Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: 2011 skoda octavia drl problem
    New User
    May 2017
    Hi all i have a problem with my 2011 vrs. My drls was working fine then they went off with a bulb warning.
    I did a light test with vcds and they came on but thats about it.
    Wednesday,24,May,2017,03:08:35:05935
    VCDS Version: 17.1.3.0 (x64)
    Gateway Installation List:  7N0 907 530 C
    00984 - Left Tail Light (M4)
                014 - Defective
                        Reset counter: 246
                        Mileage: 95782 km
                        Date: 2011.10.15
                        Time: 01:08:12
    00985 - Right Tail Light (M2)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 206
                        Mileage: 95782 km
                        Date: 2011.10.15
                        Time: 01:15:35
                        Voltage: 13.90 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Reset counter: 206
                        Mileage: 95782 km
                        Date: 2011.10.15
                        Time: 01:15:35
                        Fault Status: 01101010
                        Reset counter: 206
                        Mileage: 95782 km
                        Date: 2011.10.15
                        Time: 01:15:35
                        Voltage: 13.90 V
                            Term 50 Off
    Have you tried clearing the fault codes? Do they come back?
    New User
    May 2017
    Hi yes I cleared all codes and dash warning stays out until I turn the lights back on. But when I clear the codes the central electronic malfunction code sometimes remains.
    A complete scan would be better than the above snippets that don't even show the ID data for the module with the faults.
    New User
    May 2017
    I just did a bulb test again with vcds and again all bulbs and lights came on fine
    New User
    May 2017
    I'll do a full scan when I get home from work tonight.
  7. #7
    New User
    May 2017
    Wednesday,24,May,2017,18:50:52:05935
    VIN: TMBEF21Z6B2107168   License Plate:
    Chassis Type: 1Z (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: TMBEF21Z6B2107168   Mileage: 95800km-59527miles
    Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
       Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
       Revision: AAH18---    Serial number:
       Coding: 0203000C18070160
       Shop #: WSC 73430 790 00084
       VCID: 79FE774D30CE7D89AE-802C
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 35.0C
                        Temperature: 30.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 10.414 V
    Readiness: 0010 0000
       Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 163B601C09220001680C06EA90210081340800
       VCID: 75E67B7DDCD619E9CA-8020
       Part No SW: 3T0 907 044 BD    HW: 3T0 907 044 BD
       Component: Climatronic   H16 0402
       Revision: 00006001
       Coding: 0000000002
       VCID: 75E67B7DD4D619E9CA-8020
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 48000AB8A05BB1C040100080100009C4430000DD524D8960808404040040
       VCID: 3878B2498B44A48111-806C
       Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 17011  26  0601
       Coding: 00D7B7
       Subsystem 2 - Part No: 1Z0 951 171
       Component: Innenraumuebe  008 5101
                014 - Defective
                        Reset counter: 208
                        Mileage: 95807 km
                        Date: 2011.10.15
                        Time: 16:51:33
                        Voltage: 12.70 V
                            Term 50 Off
                014 - Defective
                        Reset counter: 208
                        Mileage: 95807 km
                        Date: 2011.10.15
                        Time: 16:51:33
       Component: Q4 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PC235WLP
       Coding: 0020788
       VCID: 3D76A35D646681A9C2-8068
       Subsystem 1 - Serial number: 6332MSME5B2218000
       Subsystem 2 - Serial number: 6342MSME5A360558E
       Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20110122301821
       Coding: 5080140000
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 77FA7175CEDA6BF9D8-8022
       Part No SW: 1Z0 920 903 L    HW: 1Z0 920 903 L
       Component: KOMBI         H05 0405
       Coding: 410A01
       Shop #: WSC 73430 031 00084
       VCID: 3E74A451A1609AB1DB-806A
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 150111F1000395
       Coding: 351303
       VCID: 30688A6963347CC159-8064
       Component: IMMO          H05 0405
       VCID: 6ADC58018D68C61157-803E
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2120
       Coding: 0000756
       Shop #: WSC 73430 790 00085
       VCID: 4898C2893BA4D40161-801C
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 74     3201
       Revision: 00H20000
       VCID: 34608679572C40E13D-8060
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000756
       VCID: 479AC1B536BADB7968-8012
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
       Component: BOLERO        010 0054
       Revision: 0A001001    Serial number: SKZ1Z3L9437719
       Coding: 050004000001
       VCID: 3566BB7D9C5659E90A-8060
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012565
       VCID: 326C8061AD384ED12F-8066
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 33628565522247D924-8066
    End-------------------------(Elapsed Time: 01:53)--------------------------
  8. Likes Uwe liked this post
  9. #8
    New User
    May 2017
    Is that scan log any good
  10. #9
    New User
    May 2017
    Is anyone able to see what's wrong from the scan?
  11. #10
    New User
    May 2017
    I forgot to say my front drls are the factory fitted LED type. Also now I have 2 tail lights out that throw up a bulb error
