Results 1 to 6 of 6
Thread: ECM replacement question
    May 2017
    Have a customer with an audi A8 that has a bad ecm. Below is a vag log from before the module went haywire.
    His question is can a used ecm be installed in the vehicle. My question is what sort of programming will be needed to work. Thanks in advance!
    Friday,17,March,2017,15:26:45:05056
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170220 DS267.3
    VIN: WAUMV44E47N020729   License Plate:
    Mileage: 125250km-77826mi   Repair Order: sv09930cosgrove
    Chassis Type: 4E (4L0)
    Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 1E 28 34 36 37 38 42
              46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
    VIN: WAUMV44E47N020729   Mileage: 125250km-77826miles
    Address 01: Engine        Labels: 079-907-560-BVJ.clb
       Part No SW: 4E1 910 560 A    HW: 4E1 907 560
       Component: 4.2l V8/4V          0050
       Revision: 71H22---    Serial number: AUX3Z0G2720519
       Coding: 01060009190F0120
       Shop #: WSC 22189 444 12575
       VCID: 204F1AC7F3D02341C9-8074
    005137 - Secondary Air Injection System; Bank 2
                   P1411 - 002 - Insufficient Flow - MIL ON
                        Fault Status: 11100010
                        Mileage: 120117 km
                        Date: 2016.11.08
                        Time: 14:45:05
                        RPM: 1123 /min
                        Load: 29.0 %
                        Temperature: 27.0°C
                        Temperature: 23.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.335 V
    004964 - Cylinder 4 Ignition Circuit
                   P1364 - 004 - Open Circuit - Intermittent
                        Mileage: 120117 km
                        Date: 2016.11.08
                        Time: 14:45:05
                   P0300 - 001 -  - Intermittent - MIL ON
                        Fault Status: 10100001
                        Fault Frequency: 11
                        Mileage: 124497 km
                        Date: 2017.03.01
                        Time: 22:20:27
                        RPM: 1385 /min
                        Load: 61.9 %
                        Speed: 58.0 km/h
                        Temperature: 99.0°C
                        Temperature: 39.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.224 V
    000772 - Cylinder 4
                   P0304 - 001 - Misfire Detected - Intermittent - MIL ON
                        Fault Frequency: 11
                        Mileage: 124497 km
                        Date: 2017.03.01
                        Time: 22:20:27
       Part No SW: 4E1 910 156 C    HW: 09L 927 156 A
       Component: AG6 09L 4,2lFSI USA 0030
       Revision: --H01---    Serial number:        4313649
       Shop #: WSC 02313 758 00200
       VCID: 234515CBE2C63859D4-8076
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
       Component: ESP 5.7 allrad  H46 0510
       Coding: 0007597
       Shop #: WSC 02313 000 00000
       VCID: 224B10CFFDDC3151DF-8076
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 L
       Component:     FBS AUDID3  H10 0190
       Revision: 01904910    Serial number: AUX3Z0G2720519
       Coding: 0410624
       Shop #: WSC 02311 785 00200
       VCID: 58BF7227EB00AB81F1-800C
       Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
       Component: Sitzmemory BFS H02  0010
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 4071648
       Shop #: WSC 02313 785 00200
       VCID: 244716D7E7C83F61AD-8070
    Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
       Part No SW: 4E0 910 731 P    HW: 4E0 035 729 A
       Component: Interfacebox    H43 3360
       Revision: 00000000    Serial number: 348CQ077522562
       Coding: 0000003
       VCID: 2E53F4FFB90485314B-807A
       Subsystem 1 - Part No: 4E0 910 611
       Component: E0380 BedienteilH01 0040
       Subsystem 2 - Serial number: 00000000035903
       Subsystem 3 - Serial number: 0114.04.070000000100010021˙
       Subsystem 4 - Serial number: 010021˙
       Part No SW: 4E0 910 043 B    HW: 4E0 820 043 H
       Component: KLIMAAUTOMAT    017 0450
       Revision: 00000032    Serial number: 00000000118912
       Coding: 0102865
       VCID: 1C372E37DFB807A115-8048
       Subsystem 1 - Part No: 4E0 910 772 A
       Component: Sitzluefter  FS H02  010
       Subsystem 2 - Part No: 4E0 910 772 A
       Component: Sitzluefter BFS H02  010
       Subsystem 3 - Serial number: 898053000
       Subsystem 4 - Serial number: HO12042007065A000000000115˙†89
       Subsystem 5 - Serial number: 000115˙†898053000      000-SHO
       Subsystem 6 - Serial number:     000-SHO11042007065A00000000
       Subsystem 7 - Serial number: 65A000000000042˙
    00065 - Rear Left Footwell Heater (Z42)
                        Fault Status: 00101100
                        Reset counter: 213
                        Mileage: 113955 km
                        Date: 2015.11.09
                        Time: 10:55:50
                        Voltage: 13.60 V
    Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
       Part No SW: 4E0 910 279 Q    HW: 4E1 955 113 C
       Component: ILM Fahrer      H15 0230
       Coding: 0143123
       VCID: 3663DC9F4154BDF103-8062
       Subsystem 1 - Part No: 4E1 910 113 C
       Component: Wischer WWS D3  H60 0420
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
    Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
       Part No SW: 4E0 035 785     HW: 4E0 035 785
