EVlAP, Sec Air, ABS/ESP Faults after steering repairs
henryb
Canada
C?ID=35924
I brought my 2006 A8L in for a groaning steering wheel sound... the sound only occurs when the engine is at idle. After some diagnostic work, my best guess was that the steering pump was a little weak? Purchased a used steering pump from Wolf Auto for $89 (local Audi Dealer wanted $900). Independent shop that replaced my leaking steering rack a few months back did the re & re of the steering pump and found that it did not address the groaning sound at all. So with more stethoscope type diagnostics, they determined that one of the tie-rod ends was the source of the groaning. Tell tale sign was a ripped outer boot. Ordered new part, installed, new alignment... the groaning steering sound is gone and the car drives nice.
But noticed that the ESP light was staying ON. Called the shop, they said maybe the steering angle sensor needs re-calibration... which I had to do the last time they did an alignment when they did the steering rack. I pulled out my laptop and ran a VCDS scan, the steering angle sensor seemed to be at 0.0 degrees at center, but I tried to re-calibrate it anyways, but would not allow that function to work, it was kicking out an error? Also I found a ton of new fault codes, many of which were probably due to a low battery voltage situation. So I cleared all of the codes, drove the car around the block... all of the low voltage type codes went away... but unfortunately, there were quite a handful of new codes that were not there before I brought the car in for the steering pump/tie-rod repair (I did a scan the night before I brought it in and saved the logs).
Here is what I'm seeing from VCDS now, please note some of the Engine codes were there before, including the Engine Mount Solenoid Valve codes, but all of the EVAP, MAF, Sec Air, ABS/ESP faults are new.
What I'm most concerned about is the Control Module Defective code in the 03 ABS section.
Saturday,13,May,2017,10:32:20:08168
VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4334.4
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
          46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E26N012097   Mileage: 211470km-131401miles
Address 01: Engine        Labels: None
   Part No SW: 4E0 910 560 P    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: --H01---    Serial number: AUX3Z0E8774746
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 2E0604104C16BBF78F5-807A
10 Faults Found:
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
                    Mileage: 211472 km
                    RPM: 683 /min
                    Load: 29.0 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 14.351 V
17980 - Left Engine Mount Solenoid Valve (N144)
            P1572 - 002 - Short to Ground
                    Fault Status: 01100010
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
17833 - EVAP Purge Valve (N80)
            P1425 - 002 - Short to Ground
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
17984 - Right Engine Mount Solenoid Valve (N145)
            P1576 - 002 - Short to Ground
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
17880 - EVAP Leak Detection Pump
            P1472 - 002 - Short to Ground
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
17843 - Secondary Air Pump Relay (J299)
            P1435 - 002 - Short to Ground
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
17829 - Secondary Air Injection Solenoid Valve (N112)
            P1421 - 002 - Short to Ground
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
17475 - Intake Air Switch-Over Valve (N335)
            P1067 - 002 - Short to Ground
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
17876 - EVAP Canister Solenoid Valve 2 (N115)
            P1468 - 002 - Short to Ground
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.478 V
16486 - Mass Air Flow Sensor (G70)
            P0102 - 002 - Signal too Low
                    Mileage: 211472 km
                    RPM: 677 /min
                    Load: 28.6 %
                    Temperature: 93.0°C
                    Temperature: 33.0°C
                    Voltage: 14.351 V
Readiness: 0010 1101
   Part No SW: 4E1 910 156 E    HW: 09E 927 156 B
   Component: AG6 09E 4,2L5V USA  0100
   Revision: --H01---    Serial number:        0068069
   VCID: 2514FB3C19E0F8AF7EF-8070
009783 - Torque Management Feedback Signal A
               P2637 - 000 -
                    Reset counter: 40
                    Mileage: 211472 km
                    Date: 2017.05.13
                    Time: 10:38:53
                    RPM: 672 /min
                    RPM: 640 /min
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 68.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
   Component: ESP 5.7 allrad  H44 0500
   Coding: 0007597
   VCID: 221EE02008CE0F971BD-8076
18265 - Load Signal
            P1857 - 000 - Error Message from ECU
00003 - Control Module
            014 - Defective
            013 - Check DTC Memory
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000532
   Shop #: WSC 02610 444 72962
   VCID: 1F18E9D43BBC227F343-804A
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 16
                    Voltage: 9.11 V
                    Count: 61
Let's start here:
http://wiki.ross-tech.com/wiki/index.php/00003
There's a special note that applies to your car:
When found in Audi A8/S8 (4E): Audi A8 (4E) Brake Electronics, this Fault Code may have been stored after performing an Output Test in the Brake Electronics Control Module w/o following the proper Instructions. To clear this Fault Code, please perform/repeat the following Steps 3 (THREE) times:
Switch the Ignition OFF for 5 Seconds, then Switch it ON again.
Clear Fault Codes in Brake Electronics Control Module, then exit out of the Control Module.
henryb
Canada
C?ID=35924
Let's start here:
Ok, that was some good information. And I believe I did run an Output test on the brake system, as the parking brake wouldn't come off at one point yesterday? But it eventually did come off. Anyways, the procedure did clear one of the ABS fault codes... Thank you for the information. Here is what is left on the 03 ABS Module codes (all of the other codes in the other modules remained the same):
   Coding: 0007597
18265 - Load Signal
            014 - Defective
I'd probably fix those shorts to ground by tracing WD checking fuses/shared tracks such as a consumer/FP relay & further isolation though unplugging them one by one if the relay or fuse is not the cause.
Then move forward with ABS repair since you have a network message freaking the ABS out.
