Results 11 to 20 of 23
Thread: Led Bulbs in License Plate and Error Code
    United States
    Quote Originally Posted by Mexicano View Post
    Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
    Control Module Part Number: 5K0 937 087 AA HW: 5K0 937 087 AA
    Component and/or Version: BCM PQ35 H+ 121 0168
    Software Coding: 4C180A3E8037B0C042080080950089C442550008627D896000 8040000040
    Work Shop Code: WSC 04941 000 00000
    VCID: 74E7C4F9D726D4BE8FF-8021
    010 - Open or Short to Plus
    Ahh, this is exactly why the complete Auto-Scan helps We can tell what type of vehicle it is and most importantly which control modules are installed.
    This is a Mk6 PQ35 BCM so the Mk5 (2004-2009) suggestion and screen shot from Mari wouldn't apply to this vehicle and it is older than the MQB/Mk7 suggestion by pronet.
    Do NOT modify Byte 18 in this controller! Instead use the Long Coding Helper to enable License Plate Light w/o Pulse Width Modulation (PWM) [LED Light] and disable Lamp Monitoring (Cold) License Plate Lamps active followed by clicking [Do it!] and clearing faults to see if they operate fault-free in this particular BCM.
  2. Likes Uwe, jakematic, smartfleet liked this post
  3. #12
    Aug 2014
    Thanks Dana!
    Do You mean use the Long Coding Helper on the module 09 (Central Electronics)?????
    Thanks!
  4. #13
    Aug 2014
    This is the COMPLETE Auto-Scan Reading
    Monday,25,August,2014,09:49:09:40443
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: VSSCL61P6DR009143   License Plate:
    Mileage:    Repair Order: 08-25-14 Leon FR
    Chassis Type: 1P (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72 77
    01-Engine -- Status: Sporadic communication error 1000
    55-Xenon Range -- Status: Malfunction 0010
    Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
       Part No SW: 1P0 907 115 AD    HW: 1P0 907 115 Q
       Revision: AAH18---    Serial number:
       Coding: 0303000C18070160
       Shop #: WSC 66565 257 00032
       VCID: 6DD1D19D740C0576401-8038
    Readiness: 0010 0001
       Revision: 00H31001
       Coding: 143B601209220003280C06E8901C0041350800
       Shop #: WSC 04941 000 00000
       VCID: 7DF1E1DDE46C95F6F01-8028
                        Fault Status: 00101100
                        Reset counter: 243
                        Mileage: 5848 km
                        Count: 3
                        Count: 2
                        Count: 28672
                        Count: 48
                        Count: 43264
                        Count: 512
                        Reset counter: 243
                        Mileage: 5848 km
                        Date: 2022.14.01
                        Time: 15:27:02
                        Count: 16391
                        Count: 16896
                        Count: 88
                        Count: 43776
                        Reset counter: 243
                        Mileage: 5848 km
                        Date: 2022.14.01
                        Time: 15:27:02
                        Count: 16391
                        Count: 16896
                        Count: 72
                        Count: 43776
    02214 - Tire Pressure Warning
                        Reset counter: 249
                        Mileage: 5965 km
                        Date: 2022.14.21
                        Time: 10:59:58
                        Count: 32768
                        Count: 4608
                        Count: 397
                        Count: 50432
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:05
                        Count: 2
                        Count: 12288
                        Count: 8194
                        Count: 44032
                        Count: 63744
                        Count: 65533
       Part No SW: 5P0 907 044 T    HW: 5P0 907 044 T
       Component: Climatronic   H19 0909
       Revision: 00001001
       Coding: 0000000002
       Shop #: WSC 06402 785 00200
       ROD: EV_ClimaAutoBasis_SE35.rod
       VCID: 41895D2DD0143116D49-8014
    9473137 - Motor for Left Temperature Flap
              B108C 71 [008] - Actuator stuck
                        Reset counter: 232
                        Mileage: 5407 km
                        Date: 2013.14.13
                        Time: 18:08:43
              U1111 00 [008] - -
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:06
       Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
       Component: BCM PQ35 H+   121 0168
       Revision: BL121001
       Coding: 4C180A3E8037B0C042080080950089C442550008627D8960008040000040
       Subsystem 1 - Part No: 1P0 955 119 D
       Component: Wischer 15061  26  0611
       Coding: 00DB90
       Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A  Labels: 1P0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 02542E
       Subsystem 3 - Part No: 1P0 951 171 A
       Component: Innenraumuebe  010 4974
                        Fault Frequency: 129
                        Reset counter: 254
                        Mileage: 164 km
                        Date: 2003.14.13
                        Time: 08:49:14
                            Term 15 Off
                        Voltage: 12.75 V
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:07
                        Voltage: 12.15 V
                        Fault Status: 00101010
                        Fault Frequency: 22
                        Reset counter: 0
                        Mileage: 5791 km
                        Date: 2020.14.11
                        Time: 09:08:48
                            Term 15 Off
                        Voltage: 12.00 V
                        Reset counter: 252
                        Mileage: 5791 km
                        Date: 2020.14.11
                        Time: 11:24:02
