Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 80
Thread: VCDS Support for new VW Polo 6C
  1. #21
    Mar 2015
    Quote Originally Posted by kreativ View Post
    Is your Polo fitted with xenon headlights or the new led headlights?
    Xenons, only the GTI and the.. SEL I believe got the new funky LEDs.
  2. #22
    Mar 2015
    FYI: Data Versions 20150314 and newer should cover most of the 6C modules now.
    Any guess when we'll be able to get our grubby mitts on it?
  3. #23
    Verified VCDS User kreativ's Avatar
    Aug 2014
    Hidden
    Hi Sebastian
    Just installed newest beta 15.0.3 today and was trying to do a long coding in Adress 09 - Central electronics
    but the labels didn't exist, so just wanted to hear if the label file will be coming soon
    keep up the good work
  4. #24
    Mind posting a fresh Auto-Scan from 15.3.0?
  5. #25
    Aug 2014
    Hidden
    Here you go
    VCDS Version: 15.3.0.0
    Data version: 20150314
    VIN: WVWZZZ6RZFY087079   License Plate:
    Mileage: 18005km-11187mi   Repair Order:
    Chassis Type: 6R (6C0)
    Scan: 01 03 08 09 10 13 14 15 17 19 44 5F
    VIN: WVWZZZ6RZFY087079   Mileage: 18005km-11187miles
    Address 01: Engine (J000-CUSB)       Labels: None
       Part No SW: 04B 906 027 B    HW: 04B 907 445
       Component: R3 1,4 DCM6.2 H07 8397
       Revision: 21003001
       Coding: 01114032434401080000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_ECM14TDI03004B906027B 003024
       ROD: EV_ECM14TDI03004B906027_VW26.rod
       VCID: 2044F85B3B02AB38E7-8075
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
       Part No SW: 6C0 907 379 H    HW: 6C0 907 379 B
       Component: ESP9.0i       H01 0003
       Serial number: 08504732140524
       Coding: 21DD28858B2B33C709143070005A8414D1CC900C0007C5FB0C00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
       ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
       VCID: 346C040B9FFA279813-8061
    Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
       Part No SW: 6C0 907 044 A    HW: 6C0 907 044 A
       Component: Climatronic   H02 0104
       Serial number:  1406121A-0044
       Coding: 201000001001000201
       ASAM Dataset: EV_ACClimaValeoPQ26 003001
       ROD: EV_ACClimaValeoPQ26.rod
       VCID: 2240F253350EB928F1-8077
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 6C0 937 089 A    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H06 0047
       Serial number: 007278020956
       Coding: 0010085042530AFB0BA44080B12F07D800005B0257010000000000000000
       ASAM Dataset: EV_BCMA0 004003
       ROD: EV_BCMA0_VW26.rod
       VCID: 2E58166371D60D4865-807B
       Slave 2:
       Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A
       Component: RLHS  037 0059
       Serial number: S4Y14M06D15H23M03S03
       Coding: 0638DD
       Subsystem 2 - Part No SW: 6R0 959 801 CE    HW: 6R0 959 801 CE  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  003 9610
       Serial number: KU0KU010061441610004
       Coding: 0400A1
       Subsystem 3 - Part No SW: 6R0 959 802 CJ    HW: 6R0 959 802 CJ  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  003 9610
       Serial number: KU0KU006061441574947
       Coding: 1400A1
       Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY1404216Z5
       Serial number: 00000000000059192021
       Subsystem 6 - Part No SW: 6R0 959 591 B    HW: 6R0 959 591 B
       Component: J245 PS72.023  H02 0007
       Serial number:     WOO2877680C
       Coding: 181001
       Subsystem 7 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
       Component: J388__TSG_HL  003 8610
       Serial number: KU0KU003061441545804
       Coding: 0400A0
       Subsystem 8 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
       Component: J389__TSG_HR  003 8610
       Serial number: KU0KU002061441537034
       Coding: 1400A0
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 94231415403572
       Coding: 0031151001
       ROD: EV_EPHVA18AU3700000.rod
       VCID: 3D7A212FACB0E6D0EC-8068
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 05061476510929
       Coding: 00000000FE0739
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 3874303B8392C3F83F-806D
    Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
       Part No SW: 6C0 907 359     HW: 6C0 907 359
       Component: DAEMPFUNGS-SG H04 0007
       Serial number: 02041402000117
       Coding: 80
       ASAM Dataset: EV_SwitcDampeContiTemic 001004
       ROD: EV_SwitcDampeContiTemic.rod
       VCID: 6AD0DA738DBEA16879-803F
    Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
       Part No SW: 6C0 959 655 B    HW: 6C0 959 655 B
       Component: VW20Airbag01B 001 0330
       Revision: --------    Serial number: 003LN000C5DY
       Coding: 88CCC000000000005C0000CA000800000000
       ROD: EV_AirbaVW20BPAVW26X_SK26.rod
