Results 1 to 10 of 10
Thread: address 29 (left headlight) no response to VCDS
    Jun 2014
    OK, crashed the left headlight area. Now repaired with VIN specific genuine parts from dealer. I expected to code the new headlight but there is no communication from controller. The parking bulb and turn signal portion function. I checked all fuses for high beam and low beam per the manual. Suggestions?
    BTW, all faults cleared nicely after my autoscan.
    Friday,02,June,2017,22:59:43:34689
    VCDS Version: 17.1.3.0
    VIN: WVGPT77L46D062013   License Plate:
    Chassis Type: 7L (LG1 - My VW Touareg)
    Scan: 01 02 03 05 06 08 09 11 15 16 17 18 19 1C 22 29 34 36 37 39
              46 47 56 68 69 6C 6E 76
    VIN: WVGPT77L46D062013   Mileage: 181770km-112946miles
       Part No SW: 070 906 016 CQ    HW: 028 101 196 2
       Component: V10 5,0L EDCG000AGMª8472
       Revision: --H02---    Serial number: VWZ3Z0F6455356
       Coding: 0060575
       Shop #: WSC 31414 000 00000
       VCID: 61C2339FBBCE2B4986-FFFE
    006215 - Please check DTC Memory of ABS Controller
                   P1847 - 000 -  - Intermittent
                        Mileage: 181773 km
                        RPM: 714 /min
                        Speed: 9.5 km/h
                        (no units): 1.27
                        Voltage: 13.60 V
                        (no units): -12.80
                        (no units): 0.0
    012288 - Glow Plug Indictor Light (K29)
                   P3000 - 000 - Malfunction Message from Instrument Cluster - Intermittent
                        Mileage: 181773 km
    005716 - Please check DTC Memory of Instrument Cluster
                   P1654 - 000 -  - Intermittent
                        Mileage: 181773 km
    Readiness: N/A
       Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
       Component: AL 750 6A           0856
       Revision: 00H37000    Serial number:
       Coding: 0004200
       VCID: 7F0695E72D7AFDB990-5120
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D7AAFEF67F62FA9C2-5120
    00493 - ESP-Sensor Unit (G419)
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 137 A    HW: 5WK 485 02
       Component: 29 Kessy            6700
       Revision: 67005915    Serial number: VWZ3Z0F6455356
       Coding: 0147688
       VCID: 316283DFABAEDBC956-5102
    00955 - Key 1
                002 - Lower Limit Exceeded
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77F67DC7054AC5F9D8-5120
    Address 08: Auto HVAC        Labels: 7L6-907-044.clb
       Part No: 7L6 907 044 T
       Component: CLIMAtronic 2+2     4222
       Coding: 0020030
       VCID: 458AC70F0F2667699A-5120
       Subsystem 1 - Part No: 7L6 907 049 E
       Component: CLIMAtronic FOND    0400
    00229 - Refrigerant Pressure
    02600 - Rear Right Temperature Flap Motor (V314)
                000 -  -  - Intermittent
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3002
       Coding: 0111836
       VCID: 4796CD07352A757968-5120
    Address 11: Engine II        Labels: Redir Fail!
