Results 1 to 9 of 9
Thread: B8 S4 Touch Entry Not Working Correctly
    Verified VCDS User tehfalcon's Avatar
    Oct 2015
    Angry B8 S4 Touch Entry Not Working Correctly
    I have a 2010 Audi S4 that was taken to the dealer recently and they messed with the coding in my modules big time, the Push button start no longer worked when I got it back, and the touch entry doesn't work correctly.
    I fixed the Push Button start issue by re-enabling the Advance Key Installed in the Comfort Module and ACC/Start Auth Module.
    Before you ask, I won't bring it back to that dealer for them to fix, because they have no idea what they are doing, and were claiming I had tons of modules bad (no I didn't) and wanted to charge me a ton to fix it all (keep in mind everything was perfect on the car, no faults, I just wanted a key programmed).
    Here is a video of the issue. https://www.youtube.com/watch?v=v1rRiHJIh7k
    In a Nutshell, the touch lock portion seems to work fine, but grabbing the handle to unlock causes it to just constantly beep and it to unlock the rear doors if I grab the front handle, or the front doors if I grab the back handle.
    I imagine it is just a coding error somewhere since they messed up the coding on several modules.
    2006 Audi A6 4.2 Quattro Auto ‘Prestige’ Stock
    2007 Volkswagen Rabbit 2.5 4-Door Manual ‘S’ Stage 1
    2007 Volkswagen EOS 3.2 DSG 'Highline' Stock
    2019 Volkswagen GTI 2.0T 4-Door DSG ‘SE’ Stage 2
  2. Likes Jack@European_Parts liked this post
  3. #2
    Jul 2014
    Poland
    Start by posting recent auto-scan of your car.
    Does the problem occur on both keys? I mean if there is any difference if you walk in with new or old key?
    ESP OFFLINE coding for all VAG 2010->/ Certified GeKo user/ Retrofitting, Chip-tuning, Flash updates, ECU programming, key coding, clusters and many more...
  4. Likes Dana, Jack@European_Parts liked this post
  5. #3
    Oct 2015
    Here is my Autoscan
    Tuesday,09,May,2017,14:07:09:46885
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
    VIN: WAUKGAFL2AA181459   License Plate:
    Mileage: 166920km-103719mi   Repair Order:
    Chassis Type: FL (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
              5F 62 6C 72
    VIN: WAUKGAFL2AA181459   Mileage: 166920km-103719miles
    Address 01: Engine (J623-CCBA)       Labels: 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
       Component: 3.0T SIMOS84  X06 0003
       Revision: --X06---
       Coding: 0104010A240F0128
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
       ROD: EV_ECM30TFS0218K0907551D.rod
       VCID: 323E1302E4A413C7EBD-8066
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8K1 927 156 C    HW: 0B5 927 156 E
       Component: 0B5 30TFSINAR H03 0002
       Revision: --H03---    Serial number: 0000000810
       Coding: 000001
       ASAM Dataset: EV_TCMDL501 A02044
       ROD: EV_TCMDL501.rod
       VCID: 3534281E15CA04FFCEF-8060
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0030
       Coding: 294D18
       VCID: 7AAEFB227CD42B8763D-802E
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0328
       Coding: 0D0100
       Shop #: WSC 03889 003 104857
       VCID: 78AAE12A42D83997159-802C
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Serial number: 0210000064781009
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01100520101050
       Coding: 66002000
       Shop #: WSC 03889 003 1048576
       VCID: 005A89CA1A0871572D9-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H29 0380
       Revision: 10029001    Serial number: 00000000667537
       Coding: 26001897413CAF010000000300003D0D4F1C530800010161000000
       VCID: 3C223D3A3660D5B7311-8068
       Component: WWS 120510  H06 0070
       Serial number: SWF10050125449
       Coding: 00FD31
       Component: RLS  H04 0003
       Serial number: 10900297
       Coding: 035028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000505102274
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
                013 - Check DTC Memory
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51241013008523
       Coding: 30010D
       VCID: 47C852D67FA6866FAC3-8012
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0G0U2F
       Coding: 303837354230303030304A55304C384B3053
       VCID: 45D458DE452A947F5EF-8010
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R1000006Y06
       Serial number: 6334MSME5245635DG
       Serial number: 6344MSME524570399
       Serial number: 6352QSME4260262CB
       Serial number: 6362QSME4C603416E
       Serial number: 63732SME4B601E2E8
       Serial number: 63832SME50603328R
       Revision: --------    Serial number: 90304JED000J5
       Coding: 000036
       VCID: 3D24303E2D7ADCBF06F-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 Q    HW: 8K0 920 980 Q
       Component: KOMBIINSTR.   H06 0255
       Revision: 00000000    Serial number: CJ267H95A
       Coding: 8FFF09000300D705020201
