Results 1 to 9 of 9
Thread: VCDS Auto-Scan Module List Query
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    Quick question. When an Auto-Scan is done, at the top it lists a load of module numbers. Is VCDS using some kind of intelligence to gather this list or is it simply just looking in the CAN Gateway "Installation List" for any items that have been ticked as being installed?
    Chassis Type: 1P (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 62
              72
    VIN: VSSZZZ1PZCRXXXXXX   Mileage: 39360km-24457miles
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by GaryM View Post
    If the vehicle has a CAN gateway that supports that function, the installed list can be determined with Auto-Scan auto-detect using the CAN gateway and you'll get that summary of fault status per module at the beginning of the scan, because the CAN gateway has all that data cached. If the vehicle doesn't do diagnostics via CAN and you choose a chassis manually, the module list will be as-configured in AutoScan.txt/MyAutoScan.txt in C:\Ross-Tech\VCDS and you won't have the summary (because the CAN gateway either doesn't exist or doesn't support that function).
    Jason
  3. Likes GaryM, Uwe liked this post
    Nov 2014
    Oxford, UK
    Thanks Jason. I think that has answered my question perfectly. The CAN Gateway in my car does have in "Installation List" and I always use the "Auto-detect (CAN only)" option when I do an Auto-Scan but I have never taken a note of what items were actually ticked in that list. However, from your reply it appears that I can just look at that module number list at the top of any the my past Auto-Scans I have done on my car and those are the items that are were installed ("ticked") in my CAN Gateway "Installation List" at the time I did the scan. This is correct, yes?
    And is it the CAN Gateway Installation List also drive what buttons you see on the "Installed" tab of the "Select Control Module" screen?
    The list isn't just modules that have been ticked as "installed". It's modules that are ticked as installed (whether the gateway thinks they are present or not) and modules that gateway thinks are present (whether they are ticked "installed" or not). The latter would be a module that shows up in the list as "Unregistered".
    Nov 2014
    Oxford, UK
    OK, maybe will make things a bit clearer if I put some context around why I'm asking.
    Over the weekend I installed a PolarFIS device in my car (another related post about that HERE). The PolarFIS is installed by plugging it in series with the CAN Gateway. So the connector that usually plugs into the CAN Gateway plugs into the top of the PolarFIS instead, and a piece of loom coming out of the bottom of the PolarFIS then plugs into the CAN Gateway.
    Since I've installed the PolarFIS, I'm getting some new fault codes that won't clear. I think the PolarFIS may have installed ("ticked") module "77-Telephone" in my CAN Gateway which appears to be the crux of the problem. However, I can't be sure because I don't know if module 77 was ticked before I introduced PolarFIS to the car as I have never made any explicit records of my GW installation list. I have certainly never made changes to GW installation list myself while I've owned the car.
    Before I start digging a bit deeper or firing off emails to Auto Polar, I just want to try and ascertain if module 77 was already ticked as an installed module in the CW before I installed the PolarFIS device.
    Latest Auto-Scan before PolarFIS was installed...
