VCDS Support for new VW Polo 6C
   #61
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Keith, the MK60EC1 coding table doesn't apply here.
bluey
Australia
C?ID=204201
Hello, not quite sure if this is the correct forum to ask this in but the cars concerned are both Polo 6C.
I've done an autoscan on my and my mother's new Polos (one's an SE, the other SEL) and both have come up with the following fault:
590081 - Control Circuit for A/C Compressor
B10A9 11 [012] - Short to Ground
I had the same fault. Ignored it. I presume that comes up if the engine is off, since the compressor does not want to run if the engine is off.
   #64
sportmotor
Czech Republic
C?ID=14747
I strongly disagree, the MQB/PQ37 coding table doesn't have the same layout as the PQ26. If things would be as easy, they would be done already. Please understand that I am working not just on the PQ26 but also on other models/platforms, meaning I cannot focus all my attention towards you but instead need to please other customers as well. ;)
You're probably right but except Byte 3 Climate control, Byte 5 bit 6 it looks like OK, see pictures.
   #66
kreativ
Hidden
C?ID=108852
I can also confirm that it works for my polo 6c with modified label file
Awesum
South Africa
C?ID=40265
Hi, I need help with getting my rain closing working on my Polo GTI 6C.
I've done most of the coding using the Golf 7 guide and everything except the RLS coding worked.
My RLS coding is different from the Golf 7.
This is my Cent. Elect. module coding:
VIN: WVWZZZ6RZFY330150   License Plate: POLO GTI
Mileage: 242km-150mi
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 001098127020
   Coding: 03101A5040530A7B0BA44080B12F078010005B0057010000000000000000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_BCMA0_VW26.rod
   VCID: 2F6863D4763A3D59C75-807A
   Slave 2:
   Subsystem 1 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A
   Component: RLS  037 0059
   Serial number: S3Y15M04D20H09M38S28
   Coding: 9038DD
   Subsystem 2 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU018021550490665
   Coding: 1000A0
   Subsystem 3 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU027021550583735
   Coding: 0000A0
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1503339D0
   Serial number: 00000000000062008281
   Subsystem 6 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H03 0004
   Serial number: 0000FST0009EQ3G00000
   Coding: 181001
   Subsystem 7 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serial number: KU0KU022041551121605
   Coding: 1000A0
   Subsystem 8 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serial number: KU0KU002041550923426
   Coding: 0000A0
Awesum
South Africa
C?ID=40265
Here is a complete autoscan. I've made a few other changes using the Golf 7 guides.
Tuesday,28,July,2015,16:34:06:10097
VCDS Version: 14.10.2.0
Data version: 20150311
Mileage: 242km-150mi   Repair Order: new 1st scan
Chassis Type: 6R (6C0)
Scan: 01 02 03 08 09 15 17 19 44 55 5F A9
VIN: WVWZZZ6RZFY330150   Mileage: 242km-150miles
Address 01: Engine (J623-DAJB)       Labels: None
   Part No SW: 6C0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 09250012242400080000
   ASAM Dataset: EV_ECM18TFS0206C0906264 001004
   ROD: EV_ECM18TFS0206C0906264.rod
   VCID: 64C2DCF86F7CCE01EA7-8031
   Part No SW: 0CW 300 046 S    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0307
   Revision: 00005005    Serial number: CU501503297559
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 4A9E1240ED987871F0B-801F
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08509261150419
   Coding: 24DD68858B2633C00915006E00512416D1CC90000012E7098700
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
   VCID: 33606FA49A1219B9A3D-8066
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H03 0108
   Serial number:  1504151B-1755
   Coding: 200000010000000000
   ROD: EV_ACManueKMMValeoPQ26_SE25.rod
   VCID: 1D34A91C0C96BFC9659-8048
   Slave 2:
   Coding: 9038DD
   Coding: 1000A0
   Coding: 0000A0
   Coding: 181001
   Coding: 1000A0
   Coding: 0000A0
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 G    HW: 6C0 959 655 G
   Component: VW20Airbag00T 001 0360
   Revision: --------    Serial number: 003RK00010S-
   Coding: 88C0C00000800000000000CA008800000000
   ROD: EV_AirbaVW20BPAVW26X_SK26.rod
   VCID: 37785BB48E6AF5999F5-8062
   Subsystem 1 - Part No SW: -----------    HW: 410 820 904 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C51998AB311CX
   Subsystem 2 - Part No SW: -----------    HW: 410 820 904 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00B519E60B3334M
   Subsystem 3 - Part No SW: -----------    HW: 442 153 004 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00AB19EAD15C0C
   Subsystem 4 - Part No SW: -----------    HW: 442 153 004 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00B319EACE3B25-
   Part No SW: 6C0 920 746     HW: 6C0 920 746
   Component: KOMBI         252 0310
   Coding: 232D09082980000800082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW26.rod
   VCID: 65C4C1FC6446B709FD9-8030
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001098127020
   Coding: 010100083000590071000028180000000001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_VW26.rod
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C
   Component: E221__MFL-DC1  H03 0102
   Serial number: 29150000435860085102
   Coding: 31FFFF
Address 44: Steering Assist (J792)       Labels: Redir Fail!
