Results 1 to 9 of 9
Thread: Passat B8 (3G) Daytime Running Light Behaviour
    Northern Ireland
    Scan: (please ignore all Databus DTC's)
    Thursday,18,May,2017,18:54:46:49196
    VCDS Version: 17.1.3.0 (x64)
    Workshop Code: 874 00874 000874
    VIN: WVWZZZ3CZGExxxxxx   License Plate:
    Chassis Type: 3C (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
              6C BB BC
    VIN: WVWZZZ3CZGExxxxxx   Mileage: 16496km-10250miles
    Address 01: Engine (J623-CUAA)       Labels: 03N-906-026-CUA.clb
       Part No SW: 03N 906 026 E    HW: 03N 907 309
       Component: R4 2,0L EDC   H23 1754
       Revision: A1H23---
       Coding: 01250012036705083000
       Shop #: WSC 05311 115 00300
       ASAM Dataset: EV_ECM20BTD01103N906026E 001002
       ROD: EV_ECM20BTD01103N906026E.rod
       VCID: 2D55717A7CD1122972-8078
    Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
       Part No SW: 0DL 300 011 H    HW: 0BH 927 711 F
       Component: GSG DQ500     H10 5201
       Revision: 00H10V01
       ROD: EV_TCMDQ500021_VW41.rod
       Revision: 00000000    Serial number: 62615000001225
       Coding: 0EEC938F54280B6E077E070841C46970C92AD0E0E08296F5186250F8C209
       Shop #: WSC 12345 111 12345
       ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
       VCID: 7AFF8A26FD1F7591A7-802E
    8277 - Databus
              U1122 00 [009] - Implausible Message
                        Reset counter: 185
                        Date: 2017.05.13
                        Time: 10:51:12
    8299 - Databus
                        Reset counter: 185
                        Date: 2017.05.13
                        Time: 10:51:12
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0710
       Revision: 00026000    Serial number: 0380968757
       Coding: 000F0F0703
       ASAM Dataset: EV_KessyHellaMQBAB 004032
       VCID: 397D552AB899BE89EE-806C
       Part No SW: 5G2 907 044     HW: 5G2 907 044
       Revision: 00001K10
       Coding: 11120104202100011015504C0010180A
       Shop #: WSC 00015 115 00001
       ROD: EV_ACClimaBHBVW37X_004_VW48.rod
       VCID: 66C7CE5699A7E17173-8032
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580309150065
       Coding: 03011C46C2C102FF07804094B11807281880000000000000000000000000
       Shop #: WSC 00015 115 08193
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: 0301F7C28AD53459F4-8056
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    150727  043 0607
       Serial number:         150820165011
       Component: RLHS  037 0059
       Serial number: S2Y15M09D23H21M17S56
       Coding: 90A8DD
       Light switch:
       Serial number: 11 06 2015  10001099
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY152170WU6
       Serial number: 00000000000063683899
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391526001331
       Coding: 0071151811
       VCID: 448334DECF5BF3618D-8010
    Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200678251FFC428949C804D
       Shop #: WSC 05311 115 00090
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3463641E9FFB43E13D-8060
    0836 - Databus
                        Reset counter: 239
                        Mileage: 15407 km
                        Date: 2017.05.03
                        Time: 19:56:36
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 12.9 V
                        Velocity_vehicle_reference: 0.20 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.77 m/s²
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0120
       Serial number: 19091541350191
       ROD: EV_DRCONTITEMIC.rod
       VCID: 377953128E8DA8F918-8062
       Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003SSPJF5JS+
       Coding: 98FCC0C0008000005C5400CC008800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7EF78636E13759B19B-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G2857705E0261P00127
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G2857706E0260P01251
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 000 609 15
       Serial number: 3576U0000001C969661F
       Subsystem 4 - Part No SW: -----------    HW: 454 000 609 15
       Serial number: 3586U0000006D969661M
       Subsystem 5 - Part No SW: -----------    HW: 454 800 609 15
       Serial number: 3516R78332908000000$
       Subsystem 6 - Part No SW: -----------    HW: 454 800 909 15
       Serial number: 3526R5E0B61080000002
       Subsystem 7 - Part No SW: -----------    HW: 454 803 108 15
       Serial number: 3556V386625080000002
       Part No SW: 3Q0 953 521 AL    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0185
       Revision: FF033033    Serial number: 20140801500212
       Coding: 8010
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       ROD: EV_SMLSVALEOMQBLRH.rod
       Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
       Component: KOMBI         411 1340
       Coding: 27A50018BF80AE0001867F011000000000000000
       Shop #: WSC 00874 210 00000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009048
       VCID: 275983525E2D387988-8072
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2227
       Revision: --------    Serial number: 16091510800242
       Coding: 030300045F017300FB00025E9C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 75E5991AD4011AE9CA-8020
       Serial number: 29160000688370046133
       Coding: 2FFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 6808707503
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 0308201500010237
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Serial number: HA1-00028.07.15
       Coding: 0301
       VCID: 4A9F1AE6ED7F251177-801E
       Serial number: 15000073687012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71EDAD0AA06936C916-8024
       Serial number: 140915BIC20916
       Coding: 001F0A20D001028000001000
       VCID: 438137C2CA55F459B4-8016
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 0002
       Shop #: WSC 00015 115 00300
       ROD: EV_SteerAssisMQB_VW31.rod
       Serial number: 100915BIA01933
       Coding: 001F0020D001028000001000
       VCID: 428F32C6D54FFD51BF-8016
       Coding: 03A602000F200200
       Shop #: WSC 05311 000 08193
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       VCID: 3F893B32A6BD90B9D0-806A
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0627
       Coding: 02840101FF00000051111101008808001F0100D601200100CF
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 306B680E6BE37FC159-8064
       Component: ABT_Std-2_Nav  H43 4064
       Serial number: VWZ6Z9R2580238
       Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
       Component: ECE1 2017  --- 0730
              B201A 00 [009] -  -
                        Fault Frequency: 16
                        Reset counter: 192
                        Mileage: 15378 km
                        Date: 2017.05.03
                        Time: 19:26:10
                        Voltage terminal 30: 12.6 V
                        Status_Software_Version_Management-module_name: C
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
       Part No SW: 5Q0 980 568     HW: 5Q0 980 568
       Component: RVC Compact+  H03 0100
       Coding: 01000101E2002017000048
       ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
       ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW48.rod
    13705497 - Databus
                        Reset counter: 175
                        Mileage: 15378 km
                        Date: 2017.05.03
                        Time: 19:26:11
                        ARA_error_bits: 0
                        ARA_function_operating_time: 0.0000 s
                        Poor_image_quality_reason: Environmental conditions
                        Poor_image_quality_reason: 0.0000
                        Camera_System_Operating_Condition: passive
    13705498 - Databus
                        Reset counter: 175
                        Mileage: 15378 km
                        Date: 2017.05.03
                        Time: 19:26:11
                        ARA_error_bits: 0
    Address BB: Door Rear Drv (J388)       Labels: None
       Serial number: 270815BHR05229
       Coding: 000E00200101028000001000
       VCID: 458529DAC461CA699A-8010
    Address BC: Door Rear Pass (J389)       Labels: None
       Serial number: 270815BHR0522B
    End-------------------------(Elapsed Time: 05:40)--------------------------
    Fitted to the vehicle are the Premium Adaptive LED headlamps, the current DRL state is as below;
    What I would like the behaviour to be is this; (circled LED also active as DRL)
    The circled LED is active when the dipped beam headlights are on so I'm guessing its actually do-able?
    I did look in the Adaption channels of 09-Cent Elec and got confused over the numerous lighting options hence my question on here
    PS - If anyone knows how to clear the error in 5F, please let me know as it appeared after I updated the nav maps via the VW website.
              B201A 00 [009] -  -
                        Fault Frequency: 16
                        Reset counter: 192
                        Mileage: 15378 km
                        Date: 2017.05.03
                        Time: 19:26:10
    Dec 2016
    DE
    As for the SVM error, perform the following:
    1. goto http://xor.pw/
    2. in the field I. Input insert the value you read from the adaption channel "IDE02502" in the 5F module (without spaces)
    3. insert the value "51666" into II. Input and set its type to "decimal"
    4. click the XOR button
    5. input the result as new value in the adaption channel "IDE02502" (please remember to add the space between the second and third digit)
    This should allow you to remove the error.
    Regarding the DRL I'd suggest you post an adpmap of your BCM.
  3. Likes drennie599, Uwe, Dana, Jef, fzanicotti liked this post
    Northern Ireland
    Thanks for that, I'll sort that error tomorrow
    By adpmap you mean following this ... http://www.ross-tech.com/vcds/tour/c...annels-map.php ?
    The inner 'U' definitely does have LED, see the picture I've just taken below showing Coming Home & Leaving Home behaviour and dipped headlights 'on' behaviour respectively;
    You can clearly see that they are illuminated, just in a dimmed state.
