Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: 2007 AUDI A4 2.0T strange Aircon issue
    Aug 2014
    Now permanent in Maryland, USA.
    Folks,
    I havent seen anything like this before. Car AC blows warm air. Freon level good. In AUTO mode when temp setting is on "Lo" the interior air blower goes to maximum speed but no air comes out of the vents. I hear the air sound rushing inside/seem recirculating in dashboard until I press the ECON button then air suddenly rush out of the vents but no cooling. In ECON mode, I see on VCDS that current supply to N280 cuts off. In AUTO mode, current is supplied to N280 regulating valve about 0.635A.
    I have done the air flaps basic initialization settings two times but nothing changed. What could cause the air not flowing through the vents when in AUTO Mode? What does the shut off stages set in MVB 2 mean?? Help appreciated!
    Sunday,04,June,2017,18:36:48:46890
    VCDS Version: 17.1.3.0 (x64)
    VIN:    License Plate: QUERT
                    Address 08: Auto HVAC       Labels: 8E0-820-043.lbl
    Control Module Part Number: 8E0 820 043 BM
      Component and/or Version:   A4 Klimaautomat   2833
               Software Coding: 00000
                Work Shop Code: WSC 00000
                          VCID: 6DDA00AD2726D42932-5120
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
                09-00 - Adaptation Limit Surpassed
    Address 08: DTCs cleared
              67 69 75 76 77
    VIN: WAUDF78E37A055729   Mileage: 177990km-110597miles
    Address 01: Engine        Labels: 06F-907-115-AXX.clb
       Part No SW: 8E0 910 115 P    HW: 8E0 907 115 D
       Revision: 5EH13---    Serial number:
       Coding: 0104010A190F0120
       Shop #: WSC 01126 444 65050
       VCID: 2E58C7A1B9A06F314B-807A
       Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
       Component: AG6 09L 2.0TFSI USA 0030
       Revision: --H01---    Serial number:        4212985
       Shop #: WSC 06335 000 00000
       VCID: 2F66DAA5BEAA663940-807A
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Coding: 0004528
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2833
       Coding: 00000
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  USA 0907
       Coding: 01023
       Shop #: WSC 65536
       VCID: 3D7AF0ED37C684A9C2-4ACE
       Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
       Component: SDAR SIRIUS         0120
       Serial number: AUZ4Z7F1031323
       VCID: 2C5CCDA98CBC1D2165-5102
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H12 3840
       Revision: 91H12384    Serial number: 0036N0G041R.
       Coding: 0032607
       VCID: 3C7CFDE97FDC8DA1F5-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 3BK6A
       Subsystem 3 - Serial number: 0001.01.000000200000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332DRB40399461ET˙†63
       Subsystem 5 - Serial number: 9461ET˙†6342DRB4037ACD0B/˙†63
       Subsystem 6 - Serial number: ACD0B/˙†6352ARB40163C593L˙†63
       Subsystem 7 - Serial number: 3C593L˙†6362ARB401702F49L˙†63
       Subsystem 8 - Serial number: 02F49L˙†63729RB401733A25E˙†63
       Subsystem 9 - Serial number: 33A25E˙†63829RB401733A04C˙
       Subsystem 10 - Serial number: 33A04C˙
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                        Fault Status: 00100001
                        Reset counter: 39
    00591 - Seat Belt Switch; Driver (E24)
                        Reset counter: 39
    00532 - Supply Voltage B+
                        Reset counter: 39
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0701
       Coding: 02041
       Shop #: WSC 06335
       VCID: 41828C1D4B3EE049A6-4ACE
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
       Component: KOMBI+WFS 4     H14 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0023261
       Shop #: WSC 01126 444 59246
       VCID: 2E58C7A1BAA06F314B-5102
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023261
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
       Part No: 8E0 959 433 CG
       Component: Komfortgerát T7B    4135
       Coding: 11820
       Shop #: WSC 06335
       VCID: 78F421F958646181D1-4AE6
       Component: Tőrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tőrsteuer.BF BRM 0706
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
                35-00 -  -
                35-00 -  -
                35-00 -  -
       Coding: 0000019
       VCID: 295234BD804E08099E-807C
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H03 0010
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH03 0010
       Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
       Component: R Symphony2+    H02 0070
       Revision: 00H02000    Serial number: AUZ1Z4F2829251
       Coding: 0250102
       VCID: 68D471B958C4F10141-5102
    End-------------------------(Elapsed Time: 06:32)--------------------------
                    Address 08: Auto HVAC  (8E0 820 043 BM)
    18:54:24 Group 001
      0.000 A  A/C Valve (N280) Current
      0.0 %  A/C Valve (N280) Duty Cycle
      26.0 %  High-Pressure Signal (G65)
      7.0 bar  Refrigerant Circuit Pressure
    18:54:27 Group 001
    18:54:32 Group 002: Compressor Shut-Off Criteria
      6.0  Current Shut-Off Criteria
      1.0  Last Shut-Off Criteria
      12.0  Second to Last Shut-Off Criteria
      1.0  Third to Last Shut-Off Criteria
    18:54:39 Group 003: Left Temperature Flap Control Motor (V158)
      22.0  Current Value
      18.0  Specified Value
      21.0  Minimum Position (Cooling)
      223.0  Maximum Position (Heating)
    Address 08,8E0 820 043 BM,channel 0,adapted from,---,to,000
    Aug 2014
    I'm just wondering if anybody has input on this of some form. Even when I push the center air vents button, still no air comes out from vents..air seem recirculating in dashboard/AC housing. Econ button when pressed cuts off supply to N280 valve which I think it is normal as seen in the diagnosis.current to compressor N280 is restored when econ is deactivated. Can this fault 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    09-00 - Adaptation Limit Surpassed prevent the air flow through the vents?