                            Term 15 Off
                        Voltage: 12.00 V
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.17
                        Time: 13:24:24
                        Voltage: 14.05 V
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5P0 919 475 B    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H08 0008
       Revision: --------    Serial number: 36861216200377
       Coding: 000004
       VCID: 3A7B2AC1B5C262CE953-806F
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__A09 VW10 HI   2118
       Revision: 24017000    Serial number: 003L7PD18S4O
       Coding: 0012345
       VCID: 7CF7ECD93F769CFEC7F-8029
       Subsystem 1 - Serial number: 6332MTS637561572
       Subsystem 2 - Serial number: 6342MTS621481572
       Subsystem 3 - Serial number: 6351HTS61SPC5BKR
       Subsystem 4 - Serial number: 6361HTS687HU4BKR
       Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
       Revision: FF010041    Serial number: 20120616101733
       Coding: 108A140002
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 79F9F5CDF844A9D6DC9-802C
       Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H02 0102
       Coding: E20000
       Part No SW: 1P0 920 850 M    HW: 1P0 920 850 M
       Component: KOMBI         H03 0705
       Coding: 110F01
       ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
       VCID: 36633EF189DA86AE71B-8063
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:06
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 070612F2002678
       Coding: 350202
       VCID: 3F8D5BD5AEE047E6A2D-806A
                        Fault Status: 00110100
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:06
       Component: IMMO          H03 0705
       VCID: EADB5A810DE2924EA53-80BF
       Component: SG EXT.PLAYER H18 0530
       Revision: A1001003    Serial number: 7662787081
       Coding: 010100
       VCID: 2A5B1A814562D24EE53-807F
                        Reset counter: 252
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0507
       Revision: 12110009    Serial number: 0004933421
       Coding: 0010B0
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: EDD1519D3C0C8576C01-80B8
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 E    HW: 3C0 959 795 E
       Component: J388__TSG-HL  008 1501
       Serial number: 00000006807459
       Coding: 000090
    68108 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:06
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 142    3305
       Revision: 00H22000
       VCID: 377D33F546D07FA66AD-8062
                        Fault Status: 00101101
                        Reset counter: 243
                        Mileage: 5848 km
                        Date: 2021.14.30
                        Time: 19:13:18
                        Voltage: 11.88 V
                            DD
                        Temperature: 17.0C
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:06
                        Voltage: 12.13 V
                            DU
                        Temperature: 20.0C
                        RPM: 1498 /min
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0507
       Revision: 14110009    Serial number: 0004905415
       Coding: 0010B0
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: EED35691310A7E6EF9B-80BB
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704 E    HW: 3C0 959 794 E
       Component: J389__TSG-HR  008 1501
       Serial number: 00000006811336
       Coding: 000090
              U1111 00 [008] - -
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:06
    Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
       Coding: 2556933
       VCID: 346704F957A694BE4FF-8061
       Subsystem 1 - Part No: 7L6 941 329 C
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000039
       Subsystem 2 - Part No: 7L6 941 329 C
       Coding: 00000039
                        Reset counter: 252
                        Mileage: 6058 km
                        Date: 2023.14.20
                        Time: 10:04:06
                        Voltage: 11.93 V
                            ABS 1
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5P0 035 186 B    HW: 5P0 035 186 B
       Component: Media2.0      004 0082
       Revision: 01000001    Serial number: SEZ1Z3M5070574
       Coding: 01060410040000
       VCID: 2E531691798ABE6E39B-807B
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007662844679
       Coding: 0D10000000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A7B2AC1BDC262CE953-806F
    Last edited by Uwe; 08-27-2014 at 08:58 PM. Reason: Wrapped CODE tags around Auto-Scan
  5. Likes jakematic liked this post
  6. #14
    Aug 2014
    Hi Again,
    Seems like the Long Coding Helper on module 09 do not show options for License Plate Lights and or Lamp Monitoring :-(
  7. #15
    United States
    Both of the coding bits in question (License Plate Light w/o Pulse Width Modulation (PWM) [LED Light] and Lamp Monitoring (Cold) License Plate Lamps active) were updated in that lbl file back in 2012 (or so). Are you using a current VCDS release and clicking on each of the Byte numbers in row 3) to see the selectable options in all 30 Bytes as explained here?
  8. Likes Uwe, jakematic liked this post
  9. #16
    Aug 2014
    Hi Dana, I'm using the 12.12 version...I will try again...Module 09, right?..sorry...I'm a REAL NEWBIE with all this stuff :-)
  10. #17
    United States
    Yes, Address 09: Cent. Elect.
  11. #18
    Aug 2014
    Thanks Dana!...I will check again ASAP
  12. #19
    Aug 2014
    Thanks for all the help Dana!...I did it!!
  13. Likes Uwe, jakematic liked this post
  14. #20
    NC USA
    Dana knows her stuff!
    Please post a fresh Auto-Scan so others can see. Thanks-Jake
  15. Likes Uwe liked this post
