Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 1996 passat GLX won't record readiness
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    Readiness bits in basic settings will pass (xxxx x100), but it doesn't record that to the readiness menu. Checking readiness with my handheld Autel also says it's not ready.
    Car was in a while ago for emissions repairs, readiness was set then, but had faults. First autoscan.
    After repairs were done, faults were cleared and they drove it over 200 miles.
    Monday,03,April,2017,14:10:05:05734
    VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4334.4
    Dealer/Shop Name: hans j
    VIN:    License Plate: 046416
    Mileage: 28682   Repair Order:
    Chassis Type: 3A - VW Passat B4 (1994 > 1997)
    Scan: 01 02 03 08 15 25 41
    Address 01: Engine        Labels: 021-906-259-AAA.lbl
       Part No: 021 906 259 B
       Component: MOTRONIC M5.9    HS V05
       Coding: 00000
       Shop #: WSC 41940
       VCID: 9464FCCEE66D69E1DD-4B3C
    16885 - Vehicle Speed Sensor
                P0501 - 35-10 - Implausible Signal - Intermittent
    16824 - EVAP Emission Control Sys
                P0440 - 35-10 - Malfunction - Intermittent
                P0300 - 35-00 -
    16685 - Cylinder 1
                P0301 - 35-00 - Misfire Detected
    16690 - Cylinder 6
                P0306 - 35-00 - Misfire Detected
    Address 03: ABS Brakes        Labels: 3A0-907-379.lbl
       Part No: 3A0 907 379 A
       Component: ABS/EDS ITTAE 20 GI V00
       Coding: 04505
       VCID: A81CB83E4AE5FD0101-4AC2
    13 Faults Found:
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
                16-10 - Signal Outside Specifications - Intermittent
                04-10 - Mechanical Malfunction - Intermittent
    Address 15: Airbags        Labels: 6N0-909-60x-VW2.lbl
       Part No: 6N0 909 603 G
       Component: AIRBAG VW2          V00
       Coding: 00071
       Shop #: WSC 05311
       VCID: B620664690519BF183-4BF8
    00532 - Supply Voltage B+
    End----------(Elapsed Time: 02:15, VBatt start/end: 11.4V/11.2V)-----------
    200 miles later and a failed emissions test:
    Wednesday,03,May,2017,15:05:14:05734
    Mileage: 28927   Repair Order:
       Coding: 00000
       Shop #: WSC 41940
    Readiness: 0110 1101
       Coding: 04505
    13 Faults Found:
                16-00 - Signal Outside Specifications
                35-00 -  -
                35-00 -  -
                35-10 -  -  - Intermittent
       Coding: 00071
       Shop #: WSC 05311
    End----------(Elapsed Time: 02:15, VBatt start/end: 11.6V/11.6V)-----------
    I've tried two ECU's and two others that we had that had a MIL circuit fault, but obviously wouldn't pass with the CEL on.
    Both ECU's do the exact same thing, will pass readiness at basic settings, but it doesn't record that it's been set.
    Am I still chasing an ECU issue?
    I have a feeling I've dealt with this before, but can't remember the result.
    I also have three other autoscans of the vehicle dating back to 2011, all with different faults and all had the readiness set when it came in the next time with new faults.
    Those 1996 ECUs were notoriously difficult with respect to Readiness.
    Jack will probably chime in with some advice.
    YUP!
    Coding: 00000
    Shop #: WSC 41940
    Okay I see we have a bunch of loops here..........
    First JPPSG! and WTF am I talking about?
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    Your car have LDP and Evap or just Evap?
    What is the status of the TV?
    What did you do to rectify the Evap fault?
    Want to do a TV & remote me in?
    This ecu is supercritical of how we commence....
    Mar 2014
    Utah
    Last time it was in it had misfires and the boss wanted to use a ford coil pack to replace the VW coil. A vacuum leak was found on the brake booster one way valve and capped. I don't believe anyone tried to check readiness after work was completed, especially since it was an intermittent fault. Other than that, all stock, except for the cluster which is now just over 28000 miles old.
