Results 1 to 4 of 4
Thread: Transporter T5 Abs module coding (diagnose doesn't connect to old module)
    May 2017
    hi
    can you help me please with coding for an Abs control module - vw transporter 2007
    - the interface won't communicate with old control module, so I could'n retrieve the old code
    - it does connect to the replacement module, but is throwing some codes, one of it is "control module not coded"
    old control module number: 7H0907379P
    new control module number: 7H0907379R
    I've got the pr code list from main dealer (the owner book was missing from the car, and the sticker on the car body is damaged/unreadable)
    thank you
    Car data
    Chassis No               WV2ZZZ7HZ7H149966
    Sales Type               7HJS03
    Model Year               2007
    Model                      TR
    Model Designation     transporter shuttle
    Engine Code             BNZ
    Transmission Code    JUL
    Finaldrive Ident        6A
    Interior Trim Code    GV
    Roof Color              3P
    Exterior Color/Paint Code     3P/A6W
    Date of Production    24.05.2007
    PR Numbers
    Page : 001
    Open field campaigns none available
    A9K Shuttle
    AE0 Without camping stove
    AF0 Without stowage compartment
    B09 Type approval Great Britain and Northern
    Ireland
    B0A Component parts set without
    country-specific design requirement
    C14 Operating permit, alteration
    C1G Steel wheels 6.5J x 16
    E0A No special edition
    F4U Cab with comfort equipment
    G1A 6-speed automatic transmission
    GX0 Manually operated doors
    GZ0 Manually operated doors
    H0D Tires 215/65 R16 C 106/104T
    J1U Battery 450 A (95 Ah)
    K4B Window van
    L0R Right-hand drive vehicle
    MM3 5-cyl. turbo diesel engine 2.5 L/96 kW
    pump-jet injection system
    base engine is T85/TM7
    N0P Woven fabric seat covering
    NF0 Without awning
    NG0 Without top carrier
    NR0 Without insert/badges (interior)
    NY0 Standard battery/alternator capacity
    PK1 Air conditioning system for cab and
    passenger compartment
    QA0 Without child seat
    QE0 Without tray areas package/box
    QG1 Service interval prolongation
    QL5 Dark tinted glass in rear seat area
    (Venus 35/Privacy)
    heat-insulating glass (green) in front
    R20 Radio system "RCD 200" with CD drive and
     4 speakers
    S0G Special control country group 2
    TM7 5-cylinder diesel engine 2.5 L
    unit 070.M
    et_fd1.frm
    Car data
    15:46 27.04.2017
    PR Numbers
    Page : 002
    U4B Instrument insert, mph speedometer
    Great Britain
    UF0 Without electric interface
    UG0 Without hill hold control / hill descent
    control / comfort driving assist
    V0A Tires w/o specification of tire brand
    VX0 Without hands-free system
    WF3 Package for Great Britain
    ZA1 Comfort package
    ZA7 Appearance package for Shuttle
    ZE5 Radio remote controlled central locking
    system with safe securing and operated
    from inside
    ZE8 Electric equipment package I
    ZP4 Diesel particulate filter (DPF)
    ZR9 Steel spare wheel with original
    equipment tire (Tire Mobility Set
    deleted)
    ZS4 Right cab seat with arm rests, height
    adjustment and lumbar support
    ZU3 Carpet floor covering in cab and
    ZV6 Front passenger double bench seat in
    cab, left
    0E2 Long wheelbase
    0FA Standard manufacturing sequence
    0JF Weight category front axle
    weight range 6
    0KA Without stickers and badges
    0NB Nameplate set in base trim
    0SS Labels/plates in English and French
    0TA Without floor mats
    0VF Information kit in English
    0WQ Gross vehicle weight rating
    0Y1 Standard climatic zones
    0YG Weight range 7
    installation control only, no
    requirement forecast
    0ZN Transmission ratio, high geared
    1AR Anti-spin regulation (ABS/ASR)
    1B1 Standard spare wheel bracket
    1BA Standard suspension/shock absorption
    1CP Fahrzeugklassen-Differenzierung -7H0-
    1D0 Without trailer hitch
    1EX Spezielles Typschild für EG
    1G2 Steel spare wheel with original
    equipment tires
    1HN Labels for country group 13
    1L0 Standard air cleaner
    1ND Full wheel covers
    1PA Standard wheel bolts
    1Q3 Mass damper for steering wheel, XXHz
    1S1 Tool kit and jack
    et_fd2.frm
    Car data
    15:46 27.04.2017
    PR Numbers
    Page : 003
    1T0 Without first aid kit and warning
    triangle
    1U0 Without table
    1W0 Without refrigerator/glove compartment
    cooling system
    1Y0 Without differential lock
    1Z0 Initial standard fuel filling
    2A0 Without delivery equipment
    2B1 Additional exterior noise suppression
    2E3 16-inch chassis
    2G2 W/o insert for the filling up (diesel)
    without fluorination
    (not RME resistant)
    2JG Body-colored bumpers
    2N3 Additional anti-drum measures
    in cab and passenger compartment
    2P1 Plastic trunk sill protection
    2PG Steering wheel
    2Q0 Without modular seat mounting
    2V1 Dust and pollen filter
    2WA Without additional tires
    3B4 Child seat anchor for
    child seat system ISOFIX
    3CA Without partition
    3HA Without leather parts scope
    3J2 Height-adjustable headrests
    3JA Without roof insert in load and
    3L2 Manual height adjustment for right front
    seat
    3M9 Passenger car version with up to 9 seats
    3R0 Standard roof
    3RC Trunk lid with window aperture
    3S0 Without roof rails/roof load rack
    3SN Right seat in cab with lumbar support
    3TJ Double bench seat in cab, left
    3U0 Without luggage compartment cover
    3UD 2-seater bench and separate seat, left
    3VF 3-seater bench seat, folding/tipping
    3W3 Special interior noise suppression
    3WA Without bench seat
    3YQ Door pockets without insert mats
    4A0 Without seat heater
    4B0 Without protective side molding
    4E4 Rear door/tailgate release lever inside
    4FN Sliding window
    passenger compartment left
    4GF Windshield in heat-insulating glass
    4H1 Child lock in passenger compartment
    4HS Heated rear window with rear wiper
    4JN Sliding window
    in passenger compartment right
    4K3 Radio remote controlled central locking
    et_fd2.frm
    Car data
    15:46 27.04.2017
    PR Numbers
    Page : 004
    operated from inside and safe securing
    4L2 Dipping breakaway interior rear view
    mirror
    4LA Without controls
    4N2 Standard dashboard
    4R1 Power windows
    4S3 Armrest for right front seat
    4SB Vanity mirror left
    4TB Vanity mirror right
    4UE Air bag for driver and front seat
    passenger
    4X0 Without side air bag
    4Y0 Without storage compartment/safe box
    5AD Carpet floor covering in cab
    5BF Carpet floor covering in passenger
    compartment
    5C0 Without special body measures
    5CJ Roof interior trim, two-shell comfort
    molded headlining in cab and passenger
    compartment
    5D1 Carrier frequency 433.92 MHz-434.42 Mhz
    5DC Standard side panel trim in passenger
    compartment
    5FA Without additional trays in cab
    5G0 Without curtains
    5K0 Without surface protection, with
    additional transit coating
    5N2 Folding grab handles at roof frame
    5NC Standard tailgate stay
    5Q2 Sliding door left
    in load/passenger compartment
    5R2 Sliding door right
    5RV Right exterior mirror: aspherical
    5SJ Left exterior mirror: convex
    5TC Without decorative inserts
    5V3 Hinges for tailgates/trunk lid
    (standard design)
    5YE Unpainted door trim panel (plane)
    6A0 Without fire extinguisher
    6B1 Lashing rings for load restraint
    6CH Air outlet vent B-pillar
    6FA Components without special surface
    appearance
    6L0 Without C-rails
    6N0 Without mud flaps
    6U0 Without additional seals outside
    6X2 Entry grab handle (front passenger)
    6XN Exterior mirrors: electrically
    adjustable, separately heated
    7A0 Without CD changer/CD player
    7AL Anti-theft alarm system, passenger
    compartment control, backup horn and
    et_fd2.frm
    Car data
    15:46 27.04.2017
    PR Numbers
    Page : 005
    towing protection
    7B3 12-volt socket(s)
    7GG Emission standard EU4 DPF
    7Q0 Without navigation device
    7QA Without CD/DVD for navigation
    7V0 Standard dashboard illumination
    7X0 Without park distance control
    8BF Halogen headlight for driving on the
    left
    8FA Without second battery
    8GV Alternator 180 A
    8K0 Without special headlight
    activation
    8L8 Inside-windshield antenna
    8N1 Windshield wiper intermittent control
    8Q1 Headlight-range adjustment
    8QD Key for locking system
    8RE 4 speakers (passive)
    8SA Taillight assemblies, standard design
    8T0 Without cruise control system (CCS)
    8TD Rear fog light for driving on the left
    8UA Radio with CD player
    8W0 Without washer fluid level indicator
    8WA Without front fog light
    8X0 Without headlight washer system
    8Y1 Two-tone horn
    8Z5 Not hot country
    9AG Mechanically controlled air conditioning
    with second evaporator and second
    heating system
    9CK Interior light design in passenger
    compartment
    9H0 Without roof turn signal lights
    9KA Without identification lights
    9LA Without rotating emergency lights
    9M5 Auxiliary heater
    9N1 Step illumination, sliding door(s)
    9ND Tachograph preparation
    9P0 Without seat belt reminder
    9Q0 Without multi-function display/
    on-board computer
    9T0 Without heated washer nozzles
    9W0 W/o car phone preparation/installation
    9WC Without "Multimedia" in vehicle
    May 2017
    Tuesday,09,May,2017,16:50:02:39860
    VCDS Version: 17.1.3.0 (x64)
    VIN: WV2ZZZ7HZ7H149966   License Plate: SE07VFW
    Mileage: 231280km-143710mi   Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ7H149966   Mileage: 231280km-143710miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 997 016 M    HW: 070 997 016 M
       Component: R5 2,5L EDC  000AG  0860
       Revision: --H05---    Serial number: VWZ7Z0G5304999
       Coding: 0001075
       Shop #: WSC 02756 790 00000
       VCID: 2447D8B7E4404B61AD-5140
       Part No SW: 09K 927 750 K    HW: 09K 927 750 K
       Component: AQ 250 6F           1044
       Revision: 00H67000    Serial number:
       Coding: 0000072
       VCID: 3D710DD367EA1AA9C2-5140
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
       Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
       Component: ESP MK25E1          0104
       Revision: 00H31001
       Coding: 0000556
       VCID: 4487783704006B618D-5106
                        Reset counter: 15
                        Mileage: 231284 km
                        Count: 128
                        Count: 4353
                        Count: 8214
                        Count: 1
    00003 - Control Module
                        Reset counter: 15
                        Mileage: 231284 km
                003 - Mechanical Failure
                        Reset counter: 15
                        Mileage: 231284 km
    00814 - Solenoid for Brake Pressure (N247)
                        Reset counter: 15
                        Mileage: 231284 km
    00493 - ESP-Sensor Unit (G419)
                        Reset counter: 15
                        Mileage: 231284 km
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 7H0 820 045 AL
       Component: CLIMA/AC            0303
       VCID: 6FEDE79B7D06B83900-5122
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
       Part No: 7H0 937 049 AA
       Component: BORDNETZ SGVER 1.0  2001
       Coding: 0000101
       VCID: 71E9E1E36B32AEC916-5122
    01117 - Generator Terminal DF Load Signal
       Part No: 1C0 909 605 A
       Component: 3C AIRBAG VW51      0010
       Coding: 13123
       Shop #: WSC 02756
       VCID: 224BDEAFAE544551DF-5122
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 953
       Component: KOMBI+WEGFAHRSP VDO V02
       Coding: 00413
       Shop #: WSC 00001
       VCID: 6BD5F38B191E44192C-5122
       WV2ZZZ7HZ7H149966     VWZ7Z0G5304999
    Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
       Part No: 7H0 815 071 F
       Component: Standheizung        0209
       VCID: 2B55338B899E84196C-5122
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02756
       VCID: 70EFE4E73038A7C119-5122
    02065 - Control Module for Speech Amplifier (J656)
                49-00 - No Communications
    Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
       Part No: 7H5 951 171 C
       Component: Innenraumueberw.    2917
       Coding: 0000012
       Shop #: WSC 02757 790 00000
       VCID: 2F6D279BBD86F83940-51B6
       Subsystem 1 - Part No: 7H5 951 178
       Component: Innenraumueberw.    1607
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: CXL Komfortger·t     0004
       Coding: 00030
       Shop #: WSC 02756
       VCID: 326B2EEFFEB4D5D12F-4B00
       Part No SW: 7H0 035 152 H    HW: 7H0 035 152 H
       Component: Radio DE2           0004
       Revision: 00005000    Serial number: VWZ4Z4FD210838
       Coding: 0020200
       VCID: 275DCFBB9576A07988-5122
    End-------------------------(Elapsed Time: 06:15)--------------------------
    Address 56: DTCs cleared
    Address 56,7H0 035 152 H,recoded (Short coding),from,0020200,to,0020010,(02756/790/00000),
    thanks,
    radu
    Mar 2014
    I think that number module with an 'R' at the end is the ESP version which has a steering angle sensor. Does your van have ESP? If not, that is why you have the steering angle code as well! If you do have ESP then try 0002604.