       VCID: 3260021365EE29A801-8067
       Subsystem 1 - Part No SW: -----------    HW: 410 823 005 14
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00B51573992A34K
       Subsystem 2 - Part No SW: -----------    HW: 410 823 005 14
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00AB1569C6360CX
       Subsystem 3 - Part No SW: -----------    HW: 442 150 306 14
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00AD15A9955D2E-
       Subsystem 4 - Part No SW: -----------    HW: 442 150 306 14
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00AB15A995553FT
       Part No SW: 6C0 920 741 A    HW: 6C0 920 741 A
       Component: KOMBI         211 0260
       Coding: 072D09003580000801887A011000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009036
       ROD: EV_DashBoardVDDMQBAB_VW26.rod
       VCID: 2142FD5F3008A230E8-8074
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H06 0047
       Revision: --------    Serial number: 007278020956
       Coding: 030100044F0A590071000000800000010001000000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: EV_GatewA0Lear_VW26.rod
       VCID: 65CAA94F64A08E1054-8030
       Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAT  H03 0015
       Serial number: 1431405261600586AF1B
       Coding: 2C0000
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 51157C55592821366669
    Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
       Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  312 3211
       Serial number: PE6K0475
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_VW26.rod
       Part No SW: 3Q0 035 864     HW: 3Q0 035 864
       Component: MU-S-N-ER     H04 0105
       Serial number: VWZAZ2P4526728
       Coding: 02620001BE00000011110001000808001F0100D401200100C6
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_SK35.rod
       VCID: 6ED8D663B1564D4825-803B
       Media Player Position 1:
       Subsystem 1 - Part No SW: 6C0 919 603 A    HW: 6C0 919 603 A
       Component: ABTm_Std2_Nav  H41 1015
       Serial number: VWZ8Z9PH2004JW
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 3G0 919 866 E    HW: -----------
       Component: ECE 2015  --- 0335
  6. Likes Uwe liked this post
  7. #26
    Magdeburg, Germany
    The PQ26 BCM is high on my todo list, the groundwork has been laid but we still need some more reference scans to double check things.
  8. #27
    Aug 2014
    Hidden
    Thank you for your quick reply Sebastian, I will be looking forward to see the results
    In the mean time I have another question, i've been trying to do some coding stuff with the tire pressure system so I can get it to show in my Discover Media radio. I have followed a guide from the Skoda Octavia 5E since i've have succes with coding the same things to my Polo.
    STG03
    Letzte 6 Ziffern in folgende Werte ändern: 30C202
    STG5F
    Anpassung -> (13) - Fahrzeug-Funktionsliste BAP-tire_pressure_system_0x07 -> Aktiv
    Anpassung -> (14) - Fahrzeug-Funktionsliste BAB-tire_pressure_system_0x07_msg_bus -> Datenbus Fahrwerk
    Anpassung -> (56) -Vehicle Menübedienung-menu_display_rdk -> Aktiv
    Anpassung -> (58 ) - Fahrzeugmenübedienung-menu_display_rdk_over_threshold_high -> Aktiv
    STG17
    Codierung -> Byte04 -> Bit0 setzen
    The only thing i'm missing is the coding in Adress 03 ABS and since the labels isn't fully updated I can't see which bit I need to mark to get it working.
    Since my Abs controller only has 22 bytes and the Skoda Octavia has 29 bytes i presume its not just adding the six numbers (30C202) to my previous long coding
    my current coding:
    As you can see from the picture below I got the following screen on my radio and only need to get the signal from the abs controller as it always keeps saying starting as shown on screen
  9. #28
    Jul 2014
    Czech Republic
    Here is scan of 09 Central electric from Skoda Fabia 2015:
    Friday,03,April,2015,19:12:36:05278
    VIN: TMBEM6NJ9FZ016801   License Plate:
    Mileage:    Repair Order: Fabi TSI
                    Address 09: Cent. Elect.       Labels: 6R0-937-08x-09.clb
    Control Module Part Number: 6C0 937 090 B    HW: 6C0 937 090
      Component and/or Version: BCM PQ26 HiKR H07 0065
               Software Coding: 0C010840421509FB43804000400703080800D800D30A3500000000000000
                Work Shop Code: WSC 73430 790 00063
                  ASAM Dataset: EV_BCMA0 004008 (SK26)
                           ROD: EV_BCMA0_SK26.rod
                          VCID: 275792DE5EF98A00A6-8072
  10. #29
    Jul 2014
    Czech Republic
    Does anyone knows coding for hill Hold activation for ESP 9.0i ECU nr. 6C0 907 379 G, byte 16, bit 0, 0 to 1 - is out of range, Adaptation Hill Hold from not active to normal - out of range too.
  11. #30
    Jul 2014
    Czech Republic
    Is it 6C0-937-089-V1.CLB already available ?
