Results 1 to 2 of 2
Thread: Audi 8P DPF limp mode etc
    Feb 2016
    First off thanks in advance if you can help me
    sorry guys if this is yet another post about DPF issue.
    on wife 2008 TDI 8P with BMN engine
    in limp mode have ross tech cable but cant make no sense of instructions or guides,
    first off 40 grams and 45 grams of what is this and where is this figure shown
    loading is over 95% of what where is this figure shown
    I found particle load coefficient 146% in the heat temperature settings for PDF
    Is it true if you have a fault code elsewhere automatic regen will not happen as have a ABS pressure switch fault so haldex is not working.
    i cant get into any DPF regen options
    If i use instructions for CR tdi I dont get a code for security access - 16
    car has DPF light flashing glow plug light and is in limp mode
    fault is
    i only use the cable once in a blue moon so hence being a knob.
    Tuesday,09,January,2018,21:10:12:42779
    VCDS Version: 17.8.1.0 (x64)
    VIN: WAUZZZ8PX8A172638   License Plate:
    Mileage: 123890km-76981mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56 62 72 76
    VIN: WAUZZZ8PX8A172638   Mileage: 123890km-76981miles
    Address 01: Engine        Labels: 03G-906-018-BMN.clb
       Part No SW: 03G 906 018 DN    HW: 03G 906 018 DN
       Component: R4 2.0l PPD1.2 G    1247
       Revision: --H52---    Serial number: AUX7Z0H2FNB078
       Coding: 0000172
       Shop #: WSC 06314 000 00000
       VCID: 74E7B5C9171C34E685-8020
    008194 - Particulate Trap Bank 1
                   P2002 - 006 - Efficiency Below Threshold
                        Fault Status: 11010001
                        Reset counter: 40
                        Mileage: 123892 km
                        Date: 2018.01.08
                        Time: 19:36:32
                        RPM: 768 /min
                        Torque: 56.0 Nm
                        (no units): 3.0
                        Lambda: 145.5 %
                        Pressure: 0.0 mbar
                        Time: 2176.5 s
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
       Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
       Component: ESP 4MOTION MK60    0102
       Revision: 00H13001
       Coding: 0023170
       VCID: 72EBB3D16D083AD697-8026
       Part No SW: 8P0 820 043 AH    HW: 8P0 820 043 AH
       Component: KlimavollautomatH19 0430
       Revision: 139927      Serial number: 8P0820043AH
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
       Component: Bordnetz-SG     H54 2501
       Revision: 00H54000    Serial number: 00000008174551
       Coding: E1881F01B01410004F1600001600000000085E175C010000000000000000
       Shop #: WSC 06314 000 08192
       VCID: 4581380D0C06FD6EE2-8010
       Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 06314
       Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0100
       Coding: 00150573
       Shop #: WSC 06314
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 L    HW: 8P0 959 655 L
       Component:    Airbag 9.41  H01 4220
       Revision: 91H01422    Serial number: 003CP00394ER
       Coding: 0071612
       VCID: 4B950E352A620B1E34-801E
       Subsystem 1 - Serial number: 6332DRB406F15133H
       Subsystem 2 - Serial number: 6342DRB406F18B2F%
       Subsystem 3 - Serial number: 63528RB403A2C6D5V
       Subsystem 4 - Serial number: 63628RB403A66242E
       Subsystem 5 - Serial number: 63747RB4038FBB2D3
       Subsystem 6 - Serial number: 63847RB4038FBAEEG
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0002042
       VCID: 41892C1D182ED14EDE-8014
       Component: E0221           H02 0030
       Part No SW: 8P0 920 981 K    HW: 8P0 920 981 K
       Component: KOMBIINSTR. VDO H22 0660
       Revision: D0H22003    Serial number: 2242H003112170
       Coding: 0005428
       Shop #: WSC 07873 000 1048576
       VCID: 408F29191324D846D1-8014
       Part No SW: 1K0 907 530 P    HW: 1K0 907 951
       Component: J533__Gateway   H16 0192
       Revision:   H16       Serial number: 2500K083060493
       Coding: E9827F0E1002022103
       VCID: 346775C9579C74E645-8060
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 L
       Component: Haldex 4Motion      0116
       Coding: 0000001
       VCID: 36634FC141E066F67B-8062
    01316 - ABS Control Module
                013 - Check DTC Memory
       Revision: D0H22003    Serial number: AUX7Z0H2FNB078
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
       Component: Tuer-SG         H03 0060
       Coding: 0004784
       VCID: 428B23111D28CA56C7-8016
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.079 H08 1901
       Shop #: WSC 02069 000 90108
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 J
       Component:    KSG          H11 0080
       Coding: 0080202002186D0985054C9FC637
       VCID: 438526150232C35ECC-8016
       Subsystem 2 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 8P0 951 177
       Component: Innenraumueberw.H04 0020
       Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
       Component: AB2 SUBWOOFERBOXH06 0180
       Revision: 00005       Serial number: 30674802359263
       VCID: 356148CD5CE66DEE72-8060
       Part No SW: 8P0 959 802 J    HW: 8P0 959 802 J
       Coding: 0004784
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
       Component: R Concert2+     H02 0270
       Revision: 00H02000    Serial number: AUZ1Z3H8898251
       Coding: 0310211
       VCID: 3F8D2AE56EDAA7BEA8-806A
       Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
       Component: Tuer-SG         H04 0040
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
       Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
       Coding: 0000144
    Address 76: Park Assist        Labels: 8P0-919-283.lbl
       Part No SW: 8P0 919 283 D    HW: 8P0 919 283 D
       Component: Parkhilfe 4-Kan H09 0070
       Revision: 00H09000    Serial number: 00067824840807
       Coding: 0000113
       VCID: 3C775DE97FCCBCA68D-8068
    End-------------------------(Elapsed Time: 01:56)--------------------------
    Jul 2014
    Have you been here? http://wiki.ross-tech.com/wiki/index...4/P2002/008194
    Your DPF pressure is showing as 0 in the scan, does this change at all? What is it with the ignition on but engine not running?
    Possible G450 Pressure Sensor faulty.
    Regards HMC
  3. Likes Jack@European_Parts, Uwe liked this post
