Results 11 to 20 of 27
Thread: VW TOUAREG 2013 EPB ISSUE
    Mar 2017
    Is it neccesery to adjust the shoes mechanically first?there are gaps left 2.2 right 2.5
  2. #12
    Mar 2017
    Quote Originally Posted by Ashraf6119 View Post
    Yon need to carry out Calibration and the Basic Settings to get those fault clear.........There is a YouTube Video somewhere here on the forum try looking for it which shows how to carry out those settings.....
    I can not do it it just does not work
  3. #13
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Quote Originally Posted by Milan View Post
    Ok I have a video and going to carry it out
    Could you please post here the Security Access Code which you successfully logged in so it can be helpful to others
  4. #14
    Mar 2017
    Yes sure no problem
    Security access code for 53 parking brake 21673
    Code 01040000
  5. Likes Ashraf6119 liked this post
  6. #15
    Mar 2017
    Unfortunately I haven't managed to fix the EPB problem today,I don't even know what to do next
  7. #16
    Nov 2017
    Sorry to revive this thread after such a long time but I had a problem with my EPB on my 2012 Touareg. The switch went dead because it had soda in there. Now i cleaned it and it works but when i re-plugged it, it gives me the same errors (Calibration and Basic Setting not found). I followed the "grinding in procedure" on the video but it keeps aborting for "safety reasons". Is this really necessary or how else do i reset the light? I have no clue why it would need new coding and all this procedure even if i didn't change any parts at all...
    The EPB is actually working correctly but i cannot reset the light on the dashboard....
    Any advice?
  8. #17
    Quote Originally Posted by amizan View Post
    Any advice?
    Please post an Auto-Scan so people can see what, if any faults are present.
  9. Likes Jack@European_Parts liked this post
  10. #18
    Nov 2017
    Hi Uwe,
    Here's the Autoscan. I want to say that i have tried the video "grinding in" and basic settings procedure but the damn thing does not want to calibrate even though i get no errors while doing the whole procedure exactly as in the video....
    Also, i just did the autoscan and it only gives me an error on missing basic setting but when i go to the module, then it also gives me the "calibration outside the expected range" error but for some reason it does not show up here....
    Let me know what you think.
    Tuesday,20,August,2019,00:01:43:45649
    VIN: WVGEK9BP1CD005604   License Plate:
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
              69 6C 6D 72
    VIN: WVGEK9BP1CD005604   Mileage: 334520km-207861miles
    Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
       Component: 3.0TDI EDC17  H17 0005
       Revision: 56H17---
       Coding: 292A4012233600050000
       Shop #: WSC 02330 444 92460
       ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
       ROD: EV_ECM30TDI0117P0907401J_001.rod
       VCID: 3635DA6018CC58A7205-8062
    10615 - Reductant Tank Temperature Sensor
              P205B 00 [101] - Implausible Signal
                        Mileage: 334464 km
                        Date: 2019.08.18
                        Time: 09:38:40
                        Engine speed: 372.00 /min
                        Normed load value: 100.0 %
                        Coolant temperature: 27 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 9.680 V
                        Outside air temperature: 22.0 °C
                        Pressure sensor for reducing agent: measured pressure: 0 hPa
                        Sensor for reducing agent fill level: fill level: 80.33 %
                        Sensor for reducing agent tank temperature: temperature: 52.5 °C
                        Reducing agent pump: activation: 0.00 %
       Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
       Component: AL1000 AISIN  001 1857
       Coding: 001368
       Shop #: WSC 42005 002 1048576
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: EV_TCMAL991031_001_VW52.rod
       VCID: 3039EC78FAA876977A9-8064
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
       Component: MK25A         H36 0433
       Revision: --------    Serial number: 427310010EC010
       Coding: 5B7613C349242558DAFAC89392D6A4407300
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_MK25AXT 008001
       ROD: EV_ESPMK25A00800.rod
       VCID: 44D1B0A85E10FA37AE1-8010
       Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
       Coding: 09860000000000000000
       VCID: 73B323744BBE0D8FC7B-8026
       Subsystem 1 - Part No SW: 7P6 959 754 M    HW: 7P6 959 754 M
       Component: FBSTOUAREGIDG  H04 0051
       Serial number: 0511000056915016
       Serial number: 2311000221683004
       Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
       Component: Klima 2 Zonen H20 1305
       Coding: B606200A80
       VCID: 7EA50240707C50E7B85-802A
       Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0100
       Revision: 15012002    Serial number: 00000001111655
       Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
       VCID: 6B833B14138ED54F0FB-803E
       Component: WWS    111021  31  0020
       Serial number: 90243400111028231403
       Coding: 004DBD
       Component: RLFS  H09 0011
       Serial number: 10264691
       Coding: 025223
       Component: E1 - LDS  H04 0031
       Serial number: 00000000001110110267
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R0S3807
       Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
       Component: VW10Airbag025 H05 0025
       Revision: --------    Serial number: 003L0000JX0X
       Coding: 000000000000000000000000000000003235
       VCID: 41DFB9BC4102EF1F857-8014
