Results 1 to 10 of 12
Thread: 2017 Tiguan Seat Basic Setting
    Sep 2015
    AU/TH
    Hi Guys,
    I have a new Tiguan, only had it a few weeks.
    The seat memory for the drivers seat had been working fine and the seat and mirrors had been automatically setting themselves in accordance with the key used to open the drivers door. Recently this has stopped working. I can't even save a seat position using the memory buttons on the seat.
    The scan of module 36 reveals that it has somehow lost its basic setting. I had a similar issue with the rear cargo blind on my A6 Allroad and used the basic settings within VCDS to drive the blind through its full range of movement and the problem was solved. I thought the seat would be another straightforward procedure. Not so lucky.
    The basic setting gives me three options, the first of which is labelled "Norming" automatically runs the seat through its full range of travel, as expected, but has no effect on the problem and the fault codes reappear. The second option is "Reset to factory setting" but activating it gives an Error:Request out of range. The third option is "Resetting Standardization" but it seems to need a 0-3 digit code that VCDS doesn't know. Running it gives the same out of range error message.
    I read somewhere on the forum, Uwe suggested that VCDS wasn't used for basic settings for the seat and that all was required was to run the seat through the full range of travel in all axes so I tried this as well without success.
    I know the car is still under warranty, and I could just take it back to the dealer. Trouble is I'm certain its a quick fix but the dealer wants the car for the whole day and its 3 weeks until I can get an appointment. Its easier to launch a satellite into orbit.
    Any ideas anyone?
    Thursday,15,June,2017,15:48:18:54078
    VCDS Version: 17.4.2.3 (x64)  HEX-NET CB: 0.4341.4
    Data version: 20170505 DS270.4
    VIN: WVGZZZ5NZHW405800   License Plate: NBV72J
    Mileage: 3530km-2193mi   Repair Order:
    Chassis Type: 5N (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 52
              5F 6C 6D A5 BB BC CF
    VIN: WVGZZZ5NZHW405800   Mileage: 3530km-2193miles
    Address 01: Engine (J623-CHHB)       Labels: None
       Part No SW: 5N0 906 259     HW: 06K 907 425 B
       Revision: --H13---
       Coding: 092500322466050B3000
       ASAM Dataset: EV_ECM20TFS0205N0906259 001004
       ROD: EV_ECM20TFS0205N0906259.rod
       VCID: 72A83921A57C1FD70A-8026
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0DL 300 011 P    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2001
       Revision: 00H06V07
       VCID: 3522C23D949248EFEF-8060
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 60277000001739
       Coding: 0AEE939A54202371477F070062C34950C92AC4E2E046927D384250B8C2AA4200002F641A1B13111435351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 79BA0E0DF80A6C8F4B-802C
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0429866611
       Coding: 032C2C070F
       VCID: 3C34D719B7B899A710-8068
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98140687
    133124 - Databus
                        Reset counter: 157
                        Mileage: 2891 km
                        Date: 2017.06.12
                        Time: 10:49:34
    Address 08: Auto HVAC (E87)       Labels: 3V0-907-044.clb
       Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000E00406453
       Coding: 0012000420010000110510001210142A
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4AD881C1ED6C371792-801E
       Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number:       04031501850571
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
       Serial number: 02001703400452
       ROD: EV_BCMBOSCH_017_VW27.rod
       VCID: 7EB01D11E1244BB77E-802A
       Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
       Component: 326 RL 161201  033 0372
       Serial number: 00000001611280414593
       Component: RLHS  042 0105
       Serial number: S3Y17M02D13H21M37S04
       Coding: 00A8DD
    534549 - Databus
                        Reset counter: 128
                        Mileage: 298 km
                        Date: 2017.05.07
                        Time: 15:10:47
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H10 0021
       Serial number: 002601177478080
       Coding: 0331667851
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3B36D405B2B69E9F19-806E
    13679388 - Databus
                        Reset counter: 165
                        Mileage: 829 km
                        Date: 2017.05.26
                        Time: 20:00:33
    1112305 - Parking Sensor; Front Left Center
              U8EB251 F1 [008] - Reverberation Time too Long
                        Reset counter: 149
                        Mileage: 2280 km
                        Date: 2017.06.09
                        Time: 16:25:45
    1113328 - Parking Sensor(s); Front
              U8EB650 F0 [008] - Function Limitation due to External Factors
                        Reset counter: 140
                        Mileage: 1150 km
                        Date: 2017.06.05
                        Time: 16:13:45
    1080304 - Parking Sensor(s); Rear
              U8E3550 F0 [008] - Function Limitation due to External Factors
                        Reset counter: 157
                        Mileage: 2582 km