       Component: V10 5,0L EDCG000AGSª8472
       Coding: 0060575
       VCID: 61C2339FBBCE2B4986-5102
       Part No: 3D0 909 601 H
       Component: 05 Airbag 8.4E++H01 0562
       Revision: BB38727     Serial number: 0007379>
       Coding: 0012341
       VCID: 28546EBB98749A0181-5120
       Subsystem 1 - Part No: 7L0 959 339 C
       Component: BF-Gewichtsens. 006 0008
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
                        Fault Status: 00101011
                        Reset counter: 39
                        Reset counter: 39
       Part No: 7L6 953 549 H
       Component: Lenksäulenmodul     3401
       Coding: 0010032
       VCID: 448CDA0B041C5E618D-5120
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 R
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0005231
       VCID: 4894CE3B38347A0161-5102
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 819 008 G
       Component: Standheizung E1MAC
       VCID: 3A70A4F376D81891E7-5120
    01126 - Engine Speed Signal
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70E446DB602492C119-5120
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       Part No: 0AD 927 755 AT
       Component: TRANSFERCASE        0114
       VCID: 0D1A3F2F17D6DF2992-5120
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       VCID: 3668B0C342C0FCF103-5102
    01772 - Signal from Level Control Pressure Sensor (G291)
       Component: Sitzverstellung     0703
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 M
       Component:      Navigation     0047
       Coding: 0000101
       VCID: 50A4E65BC064B2C139-5120
       Part No: 3D0 909 158
       Coding: 0000003
       VCID: 67D62D8755EA557948-5120
       Part No: 7L0 959 933 J
       Component:    HSG              5115
       Coding: 0000085
       VCID: 438ED91701125959B4-4ACE
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    6 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    01134 - Alarm Horn (H12)
    01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 7L6 035 456
       Component: 08K Audioverst.     0105
       VCID: 70E446DB602492C119-5102
       Subsystem 1 - Part No: 7L6 035 456
    No Faults Found
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 E
       Component:        Radio        0047
       Coding: 0014042
       VCID: 356AB7CF5FC6F7E90A-5120
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000341
       Shop #: WSC 31414 000 376832
       VCID: 3C7CA2EB7CEC26A1F5-5120
       Component: RLS     010510 054  0403
       Coding: 00133665
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       VCID: 3874BEFB48D40A8111-5120
       Part No SW: 7L6 907 441     HW: 7L6 907 441
       Component: J772__Rearview      0051
       Revision: 00H07000    Serial number:    PA8 J620685
       Coding: 0000101
       VCID: 72E04CD36E28A0D1EF-5120
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 12
                            Reverse OFF
                        Count: 3
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 J
       Component: DACHDISPLAY         0538
       Revision: 00700538    Serial number: 2009266.06
       VCID: 3E78A8E36AF034B1DB-5120
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 3972BBFF73DE1389EE-5120
    01629 - Sensor for Parking-Aid; Front Left (G255)
                009 - Open or Short to Ground
    End-------------------------(Elapsed Time: 06:52)--------------------------
    Apr 2016
    Your auto-scan - did that auto-detect, or did you select that from the drop down?
    Did you notice that there are 2 different 7L Touaregs? IIRC the early cars don't use a 55 address, (but do use 29) and vv for the later Touaregs.
    In short you might want to try address 55 and/or use the other Touareg option for the autoscan.
    Quote Originally Posted by dieselland View Post
    Based on the VIN, this is a 2006, which should be a pre-facelift. The cluster and GW part numbers also look pre-facelift to me. That, combined with the fact that he does have 39-Right Light makes me reasonably confident that he should also have 29-Left light and not 55-Xenon Range.
    Apr 2016
    Based on the VIN, this is a 2006, ...
    Right. Apparently I can't count to 10 properly. I counted to 7 instead of 10, saw a 7, and said "this is a 2007! that's a split year! I'm an internet hero who will be admired the world over!". Nope, I'm just a dummy that can't count to 10.
  5. Likes jyoung8607, Uwe, Eric liked this post
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    LOL, the number of times I've done exactly that (and dicked it up on occasion) on 2001 Passats...
  7. Likes Uwe liked this post
    Jun 2014
    yes, there is definitely an address 29. VCDS does not see it. Does it live in that $600 projector unit? Is it possible the xenon bulb was not included? Would no bulb cause no communication?
    Jul 2014
    Did you buy the headlight because the module does not come with it
  10. #8
    Jul 2014
    The modulus what communicates did you put the module in it
  11. #9
    Jun 2014
    Quote Originally Posted by ivagp View Post
    yes I did. now tnat I have time to compare right and left I see lots of missing stuff in the new unit!
    color me embarrassed.
  12. #10
    Jul 2014
    Hey hope everything is going good just wanted to clarify when you said yes I did does that mean you bought the control module