    Thursday,11,May,2017,10:59:12:55895
    VCDS Version: 17.1.3.0 (x64)
    VIN: VSSZZZ1PZCRXXXXXX   License Plate:
    Mileage: 39360km-24457mi   Repair Order:
              72
    Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 TP    HW: 03L 906 022 GP
       Component: R4 2,0L EDC G000AG  5763
       Revision: 13H14---    Serial number:
       Coding: 0000078
       Shop #: WSC 06402 785 00200
       VCID: 0603B34371FD7A71D3-8052
       Part No SW: 02E 300 057 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3101
       Revision: 05551213    Serial number: 00001111122064
       VCID: 2447C9CBE701A861AD-8070
       Revision: 00H31001
       Coding: 163B6012092600FD680C06E4901A0082350800
       Shop #: WSC 04941 000 00000
       VCID: 7BF5D2B7FA3F3799BC-802E
       Part No SW: 5P0 907 044 S    HW: 5P0 907 044 S
       Component: Climatronic   H18 0804
       Revision: 00001001
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SE35.rod
       VCID: 408F655BDB599441A9-8014
       Part No SW: 5K0 937 087 R    HW: 5K0 937 087 R
       Component: BCM PQ35 H    021 0064
       Revision: BE021001
       Coding: 46180A3EE025B0C042080080950009C442550008727D8560008040000040
       Shop #: WSC 54559 001 104857
       VCID: 4487694BC74188618D-8010
       Subsystem 1 - Part No: 1P0 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 24111  26  0611
       Coding: 00DB90
       Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A  Labels: 1P0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 02542E
       Subsystem 3 - Part No: 1P0 951 171 A
       Component: Innenraumuebe  010 4974
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5P0 919 475 C    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H08 0008
       Revision: --------    Serial number: 12561133903563
       Coding: 100104
       VCID: 3B7512B7BABFF799FC-806E
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__A0E VW10 HI   1918
       Revision: 23016000    Serial number: 003K0PPTCX2K
       Coding: 0012357
       VCID: 4C97416B2F11402145-8018
       Subsystem 1 - Serial number: 6332MTS610773401
       Subsystem 2 - Serial number: 6342MTS643573401
       Subsystem 3 - Serial number: 6351HTS66QJC0AKR
       Subsystem 4 - Serial number: 6361HTS6UVFA0AKJ
       Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20111207200300
       Coding: 189A140002
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 7EF3DBA3E12D22B19B-802A
       Subsystem 1 - Part No SW: 1P0 959 538 B    HW: 1P0 959 538 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H02 0102
       Coding: E30000
       Part No SW: 1P0 920 950 K    HW: 1P0 920 950 K
       Component: KOMBI         H05 0607
       Coding: 410F01
       VCID: 3561048F949B21E90A-8060
       Part No SW: 7N0 907 530 M    HW: 1K0 907 951
       Component: J533  Gateway H42 1623
       Revision:   H42       Serial number: 281111F1000312
       Coding: 350203
       VCID: 3A7B17B3B585CE91E7-806E
       Component: IMMO          H05 0607
       VCID: 6ADBE7F38DA5BE1157-803E
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Revision: A1001003    Serial number: 7661443894
       VCID: 2959D8FF402375099E-807C
    Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
       Part No SW: 5P0 035 191 G    HW: 5P0 035 191 G
       Component: RNS315-EU   H35 0263
       Serial number: SEZAZ2L9157843
       Coding: 040004010402000000000002
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2F6D36E776C71B3940-807A
       Component: EUR_W_V7  0066
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0508
       Revision: 12110009    Serial number: 0003506013
       Coding: 0012B0
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 6DD1ECEFBC4BA92932-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704 E    HW: 3C0 959 794 E  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  007 1501
       Serial number: 00000006219061
       Coding: 000290
       Part No: 1K0 909 144 N
       Component: EPS_ZFLS Kl. 142    3301
       Revision: 00H22000
       VCID: 3561048F5C9B21E90A-8060
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0508
       Revision: 14110009    Serial number: 0003506882
       Coding: 0012B0
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 6ED3EBE3B14D52310B-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703 E    HW: 3C0 959 795 E  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  007 1501
       Serial number: 00000006236000
       Coding: 000290
       Coding: 2557189
       VCID: 3467398B57E138E13D-8060
       Subsystem 1 - Part No: 7L6 941 329 C  Labels: 3D0-941-329.CLB
       Coding: 00000039
       Subsystem 2 - Part No: 7L6 941 329 C  Labels: 3D0-941-329.CLB
       Coding: 00000039
    End-------------------------(Elapsed Time: 02:50)--------------------------
    Auto-Scan (with fault codes) after PolarFIS was installed...