    Coming / Leaving Home
    Dipped Headlights
    Northern Ireland
    See admap below in Uwe's post
    In-line like this is preferred here:
    ;SW:5Q0-937-086-AK   HW:5Q0-937-086-AK ---  Cent. Elect.,,,,
    ;Component:BCM PQ37BOSCH 028 0162, Coding:03011C46C2C102FF07804094B11807281880000000000000000000000000,,,
    ;EV_BodyContrModul1UDSBosc,15002,EV_BCMBOSCH_016_AU37.rod,,
    ;Friday,19,May,2017,16:55:48:49196
    ;VCDS Version: Release 17.1.3 (x64)  Data version: 20170320 DS267.7,,,,
    ;VCID: 0301F7C28AD53459F4-8056,,,,
    IDE00001-ENG99061-Production mode-Access control,not active ,,,
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active ,,,
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,,,
    IDE00001-ENG112304-Production mode-Heckwischer,not active ,,,
    IDE00001-ENG98647-Production mode-Interior lighting,not active ,,,
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active ,,,
    IDE00001-ENG115731-Production mode-Virtuel_pedal,not active ,,,
    IDE00002-Transport mode,active ,,,
    IDE00820-Activating and deactivating all development messages,not active ,,,
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,,,
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10,,,
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,,,
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,,,
    IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition,not active ,,,
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,,,
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,,,
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,,,
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,,,
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2550 ms,,,
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1200 ms,,,
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,,,
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,,,
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1200 ms,,,
    IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen,not active ,,,
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,,,
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,,,
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,,,
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0,,,
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,,,
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,,,
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,,,
    IDE01550-Service position,153.30 °,,,
    IDE02152-Characteristics in production mode,2000 ms,,,
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,,,
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,,,
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,,,
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,,,
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,,,
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz ,,,
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,,,
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,,,
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,,,
    IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active ,,,
    IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,,,
    IDE02332-Deactivate production mode,0,,,
    IDE02488-DWA Interior monitoring,100%,,,
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,,,
    IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,,,
    IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s,,,
    IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s,,,
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,,,
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,,,
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,,,
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,,,
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,,,
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,,,
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,,,
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,,,
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,,,
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80%,,,
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80%,,,
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,10%,,,
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,,,
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,,,
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,,,
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.25 °,,,
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,,,
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,,,
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,,,
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,,,
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,,,
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,,,
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,,,
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,,,
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,,,
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,,,
    IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active ,,,
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,,,
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,,,
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3,,,
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,,,
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,,,
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,,,
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,,,
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.1,,,
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00%,,,
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,,,
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,,,
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,,,
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,,,
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,,,
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,,,
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,,,
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,,,
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,,,
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,,,
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,,,
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,,,
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,,,
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,,,
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,,,
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,,,
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,,,
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,,,
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,,,
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,,,
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s,,,
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s,,,
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,,,
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,,,
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,,,
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,,,
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,,,
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,,,
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,,,
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,,,
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,,,
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,,,
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,,,
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,,,
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,,,
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,,,
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,,,
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,,,
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,,,
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,,,
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,,,
    IDE05142-ENG116706-Access control-Autounlock NAR,not active ,,,
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,,,
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,,,
    IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern,not active ,,,
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,,,
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,,,
    IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active ,,,
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,,,
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,,,
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,,,
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,,,
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,,,
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,,,
    IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung,not active ,,,
    IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion,not active ,,,
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,,,
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,,,
    IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s,,,
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,,,
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,,,
    IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung,not active ,,,
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,,,
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,,,
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,,,
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,,,
    IDE05142-ENG115758-Access control-Valet Parking,not active ,,,
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,,,
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,,,
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,,,
    IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch ,,,
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,,,
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,,,
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,,,
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,,,
    IDE05143-MAS02985-Writing parameter-Value,130,,,
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,,,
    IDE05144-Read parameter address,FE 00 00 ,,,
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34,,,
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,,,
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,0,,,
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,0,,,
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38,,,
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42,,,
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,0,,,
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,0,,,
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,20,,,
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,10,,,
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,8,,,
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18,,,
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48,,,
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,9,,,
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19,,,
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29,,,
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,,,
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,,,
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28,,,
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,1C ,,,
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1A ,,,
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,9,,,
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,,,
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,,,
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,0,,,
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,0,,,
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,0,,,
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,0,,,
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,0,,,
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,,,
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44,,,
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36,,,
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40,,,
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,0,,,
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,0,,,
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,,,
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,,,
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,,,
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,,,
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,,,
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,,,
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,,,
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,,,
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,,,
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,,,
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,,,
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,,,
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,minimize ,,,
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,,,
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,,,
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,,,
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,minimize ,,,
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,minimize ,,,
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,,,
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,,,
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,minimize ,,,
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,minimize ,,,
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,,,
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,minimize ,,,
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,,,
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,,,
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,,,
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,,,
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,,,
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,,,
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,,,
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,,,
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,,,
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,,,
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,,,
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,,,
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,,,
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,,,
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,,,
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,,,
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,,,
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,,,
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,,,
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,,,
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,,,
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,,,
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,,,
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,,,
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,,,
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,,,
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,,,
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,,,
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,,,
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,,,
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,,,
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,,,
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,,,
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,,,
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,,,
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,,,
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,,,
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,,,
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,,,
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,,,
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,,,
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,,,
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,,,
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,,,
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,,,
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,,,
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,,,
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,,,
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,,,
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,,,
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,,,
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,,,
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,,,
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,,,
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,,,
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,,,
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,,,
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,,,
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,minimize ,,,
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,,,
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,,,
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,,,
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,,,
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,,,
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,,,
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,,,
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,,,
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,,,
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,,,
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,minimize ,,,
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,,,
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,,,
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,,,
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,,,
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,,,
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,,,
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,,,
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,,,
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,,,
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,,,
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,,,
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127,,,
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127,,,
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0,,,
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0,,,
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100,,,
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100,,,
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0,,,
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0,,,
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100,,,
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100,,,
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100,,,
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100,,,
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100,,,
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100,,,
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100,,,
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100,,,
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100,,,
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100,,,
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127,,,
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,90,,,
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100,,,
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100,,,
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100,,,
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100,,,
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100,,,
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0,,,
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0,,,
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0,,,
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0,,,
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127,,,
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127,,,
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127,,,
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127,,,
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,0,,,
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,0,,,
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0,,,
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0,,,
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0,,,
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0,,,
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0,,,
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0,,,
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0,,,
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0,,,
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,100,,,
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,100,,,
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0,,,
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0,,,
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,28,,,
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0,,,
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0,,,
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0,,,
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0,,,
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0,,,
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0,,,
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0,,,
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0,,,
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0,,,
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0,,,
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,28,,,
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0,,,
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0,,,
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0,,,
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0,,,
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0,,,
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0,,,
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0,,,
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0,,,
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0,,,
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0,,,
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0,,,
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0,,,
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0,,,
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0,,,
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0,,,
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0,,,
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0,,,
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0,,,
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0,,,
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0,,,
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0,,,
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0,,,
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0,,,
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,28,,,
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0,,,
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0,,,
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0,,,
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0,,,
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0,,,
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0,,,
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0,,,
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,100,,,
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0,,,
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0,,,
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,28,,,
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0,,,
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0,,,
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0,,,
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0,,,
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0,,,
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127,,,
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127,,,
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0,,,
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0,,,
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0,,,
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0,,,
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0,,,
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0,,,
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0,,,
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0,,,
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0,,,
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0,,,
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0,,,
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0,,,
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0,,,
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0,,,
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0,,,
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0,,,
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,28,,,
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0,,,
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0,,,
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0,,,
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0,,,
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0,,,
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0,,,
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0,,,
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0,,,
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0,,,
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0,,,
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,28,,,
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0,,,
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0,,,
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0,,,
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0,,,
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0,,,
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0,,,
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0,,,
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0,,,
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0,,,
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0,,,
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0,,,
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14,,,
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15,,,
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,0,,,
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,0,,,
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22,,,
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23,,,
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,0,,,
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,0,,,
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,3A ,,,
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,39,,,
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16,,,
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18,,,
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,,,
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,,,
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,,,
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,,,
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29,,,
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,,,
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30,,,
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2F ,,,
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,36,,,
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,37,,,
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32,,,
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,,,
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,2,,,
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,0,,,
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,0,,,
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,0,,,
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,0,,,
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49,,,
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,,,
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,,,
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,,,
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,0,,,
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,0,,,
    IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,,,
    IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,,,
    IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,,,
    IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,,,
    IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,,,
    IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,,,
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,,,
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,,,
    IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,,,
    IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,,,
    IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,,,
    IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,,,
    IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,,,
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,,,
    IDE05145-ENG116309-Light configuration-Lasttyp 23,32 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116328-Light configuration-Lasttyp 24,32 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,,,
    IDE05145-ENG116366-Light configuration-Lasttyp 26,43 - allgemeine LED ,,,
    IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116404-Light configuration-Lasttyp 28,34 - LED Bremsleuchten ,,,
    IDE05145-ENG116423-Light configuration-Lasttyp 29,37 - allgemeine LED bis 12W ,,,
    IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,,,
    IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,,,
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,,,
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,,,
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,,,
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,,,
    IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,,,
    IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,,,
    IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,,,
    IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,,,
    IDE05145-ENG116024-Light configuration-Lasttyp 8,not active ,,,
    IDE05145-ENG116043-Light configuration-Lasttyp 9,not active ,,,
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,,,
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,,,
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,,,
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,,,
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,,,
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,,,
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,,,
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,,,
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,,,
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,,,
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,,,
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,,,
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,,,
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,,,
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,,,
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,,,
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,,,
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,,,
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,,,
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,,,
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,,,
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,,,
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,,,
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,,,
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,,,
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,,,
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,,,
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,,,
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,,,
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,,,
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,,,
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,,,
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,,,
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,,,
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,,,
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,9,,,
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0,,,
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2,,,
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4,,,
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0,,,
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0,,,
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18,,,
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19,,,
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0,,,
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0,,,
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,8,,,
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,8,,,
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2,,,
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4,,,
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20,,,
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24,,,
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24,,,
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24,,,
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8,,,
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8,,,
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8,,,
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,28,,,
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8,,,
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,24,,,
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25,,,
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20,,,
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43,,,
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0,,,
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0,,,
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0,,,
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0,,,
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20,,,
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20,,,
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11,,,
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12,,,
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,0,,,
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,0,,,
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0,,,
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0,,,
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0,,,
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0,,,
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0,,,
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0,,,
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0,,,
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0,,,
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,10,,,
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0,,,
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0,,,
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0,,,
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0,,,
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0,,,
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,36,,,
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,9,,,
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,10,,,
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0,,,
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0,,,
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0,,,
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0,,,
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0,,,
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0,,,
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0,,,
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0,,,
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0,,,
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0,,,
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0,,,
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0,,,
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0,,,
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15,,,
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15,,,
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0,,,
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0,,,
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0,,,
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0,,,
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0,,,
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0,,,
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0,,,
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0,,,
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0,,,
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,24,,,
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,24,,,
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0,,,
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0,,,
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,6,,,
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0,,,
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0,,,
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0,,,
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,6,,,
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,7,,,
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0,,,
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0,,,
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,24,,,
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,28,,,
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0,,,
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,7,,,
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0,,,
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0,,,
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0,,,