                        Date: 2017.06.12
                        Time: 07:41:45
    10494464 - Function Limitation due to Environmental Factors
              B2022 00 [008] -  -
                        Reset counter: 149
                        Mileage: 2280 km
                        Date: 2017.06.09
                        Time: 16:25:45
    Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
       Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0156
       Coding: 320047C358FF8428749C8065303085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001011
       ROD: EV_ACCMRRCONTIVW376_001_VW37.rod
    196741 - Sensor for Automatic Distance Control
                        Reset counter: 149
                        Mileage: 1855 km
                        Date: 2017.06.09
                        Time: 11:50:46
                        Voltage terminal 15: 12.7 V
                        Control Module temperature: 24 °C
                        Velocity_vehicle_reference: 28.96 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.22 m/s²
                        Status_ACC_System: ACC_activ_controlled
       Serial number: 21011741350073
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 383CCB098380B587F4-806C
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2JYSK3
       Coding: 98CCC0C00C0000005C540000008800000065
       VCID: 106C53A9CBB04DC79C-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 000 102 17
       Serial number: 357000000000D545B02C
       Subsystem 2 - Part No SW: -----------    HW: 480 000 102 17
       Serial number: 3580000000018999BF1-
       Subsystem 3 - Part No SW: -----------    HW: 480 400 902 17
       Serial number: 3510001A1244A733250I
       Subsystem 4 - Part No SW: -----------    HW: 480 400 902 17
       Serial number: 3520001A1244A734523N
       Subsystem 5 - Part No SW: -----------    HW: 480 400 302 17
       Serial number: 3550001C1246A8E4D158
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 902 17
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001BF244A735F3BH
       Subsystem 7 - Part No SW: -----------    HW: 480 401 002 17
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001A52465B3591D2
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 902 17
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001C1247FF93F429
       Subsystem 9 - Part No SW: -----------    HW: 480 000 502 17
       Serial number: I0M00000000FB16DF02H
       Subsystem 10 - Part No SW: -----------    HW: 480 000 502 17
       Serial number: I0N00000000A9884B128
       Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20170210201096
       Coding: 0C10
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB_VW37.rod
       Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
       Component: KOMBI         408 2170
       Coding: 27A400187F88000801887B0B1401000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 41CAA6EDD05AF44F43-8014
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Fault Frequency: 25
                        Reset counter: 159
                        Mileage: 1255 km
                        Date: 2017.06.08
                        Time: 11:43:22
       Component: GW MQB High   515 5286
       Serial number: 09021710520351
       Coding: 030500347F085900FB07225A9E0F00010001050000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F2EF05576CE723FA5-807A
       Serial number: 29170000163510017042
       Coding: 2DFFFF
       Serial number: 3943583004
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Serial number: HA1-00024.01.17
       Coding: 0101
       ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
       Serial number: 17000031089005
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 71AA362DA07A24CFF3-8024
    Address 36: Seat Mem. Drvr (J810)       Labels: None
       Component: Sitzmemory    H08 0021
       Serial number: Y0006QB414275
       Coding: 0014000000000500018281808181000000008181000000F400
       ROD: EV_SeatMemorDriveSide_002_VW48.rod
    7 Faults Found:
    9655636 - Motor for Seat Fore/Aft Adjustment
              B1355 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 125
                        Mileage: 3527 km
                        Date: 2017.06.15
                        Time: 14:23:31
    9655892 - Motor for Seat Backrest Adjustment
              B1356 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 165
                        Mileage: 3527 km
                        Date: 2017.06.15
                        Time: 14:23:42
    9655380 - Motor for seat height adjustment
              B1354 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 125
                        Mileage: 3527 km
                        Date: 2017.06.15
                        Time: 14:23:31
    9655124 - Motor for Seat Tilt Adjustment
              B1353 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 125
                        Mileage: 3527 km
                        Date: 2017.06.15
                        Time: 14:23:31
    9654868 - Motor for Lumbar Support Fore/Aft Adjustment
              B1352 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 125
                        Mileage: 3527 km
                        Date: 2017.06.15
                        Time: 14:23:31
    9654612 - Motor for Lumbar Support Height Adjustment
              B1351 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 125
