hi this 2.0 has had pcv replaced turbo replaced two times second was used, work was done at another shop. car needs a camshaft adjuster solenoid, but the complaint is excessive smoke which is caused by the turbo pipes getting filled with oil. the crankcase has 4 inches of water pressure, measured at dipstick tube. how can I narrow down piston rings or a bad turbo. Thanks Mario
Thursday,07,August,2014,11:37:08:15785
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: License Plate: MAGALHAES 2
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8E0 910 115 P HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0104010A190F0120
Work Shop Code: WSC 06325 000 00000
VCID: 2E58B322B92AEC6E39B-807B
000017 - Bank 1: Camshaft A (Intake)
P0011 - 004 - Retard Setpoint not Reached (Over-Advanced)
Mileage: 172471 km
RPM: 2012 /min
Load: 34.5 %
Speed: 57.0 km/h
Temperature: 80.0°C
Temperature: 32.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
Readiness: 0110 0101
Mileage: 172471 km
RPM: 2012 /min
Load: 34.5 %
Speed: 57.0 km/h
Temperature: 80.0°C
Temperature: 32.0°C
Voltage: 13.970 V