   Part No SW: 6C2 909 144 AA    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3224
   Serial number: CF4U1397
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_VW26.rod
   VCID: 68DAC8C89354AA61C6F-803D
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 0D0E000001000000
   ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
   VCID: 75E491BCD4E647894D9-8020
   Part No SW: 3Q0 035 819     HW: 3Q0 035 819
   Component: MU-S--ER      H11 0138
   Serial number: VWZAZ2R0115102
   Coding: 02620000BE00000011110001000918001F0203860120010001
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 6ED6BED0B1B074518C3-803B
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H43 1017
   Serial number: VWZ8Z9RH002JXE
7177 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 51
                    Mileage: 91 km
                    Date: 2015.07.24
                    Time: 16:10:37
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 6C0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 150424201452
   VCID: 295C8DCC48DE5369191-807C
End-------------------------(Elapsed Time: 02:56)--------------------------
   #69
DV52
C?ID=194404
Awesum: Hello!
It's not surprising that the your sensor coding is different from that of the mk7 and I 'm sure that it also doesn't help that the BCM on your (very new) car doesn't as yet have a label file - likely work-to-be-done by the staff at RT in the near future. Anyway, just out of curiosity and because of the MQB-ish nature of your Polo 6C, here are the screen shots for the rain-light sensor on my mk 7 showing how the coding values change (please note that these pictures are for an RLFS: Part No SW & HW 5Q0 955 547 - label file 5Q0-955-547.CLB)
My default coding is 00A8DD and yours is 9038DD
Byte00 on your car is binary 1001 0000 (Hex90). Notice that the Auto Rain Close facility is enabled by setting Bits 1 and 2 (i.e. thereby making the lower nibble of Byte 00 equal to Hex6)
On my sensor, the higher order Bits for Byte 00 appears to deal with the light activation threshold. Although the "LCode" descriptor for the higher order Bits in Byte 00 says that light activation threshold is set by Bits 3-5, I suspect that this is in error and that it really meant to say Bits 3-7. My hypothesis is base on the fact that the Hex values shown on the pull-down panel for Byte 00 can't be defined by only 3 x Bits (i.e. Bit 3, Bit 4, & Bit 5). For example, for a Light activation threshold earlier (+20%), it takes 5 x binary Bits to specify the Hex value 08 (i.e. 01000). So, the LCode description for the Higher nibble plus Bit 3 should have said Bits 3-7 (I think). This is a long-winded way of saying that your value of Hex90 for Byte 00 could be some variant of the light activation thresholds shown on my screens (Just guessing)
As for Byte 1-2, my sensor seems to define the type of vehicle for these Byte, so Hex 38DD may well be the code for a Polo 6C.
Anyhow, just food for thought - I think
cheers
Awesum
South Africa
C?ID=40265
Thank you for the valuable information.
I tried ticking Bit 1 and 2 of byte 00, but the rain closing didnt work, so I changed it back to its default settings.