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0,,,
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0,,,
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0,,,
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0,,,
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0,,,
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0,,,
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0,,,
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0,,,
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0,,,
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0,,,
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0,,,
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0,,,
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0,,,
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0,,,
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0,,,
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0,,,
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0,,,
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0,,,
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0,,,
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0,,,
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0,,,
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0,,,
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0,,,
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0,,,
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,24,,,
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,24,,,
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0,,,
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0,,,
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0,,,
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0,,,
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0,,,
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0,,,
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0,,,
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0,,,
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0,,,
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0,,,
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0,,,
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0,,,
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0,,,
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0,,,
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0,,,
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0,,,
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0,,,
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0,,,
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0,,,
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0,,,
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0,,,
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0,,,
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0,,,
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0,,,
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0,,,
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0,,,
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0,,,
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0,,,
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0,,,
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,8,,,
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0,,,
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0,,,
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0,,,
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0,,,
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0,,,
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0,,,
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0,,,
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,28,,,
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0,,,
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0,,,
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,8,,,
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0,,,
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0,,,
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0,,,
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0,,,
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0,,,
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,8,,,
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,8,,,
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0,,,
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0,,,
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0,,,
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0,,,
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0,,,
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0,,,
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0,,,
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0,,,
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0,,,
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0,,,
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0,,,
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0,,,
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0,,,
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0,,,
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0,,,
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0,,,
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,9,,,
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0,,,
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0,,,
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0,,,
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0,,,
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0,,,
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0,,,
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0,,,
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0,,,
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0,,,
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0,,,
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0,,,
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0,,,
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0,,,
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0,,,
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0,,,
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9,,,
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0,,,
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0,,,
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0,,,
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0,,,
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,10,,,
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10,,,
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0,,,
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0,,,
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0,,,
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0,,,
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0,,,
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0,,,
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0,,,
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0,,,
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0,,,
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0,,,
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0,,,
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0,,,
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,18,,,
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0,,,
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0,,,
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0,,,
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0,,,
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0,,,
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0,,,
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0,,,
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0,,,
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0,,,
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0,,,
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,19,,,
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0,,,
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0,,,
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0,,,
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0,,,
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0,,,
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0,,,
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0,,,
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0,,,
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0,,,
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0,,,
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0,,,
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0,,,
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0,,,
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0,,,
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0,,,
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0,,,
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0,,,
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0,,,
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0,,,
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0,,,
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0,,,
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0,,,
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0,,,
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0,,,
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0,,,
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0,,,
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0,,,
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0,,,
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0,,,
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0,,,
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0,,,
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0,,,
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0,,,
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0,,,
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0,,,
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0,,,
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0,,,
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0,,,
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0,,,
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0,,,
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0,,,
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0,,,
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0,,,
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0,,,
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0,,,
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0,,,
    IDE05822-DWA Vehicle inclination sensor,100%,,,
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 C2 28 29 ,,,
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,,,
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,,,
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,23.00 °C,,,
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C,,,
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C,,,
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,,,
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,,,
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,,,
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,,,
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,,,
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C,,,
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,53.00 °C,,,
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C,,,
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,53.00 °C,,,
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,not active ,,,
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,,,
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,,,
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,,,
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,,,
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100%,,,
    IDE06425-Roller test bench mode: functional,not active ,,,
    IDE06507-MAS13125-Button in center console-Funktion Taster 1,Start-stop ,,,
    IDE06507-MAS13129-Button in center console-Funktion Taster 2,GTE ,,,
    IDE06507-MAS13132-Button in center console-Funktion Taster 3,Driving program ,,,
    IDE06507-MAS13135-Button in center console-Funktion Taster 4,Steering wheel heater ,,,
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,,,
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,,,
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,,,
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,,,
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,,,
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,,,
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,,,
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,,,
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,,,
    IDE07356-Position during interval mode,24.89 °,,,
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,,,
    IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,,,
    IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,,,
    IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten ,,,
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,,,
    IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit,24 s,,,
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,,,
    IDE08542-IDE02022-Access control 2-Comfort opening,not active ,,,
    IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active ,,,
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,,,
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,,,
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,,,
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,,,
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,,,
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,,,
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,,,
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,,,
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,,,
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,,,
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,,,
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,,,
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,,,
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,,,
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,,,
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,,,
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,,,
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,,,
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,,,
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,,,
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,,,
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,,,
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active ,,,
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active ,,,
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,,,
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,,,
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,,,
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,,,
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,,,
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,,,
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,,,
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,,,
    IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active ,,,
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,,,
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,,,
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,,,
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,,,
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,,,
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,active ,,,
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,,,
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,,,
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,,,
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,,,
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,,,
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,,,
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,,,
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,,,
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,,,
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,,,
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,,,
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,,,
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,,,
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,,,
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,,,
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,,,
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,,,
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,,,
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,,,
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,,,
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,,,
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,,,
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,,,
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,,,
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,,,
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,,,
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,,,
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,,,
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,,,
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,,,
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,,,
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,,,
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0,,,
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0,,,
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0,,,
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225,,,
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225,,,
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225,,,
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80%,,,
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0,,,
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80%,,,
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225,,,
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225,,,
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225,,,
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,,,
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,,,
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225,,,
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225,,,
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225,,,
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,,,
    IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,,,
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,,,
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,,,
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,,,
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,,,
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,,,
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,,,
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,,,
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,,,
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,,,
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,,,
    IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active ,,,
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,,,
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,,,
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,,,
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30%,,,
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30%,,,
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30%,,,
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30%,,,
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50%,,,
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50%,,,
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50%,,,
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50%,,,
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75%,,,
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75%,,,
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80%,,,
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80%,,,
    IDE10298-Alternating park position 1,8.30 °,,,
    IDE10299-Alternating park position 2,24.89 °,,,
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,64,,,
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,28,,,
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,28,,,
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,3C ,,,
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,64,,,
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,64,,,
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,64,,,
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,3C ,,,
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,1,,,
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,3C ,,,
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,0,,,
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,0,,,
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,0,,,
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,0,,,
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,0,,,
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,0,,,
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,1,,,
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,1,,,
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,0,,,
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,0,,,
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,60%,,,
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100%,,,
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,60%,,,
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70%,,,
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100%,,,
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96%,,,
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100%,,,
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100%,,,
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100%,,,
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96%,,,
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,60%,,,
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100%,,,
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,60%,,,
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70%,,,
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100%,,,
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96%,,,
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100%,,,
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100%,,,
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100%,,,
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96%,,,
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100%,,,
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,60%,,,
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70%,,,
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100%,,,
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96%,,,
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100%,,,
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100%,,,
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100%,,,
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96%,,,
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100%,,,
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,60%,,,
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0%,,,
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100%,,,
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0%,,,
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100%,,,
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100%,,,
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100%,,,
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0%,,,
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100%,,,
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,60%,,,
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70%,,,
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100%,,,
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96%,,,
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100%,,,
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100%,,,
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100%,,,
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96%,,,
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127%,,,
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127%,,,
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127%,,,
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100%,,,
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100%,,,
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127%,,,
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126%,,,
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126%,,,
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126%,,,
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0%,,,
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126%,,,
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126%,,,
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126%,,,
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126%,,,
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126%,,,
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127%,,,
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127%,,,
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127%,,,
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127%,,,
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100%,,,
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126%,,,
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126%,,,
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100%,,,
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126%,,,
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100%,,,
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100%,,,
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100%,,,
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126%,,,
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100%,,,
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60%,,,
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70%,,,
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100%,,,
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96%,,,
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100%,,,
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100%,,,
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100%,,,
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96%,,,
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,60%,,,
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,60%,,,
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100%,,,
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100%,,,
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100%,,,
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,60%,,,
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70%,,,
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100%,,,
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96%,,,
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100%,,,
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100%,,,
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100%,,,
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96%,,,
    IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,0 ms,,,
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0 s,,,
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0 s,,,
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0 s,,,
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0 s,,,
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0 s,,,
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0 s,,,
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,20 s,,,
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0 s,,,
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,20 s,,,
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0 s,,,
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0 s,,,
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,5 s,,,
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0 s,,,
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0 s,,,
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0 s,,,
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0 s,,,
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0 s,,,
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0 s,,,
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0 s,,,
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0 s,,,
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0 s,,,
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0 s,,,
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0 s,,,
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0 s,,,
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0 s,,,
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0 s,,,
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0 s,,,
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0 s,,,
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0 s,,,
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0 s,,,
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0 s,,,
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0 s,,,
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0 s,,,
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0 s,,,
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0 s,,,
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0 s,,,
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0 s,,,
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0 s,,,
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0 s,,,
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0 s,,,
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0 s,,,
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0 s,,,
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,0,,,
    IDE11714-ENG02360-Ambientelicht Farbliste-Blauwert Farbe 10,E1 ,,,
    IDE11714-ENG02342-Ambientelicht Farbliste-Blauwert Farbe 4,E1 ,,,
    IDE11714-ENG02345-Ambientelicht Farbliste-Blauwert Farbe 5,E1 ,,,
    IDE11714-ENG02348-Ambientelicht Farbliste-Blauwert Farbe 6,E1 ,,,
    IDE11714-ENG02351-Ambientelicht Farbliste-Blauwert Farbe 7,E1 ,,,
    IDE11714-ENG02354-Ambientelicht Farbliste-Blauwert Farbe 8,E1 ,,,
    IDE11714-ENG02357-Ambientelicht Farbliste-Blauwert Farbe 9,E1 ,,,
    IDE11714-ENG02359-Ambientelicht Farbliste-Gruenwert Farbe 10,E1 ,,,
    IDE11714-ENG02341-Ambientelicht Farbliste-Gruenwert Farbe 4,E1 ,,,
    IDE11714-ENG02344-Ambientelicht Farbliste-Gruenwert Farbe 5,E1 ,,,
    IDE11714-ENG02347-Ambientelicht Farbliste-Gruenwert Farbe 6,E1 ,,,
    IDE11714-ENG02350-Ambientelicht Farbliste-Gruenwert Farbe 7,E1 ,,,
    IDE11714-ENG02353-Ambientelicht Farbliste-Gruenwert Farbe 8,E1 ,,,
    IDE11714-ENG02356-Ambientelicht Farbliste-Gruenwert Farbe 9,E1 ,,,
    IDE11714-ENG02358-Ambientelicht Farbliste-Rotwert Farbe 10,E1 ,,,
    IDE11714-ENG02340-Ambientelicht Farbliste-Rotwert Farbe 4,E1 ,,,
    IDE11714-ENG02343-Ambientelicht Farbliste-Rotwert Farbe 5,E1 ,,,
    IDE11714-ENG02346-Ambientelicht Farbliste-Rotwert Farbe 6,E1 ,,,
    IDE11714-ENG02349-Ambientelicht Farbliste-Rotwert Farbe 7,E1 ,,,
    IDE11714-ENG02352-Ambientelicht Farbliste-Rotwert Farbe 8,E1 ,,,
    IDE11714-ENG02355-Ambientelicht Farbliste-Rotwert Farbe 9,E1 ,,,
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active ,,,
    MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active ,,,
    MAS05055-lower turn position,26.30 °,,,
    MAS05056-upper turn position,171.30 °,,,
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,,,
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,,,
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,,,
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,,,
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,,,
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,,,
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,,,
    MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1,80 s,,,
    MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3,20.000 ms,,,
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,,,
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,,,
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,,,
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,,,
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,,,
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,,,
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,,,
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,active ,,,
    MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,60 lx,,,
    MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,110 lx,,,
    MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,,,
    MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO,30 lx,,,
    MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten,60 lx,,,
    MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten,110 lx,,,
    MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,80,,,
    MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell,100 lx,,,
    MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung,4500 mV,,,
    MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke,300 lx,,,
    MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung,2000 mV,,,
    MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke,0 lx,,,
    MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung,2,,,
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1,,,
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1,,,
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1,,,
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1,,,
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1,,,
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1,,,
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1,,,
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1,,,
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1,,,
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1,,,
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1,,,
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1,,,
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1,,,
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1,,,
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1,,,
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,,,
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,,,
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,,,
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,,,
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,,,
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,,,
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,,,
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,,,
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,,,
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,,,
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,,,
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,,,
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,,,
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,,,
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,,,
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed ,,,
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed ,,,
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed ,,,
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed ,,,
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed ,,,
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed ,,,
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed ,,,
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,,,
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed ,,,
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed ,,,
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed ,,,
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed ,,,
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed ,,,
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed ,,,
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed ,,,
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0,,,
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0,,,
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0,,,
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0,,,
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0,,,
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0,,,
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0,,,
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0,,,
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0,,,
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0,,,
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0,,,
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0,,,
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0,,,
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0,,,
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0,,,
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0,,,
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0,,,
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0,,,
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0,,,
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0,,,
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0,,,
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0,,,
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0,,,
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0,,,
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0,,,
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0,,,
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0,,,
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0,,,
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0,,,
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0,,,
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0,,,
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0,,,
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0,,,
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0,,,