    Sunday,14,May,2017,20:08:05:55895
    Mileage: 39420km-24494mi   Repair Order:
              72 77
    VIN: VSSZZZ1PZCRXXXXXX   Mileage: 39420km-24494miles
       Coding: 0000078
       Revision: 00H31001
       Revision: 00001001
       Coding: 0000000002
       Revision: BE021001
       Coding: 00DB90
       Coding: 02542E
       Coding: 100104
       Coding: 0012357
       Coding: 189A140002
       Coding: E30000
       Coding: 410F01
       Coding: 350203
                        Reset counter: 191
                        Mileage: 39415 km
                        Date: 2017.05.14
                        Time: 00:01:19
    1048659 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 191
                        Mileage: 39415 km
                        Date: 2017.05.14
                        Time: 00:01:16
       Coding: 0012B0
       Slave Driver:
       Coding: 000290
       Revision: 00H22000
       Coding: 0012B0
       Slave Passenger:
       Coding: 000290
       Coding: 2557189
       Coding: 00000039
       Coding: 00000039
    Address 77: Telephone
    End-------------------------(Elapsed Time: 02:57)--------------------------
  7. Likes Uwe liked this post
    If something is ticked but the gateway can't talk to it, then VCDS would produce: "Status: Cannot be reached". Ergo, in your first scan above, 77-Telephone was not ticked.
    Nov 2014
    Oxford, UK
    OK, so that can only mean that PolarFIS is to blame for the installation of module 77. Thanks for the confirmation.
    PolarFIS is displaying its information under the "Phone" page in the MFD so I think it might be masquerading as a telephone control module which could explain the mysterious appearance of module 77. I don't know.
    Everything seems to be working OK and I've not noticed any issues so far but my OCD kicks in whenever I see fault codes that shouldn't really be there and which I can't get rid of, especially faults like "1048659 - Function Restricted due to Missing Message(s)" in the CG
    I think I'll try unticking module 77 in the CG installation list and see if PolarFIS stops working, or if doing that just triggers PolarFIS to automatically reinstall module 77 again.
  10. #8
    If you contact their tech support, also ask them how much longer us poor B8 S4 owners are going to have to wait to have something comparable I'd gladly trade a DTC for all the info they're able to display!
  11. #9
    Nov 2014
    Oxford, UK
    And I would gladly trade my 1P FR+ with working PolarFIS for a B8 S4 without PolarFIS. Deal?
    Anyway, I've now done some further experimentation by unticking module "77-Telephone" in the CAN Gateway which PolarFIS appeared to have installed to see what happened. After doing this another Auto-Scan came back completely clean with no faults (hurrah! ) and to my surprise, PolarFIS still seemed to work without any issues that I could find. Even all the Bluetooth phone functionality still seemed to work seamlessly. I switched off the car and left it so the control modules would go to sleep, then came back an hour or so later and everything was still working fine - PolarFIS, Bluetooth phone functionality, the works. Another Auto-Scan revealed that PolarFIS had not reinstalled module 77 in the CG again and the scan was still completely fault-free so this was a good result...almost.
    What I have found is that if I "switch off" PolarFIS (done in the MFD/MFI under the PolarFIS menus) which effectively just removes/hides all evidence of it from the MFD/MFI screens, and then switch it back on again (done using a secret command which is to hold down the OK button on the MFSW for at least 10 seconds), module "77-Telephone" gets reinstalled back into the CG again. This seems to happen every time PolarFIS is switched from an "off" state to an "on" state. It doesn't happen if PolarFIS is left in an "on" state, even if ignition power is removed and reapplied, or after control modules have been asleep for a period of time. I can of course uninstall module 77 again using VCDS if I ever have a reason to "switch off" PolarFIS and then switch it back on again later, but it raises the question as to why PolarFIS is installing that module into the CG in the first place if it's evidently not needed. I've now raised a support ticket with Auto Polar asking why PolarFIS is installing module 77. Maybe it's just a bug(?) Hopefully they will get back to me with a decent explanation.
    I'm not expecting anyone here to chip in with any help because I doubt they can when my problem is to do with a 3rd party device, but I just thought I'd post up my findings in case anyone else in the world installs PolarFIS and gets the same issue, and is able to find this thread
    If I get a response from Auto Polar I will post it back here.
  12. Likes Eric, Uwe liked this post
