How to disable seltbelt chimes on a 2006 Jetta?
redrooster
Canada
C?ID=307086
Hello all. This is my first post as not yet verified.
I just got and tried the software for the first time. I want to disable the seatbelt warning chimes.
I found this on a post under teaks:
9. Disabling seatbelt reminder chimes.
Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
Check this option
[Do It!]
Ok I followed the directions up to [ Coding-07] then another window opens but shows nothing with [ Long Coding helper]?
It does warn you to copy down all the values as you can make a module non functional if you do the change wrong which I don't want to do.
Can anyone help with the instructions after I click on "Coding-07"?
I wish I had the program to take a snapshot of the window that opens when I click coding but I don't.
ivagp
C?ID=95551
this is safety related, you should not mess with it
Ashraf6119
C?ID=174194
It is also advisable that before you start changing any of your software coding make sure you have fully auto scanned your vehicle and have saved it some where so if some things go wrong than you can copy back your old software coding.....
