Results 1 to 7 of 7
Thread: 2005 Golf AC does not cool
    Aug 2014
    Maryland, USA
    Hi Folks,
    Warm air comes from AC vents..compressor does not engage when turned on. I checked freon pressure, low side reads over pressure (160> PSI), high side reads about 80 psi. Power supply to compressor clutch on pin 1 comes and goes off withing 1 second (just a flash) so compressor doesnt work. The load signal in MVB doesnt change even when AC switch is turned on.
    Is the 12V supply provided by a relay or so? Would it be one of those relays under the dash?? I am stuck and would appreciate help in this.
    Thanks.
    Wednesday,31,May,2017,16:49:46:46890
    VCDS Version: 17.1.3.0 (x64)
    VIN: License Plate: ALLEY
    Address 01: Engine Labels: 06A-906-032-BEV2.clb
    Control Module Part Number: 06A 906 032 RF
    Component and/or Version: 2L A4 MT5 G 6380
    Software Coding: 00001
    Work Shop Code: WSC 09454
    Additional Info: 9BWFL61J554010735 VWZ7Z0D0436783
    VCID: 73EE16D5410202D9E4-5120
    Address 01: Engine (06A 906 032 RF)
    16:52:12 Group 002: General
    760 /min Engine Speed (G28)
    16.5 % Engine Load
    3.28 ms Injection Timing
    2.92 g/s Mass Air Flow Sensor (G70)
    HQ
    Please post a full Auto-Scan.
    I'll say I'm not putting a lot of faith in the compressor... and I can't think of running into flip-flop readings like that in my years on the line.
    Jef
  3. Likes Uwe, Ashraf6119 liked this post
    Has this freon been over charged in system?
  5. Likes Ashraf6119 liked this post
  6. #4
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    80PSI = to 5624grams which looks like its OK for its system.......Have you tried powering up the Compressor manually and see if the clutch is working fine also check the 8mm bolt which holds the pull they do brake and live the pulley free
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    Aug 2014
    Maryland, USA
    That will be next step tomorrow.will do that and post results here. Thanks a lot!
  9. #6
    Aug 2014
    Maryland, USA
    Jeff,
    Auto scan below. I also went ahead to power the ac compressor directly with 12V on T2/1 i mean pin 1 but clutch didnt not engage.Im thinking compressor gone bad?
    Friday,02,June,2017,13:24:37:46890
    VIN: 9BWFL61J554010735   License Plate: ALLEYG
    Mileage: 167940km-104353mi   Repair Order:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: 9BWFL61J554010735   Mileage: 167940km-104353miles
       Part No: 06A 906 032 RF
       Component: 2L A4 MT5       G   6380
       Coding: 00001
       Shop #: WSC 09454
       VCID: 73EE16D5410202D9E4-5102
    18017 - Crash Shut-Down Activated
                P1609 - 35-00 -
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0022530
       Shop #: WSC 09454 444 59381
       VCID: 346CD5C9548C45E13D-5120
       Part No: 1C0 909 605 F
       Component: 08 AIRBAG VW61 0202 0003
       Coding: 12344
       Shop #: WSC 00001
       VCID: 27563285C55A3E7988-50E6
       Part No: 1J0 920 907
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 15232
       Shop #: WSC 00001
       VCID: 66C87F8102D0E77173-50E6
    01304 - Radio
                49-00 - No Communications
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00001
       VCID: 70E419D9301439C119-50E6
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 8C Komfortgerát HLO 0004
       Coding: 00258
       Shop #: WSC 00001
       VCID: 3776E2C515FAAEF918-4AE6
       Component: 8C Tőrsteuer.FS KLO 0202
       Component: 8C Tőrsteuer.BF KLO 0202
       Component: 8C Tőrsteuer.HL KLO 0202
       Component: 8C Tőrsteuer.HR KLO 0202
                53-10 - Supply Voltage Too Low - Intermittent
    00912 - Window Regulator Switch; Front Left (E40)
    01359 - Internal Central Locking Switch; Passenger Side (E198)
    End-------------------------(Elapsed Time: 05:41)--------------------------
  10. #7
    Apr 2016
