Results 1 to 5 of 5
Thread: Jetta Sportwagen byte 18 issues
    Apr 2015
    Edit: If someone has the mk6 bixenon LED headlamp configuration in your BCM for a jetta sportwagen/golf variant please post your Address 09 coding
    Hello, I am writing to solicit some help in getting the LED DRLs to work on my 2013 Jetta Sportwagen. The compatible Bixenon LED headlamps were recently retrofitted to the car along with some other components including AFS, high beam assist, and park assist. I am pretty sure it is a byte 18 issue in J519 and have read about byte 18 issues:
    http://forums.vwvortex.com/showthrea...8-issues-(MK6)
    http://forums.ross-tech.com/showthre...-Coding-tweaks
    My own troubleshooting hasn't been able to activate either side, the wiring follows the schematic (with no shorting) and I got some help from here: http://forums.ross-tech.com/showthre...FS-retrofitted.
    Two scans are attached, the first is prior to any part fitment for a baseline and the second is most recent last night. Some faults appear to occur because the car was just put back together.
    Any help to activate the LED DRLs is greatly appreciated, thanks!
    Auto-Scan baseline:
    Tuesday,02,September,2014,19:17:39:62128
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140822
    VIN: 3VWML7AJ0DM693810   License Plate:
    Mileage: 15160   Repair Order:
    Chassis Type: AJ (7N0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72 77
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 HB    HW: 03L 907 309 AA
       Component: R4 2,0L EDC G000SG  4817
       Revision: 12H15---    Serial number:
       Coding: 0050072
       Shop #: WSC 00066 000 00000
       VCID: 72C534446D5D918E9D9-8027
       Revision: 00H31001
       Coding: 114B600C492B00FD881306E592190042B70000
       VCID: 7DDF1778E403DEF6F0B-8028
    01550 - Signal for Reverse Gear
                        Reset counter: 139
                        Mileage: 21876 km
                        Date: 2012.14.06
                        Time: 21:52:02
                        Count: 16384
                        Count: 32768
                        Count: 12800
                        Count: 202
                        Count: 49664
                        Count: 253
                        Count: 1024
                        Reset counter: 145
                        Mileage: 22335 km
                        Date: 2012.14.20
                        Time: 00:00:32
                        Count: 16386
                        Count: 2
                        Count: 12800
                        Count: 16390
                        Count: 50432
                        Count: 765
                        Count: 12544
    Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 00066 000 00146
       ROD: EV_ClimaBasis_SE36.rod
       VCID: 75CF0F58D43386B6B8B-8020
       Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
       Component: BCM PQ35 B    021 1068
       Revision: BG021001
       Coding: 2F380E1F802F3EC4008800C17000004449000086535D0560648020200040
       VCID: 3957C368B0AB22D69C3-806C
       Component: Wischer 08061  26  0512
       Coding: 009795
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R01WPH1
       Coding: 00004E42
       Shop #: WSC 00066 790 00185
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C59DA7CB79917FE875-8069
       Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
       Component: BF-Gewichtss.  006 0001
       Serial number: ---0000R--000079S600
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME33031378ZZZL
       Crash sensor for side airbag; passenger side:
       Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME6E0A1378ZZZ0
       Crash sensor for side airbag; rear driver side:
       Serial number: 3511HSME0C714A2FZZZW
       Crash sensor for side airbag; rear passenger side:
       Serial number: 3521HSME6106402FZZZG
       Serial number: 35527SME35593B2FZZZT
       Crash sensor for front airbag; passenger side:
       Serial number: 35627SME316B3B2FZZZT
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number:  90440MF40017L
       Coding: 108A140000
       Shop #: WSC 00066 000 00184
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 72C53444A55D918E9D9-8027
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0204865 FLE 20130410
       Coding: 820000
       Part No SW: 5K0 920 973 C    HW: 5K0 920 973 C
       Component: KOMBI         H05 0705
       Coding: 270F01
       Shop #: WSC 00066 000 00120
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 3147FB4860DBEA96243-8064
       Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
       Component: J533  Gateway H50 1634
       Revision:   H50       Serial number: 08061303290220
       Coding: 352002
       VCID: 76CD0854C1358DAEB11-8023
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RNHRR07
       VCID: FEDD9074A90545EE691-80AB
       Component: IMMO          H05 0705
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EAF5AC240D8DD94EA59-80BF
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664571695
       Coding: 010100
       VCID: 2A75EC24450D994EE59-807F
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 3753C55046BF34A66A7-8062
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
       Component: EZE_2         H50 1634
       Coding: 050B0500
       VCID: EFC3BD303E6F3C66F27-80BA
       Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H05 0220
       Component: J394EE20SKB13  H05 0220
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0501
       Revision: 15110009    Serial number: 0006885944
       Coding: 0004B4
       Shop #: WSC 01383 790 50316
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: DC99FAFCD7D9B7FE275-8089
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1509
       Serial number: 00000007813157
       Coding: 000490
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
       Component: Radio Prem-8  H05 0008
       Revision: -----09S    Serial number: VWZ4Z7N3493697
       Coding: 0100044004000C
       VCID: 2B7BE9204AF780461EF-807E
                        Reset counter: 127
                        Mileage: 576 km
                        Date: 2004.14.07
                        Time: 09:32:23
    Auto-Scan current
    Monday,13,April,2015,21:59:56:62128
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    Dealer/Shop Name: Ross-Tech LLC.