   #71
Awesum
South Africa
C?ID=40265
I was hoping that the new version of VCDS would have some labels for the Polo 6C. :(
   #72
SI-R32
C?ID=99715
Hi everyone
a friend of mine has a 2014 polo and has the inspection service interval up, he also had the standard service interval up but has reset this from the cluster in the usual way, we can not however reset this
so using the SRI function of VCDS doesn't work due to a message like "this uses upd protocol please goto into instruments 17 and reset from there", so i try all of the things listed in next pic
but everytime i try and reset or change a figure it just gives a message "Out Of Range" does anyone know how to reset this message? any help greatly appreciated
VCDS Version: Release 15.7.0 Running on Windows 7 x86
Data version: 20150729
Thursday,10,September,2015,15:17:01:44907
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZEU043001   Mileage: 30150km-18734miles
Address 01: Engine (J623-CGPB)       Labels: None
   Part No SW: 03E 906 019 AK    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 5151
   Revision: --H03---    Serial number:
   Coding: 00110016002400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12MPI02103E906019AK 001003
   ROD: EV_ECM12MPI_SE25.rod
   VCID: 6DD5AC02BC3E95568D-8038
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Coding: 23DD2485212700C3C4142469845200800905
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: N/A
   VCID: 0F29D68AD6F20746DF-805A
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW26)
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397D4852B0F6F9F651-806C
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 P    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0411
   Revision: BF034001    Serial number: 0581 334130403
   Coding: 24B42BBF08E12400923008002D2B0CD000C0410F60060000200020000000
   VCID: 4A9F079EE510626EC8-801E
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8611
   Coding: 1000A0
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Coding: 0000A0
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Coding: 0000A0
   Component: J389__TSG_HR  003 8610
   Coding: 1000A0
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47331335300691
   Coding: 108001
   ASAM Dataset: EV_VW250ParkiAssis2 S01008
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E775B4EA1D8DECE64-806A
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H10 0020
   Revision: --------    Serial number: 003GX01ZN75.
   Coding: 003237
   Shop #: WSC 31414 790 31414
   ROD: N/A
   VCID: 4A9F079EED10626EC8-801E
   Subsystem 1 - Serial number: 3575HRB401A50M5K810M
   Subsystem 2 - Serial number: 3585HRB400M50M5KJ8V/
   Subsystem 3 - Serial number: 3515RRB400G50Q3OHOQ9
   Subsystem 4 - Serial number: 3525RRB401C50QDKPP73
No ASAM data for: "EV_AirbaVW10BPAVW250" (VW26)
   Part No SW: 6R0 920 960 M    HW: 6R0 920 960 M
   Component: KOMBI         H04 0709
   Coding: 140A01
   VCID: 3F89264AA6D2D7C66F-806A
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0411
   Revision: BF034001
   Coding: 002300
   VCID: 70EBB576A30C78BEA6-8024
   Component: IMMO          H04 0709
   VCID: 6ADFA71E8DD0826EE8-803E
   Revision: A1001003    Serial number: 7665647450
   Coding: 010100
   VCID: 2B51621A4AAA5B66D3-807E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11250
   Shop #: WSC 31414
   VCID: 306B7576F78C38BEE6-8064
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  004 0119
   Revision: 01000001    Serial number: VWZ1Z2P0256329
   Coding: 01000400020001
   VCID: 356544629CEE1D96B5-8060
End-------------------------(Elapsed Time: 02:36)--------------------------
Can you make an Adaptation Channel Map please?
[Applications]
[Controller Channel Map]
- Controller Address = 17
- Login or security code: Leave blank
- Function: Adaptations
- Output: CSV File
[Go]
SI-R32
C?ID=99715
[Applications]
- Output: CSV File
[Go]
will do, will post up thurs or fri
cheers
Andy
Sector 7G
HC424490
We got your CSV, thanks!
Some relevant bits:
ESI: Resetting ESI Reset
FIX: Distance covered since last mileage-dependent inspection 30300 km
FIX: Time since last time-dependent inspection 519 d
Try setting each of the above FIX ones to zero and let us know the result.
   #76
SI-R32
C?ID=99715
Sadly still not been able to try on car due to work commitments, really appreciate response and as soon as I can try I'll let you know how I got on
   #77
trs
New Member
HC453194
Hi.