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R1172706H59
       Serial number: 3575LRB40690T3R6A0UV
       Serial number: 3585LRB40690T3R69HP0
       Serial number: 3515RRB40550OPMK49H%
       Serial number: 3525RRB405B0OPMKH9NP
       Serial number: 3555NRB40590PIJQEGOO
       Serial number: 3565NRB40550PIJQKHEI
       Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
       Revision: --------    Serial number: 90815KJP0005S
       Coding: 000015
       VCID: 3635DA60184C58A7205-8062
       Serial number: 0124203
       Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
       Component: Kombi         H13 0239
       Revision: 11240062    Serial number: 658221011593041
       Coding: 8B7733022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 47CBA7A46F26D12F4B3-8012
       Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5202
       Revision: --------    Serial number: 00000000291319
       Coding: 0001037500
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3829D45812D8AED7329-806C
       Serial number: 00000000005650843827
       Revision: AA000000    Serial number: 00000016937431
       Coding: 0058130000004001000001010101202020202121202020
       VCID: 3431E0680E304AB71E1-8060
       Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
       Component: TSG FA        H07 0166
       Revision: --------    Serial number: 0000121063960
       Coding: 011D07205E00453005080000
       VCID: 44D1B0A85E90FA37AE1-8010
       Revision: 00002001    Serial number: 0161545821
       Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 284119591
       Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Serial number:     WOO13391685
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Serial number:     WOO1336156%
       Coding: 191100
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0166
       Revision: --------    Serial number: 0000121426575
       VCID: 3B23CB54236E85CFDFB-806E
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: A11A070021C
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       Slave 1:
       Slave 3:
    0024 - No Basic Setting
              B2010 00 [009] - -
              [Steuergerät EPB - System nicht kalibriert]
                        Reset counter: 25
                        Mileage: 334519 km
                        Date: 2019.08.18
                        Time: 14:13:25
                        Voltage: 13.4 V
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 010A00010F000400
       VCID: 7CA10848666042F7961-8028
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0006
       Coding: 130000
       Component: Radio U SIRIU H53 0133
       Revision: AB001007    Serial number: 156J20B7565751
       Coding: 020007020100000001
       VCID: 24111028BED0DA378E1-8070
       Part No SW: 7P6 035 664 D    HW: 7P6 035 664
       Component: H-BN-NA       H44 0706
       Revision: --------    Serial number: 445J 0B7521662
       Coding: 010200050040E1EE41022B0C00000003F00001010000000000
       VCID: 392FD15C2952B7DFCD7-806C
       Subsystem 1 - Part No: 8R0 060 884 AC
       Component: NAR 2011  0503
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H26 0045
       Serial number: VWZ8Z9L79004S3
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
                        Reset counter: 24
                        Mileage: 334462 km
                        Date: 2019.08.17
                        Time: 18:21:32
                        Text: DUA001,Front,M,0,0,6
    03175 - Invalid Data Set
                        Reset counter: 24
                        Mileage: 334462 km
                        Date: 2019.08.17
                        Time: 18:21:30
                        Voltage: 14.10 V
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0167
       Revision: --------    Serial number: 0000121490349
       Coding: 011C07200000253005080000
       VCID: 3A2DCE502C54BCC7C4D-806E
    Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000050575
       ROD: EV_RDKBERU25_VW52.rod
       VCID: 3FDBBF4437F699EFF33-806A
    8397058 - Front Left TPMS Sensor
              C1050 31 [009] - No Signal
                        Reset counter: 24
                        Mileage: 334461 km
                        Date: 2019.08.17
                        Time: 17:07:35
                        Vehicle speed: 6 km/h
                        Outside air temperature: 24.5 °C
                        Reception level antenna 1: 730 mV
                        Offset level antenna 1: 670 mV
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H09 0110
       Revision: 5A001001    Serial number: 00000160938100
       Coding: 020D000000000000
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H04000    Serial number: 525 PA8J192588
       Coding: 0110001
       VCID: 372BD7641346A1AF3B3-8062
       Part No SW: 7P6 959 107 A    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0620
       Revision: 22010001    Serial number: 294100187
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202137
       ROD: EV_HeckkTouar.rod
       VCID: 3D27C54C3DFA8BFFE1F-8068
       Component: TSG HR        H09 0167
       Revision: --------    Serial number: 0000121399453
    End----------(Elapsed Time: 02:08, VBatt start/end: 13.9V/14.2V)-----------
  11. #19
    What do the air gaps currently look like? Previously you reported them as 2.2 and 2.5. That's more than the allowable difference of 0.2mm, and 2.5 is out-of-spec.
    * Air Gap Spec is between 1.9mm to 2.4mm
    * Left and Right sides must be within 0.2mm of each other
  12. #20
    Nov 2017
    The air gaps readinggs on VCDS are now 3.8 and 3.9 respectively. i don't know how they changed so much because i did not touch anything near the wheel...
    do i need to go there and adjust them manually? any tutorials / writeups on how to do what?
