Results 1 to 9 of 9
Thread: HEX-NET beeping
    Verified VCDS User Gizmo's Avatar
    Mar 2014
    S.E.Kent UK
    HEX-NET beeping
    I have just scanned a brand new 2017 Škoda Kodiaq and the LED 1 (car) is flashing red/green but beeping at 1 second intervals.
    I see that a stuck K line would make the interface beep but I would be only be getting a flashing red LED.
    It scanned and puled admaps off the car OK as well as enabled coding.
    So what is the cause of the beeping?
    HEX-NET
    2016 Škoda Superb L&K (190CR)
    Pre-booked a VW ID.3 1st Edition
    What do you get when you do [Options] -> [Test]?
    Mar 2014
    S.E.Kent UK
    Hmmm very strange, just plugged it back in and it’s working perfectly again (I did unplug it a few times before but it made no difference)
    Running Beta 17.4.2
    Port test showed:
    I will add a scan and full admaps to the reference scans section when I get chance.
    HEX-NET
    That code block is way out of date. I'm surprised Beta 17.4 is letting you use it.
    Mar 2014
    S.E.Kent UK
    That is strange as when I go to update it it says I am already on CB: 0.4336
    HEX-NET
  6. #6
    The EXIF info says the VCDS Test result screenshot was taken by "Martin" on "2016:02:28". I think you uploaded the wrong screenshot
  7. Likes Gizmo, Uwe liked this post
    Mar 2014
    S.E.Kent UK
    Oops yes that would do it Eric!
    HEX-NET
  9. Likes Uwe liked this post
  10. #8
    Did it only beep when you plugged it into the car, or as soon as you plugged into USB?
  11. #9
    Mar 2014
    S.E.Kent UK
    It started beeping as soon as I plugged it into the car and not yet plugged into the tablet.
    HEX-NET