Any new labelfiles on the way for the 6C?
   #79
listek2000
C?ID=226096
Hallo, i have the same issues with aircondition in VW Polo 1.4tdi 2015 (6C)
the first time it was a fuse, now everything is ok but...
one time i have cooling and once I dont have :(
I have an appointment on Wednesday in VW Service
Friday,22,July,2016,20:24:15:21845
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ6RZFY184606   License Plate: BC88982
Mileage: 24763km-15387mi   Repair Order:
Scan: 01 03 08 09 13 15 17 19 44 5F
VIN: WVWZZZ6RZFY184606   Mileage: 24763km-15387miles
Address 01: Engine (J000-CUSA)       Labels: 04B-907-445-V1.clb
   Part No SW: 04B 906 027     HW: 04B 907 445
   Component: R3 1.4l TDI   H07 9151
   Revision: 21003001
   Coding: 01114012422401080000
   ASAM Dataset: EV_ECM14TDI03004B906027 003028
   ROD: EV_ECM14TDI03004B906027_VW26.rod
   VCID: 5EB3B8A24162C0CE2C-800A
Readiness: N/A
   Serial number: 08501485141008
   Coding: 21DD2485892B33C4091A10690057842491CC90080007C9F98F00
   VCID: 336539169A603DA6B3-8066
Address 08: Auto HVAC (J301)       Labels: 6C0-820-045.clb
   Component: AC Manuell    H02 0105
   Serial number:  1409301B-1167
   Coding: 201000001000000200
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: 1D31FFAE0CE49BD675-8048
                    Reset counter: 243
                    Mileage: 24652 km
                    Date: 2016.07.22
                    Time: 12:26:10
459015 - Databus
          U1121 00 [012] - Missing Message
                    Fault Frequency: 27
                    Reset counter: 244
                    Mileage: 24096 km
                    Date: 2016.07.16
                    Time: 00:13:46
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Serial number: 009528002325
   Coding: 000008504213005B4B844000400F07080000590251010000000000000000
   ROD: EV_BCMA0_SE25.rod
   VCID: 2F6D356676481946D7-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Serial number: KU0KU013101442861731
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Serial number: KU0KU010101442833964
   Coding: 1400A0
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 17101403271189
   Coding: 00000000FE0739
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 387F0E3A8306DEFE86-806C
   Part No SW: 6C0 959 655 B    HW: 6C0 959 655 B
   Component: VW20Airbag01B 001 0330
   Revision: --------    Serial number: 003LN0012KE+
   Coding: 88CCC000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X_SE25.rod
   VCID: 326B3C12657A34AEB8-8066
   Subsystem 1 - Part No SW: -----------    HW: 410 820 609 14
   Serial number: 3575H00AD15DADE103A1
   Subsystem 2 - Part No SW: -----------    HW: 410 820 609 14
   Serial number: 3585H00B71637681309E
   Subsystem 3 - Part No SW: -----------    HW: 442 150 510 14
   Serial number: 3517A00A1176F603C0BC
   Subsystem 4 - Part No SW: -----------    HW: 442 150 510 14
   Serial number: 3527A009D176F5E6114N
   Part No SW: 6C0 920 741 A    HW: 6C0 920 741 A
   Component: KOMBI         211 0290
   Coding: 072409002180000800882A011000000000000000
   VCID: 2149C35E309CBF3651-8074
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Revision: --------    Serial number: 009528002325
   Coding: 030000045F0A590071000000000000010001010000000000000000000000
   ROD: EV_GatewA0Lear_SE26.rod
   VCID: 65C1974E64349316ED-8030
   Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61282B35132821928995
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PEAV0239
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
   Component: MU-E--ER      820 6220
   Serial number: 06091400010687
   Coding: 02620000BE00000041110001000000001F0004840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2A5B24724DAA7C6E00-807E
End-------------------------(Elapsed Time: 02:01)--------------------------
listek2000
C?ID=226096
yeahhhh :thumbs: software updates were required by VW workshop :)
Component: AC Manuell H02 0202
thanks and regards :thanks:
