Hi there guys, I am attempting to install laser headlamps on my 2017 Audi R8 v10 plus NA version and need help with coding as VCDS is missing descriptions in long coding helper. Is there anyone here with access to an Audi R8 Gen 2 with laser headlamps installed or any info I can use? I am willing to pay you for your time if need be.
More Info if needed here:
Driver Side Headlamp Part #: 4S0 941 085
Passenger Side Headlamp Part #: 4S0 941 086
Module on rear side of headlamps: 4G0 907 397 Q
Module on underside: 7PP 941 572 AB
My VCDS Auto Scan:
My VCDS Auto Scan:
Monday,08,May,2017,08:52:15:00489
VCDS Version: 17.4.1.1 (x64) HEX-V2 CB: 0.4336.4
Data version: 20170413 DS270.4
VIN: WUAKBAFX8H7904441 License Plate:
Chassis Type: FX (4S0)
Scan: 01 02 03 05 06 08 09 11 31 15 16 17 19 1B 20 22 36 3B 42 44
46 52 53 55 5F 65 6C 81 A6 C2
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPA) Labels: None
Part No SW: 4S0 907 552 A HW: 4T0 907 552 A
Component: 5.2l V10HDZ / H56 0005
Revision: NHH56---
Coding: 1A2500320526000D3000
ASAM Dataset: EV_ECM52FSI1114S0907552A 001006
ROD: EV_ECM52FSI1114S0907552A.rod
VCID: 343215369EBB7137978-8060
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4S0 927 155 E HW: 0BH 927 711 F
Component: AU 7 SB NAR H10 3913
Revision: 00H10V01
ASAM Dataset: EV_TCMDL800041 001013
ROD: EV_TCMDL800041_AU35.rod
VCID: 392C2402B9D98C5F44E-806C
Part No SW: 4S0 907 379 D HW: 4S0 907 379 D
Component: ESP PREMIUM H09 0300
Coding: 21A88109841581904B00
ASAM Dataset: EV_ESPPremiAU57X 004048
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 3E26371EA0F7AB6771C-806A
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H44 0582
Coding: 0D806506000000000000
VCID: 74B2D536DEBB3137578-8020
Serial number: 3216000310133013
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4S0 959 760 HW: 4S0 959 760
Component: MEM-BFS 001 0020
Revision: AA001003 Serial number: 00000183852606
Coding: 00001000000420F1000001210101210000000000000000
VCID: 7BA0FE0AF3E57E4F162-802E
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 4S0 820 043 K HW: 4S0 820 043 K
Component: AC Automat H08 0040
Revision: 20012000 Serial number: 96800000005905
Coding: 4000A01000000410
ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
ROD: EV_AirCondiVAPrehAU72x.rod
VCID: 3330162A9BB5760F8E2-8066
Operating and display unit 2 for air conditioning:
Subsystem 1 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000007484
Operating and display unit 3 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 4H0 907 063 HK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0725
Revision: 2502102S Serial number: 00001583385302
Coding: 010D0011143C9FF0750048C380003800C59CD2882A08322100040894F1001100006000340B0000
VCID: 78AAE106C2D355577B0-802C
Subsystem 1 - Part No SW: 4S1 955 119 B HW: 8V2 955 119 A
Component: WWS624 170122 043 0081
Serial number: 90248162170206143459
Coding: 3247FD
Component: G397_RLFS H06 0004
Serial number: 62551567
Coding: 02005D
Subsystem 3 - Part No SW: 4S0 941 531 HW: 4S0 941 531
Component: E1 - LDS H01 0044
Serial number: 08 02 2017 00001490
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02AF2B36
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 37B80C8800PAG0MUFU03
Address 11: Engine II (-----) Labels: None
Revision: NHH56---
ASAM Dataset: EV_ECM52FSI2114S0907552A 001006
ROD: EV_ECM52FSI2114S0907552A.rod
Address 15: Airbags (J234) Labels: None
Part No SW: 4S0 959 655 HW: 4S0 959 655
Component: Airbag10.43 H62 0204
Revision: -------- Serial number: 003NJ0015ZPP
Coding: 303338453036303038324A55304C34533053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
VCID: 7EA6F71EE0776B6731C-802A
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y160001K3NW0A
Serial number: 3575HRB406947OGUD89X
Serial number: 3585HRB405F47OGU7G1X
Serial number: 3515JRB4018599BEDP31
Serial number: 3525JRB400E598PKPPJB
Serial number: 3554VRB40165971E81JW
Serial number: 3564VRB40165971EK9VM
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4S0 907 129 K HW: 4S0 907 129 K
Component: Lenks.Modul H06 0007
Revision: C0071527 Serial number: 91335QA700096-
Coding: 000034
VCID: 3E26371EA077AB6771C-806A
Address 17: Instruments (J285) Labels: None
