Results 1 to 10 of 16
Thread: Volkswagen Passat CC TDI 170 DSG cannot turn on ignition?
    Jan 2015
    Sweden
    Hello!
    I need urgently help with an issue on the car above. I changed the steering lock yesterday on the car, after the repair I drove it to the customer just around the corner. When the customer was supposed to go home couldn't he start the car. I thought his battery was drained, but no. There is no ignition lamps och the dashboard light, but still is the battery in perfect condition. I cannot get the ignition/steering lock to release, so I cannot move the car either.
    And, because no ignition I cannot get any type of error codes from the car???
    Is this a common problem or do any one of you know what i can be??
    Kind regard
    //Kjell Söderberg
    Did you save an auto-scan from the repair?
    Are all fuses & plugs tight & to ignition switch or steering unit just replaced?
    You can power up the OBD by applying power from the battery to the terminal 16 DLC connector by breakout box etc. to bring on terminal 15 and then scan the car.
    Jan 2015
    Sweden
    This is what I have saved since before. Sorry, this is in Swedish but I now have the later english version (but not the scan the car in english). I do not have any breakout box, but can probably apply power on the OBD connector (right?).
    måndag,16,Januari,2017,07:49:09:01232
    VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 10 x64
    VCDS version: AER 16.8.3.3
    Dataversion: 20161205 DS267.0
    VIN: WVWZZZ3CZAE506983   Reg.nr: DXD500
    Mätarställning: 114820km   Rep.order:
    Chassityp: 3C (3C0)
    Skanna: 01 02 03 08 09 10 14 15 16 17 19 25 42 44 46 52 53 55 56 62
              69 72
    VIN: WVWZZZ3CZAE506983   Mätarställning: 114820km
    01-Motor -- Status: Felfunktion 0010
    02-Automatväxel -- Status: OK 0000
    03-Bromselektronik -- Status: OK 0000
    04-Styrposition -- Status: OK 0000
    08-Klimatanläggning -- Status: OK 0000
    09-Elektron. elcentral -- Status: OK 0000
    10-park/styr-hjälp -- Status: OK 0000
    14-Stötd.-elektronik -- Status: OK 0000
    15-Krockkuddar -- Status: OK 0000
    16-Rattelektronik -- Status: OK 0000
    17-Instrument -- Status: OK 0000
    25-Startspärr -- Status: Felfunktion 0010
    42-Dörrel. förare -- Status: Felfunktion 0010
    44-Styrservo -- Status: Felfunktion 0010
    46-Komfortcentral -- Status: Felfunktion 0010
    52-Dörrelektr. pass. -- Status: Felfunktion 0010
    53-Parkeringsbroms -- Status: Felfunktion 0010
    55-Helljusområde -- Status: OK 0000
    56-Radio -- Status: Felfunktion 0010
    62-Dörr vä. bak -- Status: OK 0000
    69-Släpvagnsfunktion -- Status: Felfunktion 0010
    72-Dörr hö bak -- Status: OK 0000
    Adress 01: Motor (CBB)       Labels: AER\03L-906-022-CBA.clb
       Artikelnr SW: 03L 906 022 QG    HW: 03L 907 309
       Komponent: R4 2,0L EDC G000AG  6212
       Revision: 13H02---    Serienummer: VWZCZ000000000
       Kodning: 0000078
       Verkstad #: WSC 18688 295 739048
       VCID: 7AC3B15535DB89928C-802E
    3 Funna fel:
    001650 - Glödstift cylinder 2 (Q11)
                   P0672 - 000 - elfel
                 frysta data:
                        Felstatus: 01100000
                        Felprioritet: 2
                        Felfrekvens: 1
                        Reset-räknare: 255
                        Mätarställning: 114410 km
                        Tidsindikering: 0
                        Datum: 2011.05.08
                        Tid: 16:27:12
                 frysta data:
                        RPM: 897 /min
                        Hastighet: 0.0 km/h
                        Spänning: 11.02 V
                        Temperatur: 15.3°C
                        Binära Bitar: 10110000
                        Tid: 0.72 s
                        Temperatur: 15.3°C
    001299 - Felaktig startspärrskod
                   P0513 - 000 -  - Intermittent fel
                 frysta data:
                        Felstatus: 00100000
                        Felprioritet: 2
                        Felfrekvens: 4
                        Reset-räknare: 255
                        Mätarställning: 114799 km
                        Tidsindikering: 0
                        Datum: 2011.06.04
                        Tid: 07:08:58
