 0120
       Revision: 00-00000
       Coding: 0001642
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01012194340000
       Coding: 0139909
       VCID: 2E591FE2B9DAD7314B-807A
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 C    HW: 4F0 035 223
       Component: Amp.-ASK        H10 0320
       Revision: 34S00001    Serial number: 00404060250884
       Coding: 0000102
       VCID: 1E39CF22C97A47B1FB-804A
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Revision:             Serial number: 00000000133358
       Coding: 0001003
       VCID: 5EB98F2289FA07B1BB-800A
       Component: TSG BF          H12 0120
       Revision: 00-00000
       Coding: 0001642
       Part No SW: 4F0 910 801 A    HW: 4F0 907 801
       Component: EPB  CA3C0040   H03 0040
       Revision: --H03---
       Coding: 0000321
       Shop #: WSC 02324 785 00200
       Part No: 8P0 907 357 F
       Coding: 0000003
       VCID: 3D7B28AE64BC3CA9C2-8068
       Part No SW: 4E0 910 541 L    HW: 4F0 035 541 E
       Component: TUNER EU/US/RDW H42 0560
       Revision: 00000000    Serial number: 352DN067640617
       Revision: 00000000    Serial number: 00000000006274
       Shop #: WSC 02241 127 82691
       VCID: 234FFED6E2186A59D4-8076
       Component: von VA0  1603300690
       Coding: 344630393135313035442056413031363033333030363930
       Shop #: WSC 00000 384 00290
       Coding: 0001066
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0001066
       Part No SW: 4F0 910 283 E    HW: 4F0 919 283 E
       Component: Parkhilfe 8-Kan H12 0020
       Revision: 00H12000    Serial number: 11820608600592
       Coding: 0201016
       VCID: 2649E7C2912A9F71B3-8072
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H20 1130
       Revision: 00000000    Serial number: 00000005320156
       Coding: 0010920
    End-------------------------(Elapsed Time: 02:36)--------------------------
    Long Adaptation Channel 081:
    Stored value 0
    Test value 0
    Diesel Particle Filter (DPF) Replacement
    Address 01: DTCs cleared
    Address 01,4F0 910 401 S,channel 81,adapted from,0,to,0,
    Stored value 0
    Test value 0
    Why not? Are you actually typing 0001 into the New Value field? If so, what exactly happens?
    Maybe post some screen-shots?
    New User
    Jun 2017
    Sweden
    Trying both with 1 and 0001. I push Test then as Test value "0" appear, both "Test" and "Save" buttons are disabled.
    Only when change Test value to "0" I am allowed to Save after Test
    New User
    Jun 2017
    Sweden
    When going to Long adaptation Channel 081 I can only set as new value 1 (not recommended 0001) = when using "Up" & "Down" selection buttons. I can type 0001 into the window, but results as descripted above
    New User
    Jun 2017
    Sweden
    is it so that G450 (exhaust pressure sensor) reset must be done before any way first? DPF was not exchanged but only cleaned. G450 working correct (zero reading when key on engine off)
    If I am not mistaken, a software update for engine is necessary to use channel 81.
    Why do you think a cleaning, removes all ash
    You should also be able to use channel 82.
  7. Likes Uwe liked this post
    New User
    Jun 2017
    Sweden
    thanks NEtech, seems be you right, just find info about TPI2012786 - without engine software update no way to adapt channel 81 or recalibrate G450. I mind time to spend money by Audi
    Cleaning was done by professional company (measurement before and after process, warranty)
    Channel 82 - what it it function?
  9. #8
    Quote Originally Posted by Optron View Post
    Still, no one can tell if it is soot, ash (or items of the filter material!) or other items that are removed!
    My opinion is, if you want to drive a diesel, then buy a new (original) particulate filter, when it is necessary.
    Mileage of particulate filter divided 1000, used, if for example ECU is changed.
  10. #9
    New User
    Jun 2017
    Sweden
    well, if Audi (VAG) offer the new PDF to reasonable price yes, but I don't like to pay almost 2K EUR for it, except the labour cost where only flashing of new software is priced to just under 200 EUR (and can be done first in the middle of September). Cost of new pdf is close to 5% of new car in standard configuration, so it is difficult to say "reasonable",specially in my case for car driven over 360k km. I am happy that it happened first now, not by half of distance which is not common but usually.
    So I trust company which working only with this issue (regeneration of PDF), both for personal car but mostly for heavy equipment where this procedure is common. And I am very confuse about future as rumors about new regulations - requirement of pdf for petrol motors too.
    Why no "open PDF" (as in heavy trucks or construction machines) is installed in any personal car allowing removing & cleaning to reasonable cost for user?