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0,,,
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0,,,
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0,,,
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0,,,
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0,,,
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0,,,
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,,,
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed ,,,
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed ,,,
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed ,,,
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed ,,,
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed ,,,
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed ,,,
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed ,,,
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed ,,,
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed ,,,
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed ,,,
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,,,
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed ,,,
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,,,
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,,,
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed ,,,
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed ,,,
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed ,,,
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed ,,,
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed ,,,
    ENG126647-ENG98399-debug_light_function-Activation,0,,,
    ENG126647-ENG101417-debug_light_function-Adresse,0,,,
    ENG126647-ENG126820-debug_light_function-Bitmask,0,,,
    ENG126647-ENG126821-debug_light_function-Divisor,0,,,
    ENG126647-ENG98827-debug_light_function-Offset,0,,,
    ENG126647-ENG126822-debug_light_function-Polaritaet,0,,,
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0,,,
    ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,,,
    ENG122934-erase_error_table,55 00 00 ,,,
    ENG122933-error_mask,0 bit,,,
    ENG117283-Frontwaschfunktion,10,,,
    ENG99457-ENG117394-Head area heater-blower_speed,1,,,
    ENG99457-ENG98971-Head area heater-Temperature,-2,,,
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,,,
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,,,
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,,,
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,,,
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,,,
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,,,
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,,,
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,,,
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,,,
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,,,
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,,,
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00%,,,
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00%,,,
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00%,,,
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00%,,,
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00%,,,
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00%,,,
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00%,,,
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00%,,,
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00%,,,
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00%,,,
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00%,,,
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0,,,
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50,,,
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0,,,
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100,,,
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200,,,
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253,,,
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0,,,
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0,,,
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0,,,
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0,,,
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0,,,
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,,,
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,,,
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,,,
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,,,
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200,,,
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500,,,
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0,,,
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,,,
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,,,
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,,,
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,,,
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,,,
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,,,
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,,,
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,,,
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,,,
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,,,
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,,,
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,,,
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,,,
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,,,
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,,,
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00%,,,
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00%,,,
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00%,,,
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00%,,,
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00%,,,
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00%,,,
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00%,,,
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00%,,,
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00%,,,
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00%,,,
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00%,,,
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00%,,,
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00%,,,
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00%,,,
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00%,,,
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00%,,,
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00%,,,
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10,,,
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10,,,
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100,,,
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150,,,
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220,,,
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253,,,
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,,,
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,,,
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,,,
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,,,
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,,,
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16,,,
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16,,,
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100,,,
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100,,,
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100,,,
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,,,
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,,,
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,,,
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,,,
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,,,
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6,,,
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6,,,
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100,,,
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100,,,
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100,,,
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0,,,
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10,,,
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50,,,
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100,,,
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220,,,
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253,,,
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00%,,,
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00%,,,
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00%,,,
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00%,,,
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00%,,,
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00%,,,
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,,,
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,,,
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,,,
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,,,
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100,,,
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100,,,
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100,,,
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100,,,
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,,,
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,,,
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,,,
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,,,
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6,,,
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6,,,
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100,,,
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100,,,
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00%,,,
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00%,,,
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00%,,,
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00%,,,
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00%,,,
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00%,,,
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,,,
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,,,
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,,,
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,,,
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100,,,
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100,,,
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100,,,
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100,,,
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,,,
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,,,
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,,,
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,,,
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6,,,
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6,,,
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100,,,
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100,,,
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00%,,,
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00%,,,
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00%,,,
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00%,,,
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00%,,,
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00%,,,
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,,,
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,,,
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,,,
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,,,
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,,,
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00%,,,
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5,,,
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15,,,
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10,,,
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100,,,
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize ,,,
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize ,,,
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize ,,,
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127,,,
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0,,,
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0,,,
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0,,,
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14,,,
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34,,,
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,,,
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always ,,,
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,,,
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active ,,,
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active ,,,
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active ,,,
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active ,,,
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active ,,,
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active ,,,
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active ,,,
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize ,,,
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize ,,,
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize ,,,
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0,,,
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0,,,
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0,,,
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0,,,
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,0,,,
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,0,,,
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,,,
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always ,,,
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,,,
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active ,,,
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active ,,,
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active ,,,
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active ,,,
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active ,,,
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active ,,,
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active ,,,
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize ,,,
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize ,,,
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize ,,,
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0,,,
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0,,,
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0,,,
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0,,,
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,0,,,
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,0,,,
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,not active ,,,
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always ,,,
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active ,,,
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active ,,,
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active ,,,
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active ,,,
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active ,,,
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active ,,,
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active ,,,
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active ,,,
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize ,,,
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize ,,,
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize ,,,
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100,,,
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0,,,
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0,,,
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0,,,
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22,,,
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38,,,
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,,,
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always ,,,
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,,,
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,,,
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active ,,,
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active ,,,
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active ,,,
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active ,,,
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active ,,,
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active ,,,
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize ,,,
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize ,,,
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize ,,,
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100,,,
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0,,,
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0,,,
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0,,,
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23,,,
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42,,,
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,,,
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always ,,,
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,,,
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,,,
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active ,,,
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active ,,,
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active ,,,
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active ,,,
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active ,,,
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active ,,,
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,,,
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,,,
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,,,
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0,,,
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0,,,
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0,,,
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0,,,
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,0,,,
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,0,,,
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,,,
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,,,
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,,,
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,,,
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,,,
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,,,
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,,,
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,,,
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,,,
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,,,
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize ,,,
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize ,,,
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize ,,,
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100,,,
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,100,,,
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0,,,
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0,,,
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,3A ,,,
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,20,,,
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,,,
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,,,
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,,,
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake light ,,,
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active ,,,
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active ,,,
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active ,,,
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active ,,,
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active ,,,
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize ,,,
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize ,,,
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize ,,,
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100,,,
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,100,,,
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0,,,
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0,,,
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,39,,,
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,10,,,
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,,,
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,,,
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake light ,,,
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active ,,,
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active ,,,
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active ,,,
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active ,,,
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active ,,,
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,,,
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,,,
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,,,
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100,,,
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0,,,
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0,,,
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0,,,
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16,,,
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,8,,,
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,,,
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,,,
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase ,,,
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active ,,,
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,,,
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active ,,,
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active ,,,
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active ,,,
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active ,,,
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active ,,,
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,,,
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,,,
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,,,
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100,,,
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0,,,
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0,,,
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0,,,
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18,,,
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18,,,
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,,,
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,,,
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase ,,,
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active ,,,
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,,,
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active ,,,
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active ,,,
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active ,,,
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active ,,,
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active ,,,
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,,,
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,,,
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,,,
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127,,,
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0,,,
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0,,,
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0,,,
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15,,,
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,,,
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,,,
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,,,
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,,,
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active ,,,
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active ,,,
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active ,,,
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active ,,,
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active ,,,
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active ,,,
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active ,,,
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize ,,,
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,,,
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,,,
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100,,,
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0,,,
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0,,,
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0,,,
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,,,
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,9,,,
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,,,
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,,,
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,,,
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,,,
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,,,
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active ,,,
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,,,
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,,,
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,,,
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,,,
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize ,,,
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,,,
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,,,
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100,,,
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0,,,
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0,,,
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0,,,
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,,,
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19,,,
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,,,
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,,,
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,,,
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,,,
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,,,
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active ,,,
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,,,
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,,,
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,,,
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,,,
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,,,
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,,,
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,,,
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100,,,
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0,,,
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0,,,
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0,,,
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,,,
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29,,,
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,,,
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,,,
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light ,,,
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,,,
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active ,,,
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active ,,,
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active ,,,
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active ,,,
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active ,,,
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active ,,,
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,minimize ,,,
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,,,
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,,,
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100,,,
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0,,,
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0,,,
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0,,,
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29,,,
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,,,
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,,,
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always ,,,
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Blinken links aktiv (beide Phasen) ,,,
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Brake light ,,,
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,,,
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,,,
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,,,
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,,,
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,,,
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,,,
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,,,
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100,,,
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0,,,
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0,,,
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0,,,
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,,,
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,,,
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,,,
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always ,,,
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,,,
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Blinken rechts aktiv (beide Phasen) ,,,
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Brake light ,,,
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,,,
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,,,
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,,,
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,,,
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize ,,,
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize ,,,
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize ,,,
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127,,,
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0,,,
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0,,,
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0,,,
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30,,,
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28,,,
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED ,,,
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always ,,,
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,,,
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,,,
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,,,
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,,,
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,,,
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,,,
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,,,
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,,,
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,,,
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,,,
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,90,,,
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0,,,
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0,,,
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0,,,
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2F ,,,
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,1C ,,,
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,,,
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,,,
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,,,
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,,,
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active ,,,
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active ,,,
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active ,,,
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,,,
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,,,
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,,,
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,,,
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,,,
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,,,
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100,,,
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0,,,
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,100,,,
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0,,,
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36,,,
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,,,
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,,,
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,,,
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,,,
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Brake light ,,,
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active ,,,
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,,,
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,,,
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,,,
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,,,
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,,,
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize ,,,
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize ,,,
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100,,,
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0,,,
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0,,,
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0,,,
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,37,,,
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,9,,,
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,34 - LED Bremsleuchten ,,,
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,,,
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Brake light ,,,
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active ,,,
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,,,
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active ,,,
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active ,,,
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active ,,,
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active ,,,
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active ,,,
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize ,,,
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize ,,,
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize ,,,
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100,,,
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0,,,
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0,,,
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0,,,
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32,,,
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B ,,,
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,,,
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,,,
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht ,,,
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active ,,,
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active ,,,
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active ,,,
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active ,,,
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active ,,,
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active ,,,
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active ,,,
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize ,,,
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,,,
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,,,
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100,,,
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28,,,
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28,,,
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,28,,,
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,,,
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48,,,
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,,,
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always ,,,
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,,,
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active ,,,
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,,,
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,,,
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Nebellicht links ,,,
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active ,,,
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize ,,,
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize ,,,
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize ,,,
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100,,,
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0,,,
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0,,,
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0,,,
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,2,,,
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,0,,,
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,,,
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,,,
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light ,,,
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active ,,,
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active ,,,
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active ,,,
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active ,,,
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active ,,,
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active ,,,
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active ,,,
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize ,,,
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize ,,,
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize ,,,
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0,,,
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0,,,
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0,,,
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0,,,
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,0,,,
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,0,,,
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active ,,,
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always ,,,
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,,,
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active ,,,