                 frysta data:
                        RPM: 1311 /min
                        Hastighet: 0.0 km/h
                        Spänning: 10.94 V
                        Absoluttryck: 989.4 mbar
                        Absoluttryck: 948.6 mbar
                        Temperatur: -5.4°C
                        Temperatur: -5.4°C
    001674 - Huvudrelä
                   P068A - 000 - Öppnas för tidigt - Intermittent fel
                 frysta data:
                        Felstatus: 00100000
                        Felprioritet: 2
                        Felfrekvens: 1
                        Reset-räknare: 255
                        Mätarställning: 0 km
                        Tidsindikering: 0
                 frysta data:
                        Hastighet: 0.0 km/h
                        Belastning: 0.0 %
                        Spänning: 0.00 V
                        Hex-värde: 0xFF00
                        Binära Bitar: 00000000
                        Temperatur: -90.0°C
    Adress 02: Automatväxel        Labels: AER\02E-927-770.clb
       Artikelnr SW: 02E 300 051 T    HW: 02E 927 770 AJ
       Komponent: GSG DSG AG6     440 1912
       Revision: 04844002    Serienummer: 00000905170157
       Kodning: 0000020
       Verkstad #: WSC 05311 000 00000
       VCID: 247FAF2DE7DF2F6286-8070
    Ingen felkod funnen.
    Adress 03: Bromselektronik        Labels: AER\3C0-614-109-C4.clb
       Artikelnr SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Komponent: J104    C4 440 V2   0015
       Revision: --025---    Serienummer: 00000795267283
       Kodning: 0002344
       VCID: 62F3E935BD4B6152B4-8036
    Adress 08: Klimatanläggning (J255)       Labels: AER\5K0-907-044.clb
       Artikelnr SW: 5K0 907 044 BD    HW: 5K0 907 044 BD
       Komponent: Climatronic   H14 0608
       Revision: 00003001
       Kodning: 0000000000
       Verkstad #: WSC 05311 115 00000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 6EEB8D05B193D53220-803A
    Adress 09: Elektron. elcentral        Labels: 3C0-937-049-30-H.lbl
       Artikelnr SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Komponent: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serienummer: 00000009655361
       Kodning: E3E28F8B00041A0047978F0017000000000AFB4764400165170000000000
       Verkstad #: WSC 80093 222 69422
       VCID: 335D5C715231B8DA0F-8066
       Subsystem 1 - Artikelnr: 3C8 955 119   Labels: AER\1KX-955-119.CLB
       Komponent: Wischer 290409 022  0602
       Kodning: 00046997
       Subsystem 2 - Artikelnr: 1K0 955 559 AH  Labels: AER\1K0-955-559-AG.CLB
       Komponent: RLS     180609 054  0402
       Kodning: 00209133
    Adress 10: park/styr-hjälp (J446)       Labels: AER\3C8-919-475.clb
       Artikelnr SW: 3C8 919 475 A    HW: 3C8 919 475
       Komponent: PARKHILFE 8K  H07 0009
       Revision: --------    Serienummer: 08740915503159
       Kodning: 110101
       Verkstad #: WSC 05314 000 00000
       VCID: 325359756D2BB1D204-8066
    Adress 14: Stötd.-elektronik (J250)       Labels: 3C0-907-376.clb
       Artikelnr SW: 3C0 907 376 A    HW: 3C0 907 376
       Komponent: DAEMPFUNGS-SG H07 0070
       Revision: 00000000    Serienummer: 08060901450001
       Kodning: 010180
       VCID: 2765B82156E9C47AA3-8072
    Adress 15: Krockkuddar        Labels: AER\5N0-959-655.lbl
       Artikelnr SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Komponent: J234__300 VW10 HI   1916
       Revision: 20013000    Serienummer: 003E2PBHKTSK
       Kodning: 0012336
       VCID: 44BF0FAD079F0F62A6-8010
       Subsystem 1 - Serienummer: 6332MTS601331539
       Subsystem 2 - Serienummer: 6342MTS641291379
       Subsystem 3 - Serienummer: 6351HTS6D7ET16KR
       Subsystem 4 - Serienummer: 6361HTS6B1ES16KJ
       Subsystem 5 - Serienummer: 00000000000000000
       Subsystem 6 - Serienummer: 00000000000000000
    Adress 16: Rattelektronik        Labels: AER\3C0-953-549-SW25.lbl
       Artikelnr SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Komponent: J0527               0030
       Revision: 00032000    Serienummer: 3C5953507CN
       Kodning: 0001511
       VCID: 74DF9F6D17BFFFE2D6-8020
       Subsystem 1 - Artikelnr: 3C8 959 537 B  Labels: AER\3C8-959-537.CLB
       Komponent: E221__MFL-TAP   H4ÿ 0021