       Component: SG ext.Player H09 0170
       Revision: 00000000
       VCID: 65C14BD36C7206697A-8030
    Address 15: Airbags        Labels: 4E0-910-655-94.lbl
       Part No SW: 4E0 910 655 C    HW: 4E0 959 655 J
       Component:    Airbag 9.41  H14 4230
       Revision: 91H14423    Serial number: 0037Q0G02SNJ
       Coding: 0532707
       VCID: 26430CDF91F4CD71B3-8072
       Subsystem 1 - Part No: 4E0 910 339
       Component: BF-Gewichtsens. H01 0030
       Subsystem 2 - Serial number: 3LHKS
       Subsystem 3 - Serial number: 0001.01.0000H0100000000000˙†63
       Subsystem 4 - Serial number: 000000˙†63328RB402496E4CT˙†63
       Subsystem 5 - Serial number: 96E4CT˙†63428RB402496E23J˙†63
       Subsystem 6 - Serial number: 96E23J˙†63528RB402496E75R˙†63
       Subsystem 7 - Serial number: 96E75R˙†63628RB402496ECC/˙†63
       Subsystem 8 - Serial number: 96ECC/˙†63729RB403A5BEF97˙†63
       Subsystem 9 - Serial number: 5BEF97˙†63829RB40130871DH˙
       Subsystem 10 - Serial number: 0871DH˙
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549
       Component: Lenksäulenmodul H14 0040
       Coding: 0012141
       VCID: 65C14BD3AC7206697A-8030
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 951 C    HW: 4E0 920 951 C
       Component: KOMBIINSTR. VDO H82 0530
       Revision: D05         Serial number: AUDID3G3003445
       Coding: 0048263
       Shop #: WSC 46281 000 1048576
       VCID: 25410BD3ECF2C669BA-8070
    Address 19: CAN Gateway        Labels: 4L0-910-468.clb
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B07330814E
       Coding: F5F5DF7F70720E
       VCID: 6CD73EF74F98372125-8038
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
       Component: MP3-Changer     H44 0350
       Revision: 00044000    Serial number: AUZ5ZBG3210165
       VCID: 183F32272B806B8131-804C
       Part No SW: 4E0 910 158     HW: 4E0 919 158 D
       Component: KLIMA-STG. FOND 017 0230
       Revision: 00000019    Serial number: 00000000053460
       Coding: 0000000
       VCID: 61C95FC3B85A6A4986-8034
    Address 34: Level Control        Labels: 4E0-910-553.lbl
       Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
       Component: LUFTFDR.-CDC    H06 6310
       Coding: 0015510
       VCID: 2A5BF8EF85ECE91197-807E
       Component: Sitzmemory FS  H02  0010
       Coding: 4071658
       Part No SW: 4E0 910 888 D    HW: 4E0 919 887 M
       Component: MNS US          H49 0970
       Revision: 00000000    Serial number: 381DR077521746
       Shop #: WSC 25166 444 84618
       VCID: 2F6DE9FBBE0E8C3940-807A
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135
       Component: Dachknoten D3   H05 0090
       Serial number: 00000706400115
       Coding: 0003479
       VCID: 1D312333C4A20EA9E2-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 801 D
       Component: Türsteuer.FS BRM005 0180
       Coding: 0032364
    Address 46: Central Conv.        Labels: 4E0-910-289.lbl
       Part No SW: 4E0 910 289 C    HW: 4E0 907 289 C
       Component: Komfortgeraet   H09 0020
       Revision: 00200009    Serial number:  W040704160089
       Coding: 0048702
       VCID: 295907E380EAE2099E-807C
       Component: Heckdeckel   P14H06 0070
       Component: Neigungssensor  H05 0020
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 Q    HW: 4E0 035 223 G
       Component: DSP-High D3     H03 0110
       Revision: PROD_01     Serial number: 00000000007182
       Coding: 0000026
       VCID: 2B55FDEB8A16F0196C-807E
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H11 0070
       Revision:             Serial number: 00000000111949
       Coding: 0010111
       VCID: 1E33243FC9A415B1FB-804A
    02258 - Door Opener Transmitter
                        Reset counter: 178
                        Mileage: 120012 km
                        Date: 2016.10.25
                        Time: 14:29:00
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 802 D
       Component: Türsteuer.BF BRM005 0180
       Coding: 0032364
    02129 - Automatic Day/Night Exterior Mirror
                        Fault Status: 00100111
                        Reset counter: 198
                        Mileage: 123952 km
                        Date: 2017.02.21
                        Time: 08:44:50
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
       Component: EPB  A4EC0230   H03 0230
       Revision: --H03---
       Coding: 0000922
       Shop #: WSC 41349 001 1048576
       Coding: 0000018
       Shop #: WSC 26105 444 68460
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
       Revision: 00000000    Serial number: 396D3077569837
                        Reset counter: 218
                        Mileage: 121494 km
                        Date: 2016.12.26
                        Time: 00:00:26
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0550
       Revision: 00000000    Serial number: 00000000003424
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  1234567890
       Coding: 344530393135313035412056413031323334353637383930
    02272 - Quiescent Current Stage 1
                000 -  -  - Intermittent
                        Fault Frequency: 35
                        Mileage: 116544 km
                        Date: 2016.02.20
                        Time: 14:19:19
                        Fault Frequency: 35
                        Mileage: 116544 km
                        Date: 2016.02.20
                        Time: 14:19:19
    02276 - Quiescent Current Stage 5