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active ,,,
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active ,,,
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active ,,,
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active ,,,
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active ,,,
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active ,,,
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize ,,,
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize ,,,
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize ,,,
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0,,,
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0,,,
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0,,,
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0,,,
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,0,,,
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,0,,,
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active ,,,
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always ,,,
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,,,
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active ,,,
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active ,,,
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active ,,,
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active ,,,
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active ,,,
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active ,,,
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active ,,,
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize ,,,
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize ,,,
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize ,,,
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0,,,
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0,,,
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0,,,
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0,,,
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,0,,,
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,0,,,
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active ,,,
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always ,,,
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,,,
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active ,,,
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active ,,,
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active ,,,
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active ,,,
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active ,,,
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active ,,,
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active ,,,
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize ,,,
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize ,,,
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize ,,,
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0,,,
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0,,,
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0,,,
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0,,,
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,0,,,
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,0,,,
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active ,,,
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always ,,,
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,,,
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active ,,,
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active ,,,
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active ,,,
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active ,,,
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active ,,,
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active ,,,
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active ,,,
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize ,,,
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,,,
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,,,
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100,,,
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28,,,
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28,,,
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,28,,,
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,,,
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,,,
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,,,
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always ,,,
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,,,
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active ,,,
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,,,
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,,,
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,,,
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Nebellicht rechts ,,,
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active ,,,
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,,,
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize ,,,
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize ,,,
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127,,,
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0,,,
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127,,,
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0,,,
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49,,,
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,,,
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,,,
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always ,,,
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,,,
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active ,,,
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,,,
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active ,,,
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active ,,,
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active ,,,
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,,,
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize ,,,
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize ,,,
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127,,,
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0,,,
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127,,,
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0,,,
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,,,
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44,,,
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,,,
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always ,,,
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,,,
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active ,,,
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,,,
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active ,,,
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,,,
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active ,,,
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active ,,,
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize ,,,
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize ,,,
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize ,,,
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127,,,
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0,,,
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0,,,
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0,,,
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,,,
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36,,,
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,,,
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always ,,,
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links ,,,
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,,,
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,,,
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active ,,,
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active ,,,
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active ,,,
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active ,,,
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active ,,,
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize ,,,
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize ,,,
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize ,,,
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127,,,
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0,,,
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0,,,
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0,,,
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,,,
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40,,,
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,,,
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always ,,,
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts ,,,
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,,,
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,,,
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active ,,,
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active ,,,
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active ,,,
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active ,,,
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active ,,,
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize ,,,
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize ,,,
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize ,,,
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0,,,
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0,,,
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0,,,
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0,,,
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,0,,,
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,0,,,
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,,,
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always ,,,
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,,,
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,,,
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,,,
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,,,
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active ,,,
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active ,,,
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active ,,,
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active ,,,
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize ,,,
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize ,,,
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize ,,,
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0,,,
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0,,,
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0,,,
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0,,,
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,0,,,
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,0,,,
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,,,
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always ,,,
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,,,
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,,,
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,,,
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,,,
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active ,,,
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active ,,,
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active ,,,
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active ,,,
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,,,
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,,,
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,,,
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0,,,
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0,,,
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0,,,
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0,,,
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,0,,,
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,0,,,
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,,,
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,,,
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,,,
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,,,
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,,,
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,,,
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,,,
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,,,
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,,,
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,,,
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,,,
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,,,
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,,,
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,,,
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,,,
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,,,
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,,,
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00%,,,
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00%,,,
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00%,,,
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00%,,,
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110,,,
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5,,,
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00%,,,
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00%,,,
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00%,,,
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00%,,,
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00%,,,
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00%,,,
    ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,,,
    ENG98831-ENG02329-Personalisierung-Anzahl_Benutzerkonten,4,,,
    ENG98831-ENG02330-Personalisierung-Automatische_ Schluesselzuordnung,not active ,,,
    ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,,,
    ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv,active ,,,
    ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,,,
    ENG98831-ENG02331-Personalisierung-PSO_FSG_Setup2_Bit_0,not active ,,,
    ENG98831-ENG02332-Personalisierung-PSO_FSG_Setup2_Bit_1,active ,,,
    ENG98831-ENG02333-Personalisierung-PSO_FSG_Setup2_Bit_2,active ,,,
    ENG98831-ENG02334-Personalisierung-PSO_FSG_Setup2_Bit_3,not active ,,,
    ENG98831-ENG02335-Personalisierung-PSO_FSG_Setup2_Bit_4,not active ,,,
    ENG98831-ENG02336-Personalisierung-PSO_FSG_Setup2_Bit_5,not active ,,,
    ENG98831-ENG02337-Personalisierung-PSO_FSG_Setup2_Bit_6,not active ,,,
    ENG98831-ENG02338-Personalisierung-PSO_FSG_Setup2_Bit_7,not active ,,,
    ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,,,
    ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active ,,,
    ENG122927-RLS_close_glazing,2.00 s,,,
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,,,
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,,,
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,,,
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,,,
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,,,
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12,,,
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6,,,
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,,,
    ENG122929-RLS_LIN_Communication,4 s,,,
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,,,
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,,,
    ENG122930-RLS_tunel_gateway_recognize,5 s,,,
    ENG122935-RLS_Washer_Front,15 s,,,
    ENG122926-RLS_wiper_position_parking,15 s,,,
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 ,,,
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 ,,,
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 ,,,
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 ,,,
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,,,
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,,,
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,,,
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,,,
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,,,
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,,,
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40,,,
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60,,,
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30,,,
    Elapsed Time: 02:11,,,,
    ;SW:5Q0-937-086-AK   HW:5Q0-937-086-AK ---  Cent. Elect.,,,,
    ;Component:BCM PQ37BOSCH 028 0162, Coding:03011C46C2C102FF07804094B11807281880000000000000000000000000,,,
    ;EV_BodyContrModul1UDSBosc,15002,EV_BCMBOSCH_016_AU37.rod,,
    ;Friday,19,May,2017,16:59:33:49196
    ;VCDS Version: Release 17.1.3 (x64)  Data version: 20170320 DS267.7,,,,
    ;VCID: 0301F7C28AD53459F4-8056,,,,
    IDE00001-ENG99061-Production mode-Access control,not active ,,,
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active ,,,
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,,,
    IDE00001-ENG112304-Production mode-Heckwischer,not active ,,,
    IDE00001-ENG98647-Production mode-Interior lighting,not active ,,,
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active ,,,
    IDE00001-ENG115731-Production mode-Virtuel_pedal,not active ,,,
    IDE00002-Transport mode,active ,,,
    IDE00820-Activating and deactivating all development messages,not active ,,,
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,,,
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10,,,
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,,,
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,,,
    IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition,not active ,,,
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,,,
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,,,
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,,,
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,,,
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2550 ms,,,
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1200 ms,,,
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,,,
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,,,
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1200 ms,,,
    IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen,not active ,,,
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,,,
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,,,
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,,,
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0,,,
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,,,
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,,,
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,,,
    IDE01550-Service position,153.30 °,,,
    IDE02152-Characteristics in production mode,2000 ms,,,
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,,,
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,,,
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,,,
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,,,
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,,,
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz ,,,
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,,,
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,,,
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,,,
    IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active ,,,
    IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,,,
    IDE02332-Deactivate production mode,0,,,
    IDE02488-DWA Interior monitoring,100%,,,
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,,,
    IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,,,
    IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s,,,
    IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s,,,
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,,,
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,,,
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,,,
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,,,
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,,,
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,,,
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,,,
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,,,
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,,,
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80%,,,
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80%,,,
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,10%,,,
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,,,
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,,,
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,,,
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.25 °,,,
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,,,
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,,,
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,,,
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,,,
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,,,
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,,,
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,,,
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,,,
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,,,
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,,,
    IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active ,,,
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,,,
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,,,
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3,,,
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,,,
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,,,
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,,,
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,,,
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.1,,,
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00%,,,
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,,,
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,,,
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,,,
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,,,
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,,,
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,,,
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,,,
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,,,
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,,,
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,,,
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,,,
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,,,
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,,,
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,,,
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,,,
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,,,
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,,,
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,,,
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,,,
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,,,
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s,,,
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s,,,
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,,,
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,,,
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,,,
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,,,
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,,,
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,,,
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,,,
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,,,
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,,,
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,,,
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,,,
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,,,
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,,,
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,,,
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,,,
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,,,
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,,,
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,,,
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,,,
    IDE05142-ENG116706-Access control-Autounlock NAR,not active ,,,
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,,,
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,,,
    IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern,not active ,,,
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,,,
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,,,
    IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active ,,,
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,,,
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,,,
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,,,
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,,,
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,,,
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,,,
    IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung,not active ,,,
    IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion,not active ,,,
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,,,
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,,,
    IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s,,,
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,,,
    IDE05142-ENG115755-Access control-Notschließfunktion,active ,,,
    IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung,not active ,,,
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,,,
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,,,
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,,,
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,,,
    IDE05142-ENG115758-Access control-Valet Parking,not active ,,,
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,,,
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,,,
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,,,
    IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch ,,,
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,,,
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,,,
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung ,,,
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,,,
    IDE05143-MAS02985-Writing parameter-Value,130,,,
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,,,
    IDE05144-Read parameter address,FE 00 00 ,,,
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34,,,
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,,,
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,0,,,
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,0,,,
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38,,,
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42,,,
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,0,,,
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,0,,,
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,20,,,
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,10,,,
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,8,,,
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18,,,
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48,,,
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,9,,,
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19,,,
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29,,,
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,,,
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,,,
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28,,,
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,1C ,,,
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1A ,,,
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,9,,,
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,,,
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,,,
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,0,,,
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,0,,,
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,0,,,
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,0,,,
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,0,,,
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,,,
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44,,,
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36,,,
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40,,,
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,0,,,
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,0,,,
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,,,
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,,,
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,,,
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,,,
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,,,
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,,,
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,,,
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,,,
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,,,
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,,,
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,,,
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,,,
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,minimize ,,,
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,,,
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,,,
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,,,
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,minimize ,,,
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,minimize ,,,
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,,,
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,,,
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,minimize ,,,
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,minimize ,,,
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,,,
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,minimize ,,,
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,,,
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,,,
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,,,
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,,,
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,,,
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,,,
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,,,
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,,,
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,,,
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,,,
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,,,
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,,,
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,,,
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,,,
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,,,
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,,,
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,,,
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,,,
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,,,
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,,,
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,,,
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,,,
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,,,
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,,,
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,,,
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,,,
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,,,
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,,,
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,,,
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,,,
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,,,
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,,,
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,,,
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,,,
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,,,
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,,,
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,,,
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,,,
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,,,
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,,,
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,,,
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,,,
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,,,
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,,,
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,,,
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,,,
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,,,
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,,,
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,,,
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,,,
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,,,
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,,,
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,,,
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,,,
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,,,
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,,,
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,,,
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,,,
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,minimize ,,,
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,,,
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,,,
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,,,
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,,,
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,,,
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,,,
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,,,
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,,,
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,,,
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,,,
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,minimize ,,,
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,,,
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,,,
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,,,
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,,,
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,,,
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,,,
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,,,
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,,,
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,,,
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,,,
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,,,
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,127,,,
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,127,,,
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0,,,
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0,,,
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100,,,
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100,,,
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0,,,
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0,,,
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100,,,
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100,,,
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100,,,
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100,,,
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100,,,
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100,,,
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100,,,
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100,,,
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100,,,
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100,,,
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127,,,
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,90,,,
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100,,,
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100,,,
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100,,,
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100,,,
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100,,,
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0,,,
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0,,,
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0,,,
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0,,,
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127,,,
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127,,,
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127,,,
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127,,,
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,0,,,
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,0,,,
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0,,,
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0,,,
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0,,,
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0,,,
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0,,,
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0,,,
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0,,,
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0,,,
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,100,,,
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,100,,,
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0,,,
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0,,,
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,28,,,
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0,,,
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0,,,
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0,,,
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0,,,
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0,,,
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0,,,
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0,,,
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0,,,
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0,,,
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0,,,
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,28,,,
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0,,,