    Workshop Code: 123 00066 000120
    Mileage: 32490km-20188mi   Repair Order:
    Scan: 01 03 08 09 10 15 16 17 19 1C 20 25 2E 42 44 46 4F 52 55 56
              62 72 77
    VIN: 3VWML7AJ0DM693810   Mileage: 32490km-20188miles
    2E-Media Player 3 -- Status: Malfunction 0010
       Coding: 0050072
       VCID: 72C534446D5D91B168B-8027
       Revision: 00H31001
       Coding: 114B600C492B00FD881306E592190042B70950
       Shop #: WSC 00066 123 12345
       VCID: 7DDF1778E403DEC9059-8028
                        Reset counter: 41
                        Mileage: 32495 km
                        Date: 2015.04.13
                        Time: 00:01:46
                        Count: 2
                        Count: 2
                        Count: 20480
                        Count: 16390
                        Count: 43008
       Revision: 00009001
       Coding: 0000001002
       ROD: EV_ClimaBasis_VW32.rod
       VCID: 75CF0F58D43386894D9-8020
    13701936 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 81
                        Mileage: 32495 km
                        Date: 2015.04.13
                        Time: 00:05:52
       Part No SW: 5K0 937 087 AD    HW: 5K0 937 087 AD
       Component: BCM PQ35 H    122 0173
       Revision: BK122001
       Coding: 2F380E1FC02F3EC4008800C9710089EC49FD0386537D0560E48428240040
       Shop #: WSC 00066 123 00120
       VCID: 77D30550C63FF4995F5-8022
       Coding: 009F95
       Component: RLS 080213 05  54  0403
       Coding: 0330AD
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 41
                        Mileage: 32495 km
                        Date: 2015.04.13
                        Time: 01:17:41
                            Term 15 On
                        Voltage: 11.65 V
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0043
       Revision: --------    Serial number: 56231324503272
       Coding: 340003
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_EPHVA2C000000000 002014
       ROD: EV_EPHVA2C000000000_SE36.rod
       VCID: 4BBB89A0E237A079CBD-801E
    12658720 - Databus
                        Reset counter: 41
                        Mileage: 32494 km
                        Date: 2015.04.13
                        Time: 16:40:06
       Coding: 00004E42
       ROD: EV_AirbaVW10SMEVW360_SK35.rod
       VCID: 3C59DA7CB79917C1727-8069
       Coding: 108A140000
       VCID: 72C53444A55D91B168B-8027
       Coding: 820000
       Coding: 170D01
       VCID: 3147FB4860DBEAA9D11-8064
       Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1642
       Revision:   H56       Serial number: 130314F1002211
       Coding: 352002
       VCID: 7CD91A7CFF19D7C1327-8029
                000 -  -  - Intermittent
                        Mileage: 32495 km
                        Date: 2015.04.13
                        Time: 00:09:43
       VCID: 7EDD10742905C5D11C3-802B
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
       Component: FLA           H04 0006
       Revision: AA001002
       Coding: 02018C6B74745D545420363E00
       VCID: 2D7FE73874E38E49F59-8078
       VCID: 6AF52C248D8D5971D0B-803F
       Coding: 010100
       VCID: 2A75EC24450D997110B-807F
                        Reset counter: 78
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0501
       Revision: 13110009    Serial number: 0006827757
       Coding: 0004F5
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 5B9B79E052D730F95BD-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1509
       Serial number: 00000007882957
       Coding: 000490
       Revision: 00H22000
       VCID: 3753C55046BF34999F5-8062
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.0 V
                            PD
                        Temperature: 21.0∞C
                        Count: 2
                        Steering Angle: 0.00∞
                        Count: 1
                            SteerAng n.Init
       Component: EZE_2         H56 1642
       Coding: 050B0500
       VCID: 6FC33D30BE6FBC59875-803A
    01512 - Control Module for Sliding Roof
                        Reset counter: 81
                        Mileage: 32494 km
                        Date: 2015.04.13
                        Time: 16:39:48
       Coding: 0004B4
       VCID: 5C997AFC57D937C1527-8009
       Slave Passenger:
       Coding: 000490
       Coding: 1446940
       VCID: 3449F25C57C9DF81BA7-8061
       Subsystem 1 - Part No: 7L6 941 329 B
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B
       Coding: 00000022
       Coding: 01000440040007
       VCID: 2B7BE9204AF78079EBD-807E
                        Reset counter: 81
                        Mileage: 32494 km
                        Date: 2015.04.13
                        Time: 16:31:24
                000 -  -
                        Reset counter: 41
                        Mileage: 32494 km
                        Date: 2015.04.13
                        Time: 16:31:18
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007664666994
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A55DC64BDAD29F160B-806F
    End-------------------------(Elapsed Time: 02:36)-------------------------
  2. Likes Uwe liked this post
  3. #2
    Apr 2015
    The software revision for the highline BCM I installed seems to be the problem.