       Kodning: 00000226
       Verkstad #: WSC 00000
    Adress 17: Instrument (J285)       Labels: AER\3C8-920-xxx-17.clb
       Artikelnr SW: 3C8 920 870 E    HW: 3C8 920 870 E
       Komponent: KOMBI         H02 0206
       Kodning: 140F00
       Verkstad #: WSC 05314 115 00000
       VCID: 2D694A097C15EE2A59-8078
    Adress 19: CAN Gateway        Labels: AER\3C0-907-530-V3.clb
       Artikelnr SW: 3C0 907 530 L    HW: 3C0 907 951
       Komponent: J533__Gateway   H13 0152
       Revision:   H13       Serienummer: 3300P0961601B7
       Kodning: FDA97F46000202009002
       VCID: 2A63411585FBF912BC-807E
    Adress 25: Startspärr        Labels: AER\3C0-959-433-25.clb
       Artikelnr SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Komponent:    IMMO         043 0383
       Revision: 00043000    Serienummer: VWZCZ000000000
       Verkstad #: WSC 131071 1023 2097151
       Subsystem 1 - Artikelnr: 3C0 905 861 G
       Komponent:    ELV          027 0380
       3C0905861G     ELV          027 0380
    3 Funna fel:
    02861 - elektr. låsning av rattaxeln defekt
                008 - Orimlig signal - Intermittent fel
                 frysta data:
                        Felstatus: 00101000
                        Felprioritet: 4
                        Felfrekvens: 7
                        Reset-räknare: 180
                        Mätarställning: 114728 km
                        Tidsindikering: 0
                        Datum: 2011.05.27
                        Tid: 06:54:54
    02818 - Elektr. rattaxellås; frigivning för elektr. tändningslås
                009 - Avbrott eller kortsluten till jord - Intermittent fel
                 frysta data:
                        Felstatus: 00101001
                        Felprioritet: 2
                        Felfrekvens: 24
                        Reset-räknare: 180
                        Mätarställning: 114445 km
                        Tidsindikering: 0
                        Datum: 2011.05.09
                        Tid: 18:06:34
    02811 - Styrdon för ELV (elektr. rattaxellåsning)
                014 - felaktig - Intermittent fel
                 frysta data:
                        Felstatus: 00101110
                        Felprioritet: 1
                        Felfrekvens: 16
                        Reset-räknare: 180
                        Tidsindikering: 0
                        Datum: 2011.05.09
                        Tid: 18:06:36
    Adress 42: Dörrel. förare        Labels: AER\1K0-959-701-MAX3.lbl
       Artikelnr SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Komponent: J386  TUER-SG FT    1533
       Revision: 71009005    Serienummer: 00000759398612
       Kodning: 0000181
       VCID: 40B703BD1387134282-8014
    1 fel funnet:
    00932 - Motor för fönsterhiss: förarsidan (V147)
                005 - Ingen eller felatig grundinställning/anpassning - Intermittent fel
                 frysta data:
                        Felstatus: 00100101
                        Felprioritet: 6
                        Felfrekvens: 1
                        Reset-räknare: 179
                        Mätarställning: 114755 km
                        Tidsindikering: 0
    Adress 44: Styrservo        Labels: AER\5N1-909-144.clb
       Artikelnr SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Komponent: J500__APA-BS KL.137 0703
       Revision: 1AH03256    Serienummer: 00091260140902
       Kodning: 0000258
       VCID: 3A437155755B4992CC-806E
    3 Funna fel:
    00668 - Spänning klämma 30
                002 - Undre gräns överskriden - Intermittent fel
                 frysta data:
                        Felstatus: 00100010
                        Felprioritet: 4
                        Felfrekvens: 1
                        Reset-räknare: 179
                        Tidsindikering: 0
                 frysta data:
                        Spänning: 0.10 V
                        Spänning: 4.60 V
                        Spänning: 3.50 V
                            används inte
                            används inte
    01288 - Terminal 30 styrservo
                011 - avbrott - Intermittent fel
                 frysta data:
                        Felstatus: 00101011
                        Felprioritet: 9
                        Felfrekvens: 3