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0,,,
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0,,,
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0,,,
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0,,,
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0,,,
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0,,,
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0,,,
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0,,,
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0,,,
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0,,,
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0,,,
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0,,,
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0,,,
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0,,,
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0,,,
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0,,,
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0,,,
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0,,,
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0,,,
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0,,,
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0,,,
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0,,,
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,28,,,
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0,,,
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0,,,
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0,,,
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0,,,
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0,,,
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0,,,
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0,,,
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,100,,,
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0,,,
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0,,,
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,28,,,
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0,,,
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0,,,
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0,,,
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0,,,
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0,,,
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127,,,
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127,,,
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0,,,
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0,,,
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0,,,
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0,,,
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0,,,
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0,,,
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0,,,
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0,,,
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0,,,
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0,,,
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0,,,
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0,,,
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0,,,
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0,,,
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0,,,
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0,,,
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,28,,,
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0,,,
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0,,,
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0,,,
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0,,,
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0,,,
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0,,,
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0,,,
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0,,,
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0,,,
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0,,,
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,28,,,
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0,,,
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0,,,
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0,,,
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0,,,
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0,,,
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0,,,
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0,,,
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0,,,
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0,,,
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0,,,
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0,,,
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14,,,
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15,,,
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,0,,,
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,0,,,
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22,,,
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23,,,
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,0,,,
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,0,,,
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,3A ,,,
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,39,,,
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16,,,
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18,,,
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,,,
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,,,
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,,,
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,,,
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29,,,
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,,,
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30,,,
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2F ,,,
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,36,,,
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,37,,,
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32,,,
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,,,
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,2,,,
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,0,,,
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,0,,,
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,0,,,
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,0,,,
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49,,,
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,,,
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,,,
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,,,
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,0,,,
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,0,,,
    IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten ,,,
    IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten ,,,
    IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,,,
    IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,,,
    IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,,,
    IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,,,
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,,,
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,,,
    IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,,,
    IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,,,
    IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,,,
    IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,,,
    IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,,,
    IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,,,
    IDE05145-ENG116309-Light configuration-Lasttyp 23,32 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116328-Light configuration-Lasttyp 24,32 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,,,
    IDE05145-ENG116366-Light configuration-Lasttyp 26,43 - allgemeine LED ,,,
    IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,,,
    IDE05145-ENG116404-Light configuration-Lasttyp 28,34 - LED Bremsleuchten ,,,
    IDE05145-ENG116423-Light configuration-Lasttyp 29,37 - allgemeine LED bis 12W ,,,
    IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,,,
    IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,,,
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,,,
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,,,
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,,,
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,,,
    IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,,,
    IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,,,
    IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht ,,,
    IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht ,,,
    IDE05145-ENG116024-Light configuration-Lasttyp 8,not active ,,,
    IDE05145-ENG116043-Light configuration-Lasttyp 9,not active ,,,
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,,,
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,,,
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,,,
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,,,
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,,,
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,,,
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,,,
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,,,
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,,,
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,,,
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,,,
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,,,
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,,,
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,,,
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,,,
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,,,
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,,,
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,,,
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,,,
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,,,
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,,,
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,,,
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,,,
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,,,
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,,,
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,,,
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,,,
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,,,
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,,,
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,,,
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,,,
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,,,
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,,,
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,,,
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,,,
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,9,,,
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0,,,
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2,,,
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4,,,
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0,,,
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0,,,
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18,,,
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19,,,
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0,,,
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0,,,
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,8,,,
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,8,,,
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2,,,
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4,,,
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20,,,
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24,,,
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24,,,
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24,,,
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8,,,
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8,,,
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8,,,
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,28,,,
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8,,,
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,24,,,
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25,,,
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20,,,
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43,,,
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0,,,
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0,,,
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0,,,
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0,,,
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20,,,
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20,,,
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11,,,
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12,,,
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,0,,,
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,0,,,
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0,,,
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0,,,
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0,,,
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0,,,
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0,,,
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0,,,
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0,,,
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0,,,
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,10,,,
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0,,,
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0,,,
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0,,,
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0,,,
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0,,,
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,36,,,
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,9,,,
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,10,,,
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0,,,
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0,,,
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0,,,
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0,,,
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0,,,
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0,,,
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0,,,
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0,,,
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0,,,
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0,,,
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0,,,
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0,,,
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0,,,
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15,,,
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15,,,
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0,,,
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0,,,
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0,,,
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0,,,
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0,,,
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0,,,
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0,,,
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0,,,
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0,,,
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,24,,,
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,24,,,
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0,,,
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0,,,
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,6,,,
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0,,,
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0,,,
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0,,,
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,6,,,
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,7,,,
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0,,,
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0,,,
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,24,,,
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,28,,,
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0,,,
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,7,,,
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0,,,
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0,,,
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0,,,
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0,,,
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0,,,
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,0,,,
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,0,,,
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0,,,
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0,,,
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0,,,
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0,,,
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0,,,
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0,,,
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0,,,
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0,,,
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0,,,
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0,,,
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0,,,
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0,,,
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0,,,
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0,,,
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0,,,
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0,,,
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0,,,
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0,,,
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0,,,
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0,,,
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,24,,,
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,24,,,
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0,,,
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0,,,
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0,,,
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0,,,
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0,,,
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0,,,
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0,,,
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0,,,
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0,,,
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0,,,
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0,,,
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0,,,
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0,,,
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0,,,
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0,,,
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0,,,
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0,,,
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0,,,
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0,,,
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0,,,
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0,,,
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0,,,
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0,,,
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0,,,
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0,,,
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0,,,
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0,,,
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0,,,
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0,,,
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,8,,,
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0,,,
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0,,,
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0,,,
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0,,,
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0,,,
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0,,,
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0,,,
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,28,,,
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0,,,
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0,,,
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,8,,,
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0,,,
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0,,,
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0,,,
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0,,,
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0,,,
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,8,,,
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,8,,,
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0,,,
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0,,,
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0,,,
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0,,,
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0,,,
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0,,,
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0,,,
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0,,,
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0,,,
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0,,,
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0,,,
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0,,,
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0,,,
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0,,,
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0,,,
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0,,,
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,9,,,
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0,,,
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0,,,
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0,,,
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0,,,
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0,,,
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0,,,
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0,,,
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0,,,
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0,,,
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0,,,
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0,,,
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0,,,
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0,,,
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0,,,
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0,,,
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9,,,
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0,,,
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0,,,
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0,,,
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0,,,
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,10,,,
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10,,,
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0,,,
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0,,,
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0,,,
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0,,,
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0,,,
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0,,,
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0,,,
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0,,,
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0,,,
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0,,,
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0,,,
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0,,,
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,18,,,
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0,,,
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0,,,
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0,,,
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0,,,
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0,,,
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0,,,
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0,,,
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0,,,
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0,,,
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0,,,
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,19,,,
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0,,,
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0,,,
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0,,,
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0,,,
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0,,,
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0,,,
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0,,,
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0,,,
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0,,,
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0,,,
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0,,,
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0,,,
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0,,,
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0,,,
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0,,,
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0,,,
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0,,,
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0,,,
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0,,,
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0,,,
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0,,,
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0,,,
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0,,,
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0,,,
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0,,,
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0,,,
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0,,,
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0,,,
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0,,,
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0,,,
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0,,,
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0,,,
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0,,,
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0,,,
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0,,,
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0,,,
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0,,,
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0,,,
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0,,,
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0,,,
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0,,,
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0,,,
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0,,,
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0,,,
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0,,,
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0,,,
    IDE05822-DWA Vehicle inclination sensor,100%,,,
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 C2 28 29 ,,,
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,,,
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,,,
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,23.00 °C,,,
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C,,,
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C,,,
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,,,
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,,,
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,,,
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,,,
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,,,
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,54.00 °C,,,
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,53.00 °C,,,
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,54.00 °C,,,
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,53.00 °C,,,
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,not active ,,,
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,,,
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,,,
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,,,
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,,,
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100%,,,
    IDE06425-Roller test bench mode: functional,not active ,,,
    IDE06507-MAS13125-Button in center console-Funktion Taster 1,Start-stop ,,,
    IDE06507-MAS13129-Button in center console-Funktion Taster 2,GTE ,,,
    IDE06507-MAS13132-Button in center console-Funktion Taster 3,Driving program ,,,
    IDE06507-MAS13135-Button in center console-Funktion Taster 4,Steering wheel heater ,,,
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,,,
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,,,
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,,,
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,,,
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,,,
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,,,
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,,,
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,,,
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,,,
    IDE07356-Position during interval mode,24.89 °,,,
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,,,
    IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,,,
    IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,,,
    IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten ,,,
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,,,
    IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit,24 s,,,
    IDE08542-IDE02021-Access control 2-Comfort closing,active ,,,
    IDE08542-IDE02022-Access control 2-Comfort opening,not active ,,,
    IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active ,,,
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,,,
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,,,
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,,,
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,,,
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,,,
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,,,
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,,,
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,,,
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,,,
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,,,
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,,,
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,,,
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,,,
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,,,
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,,,
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,,,
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,,,
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,,,
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,,,
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,,,
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,,,
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,,,
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active ,,,
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active ,,,
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,,,
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,,,
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,,,
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,,,
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,,,
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,,,
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,,,
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,,,
    IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active ,,,
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,,,
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,,,
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,,,
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,,,
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,,,
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,active ,,,
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,,,
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,,,
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,,,
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,,,
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,,,
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,,,
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,,,
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,,,
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,,,
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,,,
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,,,
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,,,
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,,,
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,,,
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,,,
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,,,
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,,,
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,,,
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,,,
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,,,
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,,,
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,,,
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,,,
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,,,
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,,,
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,,,
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,,,
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,,,
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,,,
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,,,
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,,,
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,,,
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0,,,
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0,,,
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0,,,
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225,,,
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225,,,
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225,,,
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80%,,,
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0,,,
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80%,,,
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225,,,
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225,,,
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225,,,
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,,,
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,,,
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,,,
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225,,,
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225,,,
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225,,,
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,,,
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,,,
    IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,,,
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,,,
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,,,
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,,,
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,,,
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,,,
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,,,
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,,,
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,,,
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,,,
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,,,
    IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active ,,,
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,,,
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,,,
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,,,
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30%,,,
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30%,,,
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30%,,,
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30%,,,
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50%,,,
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50%,,,
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50%,,,
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50%,,,
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75%,,,
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75%,,,
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80%,,,
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80%,,,
    IDE10298-Alternating park position 1,8.30 °,,,
    IDE10299-Alternating park position 2,24.89 °,,,
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,64,,,
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,28,,,
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,28,,,
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,3C ,,,
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,64,,,
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,64,,,
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,64,,,
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,3C ,,,
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,1,,,
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,3C ,,,
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,0,,,
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,0,,,
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,0,,,
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,0,,,
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,0,,,
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,0,,,
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,1,,,
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,1,,,
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,0,,,
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,0,,,
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,60%,,,
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100%,,,