                        Fault Frequency: 15
                        Mileage: 116544 km
                        Date: 2016.02.20
                        Time: 14:40:37
                        Fault Frequency: 15
                        Mileage: 116544 km
                        Date: 2016.02.20
                        Time: 14:40:37
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
       Component: Türsteuer.HL BRM005 0180
       Coding: 0032364
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
       Component: Reifendruck 3   H05
       Revision: 00050340    Serial number: 00000900051014
       Coding: 0202125
    01477 - System Switched Off
                        Fault Frequency: 253
                        Reset counter: 178
                        Mileage: 120033 km
                        Date: 2016.11.02
                        Time: 13:14:25
                        (no units): 0.0
                        Temperature: 25.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000703300297
       Shop #: WSC 12336 024 394758
       VCID: 3467E6975728AFE13D-8060
    Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
       Part No SW: 4E0 910 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J7310N2
       Coding: 1120503
       VCID: 5CB76E379F3847A1D5-8008
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
       Component: Türsteuer.HR BRM005 0180
       Coding: 0032364
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
       Component: Parkhilfe 8-Kan H12 0040
       Revision: 00H12000    Serial number: 08720710601438
       Coding: 0221208
    02069 - Front Parking Aid Sensors
                        Reset counter: 241
                        Mileage: 119972 km
                        Date: 2016.10.12
                        Time: 11:12:00
       Part No SW: 4F0 910 336 D    HW: 4E0 862 335
       Component: Handyvorb2      H00 0700
       Coding: 0000000
                        Reset counter: 4
                        Mileage: 111187 km
                        Date: 2015.06.15
                        Time: 16:30:08
    End-------------------------(Elapsed Time: 03:35)--------------------------
    and here is the new scan after ecm failure...
    Thursday,25,May,2017,16:10:44:05056
    VIN: WAUMV44E47N020729   Mileage: 126370km-78522miles
    Address 01: Engine        Labels: None
       VCID: 55A17B13BC1296E9EA-FFFE
    No Faults Found
    049408 - No Communication with Engine Control Module (SAE ECM/PCM)
                   U0100 - 000 -
                        Fault Frequency: 25
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:37
                        RPM: 640 /min
                        RPM: 640 /min
                        (no units): 31.0
                        (no units): 24.0
                        Temperature: 49.0°C
                        T.B. Angle: 60.0°
    006273 - Powertrain Data Bus: Missing Message
                   P1881 - 000 - Acceleration Request
                        Fault Frequency: 25
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:37
    006231 - Load Signal
                   P1857 - 001 - Error Message from ECU
                        Fault Status: 01110001
                        Mileage: 126373 km
                        Date: 2017.05.16
                        Time: 14:35:53
    001556 - Transmission Control Module
                   P0614 - 000 - Incorrect Software Version
                        Mileage: 126373 km
                        Date: 2017.05.16
                        Time: 14:35:53
       Coding: 0007597
    02083 - Message for Delay Request
       Coding: 0410624
                        Fault Frequency: 0
                        Reset counter: 238
                        Mileage: 126368 km
                        Date: 2017.05.19
                        Time: 00:30:18
                        Fault Frequency: 0
                        Reset counter: 238
                        Mileage: 126368 km
                        Date: 2017.05.19
                        Time: 00:30:18
       Coding: 4071648
       Coding: 0000003
       Coding: 0102865
    00066 - Rear Right Footwell Heater (Z43)
                        Fault Frequency: 9
                        Reset counter: 22
                        Mileage: 125297 km
                        Date: 2017.03.26
                        Time: 19:25:51
                        Voltage: 13.90 V
                        Fault Frequency: 9
                        Reset counter: 22
                        Mileage: 125297 km
                        Date: 2017.03.26
                        Time: 19:25:51
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 238
                        Mileage: 126373 km
                        Date: 2017.05.19
                        Time: 14:41:26
                        Temperature: 34.0°C
                014 - Defective
                        Reset counter: 238
                        Mileage: 126373 km
                        Date: 2017.05.19
                        Time: 14:41:26
       Coding: 0143123
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
                        Reset counter: 23
       Revision: 00000000
       Coding: 0532707
       Coding: 0012141
       Coding: 0048263
                        Reset counter: 238
                        Mileage: 126374 km
                        Date: 2017.05.25
                        Time: 00:33:45
       Coding: 0000000
       Coding: 0015510