                        Reset-räknare: 179
                        Tidsindikering: 0
                 frysta data:
                            kl. 15 TILL
                        Hastighet: 0.0 km/h
                        (inget värde): 2.0
                        Spänning: 5.30 V
    00750 - Fellampa
                012 - Elfel i strömkrets - Intermittent fel
                 frysta data:
                        Felstatus: 00101100
                        Felprioritet: 2
                        Felfrekvens: 2
                        Reset-räknare: 180
                        Tidsindikering: 0
                        Datum: 2011.05.30
                        Tid: 14:10:37
                 frysta data:
                            kl. 15 TILL
                        Hastighet: 0.0 km/h
                        (inget värde): 4.0
                        Spänning: 11.10 V
    Adress 46: Komfortcentral        Labels: AER\3C0-959-433-46.clb
       Komponent:    KSG PQ46 ELV 043 0612
       Kodning: 00910A0001860E763604941570084FCE707801
       Subsystem 1 - Artikelnr: 1K8 951 605
       Komponent: LIN BACKUP HORN H09 9002
       Subsystem 2 - Artikelnr: 3C0 951 171 C
       Komponent: Neigungssensor  004 0611
       Subsystem 3 - Artikelnr: 3C0 951 171 C
       Komponent: Innenraumueberw.004 0611
    1 fel funnet:
    01134 - Alarmsignalhorn (H12)
                000 - - - Intermittent fel
                 frysta data:
                        Felstatus: 00100000
                        Felprioritet: 4
                        Felfrekvens: 1
                        Reset-räknare: 179
                        Tidsindikering: 0
    Adress 52: Dörrelektr. pass.        Labels: AER\1K0-959-702-MAX3.lbl
       Artikelnr SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Komponent: J387  TUER-SG BT    1533
       Revision: 71009005    Serienummer: 00000634798525
       Kodning: 0000180
       VCID: 41B106B9188D1A4A8D-8014
    1 fel funnet:
    00933 - Motor för fönsterhiss: pass.sidan (V148)
                 frysta data:
                        Felstatus: 00100101
                        Felprioritet: 6
                        Felfrekvens: 1
                        Reset-räknare: 179
                        Tidsindikering: 0
    Adress 53: Parkeringsbroms        Labels: AER\5N0-907-801.clb
       Artikelnr SW: 3C8 907 801 C    HW: 3C8 907 801 C
       Komponent: J540 EPB3  VW-13618 0005
       Revision:   010       Serienummer: 00000000024227
       Kodning: 0000057
    1 fel funnet:
    03200 - Knapp för elektr. parkeringsbroms (E538)
                 frysta data:
                        Felstatus: 00101100
                        Felprioritet: 2
                        Felfrekvens: 1
                        Reset-räknare: 180
                        Tidsindikering: 0
                        Datum: 2011.06.04
                        Tid: 07:09:08
                 frysta data:
                        Spänning: 10.80 V
                        Räkna: 93
                        Hastighet: 0.0 km/h
                        Hex-värde: 0x12F0
                        Hex-värde: 0x0001
                        Hex-värde: 0x0101
    Adress 55: Helljusområde        Labels: AER\5M0-907-357-V2.lbl
       Artikelnr SW: 5M0 907 357 C    HW: 5M0 907 357 C
       Komponent: AFS-Steuergeraet    0142
       Revision: 00H04000    Serienummer:
       Kodning: 3493064
       VCID: 345F5F6D573FBFE216-8060
       Subsystem 1 - Artikelnr: 1K0 941 329   Labels: AER\3D0-941-329.CLB
       Komponent: AFS-Lst.-Modul l    0003
       Kodning: 00000053
       Subsystem 2 - Artikelnr: 1K0 941 329   Labels: AER\3D0-941-329.CLB
       Komponent: AFS-Lst.-Modul r    0003
       Kodning: 00000053
    Adress 56: Radio (J503)       Labels: AER\5M0-035-1xx-56.clb
       Artikelnr SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Komponent: Radio RCD310  016 0049
       Revision: 01000000    Serienummer: VWZ1Z2K8216665
       Kodning: 0000000000
       Verkstad #: WSC 01286 386 08256
       VCID: 65F9F2296C65166A51-8030
    1 fel funnet:
    01042 - Styrdon ej kodat
                 frysta data:
                        Felstatus: 01100000
                        Felprioritet: 3
                        Felfrekvens: 1
                        Reset-räknare: 255
