Results 1 to 5 of 5
Thread: Polo 6C Electronic Suspension Retrofit : 2015 MY
    Oct 2014
    Singapore
    we have installed the DCC ( Sports Select ) using original VW parts onto a 2015 Polo 6C .
    The #14 Elect Suspension is working without any error itself.
    However, we are not able to engage the switch from Normal to Sports using the retrofitting Sport Select button on the dashboard. We are always in Normal mode since we cannot engage the Sports mode to come on.
    There is a new error on the ABS but we cannot figure out what is wrong. We did not change the long coding but the "wrongly coded" message kept appearing. Nevertheless, we don't think it is affecting the DCC operation. There is MIL message on the cluster and the ABS works fine.
    All wiring have followed the electrical diagram on ELSA and we believe that there is no wrong fitting of the assigned pins.
    Would believe that the problem is due to the Gateway SWAP software being not suitable for the car. Need to update the software online.
    We need the Advanced ID of a vehicle originally fitted with the DCC from VW. Need help from the Gurus here and any Bros who have a similar factory fitted DCC Polo 6C model.
    Here is a scan of the vehicle.
    Monday,08,May,2017,17:50:50:24118
    VCDS Version: 17.1.3.0
    Dealer/Shop Name: cbx auto
    Workshop Code: 305 91777 091777
    VIN: WVWZZZ6RZFUXXXXXX   License Plate: POLO LEOW 1,2 DCC AFTER ERROR
    Mileage: 25628km-15924mi   Repair Order:
    Chassis Type: 6R (6C0)
    Scan: 01 02 03 08 09 14 15 17 19 44 5F
    VIN: WVWZZZ6RZFUXXXXXX   Mileage: 25628km-15924miles
    5F-Information Electr. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CJZC)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
       Component: 1.2l R4 TSI   H21 8228
       Revision: R5H21---
       Coding: 01250012230411080000
       Shop #: WSC 31414 790 50316
       ASAM Dataset: EV_ECM12TFS01104E906027BB 001006
       ROD: EV_ECM12TFS01104E906027BB.rod
       VCID: 65CB5EAE643FF0697A-8030
       CAN Converter 01:
    Readiness: 1110 0001
       Part No SW: 0CW 300 046 G    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5206
       Revision: 00043014    Serial number: CU501409196312
       ROD: EV_TCMDQ200021.rod
       VCID: 3E79D1C2A12983B1DB-806A
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
       Part No SW: 6C0 907 379     HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0002
       Serial number: 08506045140922
       Coding: 23DD2885892733C9111C106C0057C41491CC88080005C7090000
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
       VCID: 6CDD2B8A87D5C12125-8038
    1148 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [009] - -
                        Reset counter: 155
                        Mileage: 25628 km
                        Date: 2017.05.07
                        Time: 17:39:12
    1219 - Coding invalid
              U10DA 00 [009] - -
                        Reset counter: 155
                        Mileage: 25628 km
                        Date: 2017.05.07
                        Time: 17:39:07
    Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
       Part No SW: 6C0 907 044 A    HW: 6C0 907 044 A
       Component: Climatronic   H02 0104
       Serial number:  1409101A-0029
       Coding: 200020011001100001
       ASAM Dataset: EV_ACClimaValeoPQ26 003001
       ROD: EV_ACClimaValeoPQ26_VW26.rod
       VCID: 224105B23591C751DF-8076
    Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 A    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H06 0047
       Serial number: 001028001732
       Coding: 03001840425300DB4B844000402703881000580253010000000000000000
       Shop #: WSC 91777 305 91777
       ASAM Dataset: EV_BCMA0 004003
       ROD: EV_BCMA0_004_VW26.rod
       VCID: 2E59E182714973314B-807A
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6R0 959 802 CH    HW: 6R0 959 801 CF  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 9610
       Serial number: KU0KU025091442688034
       Coding: 1400A1
       Subsystem 2 - Part No SW: 6R0 959 801 CF    HW: 6R0 959 802 CH  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 9610
       Serial number: KU0KU015091442581170
       Coding: 0400A1
       Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
       Component: J389__TSG_HR  003 8610