                        Fault Status: 11100100
                        Fault Frequency: 58
                        Reset counter: 238
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 15:03:33
    01598 - Drive Battery Voltage
                        Fault Frequency: 58
                        Reset counter: 238
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 15:03:33
       Coding: 4071658
       Coding: 0003479
    00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
                        Reset counter: 22
                        Mileage: 126372 km
                        Date: 2017.05.19
                        Time: 12:30:00
                        Reset counter: 22
                        Mileage: 126372 km
                        Date: 2017.05.19
                        Time: 12:30:00
       Coding: 0032364
       Coding: 0048702
                        Fault Frequency: 31
                        Reset counter: 22
                        Mileage: 126371 km
                        Date: 2017.05.16
                        Time: 14:30:55
                        Fault Frequency: 31
                        Reset counter: 22
                        Mileage: 126371 km
                        Date: 2017.05.16
                        Time: 14:30:55
       Coding: 0000026
       Coding: 0010111
                        Fault Frequency: 158
                        Reset counter: 238
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:00
                        Reset counter: 238
                        Mileage: 120012 km
                        Date: 2016.10.25
                        Time: 14:29:00
       Coding: 0032364
       Revision: --H03---
       Coding: 0000922
                        Fault Frequency: 168
                        Reset counter: 238
                        Mileage: 125760 km
                        Date: 2017.04.19
                        Time: 14:56:38
                        Voltage: 13.04 V
                        Count: 241
       Coding: 0000018
                        Fault Frequency: 166
                        Reset counter: 238
                        Mileage: 125768 km
                        Date: 2017.04.19
                        Time: 14:56:38
                        Reset counter: 22
                        Mileage: 126373 km
                        Date: 2017.05.19
                        Time: 12:30:24
    02274 - Quiescent Current Stage 3
                        Fault Frequency: 11
                        Mileage: 126373 km
                        Date: 2017.05.19
                        Time: 11:55:31
                        Fault Frequency: 11
                        Mileage: 126373 km
                        Date: 2017.05.19
                        Time: 11:55:31
    02252 - Generator
                        Reset counter: 248
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:49
    02252 - Generator
                        Reset counter: 248
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:49
                        Fault Frequency: 30
                        Reset counter: 238
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:37
    Address 62: Door, Rear Left        Labels: None
       VCID: 55A17B13BC1296E9EA-8000
    No Faults Found
       Coding: 0202125
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 71
                        Reset counter: 238
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:47
                        (no units): 0.0
                        Voltage: 0.00 V
                        (no units): 27.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Fault Frequency: 71
                        Reset counter: 238
                        Mileage: 125764 km
                        Date: 2017.04.19
                        Time: 14:56:47
       Coding: 1120503
       Coding: 0032364
       Coding: 0221208
                        Reset counter: 241
                        Mileage: 119972 km
                        Date: 2016.10.12
                        Time: 11:12:00
       Coding: 0000000
                        Reset counter: 4
                        Mileage: 111187 km
                        Date: 2015.06.15
                        Time: 16:30:08
    End-------------------------(Elapsed Time: 04:29)--------------------------
    It should be possible to install and match used ECM to that car, VCDS is not going to do it. The 4E chassis A8 was the first model that used true Immo-4 stuff with challenge/responses, which require an on-line connection to the corporate mothership instead of more straightforward PIN codes. Alternatively, someone might be able to do an identity transfer for you.
    I can do it through the mail............
    Let me know via contact form in signature.
    Dallas (McKinney) ,TX ,USA
    Yes it is possible but like Uwe mention, not with VCDS.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    https://www.advancedcarelectronics.com/
    email : marinmm2001@gmail.com , info@advancedcarelectronics.com
  5. Likes Uwe liked this post
    May 2017
    Update, customer decided to go with a reman unit directly from AUDI. Came from germany 7 working days to arrive. Dealer tool programmed for $130.00. Thank you for your help guys.
  7. Likes Jack@European_Parts, Jetta ,97 liked this post
    When we sell an ECU we include programming & or data transfer, further no dealer trip is needed..........or additional cost!
    I'm glad it worked out for you...........