                        Mileage: 3527 km
                        Date: 2017.06.15
                        Time: 14:23:31
    10489856 - No Basic Setting
              B2010 00 [009] -  -
                        Reset counter: 125
                        Mileage: 3527 km
                        Date: 2017.06.15
                        Time: 14:23:31
    Address 3C: Lane Change (J769)       Labels: None
       Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0310
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
       Serial number: 150117EAE04628
       Coding: 003F1B20D201040000000000
       VCID: 43C6ACE5CA46E65F51-8016
       Part No SW: 5QF 909 144     HW: 5QF 909 144 _
       Component: EPS_MQB_ZFLS  506 5572
       Coding: 9307
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 075E78F5BEFE0A7F4D-8052
       Serial number: 200117EAK03718
       Coding: 003F1120DE01040000000000
       VCID: 42C8A9E1D55CEF575A-8016
       Part No SW: 3G0 035 045 D    HW: 3G0 035 045
       Component: MU-H-N-RW     H51 0814
       Serial number: A688B0H2511982
       Coding: 02730608FF00000051510001000808001F0106E601200002DF
       VCID: 1F0E0095066EE2BF15-804A
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL0763H
       Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
       Component: ROW 2017  --- 0062
       Component: Gracenote2---  --- 4009
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
       Component: Areaview 2    H13 0607
       Serial number: C854707JG010057
       Coding: 01230600A20F200000204094
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
    Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 31127952600000
       Coding: 0A28
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H06 0271
       Serial number: 13021711K14115
       Coding: 000307060000010100022346C150A90084000E200020
       Shop #: WSC 12463 002 104857
       ROD: EV_MFKBoschMQBB_VW36.rod
    1135140 - Databus
                        Reset counter: 157
                        Mileage: 2582 km
                        Date: 2017.06.12
                        Time: 07:41:46
                        Control Module temperature: 38 °C
                        Outside air temperature: 9.5 °C
                        Vehicle speed: 16.23 km/h
                        System run time: 2170.2 s (second)
                        Voltage terminal 15: 13.0 V
                        mid: 02 65
                        Camera_state: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 1
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1135139 - Databus
                        Reset counter: 149
                        Mileage: 1150 km
                        Date: 2017.06.05
                        Time: 16:13:45
                        Control Module temperature: 40 °C
                        Outside air temperature: 18.5 °C
                        Vehicle speed: 58.45 km/h
                        System run time: 869.9 s (second)
                        Voltage terminal 15: 14.3 V
                        mid: 02 64
                        Software_Info_4: 1
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    Address BB: Door Rear Drv (J388)       Labels: None
       Serial number: 100117EAA00884
       Coding: 002A11200100040000000000
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 45C2B2FDC472D86F7F-8010
    Address BC: Door Rear Pass (J389)       Labels: None
       Serial number: 301216ELM27018
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
    End----------(Elapsed Time: 02:29, VBatt start/end: 12.5V/12.3V)-----------
    Quote Originally Posted by IsDon View Post
    Don: Hi - be very thankful that you got the "Error:Request out of range" message because successful execution of "Reset to factory setting" seems to have profound consequences.
    I've had a few distraught forum colleagues visit here after executing this option - what appears to happen (and I'm guessing) is that once this option is selected, the module forgets all (most?) for its basic setting values. I suspect (and I'm guessing, again) that the reference to "factory" means that the module reverts to the its state when taken from stock (i.e. before it was installed into the car).
    I would welcome RT's advice on what "Reset to factory" setting really does
    Don (the 2nd one)
    PS: Given the misleading and benign sounding title of this option and the ramifications of implementation - as well as the unlikely scenario for correctly using this option after the car is purchased, I reckon that implementing "Reset to factory" should be a two step process in RT's software: The first pass should be a warning message indicating the consequences of proceeding - only after the user has confirmed that he/she REALLY wants to continue, the software should allow the user to proceed to implementation - IMO
  3. Likes Uwe, IsDon, downtime liked this post
    Sep 2015
    AU/TH
    Sounds like I dodged a bullet there, thanks DV.
    Yes, reset to factory settings sound very innocuous, hence why I didn't hesitate to give it a shot. A reset to factory settings sounds exactly what was needed to fix my problem, or reinitialization which was the other option. Luckily neither of which worked.
    I'm still stuck though with an unresponsive seat. Is there anything else worth trying?