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,60%,,,
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70%,,,
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100%,,,
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96%,,,
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100%,,,
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100%,,,
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100%,,,
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96%,,,
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,60%,,,
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100%,,,
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,60%,,,
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70%,,,
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100%,,,
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96%,,,
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100%,,,
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100%,,,
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100%,,,
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96%,,,
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100%,,,
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,60%,,,
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70%,,,
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100%,,,
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96%,,,
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100%,,,
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100%,,,
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100%,,,
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96%,,,
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100%,,,
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,60%,,,
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0%,,,
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100%,,,
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0%,,,
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100%,,,
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100%,,,
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100%,,,
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0%,,,
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100%,,,
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,60%,,,
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70%,,,
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100%,,,
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96%,,,
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100%,,,
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100%,,,
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100%,,,
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96%,,,
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127%,,,
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127%,,,
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127%,,,
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100%,,,
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100%,,,
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127%,,,
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126%,,,
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126%,,,
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126%,,,
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0%,,,
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126%,,,
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126%,,,
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126%,,,
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126%,,,
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126%,,,
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127%,,,
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127%,,,
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127%,,,
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127%,,,
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100%,,,
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126%,,,
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126%,,,
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100%,,,
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126%,,,
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100%,,,
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100%,,,
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100%,,,
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126%,,,
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100%,,,
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60%,,,
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70%,,,
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100%,,,
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96%,,,
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100%,,,
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100%,,,
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100%,,,
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96%,,,
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,60%,,,
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100%,,,
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100%,,,
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100%,,,
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,60%,,,
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70%,,,
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100%,,,
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96%,,,
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100%,,,
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100%,,,
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100%,,,
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96%,,,
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100%,,,
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,60%,,,
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70%,,,
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100%,,,
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96%,,,
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100%,,,
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100%,,,
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100%,,,
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96%,,,
    IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,0 ms,,,
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0 s,,,
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0 s,,,
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0 s,,,
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0 s,,,
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0 s,,,
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0 s,,,
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,20 s,,,
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0 s,,,
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,20 s,,,
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0 s,,,
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0 s,,,
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,5 s,,,
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0 s,,,
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0 s,,,
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0 s,,,
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0 s,,,
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0 s,,,
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0 s,,,
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0 s,,,
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0 s,,,
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0 s,,,
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0 s,,,
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0 s,,,
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0 s,,,
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0 s,,,
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0 s,,,
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0 s,,,
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0 s,,,
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0 s,,,
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0 s,,,
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0 s,,,
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0 s,,,
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0 s,,,
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0 s,,,
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0 s,,,
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0 s,,,
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0 s,,,
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0 s,,,
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0 s,,,
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0 s,,,
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0 s,,,
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0 s,,,
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,0,,,
    IDE11714-ENG02360-Ambientelicht Farbliste-Blauwert Farbe 10,E1 ,,,
    IDE11714-ENG02342-Ambientelicht Farbliste-Blauwert Farbe 4,E1 ,,,
    IDE11714-ENG02345-Ambientelicht Farbliste-Blauwert Farbe 5,E1 ,,,
    IDE11714-ENG02348-Ambientelicht Farbliste-Blauwert Farbe 6,E1 ,,,
    IDE11714-ENG02351-Ambientelicht Farbliste-Blauwert Farbe 7,E1 ,,,
    IDE11714-ENG02354-Ambientelicht Farbliste-Blauwert Farbe 8,E1 ,,,
    IDE11714-ENG02357-Ambientelicht Farbliste-Blauwert Farbe 9,E1 ,,,
    IDE11714-ENG02359-Ambientelicht Farbliste-Gruenwert Farbe 10,E1 ,,,
    IDE11714-ENG02341-Ambientelicht Farbliste-Gruenwert Farbe 4,E1 ,,,
    IDE11714-ENG02344-Ambientelicht Farbliste-Gruenwert Farbe 5,E1 ,,,
    IDE11714-ENG02347-Ambientelicht Farbliste-Gruenwert Farbe 6,E1 ,,,
    IDE11714-ENG02350-Ambientelicht Farbliste-Gruenwert Farbe 7,E1 ,,,
    IDE11714-ENG02353-Ambientelicht Farbliste-Gruenwert Farbe 8,E1 ,,,
    IDE11714-ENG02356-Ambientelicht Farbliste-Gruenwert Farbe 9,E1 ,,,
    IDE11714-ENG02358-Ambientelicht Farbliste-Rotwert Farbe 10,E1 ,,,
    IDE11714-ENG02340-Ambientelicht Farbliste-Rotwert Farbe 4,E1 ,,,
    IDE11714-ENG02343-Ambientelicht Farbliste-Rotwert Farbe 5,E1 ,,,
    IDE11714-ENG02346-Ambientelicht Farbliste-Rotwert Farbe 6,E1 ,,,
    IDE11714-ENG02349-Ambientelicht Farbliste-Rotwert Farbe 7,E1 ,,,
    IDE11714-ENG02352-Ambientelicht Farbliste-Rotwert Farbe 8,E1 ,,,
    IDE11714-ENG02355-Ambientelicht Farbliste-Rotwert Farbe 9,E1 ,,,
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active ,,,
    MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active ,,,
    MAS05055-lower turn position,26.30 °,,,
    MAS05056-upper turn position,171.30 °,,,
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,,,
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,,,
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,,,
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,,,
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,,,
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,,,
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,,,
    MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1,80 s,,,
    MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3,20.000 ms,,,
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,,,
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,,,
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,,,
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,,,
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,,,
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,,,
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,,,
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,active ,,,
    MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,60 lx,,,
    MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,110 lx,,,
    MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,,,
    MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO,30 lx,,,
    MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten,60 lx,,,
    MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten,110 lx,,,
    MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,80,,,
    MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell,100 lx,,,
    MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung,4500 mV,,,
    MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke,300 lx,,,
    MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung,2000 mV,,,
    MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke,0 lx,,,
    MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung,2,,,
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1,,,
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1,,,
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1,,,
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1,,,
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1,,,
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1,,,
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1,,,
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1,,,
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1,,,
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1,,,
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1,,,
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1,,,
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1,,,
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1,,,
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1,,,
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,,,
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,,,
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,,,
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,,,
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,,,
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,,,
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,,,
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,,,
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,,,
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,,,
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,,,
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,,,
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,,,
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,,,
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,,,
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed ,,,
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed ,,,
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed ,,,
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed ,,,
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed ,,,
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed ,,,
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed ,,,
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,,,
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed ,,,
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed ,,,
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed ,,,
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed ,,,
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed ,,,
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed ,,,
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed ,,,
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0,,,
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0,,,
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0,,,
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0,,,
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0,,,
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0,,,
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0,,,
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0,,,
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0,,,
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0,,,
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0,,,
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0,,,
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0,,,
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0,,,
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0,,,
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0,,,
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0,,,
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0,,,
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0,,,
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0,,,
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0,,,
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0,,,
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0,,,
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0,,,
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0,,,
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0,,,
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0,,,
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0,,,
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0,,,
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0,,,
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0,,,
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0,,,
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0,,,
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0,,,
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0,,,
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0,,,
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0,,,
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0,,,
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0,,,
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0,,,
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,,,
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed ,,,
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed ,,,
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed ,,,
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed ,,,
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed ,,,
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed ,,,
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed ,,,
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed ,,,
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed ,,,
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed ,,,
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,,,
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed ,,,
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,,,
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,,,
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed ,,,
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed ,,,
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed ,,,
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed ,,,
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed ,,,
    ENG126647-ENG98399-debug_light_function-Activation,0,,,
    ENG126647-ENG101417-debug_light_function-Adresse,0,,,
    ENG126647-ENG126820-debug_light_function-Bitmask,0,,,
    ENG126647-ENG126821-debug_light_function-Divisor,0,,,
    ENG126647-ENG98827-debug_light_function-Offset,0,,,
    ENG126647-ENG126822-debug_light_function-Polaritaet,0,,,
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0,,,
    ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,,,
    ENG122934-erase_error_table,55 00 00 ,,,
    ENG122933-error_mask,0 bit,,,
    ENG117283-Frontwaschfunktion,10,,,
    ENG99457-ENG117394-Head area heater-blower_speed,1,,,
    ENG99457-ENG98971-Head area heater-Temperature,-2,,,
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,,,
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,,,
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,,,
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,,,
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,,,
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,,,
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,,,
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,,,
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,,,
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,,,
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,,,
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00%,,,
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00%,,,
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00%,,,
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00%,,,
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00%,,,
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00%,,,
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00%,,,
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00%,,,
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00%,,,
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00%,,,
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00%,,,
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0,,,
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50,,,
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0,,,
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100,,,
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200,,,
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253,,,
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0,,,
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0,,,
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0,,,
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0,,,
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0,,,
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,,,
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,,,
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,,,
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,,,
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200,,,
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500,,,
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0,,,
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,,,
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,,,
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,,,
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,,,
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,,,
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,,,
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,,,
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,,,
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,,,
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,,,
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,,,
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,,,
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,,,
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,,,
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,,,
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00%,,,
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00%,,,
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00%,,,
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00%,,,
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00%,,,
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00%,,,
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00%,,,
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00%,,,
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00%,,,
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00%,,,
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00%,,,
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00%,,,
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00%,,,
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00%,,,
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00%,,,
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00%,,,
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00%,,,
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10,,,
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10,,,
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100,,,
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150,,,
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220,,,
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253,,,
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,,,
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,,,
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,,,
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,,,
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,,,
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16,,,
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16,,,
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100,,,
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100,,,
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100,,,
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,,,
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,,,
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,,,
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,,,
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,,,
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6,,,
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6,,,
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100,,,
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100,,,
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100,,,
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0,,,
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10,,,
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50,,,
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100,,,
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220,,,
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253,,,
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00%,,,
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00%,,,
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00%,,,
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00%,,,
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00%,,,
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00%,,,
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,,,
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,,,
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,,,
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,,,
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100,,,
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100,,,
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100,,,
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100,,,
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,,,
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,,,
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,,,
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,,,
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6,,,
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6,,,
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100,,,
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100,,,
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00%,,,
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00%,,,
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00%,,,
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00%,,,
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00%,,,
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00%,,,
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,,,
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,,,
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,,,
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,,,
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100,,,
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100,,,
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100,,,
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100,,,
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,,,
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,,,
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,,,
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,,,
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6,,,
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6,,,
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100,,,
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100,,,
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00%,,,
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00%,,,
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00%,,,
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00%,,,
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00%,,,
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00%,,,
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,,,
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,,,
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,,,
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,,,
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,,,
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00%,,,
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5,,,
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15,,,
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10,,,
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100,,,
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize ,,,
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize ,,,
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize ,,,
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127,,,
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0,,,
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0,,,
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0,,,
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14,,,
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34,,,
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,,,
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always ,,,
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,,,
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active ,,,
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active ,,,
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active ,,,
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active ,,,
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active ,,,
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active ,,,
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active ,,,
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize ,,,
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize ,,,
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize ,,,
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0,,,
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0,,,
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0,,,
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0,,,
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,0,,,
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,0,,,
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,,,
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always ,,,
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,,,
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active ,,,
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active ,,,
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active ,,,
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active ,,,
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active ,,,
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active ,,,
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active ,,,
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize ,,,
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize ,,,
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize ,,,
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0,,,
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0,,,
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0,,,
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0,,,
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,0,,,
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,0,,,
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,not active ,,,
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always ,,,
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active ,,,
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active ,,,
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active ,,,
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active ,,,
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active ,,,
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active ,,,
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active ,,,
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active ,,,
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize ,,,
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize ,,,
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize ,,,
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100,,,
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0,,,
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0,,,
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0,,,
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22,,,
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38,,,
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,,,
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always ,,,
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,,,
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,,,
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active ,,,
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active ,,,
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active ,,,
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active ,,,
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active ,,,
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active ,,,
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize ,,,
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize ,,,
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize ,,,
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100,,,
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0,,,
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0,,,
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0,,,
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23,,,
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42,,,
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,,,
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always ,,,
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,,,
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,,,
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active ,,,
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active ,,,
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active ,,,
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active ,,,
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active ,,,
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active ,,,
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,,,
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,,,
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,,,
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0,,,
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0,,,
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0,,,
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0,,,
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,0,,,
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,0,,,
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,,,
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,,,
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,,,
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,,,
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,,,
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,,,
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,,,
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,,,
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,,,
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,,,
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize ,,,
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize ,,,
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize ,,,
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100,,,
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,100,,,
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0,,,
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0,,,
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,3A ,,,
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,20,,,
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,,,
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,,,
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,,,
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake light ,,,
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active ,,,
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active ,,,
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active ,,,
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active ,,,
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active ,,,
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize ,,,
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize ,,,
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize ,,,
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100,,,
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,100,,,
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0,,,
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0,,,
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,39,,,
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,10,,,
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,,,
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,,,
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake light ,,,
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active ,,,
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active ,,,
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active ,,,
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active ,,,
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active ,,,
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,,,
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,,,
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,,,
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100,,,
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0,,,