    I think this only has EVAP, but I'll look closer for an LDP tomorrow. I couldn't ever get MBV 153 to start the test, but 150 always ran and was passing. After a short test drive while in Basic Settings, all the readiness had been set in their respected MBV, just not saving it to where readiness is read.
    I'm sure this is just going to be common terms used in different shops, but what's TV an acronym for in your world? Haven't had to do a remote yet with HEX-NET, but we can try!
    Thanks for the links! Good info in your thread I'll have to save and print out.
    Including the rest of the autoscans I have of vehicle:
    Thursday,30,June,2016,11:42:44:05734
    VCDS Version: 16.6.0.2 (x64)  HEX-NET CB: 0.4321.4
    Data version: 20160602 DS251
    Dealer/Shop Name: Utah Imports hj
    Mileage: 21836   Repair Order:
       Coding: 00000
       Shop #: WSC 41940
       VCID: 14647CCE666DE9E36D-4B3C
       Coding: 04505
       VCID: 281C383ECAE57D03B1-4AC2
    13 Faults Found:
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
       Coding: 00071
       Shop #: WSC 05311
       VCID: 3620E64610511BF333-4B9A
    End----------(Elapsed Time: 02:15, VBatt start/end: 12.4V/12.4V)-----------
    Wednesday,29,July,2015,11:42:37:05734
    VCDS Version: 15.6.1.0 (x64)
    Data version: 20150612
    Mileage: 14890   Repair Order:
       Coding: 00000
       Shop #: WSC 41940
       VCID: 9464FCCEE66D699FCD-4B3C
    17988 - Throttle Actuator (Bank 1)
                P1580 - 35-10 - Malfunction - Intermittent
       Coding: 04505
       VCID: A81CB83E4AE5FD7F11-4AC2
    12 Faults Found:
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
       Coding: 00071
       Shop #: WSC 05311
       VCID: B620664690519B8F93-4B9A
    End-------------------------(Elapsed Time: 02:28)--------------------------
    Thursday,21,July,2011,13:53:25:03502
    VCDS Version: Beta 11.3.0 (x64)
    Data version: 20110601
    Utah Imports hj
    Control Module Part Number: 021 906 259 B
      Component and/or Version: MOTRONIC M5.9    HS V05
               Software Coding: 00000
                Work Shop Code: WSC 41940
                          VCID: 142C5E0E4B5E
    16795 - Secondary Air Injection System: Incorrect Flow Detected
            P0411 - 35-10 -  -  - Intermittent
    18021 - MIL Control Circuit: Open or Short to Plus
            P1613 - 35-10 -  -  - Intermittent
    17988 - Throttle Actuator (Bank 1): Malfunction
            P1580 - 35-10 -  -  - Intermittent
            P0300 - 35-10 -  -  - Intermittent
    16690 - Cylinder 6: Misfire Detected
            P0306 - 35-10 -  -  - Intermittent
    So is this ready now or not?
    I don't think so; those are all older scans.
    Since the tests run but the bits aren't stored, maybe time to give this ECU a proper re-boot?
    TV = Throttle Valve or Team Viewer remote session.
    Agreed a default with a TV is advised always when setting up a readiness path to be commenced unless on the second DCY doing static readiness tests in the bay.
  9. #8
    Mar 2014
    Utah
    Uwe, procedure on reboot? Discharge it by jumping the battery cables together? It had been unplugged for a few days before I had tried it again, but if there is another manual reboot that I could do, I'll give it a shot.
    I'll pull it back in and discharge the ECU, adapt the throttle body, and try running readiness again.
  10. #9
    You have not read links in Post #3 ...........
    http://forums.ross-tech.com/showthre...ll=1#post32730
  11. #10
    Mar 2014
    Utah
    Quote Originally Posted by hans j View Post
    Same result. Amazingly, SAI runs and passes on this car and is the easiest test to see if it passes readiness. So I run that test first and check readiness. Cycle the key and still readiness isn't set for SAI. Throttle body adapted okay in MBV 098. Both EVAP and LDP pass in their respected MBV, but still don't record.