    Don: Alas I'm not aux fait with how (or even, if) VCDS does seat calibration. I'm aware that there is a "guided service process" for these functions in the dealer ODIS tool, but Uwe's advice is a telling harbinger of bad news - I suspect!
    I did manage to compare the code-string on your hex36 module with a new Tiggy in my database (taken from a VWWatercooled colleague of ours who visited here recently to have Traffic alerts implemented) and the two were the same. Also, I looked at the admap for the hex36 module and it is entirely unremarkable (has only two channels). How did you manage to lose the calibrations?
    Don (the 2nd one)
  6. Likes IsDon liked this post
    Sep 2015
    AU/TH
    Mate. I don't know.
    To tell you the whole story, when we first got the car the seat wasn't working.
    I plugged in VCDS and did the "Norming" thing in Basic settings which drove the seats through its full range of travel and it worked for 4 weeks without a problem. Now it's dumped its calibration for some reason but what I did last time no longer works.
    I tried running it numerous times in various states. Engine on, engine off, door open, door closed trying to replicate what I stumbled onto to fix it last time but I can't replicate the fix. So I know VCDS can fix it, just not sure how.
    Either that, or I'm starting to suspect that I actually have a faulty module. Either way it looks like a visit to the dealer is going to be required.
  8. Likes Uwe liked this post
  9. #6
    Verified VCDS User sasha's Avatar
    Oct 2016
    Australia
    @IsDon what was the fix in the end? I ran into the same problem with 2017 Skoda Kodiaq except seats were working fine then just stopped moving to preset positions 1,2 etc and when I connected the cable showed me the error of lost calibration...
                    Address 36: Seat Mem. Drvr       Labels: None
    Control Module Part Number: 5Q0 959 760 B    HW: 5Q0 959 760 B
      Component and/or Version: Sitzmemory    H08 0022
               Software Coding: 0014000000000500018281818181000000008181000000D400
                Work Shop Code: WSC 33361 790 00063
                  ASAM Dataset: EV_SeatMemorDriveSide 002021 (SK37)
                          VCID: 3C76B186B75588AF85-8069
                        Reset counter: 42
                        Mileage: 9238 km
                        Date: 2019.07.10
                        Time: 19:55:47
              B2010 00 [009] - -
                        Reset counter: 42
                        Mileage: 9238 km
                        Date: 2019.07.10
                        Time: 19:55:47
  10. #7
    Oct 2016
    Australia
    Sharing for everyone's benefit.. I've done the "Norming" and now have 6 faults vs original 2
    Tuesday,23,July,2019,14:22:09:15919
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
    VCDS Version 19.6.1.0
    VIN: TMBMD9NS9H8030910   License Plate:
                    Address 36: Seat Mem. Drvr       Labels: NONE
    Fault Codes have been Erased
    6 Faults Found:
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
              B2010 00 [009] - -
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
  11. #8
    Apr 2020
    Milan
    Quote Originally Posted by sasha View Post
    6 Faults Found:
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
              B2010 00 [009] - -
                        Reset counter: 64
                        Mileage: 9557 km
                        Date: 2019.07.23
                        Time: 14:21:37
    Hi, I have just installed the electric heated leather seats in the aftermarket for tiguan my2019.
    I also have the same problem. Could I know if you solved the problem and how? Thanks
  12. #9
    Apr 2018
    ITALY
    alright, so this has happened to my parents Octavia a couple of times, all these cars are MQB so the procedure should work.
    first of all, VCDS cannot do anything, and if you do the "reset" option you will wipe the parameterization from the module, which, trust me, you really don't want to.
    so basicaly just move the seat with the joystick, ALL the way forward and keep the joystick pressed until you hear a BING, then all the way back and keep the joystick pressed until you hear a BING. all of it with ignition on, of course. no need to move the seat back or lumbar, just the whole seat forward and back.
    it worked for me, good luck.
    my Golf left the factory with 18 ECUs. now she has 27. and counting
  13. Likes DV52, jyoung8607, downtime, Dana liked this post
  14. #10
    Dec 2016
    Amsterdam
    What i used to do is basically the same as darkchina posted above, except for releasing the button after the movement stops, then holding it again in the same direction. The seat will move a tiny bit further and then save that as the end point. Repeat for all directions of travel/all adjustable seat parts.
    Current:
  15. Likes downtime, darkchina811, Uwe, Dana liked this post