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0,,,
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0,,,
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16,,,
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,8,,,
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,,,
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,,,
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase ,,,
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active ,,,
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,,,
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active ,,,
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active ,,,
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active ,,,
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active ,,,
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active ,,,
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,,,
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,,,
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,,,
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100,,,
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0,,,
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0,,,
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0,,,
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18,,,
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18,,,
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,,,
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,,,
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase ,,,
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active ,,,
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,,,
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active ,,,
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active ,,,
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active ,,,
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active ,,,
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active ,,,
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,,,
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,,,
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,,,
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127,,,
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0,,,
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0,,,
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0,,,
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15,,,
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,,,
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,,,
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,,,
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,,,
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active ,,,
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active ,,,
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active ,,,
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active ,,,
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active ,,,
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active ,,,
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active ,,,
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize ,,,
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,,,
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,,,
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100,,,
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0,,,
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0,,,
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0,,,
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,,,
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,9,,,
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,,,
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,,,
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,,,
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,,,
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,,,
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active ,,,
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,,,
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,,,
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,,,
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,,,
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize ,,,
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,,,
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,,,
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100,,,
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0,,,
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0,,,
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0,,,
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,,,
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19,,,
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,,,
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,,,
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,,,
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,,,
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,,,
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active ,,,
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,,,
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,,,
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,,,
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,,,
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,,,
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,,,
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,,,
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100,,,
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0,,,
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0,,,
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0,,,
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,,,
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29,,,
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,,,
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,,,
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light ,,,
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,,,
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active ,,,
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active ,,,
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active ,,,
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active ,,,
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active ,,,
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active ,,,
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,minimize ,,,
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,,,
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,,,
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100,,,
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0,,,
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0,,,
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0,,,
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29,,,
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,,,
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,,,
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always ,,,
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Blinken links aktiv (beide Phasen) ,,,
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Brake light ,,,
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,,,
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,,,
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,,,
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,,,
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,,,
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,,,
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,,,
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100,,,
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0,,,
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0,,,
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0,,,
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,,,
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,,,
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,,,
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always ,,,
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,,,
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Blinken rechts aktiv (beide Phasen) ,,,
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Brake light ,,,
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,,,
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,,,
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,,,
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,,,
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize ,,,
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize ,,,
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize ,,,
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127,,,
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0,,,
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0,,,
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0,,,
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30,,,
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28,,,
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED ,,,
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always ,,,
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,,,
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,,,
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,,,
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,,,
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,,,
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,,,
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,,,
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,,,
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,,,
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,,,
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,90,,,
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0,,,
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0,,,
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0,,,
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2F ,,,
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,1C ,,,
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,,,
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,,,
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,,,
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,,,
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active ,,,
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active ,,,
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active ,,,
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,,,
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,,,
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,,,
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,,,
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,,,
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,,,
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100,,,
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0,,,
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,100,,,
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0,,,
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36,,,
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,,,
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,,,
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,,,
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,,,
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Brake light ,,,
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active ,,,
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,,,
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,,,
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,,,
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,,,
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,minimize ,,,
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize ,,,
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize ,,,
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100,,,
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0,,,
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0,,,
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0,,,
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,37,,,
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,9,,,
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,34 - LED Bremsleuchten ,,,
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,,,
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Brake light ,,,
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active ,,,
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,,,
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active ,,,
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active ,,,
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active ,,,
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active ,,,
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active ,,,
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize ,,,
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize ,,,
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize ,,,
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100,,,
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0,,,
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0,,,
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0,,,
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32,,,
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B ,,,
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,,,
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,,,
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht ,,,
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active ,,,
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active ,,,
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active ,,,
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active ,,,
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active ,,,
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active ,,,
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active ,,,
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize ,,,
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,,,
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,,,
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100,,,
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28,,,
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28,,,
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,28,,,
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,,,
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48,,,
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,,,
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always ,,,
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,,,
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active ,,,
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,,,
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,,,
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,Nebellicht links ,,,
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active ,,,
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize ,,,
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize ,,,
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize ,,,
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100,,,
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0,,,
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0,,,
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0,,,
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,2,,,
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,0,,,
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,,,
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,,,
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light ,,,
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active ,,,
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active ,,,
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active ,,,
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active ,,,
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active ,,,
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active ,,,
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active ,,,
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize ,,,
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize ,,,
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize ,,,
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0,,,
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0,,,
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0,,,
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0,,,
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,0,,,
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,0,,,
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active ,,,
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always ,,,
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,,,
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active ,,,
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active ,,,
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active ,,,
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active ,,,
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active ,,,
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active ,,,
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active ,,,
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize ,,,
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize ,,,
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize ,,,
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0,,,
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0,,,
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0,,,
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0,,,
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,0,,,
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,0,,,
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active ,,,
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always ,,,
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,,,
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active ,,,
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active ,,,
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active ,,,
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active ,,,
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active ,,,
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active ,,,
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active ,,,
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize ,,,
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize ,,,
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize ,,,
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0,,,
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0,,,
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0,,,
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0,,,
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,0,,,
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,0,,,
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active ,,,
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always ,,,
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,,,
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active ,,,
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active ,,,
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active ,,,
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active ,,,
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active ,,,
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active ,,,
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active ,,,
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize ,,,
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize ,,,
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize ,,,
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0,,,
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0,,,
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0,,,
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0,,,
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,0,,,
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,0,,,
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active ,,,
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always ,,,
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,,,
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active ,,,
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active ,,,
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active ,,,
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active ,,,
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active ,,,
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active ,,,
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active ,,,
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize ,,,
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,,,
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,,,
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100,,,
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28,,,
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28,,,
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,28,,,
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,,,
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,,,
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,,,
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always ,,,
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,,,
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active ,,,
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,,,
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,,,
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,,,
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,Nebellicht rechts ,,,
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active ,,,
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,,,
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize ,,,
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize ,,,
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127,,,
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,0,,,
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127,,,
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0,,,
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49,,,
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,,,
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,,,
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always ,,,
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,,,
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active ,,,
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,,,
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active ,,,
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,,,
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active ,,,
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active ,,,
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,,,
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize ,,,
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize ,,,
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127,,,
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,0,,,
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127,,,
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0,,,
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,,,
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44,,,
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,,,
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always ,,,
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,,,
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active ,,,
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,,,
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active ,,,
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,,,
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,,,
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active ,,,
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active ,,,
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize ,,,
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize ,,,
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize ,,,
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127,,,
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0,,,
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0,,,
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0,,,
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,,,
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36,,,
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,,,
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always ,,,
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links ,,,
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,,,
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,,,
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active ,,,
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active ,,,
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active ,,,
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active ,,,
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active ,,,
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize ,,,
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize ,,,
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize ,,,
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127,,,
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0,,,
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0,,,
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0,,,
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,,,
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40,,,
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,,,
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always ,,,
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts ,,,
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,,,
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,,,
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active ,,,
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active ,,,
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active ,,,
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active ,,,
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active ,,,
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize ,,,
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize ,,,
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize ,,,
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0,,,
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0,,,
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0,,,
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0,,,
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,0,,,
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,0,,,
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,,,
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always ,,,
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,,,
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,,,
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,,,
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,,,
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active ,,,
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active ,,,
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active ,,,
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active ,,,
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize ,,,
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize ,,,
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize ,,,
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0,,,
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0,,,
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0,,,
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0,,,
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,0,,,
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,0,,,
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,,,
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always ,,,
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,,,
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,,,
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,,,
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,,,
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active ,,,
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active ,,,
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active ,,,
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active ,,,
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,,,
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,,,
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,,,
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0,,,
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0,,,
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0,,,
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0,,,
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,0,,,
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,0,,,
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,,,
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,,,
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,,,
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,,,
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,,,
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,,,
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,,,
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,,,
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,,,
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,,,
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,,,
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,,,
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,,,
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,,,
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,,,
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,,,
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,,,
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00%,,,
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00%,,,
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00%,,,
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00%,,,
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110,,,
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5,,,
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00%,,,
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00%,,,
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00%,,,
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00%,,,
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00%,,,
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00%,,,
    ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,,,
    ENG98831-ENG02329-Personalisierung-Anzahl_Benutzerkonten,4,,,
    ENG98831-ENG02330-Personalisierung-Automatische_ Schluesselzuordnung,not active ,,,
    ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,,,
    ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv,active ,,,
    ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,,,
    ENG98831-ENG02331-Personalisierung-PSO_FSG_Setup2_Bit_0,not active ,,,
    ENG98831-ENG02332-Personalisierung-PSO_FSG_Setup2_Bit_1,active ,,,
    ENG98831-ENG02333-Personalisierung-PSO_FSG_Setup2_Bit_2,active ,,,
    ENG98831-ENG02334-Personalisierung-PSO_FSG_Setup2_Bit_3,not active ,,,
    ENG98831-ENG02335-Personalisierung-PSO_FSG_Setup2_Bit_4,not active ,,,
    ENG98831-ENG02336-Personalisierung-PSO_FSG_Setup2_Bit_5,not active ,,,
    ENG98831-ENG02337-Personalisierung-PSO_FSG_Setup2_Bit_6,not active ,,,
    ENG98831-ENG02338-Personalisierung-PSO_FSG_Setup2_Bit_7,not active ,,,
    ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,,,
    ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active ,,,
    ENG122927-RLS_close_glazing,2.00 s,,,
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,,,
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,,,
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,,,
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,,,
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,,,
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12,,,
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6,,,
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,,,
    ENG122929-RLS_LIN_Communication,4 s,,,
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,,,
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,,,
    ENG122930-RLS_tunel_gateway_recognize,5 s,,,
    ENG122935-RLS_Washer_Front,15 s,,,
    ENG122926-RLS_wiper_position_parking,15 s,,,
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 ,,,
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 ,,,
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 ,,,
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 ,,,
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,,,
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,,,
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,,,
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,,,
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,,,
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,,,
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40,,,
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60,,,
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30,,,
    Elapsed Time: 02:10,,,,
  7. Likes drennie599 liked this post
    Northern Ireland
    Ok, so went through some channels tonight and changed some values which didn't really bring me any further forward .. I'm probably looking at the wrong thing hence no progress.
    If anyone has any sort of idea to what I could try next it would be much appreciated.
    Quote Originally Posted by drennie599 View Post
    drennie: hmm......... perhaps a bit of theory first might help tease-out possible next steps. Let's start with the anatomy of the Leuchte-sets in your admap
    Your admap would normally contain a total of 35 x Leuchte-sets with each set consisting of 19 x adaptation channels (yours has 34 x Leuchte-sets). The nomenclature for every one of these channels is the same and it follows a predetermined convention. For example, If I take the Leuchte-set for the front left-side DRL lamp (from your admap), I get the following "parent" name
    Leuchte4TFL LB4
    As I said, there are 19 x "child" adaptation channels associated with this parent name - but the anatomy of the parent name goes something like this:
    "Leucthe"= simply means "Light", or perhaps "lamp"
    "4" = is a numeric index (i.e. 0-34) that links these Leuchte-sets to another and in my view more mysterious bank of adaptation channels called "lighting configuration"
    "TFL" = short hand for Tagfahrlicht (I think) which means DRL - this is a nominal identifier for each lamp (albeit the DRL lamp performs additional functions like Parking Light, DRL wink.Single Sided Parking Lights etc)
    "L" = "Links" which is "Left" (the twin right side lamp will have a "R" - for Rechts)
    "B4" = The output pin on the BCM for the lamp. In this instance, the particular Leuchte-set controls PIN #4 on the B socket
    So, the reason for explaining this is that you might have some success in identifying the relevant Leutch-set for your mysterious lamp, by referring to the WD for your car. Once you know the BCM pin number, refer to your admap and locate the relevant Leutche-set - then modify the child channels to make the lamp illuminate as a DRL (QED)!
    EDIT: Leuchte programming is not difficult, but a common "deficiency" when modifying factory settings is not considering conflicts: that is - what you want the lamp to do when it is asked to perform multiple functions at the same time.
  10. Likes Uwe, GaryM, drennie599, Dana liked this post
  11. #8
    Verified VCDS User @DRI@N's Avatar
    Nov 2017
    Romania
    Hy,
    I am interested to make same change on my FULL LED HEADLAMP but unfortunately I don't know what channels from below list I need to modify :
    For left side .
    ENG116940-ENG115954-Leuchte4 TFL LB4-Lichtansteuerung HD AB 4, Always
    ENG116940-ENG115951-Leuchte4 TFL LB4-Lichtfunktion A 4, Daytime running lights
    ENG116940-ENG115952-Leuchte4 TFL LB4-Lichtfunktion B 4, not active
    ENG116940-ENG115955-Leuchte4 TFL LB4-Lichtfunktion C 4, not active
    ENG116940-ENG115956-Leuchte4 TFL LB4-Lichtfunktion D 4, not active
    ENG116940-ENG115959-Leuchte4 TFL LB4-Lichtfunktion E 4, Standlicht allgemein(Schlusslicht Positionslicht Begrenzungslicht)
    ENG116940-ENG115960-Leuchte4 TFL LB4-Lichtfunktion F 4, Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116940-ENG115963-Leuchte4 TFL LB4-Lichtfunktion G 4, not active
    ENG116940-ENG115964-Leuchte4 TFL LB4-Lichtfunktion H 4, not active
    For right side
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5, Always
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5, Daytime running lights
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5, not active
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5, not active
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5, not active
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5, Standlicht allgemein(Schlusslicht Positionslicht Begrenzungslicht
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5, Parking light right
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5, not active
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5, not active
    If somebody tried and solved this matter please tell us what channel he adapted in BCM .
    Thank you .
  12. #9
    Feb 2019
    Not sure if you can change much of the behavior of the drl's in the front by coding.
    And there actually are no leds in the other "u", it's just some reflection in those photos. I know the first posts are old, but still.
    passat b8 led high
