HEX-NET beeping
Gizmo
S.E.Kent UK
C?ID=49193
I have just scanned a brand new 2017 Škoda Kodiaq and the LED 1 (car) is flashing red/green but beeping at 1 second intervals.
I see that a stuck K line would make the interface beep but I would be only be getting a flashing red LED.
It scanned and puled admaps off the car OK as well as enabled coding.
So what is the cause of the beeping?
What do you get when you do [Options] -> [Test]?
Gizmo
S.E.Kent UK
C?ID=49193
Hmmm very strange, just plugged it back in and it’s working perfectly again (I did unplug it a few times before but it made no difference)
Running Beta 17.4.2
Port test showed:
I will add a scan and full admaps to the reference scans section when I get chance.
Eric
HC800000
That code block is way out of date. I'm surprised Beta 17.4 is letting you use it.
Gizmo
S.E.Kent UK
C?ID=49193
That is strange as when I go to update it it says I am already on CB: 0.4336
Eric
HC800000
The EXIF info says the VCDS Test result screenshot was taken by "Martin" on "2016:02:28". I think you uploaded the wrong screenshot :)
Gizmo
S.E.Kent UK
C?ID=49193
Oops yes that would do it Eric! :facepalm:
Shaun
Did it only beep when you plugged it into the car, or as soon as you plugged into USB?
Gizmo
S.E.Kent UK
C?ID=49193
It started beeping as soon as I plugged it into the car and not yet plugged into the tablet.