    I truly need some help in this complex matter..
    HQ
    1 = Compressor OFF: Refrigerant Pressure too high (> 32 bar)
    12 = Compressor OFF: Shut-Off requested by Engine Control
    http://forums.ross-tech.com/showthre...he-HVAC-Season
    So my first question, are we 100% sure the correct amount of charge is in the system? No codes in the engine, so not sure why it was requesting a shut down.
    Jef
  4. Likes Uwe, Jack@European_Parts liked this post
    Jun 2014
    Newcastle, England
    Carry out an Output Test to ensure the actuators are driving the flaps. It is not unheard of for the actuator arms to snap, therefore not driving the flaps but still work their feedback potentiometer and therefore not trigger any codes.
    A Code 1 shut-off may arise if the condenser is blocked with flies, leaves and othe debris; or if the radiator fans are blocked.
    Aug 2014
    The shut down request was a result of ECON button activated at the time of autoscan. Today I recharged freon (level was low) and turned on AC with auto button. I could tell the AC cools. Low side pipe feels cold and "sweaty'' but no air flows from the AC vents in dashboard, though the blower motors works. I can feel the air recirculating inside the dashboard/AC housing but the cold air doesnt flow out of any of the vents! But soon as I activate/press the ECON button, this time air flows through the vents .(of course ECON button turns off AC cooling). Very puzzling. What could cause the AC cooled air not to flow out of air vents? On previous scan the fault code 00735 and 00716 - Air recirculation Flap Positioning Motor (V113)
    41-00 - Blocked or No Voltage was recorded. Could these possibly block air flow through the vents when AC in Auto mode?
    Friday,09,June,2017,12:33:38:46890
    VIN: WAUDF78E37A055729   License Plate: QUERTIIN1
              67 69 75 76 77
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
       Coding: 0004528
                000 -  -  - Intermittent
                        Reset counter: 17
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x0024
                        Hex Value: 0x0196
                        Hex Value: 0x0001
       Coding: 00000
       Coding: 01023
       Shop #: WSC 65536
       VCID: 3D7AF0ED37C684A9C2-4AE6
    12:34:16 Group 001
      0.644 A  A/C Valve (N280) Current
      64.0 %  A/C Valve (N280) Duty Cycle
      44.0 %  High-Pressure Signal (G65)
      14.0 bar  Refrigerant Circuit Pressure
    12:34:24 Group 002: Compressor Shut-Off Criteria
      0.0  Current Shut-Off Criteria
    12:34:28 Group 003: Left Temperature Flap Control Motor (V158)
      22.0  Current Value
    12:34:32 Group 004: Right Temperature Flap Control Motor (V159)
      18.0  Current Value
      15.0  Specified Value
      18.0  Minimum Position (Cooling)
      229.0  Maximum Position (Heating)
    12:34:37 Group 005: Defroster Flap Control Motor (V107)
      21.0  Current Value
      21.0  Minimum Position (Lower Stop)
      228.0  Maximum Position (Upper Stop)
    Jun 2014
    Newcastle, England
    Please try the Output Tests as I suggested above and report back.
    Whilst running on each motor, VCDS shows the specified (where the controller wants the flaps) and actual (where the feedback pots prove the position of the flaps) values of each of the control flaps.
  8. Likes Uwe, Jack@European_Parts liked this post
    Incorrect servo motors plugged in backward from recent work possibly.................
    What does recent service history state?
    JPPSG
  10. #8
    Aug 2014
    There has not been any recent service on Ac system apart from cabin filter exhaust pipe replacement.
  11. #9
    Nevertheless check that servo motors are properly plugged in in their correct locations for each component as per the WD.
  12. Likes Uwe liked this post
  13. #10
    Aug 2014
    I tried the output tests today. VCDS screen shows the regular test screen with "Start/Nest" but there was no way to select sequential mode.So I only continued clicking 'start/next' until the program run through all tests of actuators. I could hear actuators move during the test. But this is the new thing I observed: In the AUTO mode, no air comes out of dash vents at all. Soon as I tried to force open those two closed flaps under the cabin filter, suddenly I have cooled air flow through all dash vents.When I leave let go of flaps, air flow stops immediately unless I push ECON button, which wont give me any cooled air though air will flow through vents.
    Now what could cause these two flaps under cabin filter to close that tight in AC AUTO mode?
    Is there a way I could send pictures to support these new observations?? To send pics, vcds says attach pic from URL but not sure how to create this link. All pics are loaded on my desktop.
