Good day, I tried to change coding on 09 central electric on a golf 5 with the function:"us style". When I clicked: Do it appeared: This equipmant number is invalid: Equipmant number must be 5-6 digits: 000000-262143. What code can I enter to make the new coding? Please help me.
Saturday,06,May,2017,12:48:24:14813
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ1KZ6B009724 License Plate: PH 14 KOZ
Mileage: 162990km-101277mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ6B009724 Mileage: 162990km-101277miles
Address 01: Engine Labels: 036-906-032-AXP.lbl
Part No SW: 036 906 032 BA HW: xxxxxxxxxxx
Component: BOSCH ME7.5.10 7292
Revision: -------- Serial number: VWZ7Z0E2166917
Coding: 0000071
Shop #: WSC 00046 412 40960
VCID: 50AF0415C3DAEEC139-8004
19534 - Throttle Control
P3078 - 002 - Airflow at Idle too Low - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 008 - No Activity - MIL ON
P0300 - 008 - - Intermittent
16687 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0019073
VCID: 408F345513BA1E41A9-8014
Part No: 1K0 820 047 DF
Component: Climatic PQ35 090 0505
VCID: 6BD5B3F94ABC2D192C-803E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001845941
Coding: 008D0F2700041800001400001400000000097B075C
Shop #: WSC 00046 412 860160
VCID: 2A5B76FD85C6F41197-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 00046
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 2E AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0EE9PE
Coding: 0012869
VCID: 377D5F89467459F918-8062
Subsystem 1 - Serial number: 6332MSME0A390A28D
Subsystem 2 - Serial number: 6342MSME0A210C68B
Subsystem 3 - Serial number: 6351HSME0752634E8
Subsystem 4 - Serial number: 6361HSME075B667DN
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
Component: Lenksäulenmodul 034 0070
Shop #: WSC 00046 412 524288
VCID: 75E195811CF8EBE9CA-8020
Part No: 1K0 920 852
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0003103
Shop #: WSC 50571 141 68686
VCID: 66C3C2CD515E107173-8032
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010553087C0
Coding: 3D0F0340070000
Shop #: WSC 00046 412 1638400
Component: IMMO VDD 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2313
Coding: 0000052
VCID: 3663528D417EA0F103-8062
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326B6E9DAD16BCD12F-8066
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 00C802087F2D8405484A01E010CC
VCID: 78FF9CB50BEA9681D1-802C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000052
Part No SW: 1K0 035 186 P HW: 1K0 035 186 P
Component: Radio FO3 013 0014
Revision: 00013000 Serial number: VWZ7Z2E0007259
Coding: 0020200
Shop #: WSC 50571 141 87490
VCID: 33656B99520CB5D924-8066
End-------------------------(Elapsed Time: 01:25)--------------------------