Part No SW: 4S0 920 890 A HW: 4S0 920 890 A
Component: FBenUSA H14 0251
Coding: 086F32C1AA81CF050230ECC41800001000000000
ASAM Dataset: EV_DashBoardBOSCHAU724 001022
ROD: EV_DashBoardBOSCHAU724.rod
Part No SW: 4S0 907 468 B HW: 4S0 907 468 A
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002528777
Coding: 802103161C
ROD: EV_GatewPkoUDS_VW51.rod
VCID: 3B203E0AB3E5BE4F562-806E
Subsystem 1 - Part No SW: 4S0 915 181 HW: 4S0 915 181
Component: J367-BDM H08 0270
Serial number: 54033404062871167736
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0D0000
VCID: 3A2E3B0EBC5F87474D4-806E
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 81A 857 511 H HW: 81A 857 511 H
Component: FLA H10 0003
Revision: AB001001
Coding: 0404001D00010001000001
ASAM Dataset: EV_HighBeamAssisAU724 001007
ROD: EV_HighBeamAssisAU724.rod
VCID: 2D0400527D9120FFD86-8078
Address 22: AWD (J492) Labels: None
Part No SW: 4S0 907 160 HW: 4S0 907 160
Component: 4 Wheel Drive H07 0207
Revision: 00001002 Serial number: BBPX5FO
ASAM Dataset: EV_AllWheelContrBORGLB724 006012
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 6E86C75EB0171BE7A1C-803A
Component: MEM-FS 001 0020
Revision: AA001003 Serial number: 00000183852605
Coding: 00181900000420F1C00001210101210000000000000000
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02LSBY
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3728223A8FCD9A2FB2A-8062
Component: TSG FA H03 0511
Coding: 011C53425000000300000402
VCID: 47C852FAFFADEAAFC2A-8012
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4S0 909 144 H HW: 4S0 909 144 B
Component: EPS H13 0905
Revision: 00000000 Serial number: L00189141
Coding: 0903
ASAM Dataset: EV_EPSZFAU72X 003010
ROD: EV_EPSZFAU72X_003.rod
VCID: 3A2E3B0EBCDF87474D4-806E
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0431821718
Coding: 0106069A00F24081E0B0CC00008500000001000000000000000000000000
Subsystem 1 - Part No SW: 4S0 959 719 A HW: 4S0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170116080759 00110
Component: TSG BF H03 0511
Coding: 011C53425E00000300000400
VCID: 46D65FFEF8A7F3A739C-8012
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H03 0001
Revision: -------- Serial number: 30000000002951
ROD: EV_ParkiBrake_AU72.rod
VCID: 70BAD926AA230D17B30-8024
Address 55: Headlight Range (J745) Labels: None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 077A081122600400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
VCID: 36362F3E88C76327A9C-8062
Subsystem 1 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0008
Coding: E02200
Subsystem 2 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0008
Coding: E02200
Part No SW: 4S0 035 025 B HW: 4S0 035 025
Component: MU-H-LNS-US 053 0907
Serial number: A353B0H7515434
Coding: 012704020000000013220002041A00102F0000E1007000047E
ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
ROD: EV_MUHig6C8Gen2HBAS.rod
VCID: 280AF146527305D72B0-807C
Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
Component: NAR 2017 --- 0057
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 4S1 919 614 D HW: 4S1 919 614 D
Component: ControlUnit_H H30 0206
Serial number: APVAK123121600010167
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 3011
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000037136
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C020D56468B29F7CF8-8078
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 4S0 980 556 A HW: 95B 980 551 L
Component: RVC Compact H12 0201
Coding: 027504010A000001000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_AU72.rod
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4S1 713 041 E HW: 4M1 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161111001943
ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A6: Microphone (J886) Labels: 420-907-394.clb
Part No SW: 420 907 394 B HW: 420 907 394
Component: BELTMICBOX H10 0820
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335_AU35.rod
VCID: 186AC186E213B5579B0-804C
Address C2: Auto Trans 2 (J217) Labels: None
Part No SW: 4S0 927 109 HW: 4S0 927 109
Component: DL800 ZSG H12 0002
Revision: --H12--- Serial number: 0000000059
Coding: 000001
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
VCID: 73B0D62ADB35360F4E2-8026