       VCID: 40DA49CA5A88B1576D9-8014
       Part No SW: 8T0 907 468 AE    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0117
       Revision: FC100058    Serial number: 5800F104178163
       Coding: 00C303
       VCID: 045285DA0E106D77091-8050
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 10017C62290410
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001010149479
       Coding: 00581300000000000000
       VCID: 3B203E26336ED28F38B-806E
       Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0030
       Revision: 00H01000    Serial number: 6PZ 009 014-82
       VCID: 3C223D3A3A60D5B7311-8068
       Subsystem 1 - Part No: 8K0 907 568 H
       Component: J0770_SWA_Slave_H01 0030
       Subsystem 2 - Serial number: 6PZ 009 014-92
       Subsystem 3 - Serial number: 5F07.05.1000H010003C323225˙
       Subsystem 4 - Serial number: 323225˙
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000010631814
       Coding: 011C03204E00410001
       VCID: 45D458DE45AA947F5EF-8010
       Revision: 00002001    Serial number: 0130049961
       Coding: 0106063A00FA040703B0013202000000
       Subsystem 2 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34882002480001
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000010633869
       VCID: 44D245DA4E90AD77491-8010
       Revision: 00000003    Serial number: 00000000639687
       VCID: 3432151A1E301DF7F91-8060
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 77A8E21643C636EF1C3-8022
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335ET0A7570315
       Coding: 020000010000000001
       VCID: 1D64D0BE8DBABCBF26F-8048
       Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
       Component: H-BN-NA       H47 0042
       Revision: --------    Serial number: 490EY0A7565620
       Coding: 010200000206E3FF53001F0E000000030000
       VCID: 372822160F46F6EFDC3-8062
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356EP0A1312590
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000536796
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000104200939
       Coding: 010C03204000210001
       VCID: 42DE43C25484A3477BD-8016
       Revision: --H04---    Serial number: 525PA8-J0390TU
       Coding: 1000006
       VCID: 382A212A0E58F997D59-806C
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000104200986
    End----------(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.1V)-----------
  6. #4
    United States
    Do you happen to have a scan before the dealer messed it all up? Please check the C:\Ross-Tech\VCDS\Scans -and- C:\Ross-Tech\VCDS\Logs folder for anything earlier than that visit.
    Also, let us know about automech's question. Does that happen with both keys (original and new) or just one of the keys?
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    HQ
    Dana and I have looked this over and would like you to make the following changes:
    Door control modules, front doors (J386 & J387), change coding to 011C13204E00410001
    Door control modules, rear doors (J388 & J389), change coding to 010C13204000210001
    In short, on all door control modules, Byte 2 is going from "03" to "13".
    See if that helps. If not, then also do this:
    Central Conv. (J393), change coding to 0106063A007A040703B0013200000000
    This disables Byte 5/Bit7 and Byte 12/Bit 1.
    Please post your results and a fresh follow up Auto-Scan.
    Jef
  9. Likes Uwe, Dana, Jack@European_Parts, automech liked this post
  10. #6
    Oct 2015
    It worked! Thanks guys! To answer the other question, it was doing it on both the new and old key.
    Here is the new autoscan.
    Wednesday,10,May,2017,12:30:54:46885
              5F 62 6C 72
    VIN: WAUKGAFL2AA181459   Mileage: 167010km-103775miles
       Revision: --X06---
       Coding: 000001
       Coding: 294D18
       Coding: 0D0100
       Coding: 66002000
       Coding: 260018934134BF010001010300003D0D4F1C530800010161000000
       Coding: 00FD31
       Coding: 035028
       Coding: 30010D
       Coding: 000036
       Coding: 8BFF09000300D705020201
       Coding: 00C303
       Coding: 011C13204E00410001
       Coding: 01060638007A040703B0013200000000
       Coding: 0000004
       Coding: 010C13204000210001
       Coding: 1000006
    End-------------------------(Elapsed Time: 01:43)--------------------------
    you wouldn't have any idea on the only fault I have do you? Nothing on the wiki for the "check DTC memory" on that fault code.
  11. Likes Jack@European_Parts, automech, Uwe liked this post
  12. #7
    This just means your CECM thinks there might be a fault in the CCM. But there isn't. I would explicitly clear faults in both of them again...
  13. #8
    HQ
    Quote Originally Posted by tehfalcon View Post
    Was it just recoding the door control modules, or did you have to also recode the Central Conv.?
    Jef
  14. #9
    Oct 2015
    Just recoding the door control modules made it work.
  15. Likes Uwe liked this post