    Revision: BK122001
    I know this issue has been covered before, but perhaps someone can confirm that 0173 is the software revision of the highline BCM from my second auto scan above? It seems quite low for a module produced in late 2012. I would have expected a revision at least 575 and that is required for the LED DRLs... VWoA strikes again!
    Yep, 0173 is definitely the software version in your BCM. However, I do not know whether a newer version would be helpful.
    Apr 2015
    Just wanted to share some updates here for other folks who are planning/doing a bixenon LED with AFS headlight conversion to their Jetta Sportwagen. You might also have byte 18 issues associated with it.
    LED DRLs:
    I currently have limited functionality of the LED DRLs. They operate fine as DRLs, and the lower orange side marker lights are bright. I also set it up so they work only in "auto" position (assistance driving DRL, can’t remember which byte). My LEDs do not dim but turn off completely when the headlights are on, similar to operation of the stock halogens. When the headlights are on and the DRLs are off the orange side marker lights are dimmed substantially.
    It seems to be more than just software version for the BCM for the LED DRLs to work at factory functionality. VW has utilized software in the NAR BCMs that appears to differ from the ROW and therefore finding the correct BCM which dims, turns off with turn signal etc. is tough. I think that there are just a select few BCM versions/revisions (possibly older and not newer manufactured for replacements from the dealer) that have the proper software to drive the LED DRLs properly. VW stopped manufacturing the Golf wagon ROW like ours in late 2012 I think. This swap has everything to do with obtaining the correct BCM, I used the 5K0 937 087 G Z5Y.
    Byte 18:
    You can see how mine is coded in the auto scan below. I reconfigured to allow for a rear fog light and single reverse light. No bulb light errors.
    AFS:
    My AFS works fine set to Golf coding but I would like adjust it to be more “sensitive” to steering, particularly at low speeds.
    Has anyone been able to achieve LED DRL dimming at low beams retrofitted in a Jetta Sportwagen? If so can you please share your code?
    Also, can someone recommend a more “aggressive” AFS module code to enable more movement of the headlights who has done this on a Mk6 Jetta Sportwagen?
     Saturday,11,July,2015,09:27:19:62128
    Mileage: 35610km-22127mi   Repair Order:
              62 72 77
    VIN: 3VWML7AJ0DM693810   Mileage: 35610km-22127miles
       Coding: 0050072
       Revision: 00H31001
       Revision: 00009001
       Coding: 0000001002
       Part No SW: 5K0 937 087 G    HW: 5K0 937 087 G
       Component: BCM PQ35 H+   111 1129
       Revision: BL111001
       Coding: 2F380E3FC82F3EC400080088710089C4497D0486537D05B0E98068040040
       VCID: 3957C368B0AB22E9691-806C
       Coding: 009F95
       Coding: 0730AD
       Coding: 340003
    12658720 - Databus
                        Reset counter: 111
                        Mileage: 35618 km
                        Date: 2015.07.11
                        Time: 09:19:17
       Coding: 00004E42
       Coding: 108A140000
       Coding: 820000
       Coding: 170D01
       Coding: 352002
       Revision: AA001002
       Coding: 010100
       Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
       Component: TUER-SG FT    002 0307
       Revision: 12101005    Serial number: 0000206824
       Coding: 0015F6
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide.rod
       VCID: 2871162C5301AB6106F-807D
       Slave Driver:
       Coding: 000490
       Revision: 00H22000
       Coding: 050B0500
       Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
       Component: TUER-SG BT    002 0307
       Revision: 14101005    Serial number: 0000351841
       Coding: 0015F6
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 29771328480B9269191-807C
       Slave Passenger:
       Coding: 000490
       Coding: 1446940
       Coding: 00000022
       Coding: 00000022
                000 -  -
                        Reset counter: 111
                        Mileage: 35618 km
                        Date: 2015.07.11
                        Time: 09:19:43
       ROD: EV_UHVNA.rod
    End
  6. Likes Uwe liked this post
    Apr 2015
    A final update on this. For those who have a 2013 Jetta Sportwagen and wish to add the LED DRL bixenon headlamps, here is my coding for full factory functionality. The magic byte 18 was "4E" for my installation.
    Revision: BK122001
    Coding: 2F380E3FC82F3EC400080088710089EC47FD4E08537D0560E4 806024A040
    VCID: 77D30550C63FF48667-8022
    Coding: 009F95
    Coding: 0730AD
  8. Likes Dana, Uwe liked this post