       Serial number: KU0KU016091442593683
       Coding: 1400A0
       Subsystem 5 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
       Component: J388__TSG_HL  003 8610
       Serial number: KU0KU020101442934135
       Coding: 0400A0
    Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
       Part No SW: 6C0 907 359     HW: 6C0 907 359
       Component: DAEMPFUNGS-SG H04 0007
       Serial number: 13061602000033
       Coding: 80
       ASAM Dataset: EV_SwitcDampeContiTemic 001004
       ROD: EV_SwitcDampeContiTemic.rod
       VCID: 6AD12D928D21DF1157-803E
    Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
       Part No SW: 6C0 959 655 B    HW: 6C0 959 655 B
       Component: VW20Airbag01D 001 0330
       Revision: --------    Serial number: 003LN000ZYH4
       Coding: 88CCC000000000005C0000CA008800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3261F5F2657157D12F-8066
       Subsystem 1 - Part No SW: -----------    HW: 410 821 408 14
       Component: SideSensor_Df  151 0800
       Serial number: 3575H009F1627C1271FT
       Subsystem 2 - Part No SW: -----------    HW: 410 821 408 14
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00BF1628C01A09R
       Subsystem 3 - Part No SW: -----------    HW: 442 152 709 14
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00A31730323909X
       Subsystem 4 - Part No SW: -----------    HW: 442 152 709 14
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00A5176F6017144
       Part No SW: 6C0 920 730 A    HW: 6C0 920 730 A
       Component: KOMBI         110 0260
       Coding: 2724090820000008000808000000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009036
       VCID: 1F470C4606E3EAB9F0-804A
              U1014 00 [009] - -
                        Reset counter: 155
                        Mileage: 25628 km
                        Date: 2017.05.07
                        Time: 00:13:25
    Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H06 0047
       Revision: --------    Serial number: 001028001732
       Coding: 030100046F0A560071000000000000010001000000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: EV_GatewA0Lear_VW26.rod
       Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAT  H04 0019
       Serial number: 2561420373502242AB1B
       Coding: 240000
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 51281E41142821930261
    131699 - Control unit for information electronics 1
              U1054 00 [009] - No Communication
                        Reset counter: 155
                        Mileage: 25628 km
                        Date: 2017.05.07
                        Time: 00:12:49
                        Supply voltage: Terminal 30: 13.1 V
                        Terminal 15: On
    Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
       Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
       Component: EPS_TRW_ALow  322 3211
       Serial number: CE9O0276
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 336FF0F69A6B5ED924-8066
    End---------------------(Elapsed Time: 02:43, Deb=2)-----------------------
  2. Likes Boki Ar liked this post
  3. #2
    No guarantees at all, but try this for [ABS-03]:
    23DD2885892733C9111C106C0057C41491CC880C0005C7090000
  4. Likes Uwe, cbx750p liked this post
  5. #3
    Oct 2014
    Singapore
    Polo 6C Elect Suspension
    Hi Bro,
    thanks for your information on the ABS long coding. Will give it a try on the car
    Actually, we need the Advanced ID from an originally equipped Polo 6C.
    Thanks
    Jim
    Quote Originally Posted by cbx750p View Post
    From Address [03] or [14] or [19] ?
    What do you need it for ?
    Try also coding [CAN Gateway-19]:
    030100046F0A560071000000800000010001000000000000000000000000
  7. Likes cbx750p liked this post
  8. #5
    Oct 2014
    Singapore
    We need the Advanced ID from #17 Instrument. With this data, we believe that we would be able to replicate our Polo Gateway to be flashed with the same software as the GTI. This would be done via ODIS online. Once this is done, the BCM should be able to recognise the presence of the Drive Select switch which is already installed and wired up.
    We already coded the #09 Centre Electric to have "Drive Select installed" option but when we press the button, nothing happens ( button does not light up ).