                        Tidsindikering: 0
    Adress 62: Dörr vä. bak        Labels: AER\1K0-959-703-GEN3.lbl
       Artikelnr SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Komponent: J388   TUER-SG HL   0309
       Revision: 43004101    Serienummer: 00000000941425
       Kodning: 0000144
       VCID: 31515679A82D8ACA7D-8064
    Adress 69: Släpvagnsfunktion (J345)       Labels: AER\1K0-907-383-V2.clb
       Artikelnr SW: 1K0 907 383 E    HW: 1K0 907 383 E
       Komponent: Anhaenger     H07 0080
       Revision: 3A002002    Serienummer: 00000119108230
       Kodning: 4100000100000000
       VCID: 2F5550017E199C3A6B-807A
    1 fel funnet:
    02563 - Lampa för höger bakljus: släp-Mx
                010 - Avbrott eller kortsluten till plus - Fellampa(MIL) tänd
                 frysta data:
                        Felstatus: 11101010
                        Felprioritet: 3
                        Felfrekvens: 1
                        Reset-räknare: 136
                        Mätarställning: 114570 km
                        Tidsindikering: 0
                        Datum: 2011.05.14
                        Tid: 13:36:52
    Adress 72: Dörr hö bak        Labels: AER\1K0-959-704-GEN3.lbl
       Artikelnr SW: 3C8 959 704 B    HW: 1K0 959 794 Q
       Komponent: J388   TUER-SG HR   0309
       Revision: 43004101    Serienummer: 00000000953985
       Kodning: 0000144
       VCID: 32535975AD2BB1D204-8066
    Slut------------------------(Förfluten tid: 01:54)-------------------------
    Affirmative, with aid of using WD to explore and hook up correctly!
    Jan 2015
    Sweden
    Can you please give me a tip where I should apply 12 volt so I can run the diagnose? I tried this morning to find out, checked on Erwin-VW but could not find where I should
    Kind regard and thanks in advance
    //Kjell Söderberg
    Tartu, Estonia
    You say you replaced steering lock. Did you also match it to car?
    The world is my oyster...
  7. #7
    Jan 2015
    Sweden
    Yes, I did match the steering lock!
    And the funny thing was that I drove the car the 200 meter to my old neighbours company. No problem during that time and no warning lights. When the customer was supposed to go home later that same day the car didn't start. I had already left my garage at that time and thought that I forgot to turn of the light or something so the car became without power from battery. But that wasn't the case. Trying with external battery hasn't helped me. The radio is coming on when I put the key in the key lock, but no ignition lamp or no possibility to crank the engine...
    //Kjell Söderberg
  8. #8
    Aug 2014
    Now permanent in Maryland, USA.
    [QUOTE=Samson;94969]Can you please give me a tip where I should apply 12 volt so I can run the diagnose? I tried this morning to find out, checked on Erwin-VW but could not find where I should
    Sampson,
    Sampson,
    You will need a wiring diag for this. Look on T16 connector in car. One of the pins has batt 12v just connect that pin to battery direct to power up obd as Jack indicated earlier.
  9. Likes Jack@European_Parts liked this post
  10. #9
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Smile
    [QUOTE=TFSI;94980]
    Quote Originally Posted by Samson View Post
    Sampson,
    Sampson,
    Try ignition on and put lights on. Then tape the main beam on permanently using masking tape to the steering wheel. This should help. I used to do loads of these in the dealer using this method.
    Hope this helps Danners.
  11. #10
    Jan 2015
    Sweden
    Thanks for you tip.
    Danners, that did not work unfortunately. BUT, I went and put the old steering lock unit back (just connected beside) and then I could start up the car. Of course, still is the steering column locked, so I could not move it. But obviously is the problem that maybe the new steering lock unit hasn't been adapted correctly.
    The strange thing is that I was able to drive the car the 2-300 meter to park it but after that no cranking when customer was going home. And I did the adaptation according to what I could read from here.
    Maybe someone can help me through the way (or more likely add a link to the correct way of doing it).
    Thanks in advance
    //Kjell SÖderberg
