Results 1 to 5 of 5
Thread: Beetle MIB2 With NAV Retrofit
    Mar 2017
    Working on a Beetle retrofit to a MIB2 with NAV but having problems getting the Bluetooth to function. Not my car, helping a friend.
    Details:
    Original radio was MIB2 Entry, new radio is MIB STD2 PQ +/NAV (from a Passat)
    Car does not have a Bluetooth module under the passenger seat and based on scans I believe it's in the radio, there is no Module 77 found during scans.
    When new radio was installed Bluetooth functioned with iPhone but radio did not since Component Protection was enabled. Car was taken to dealership and CP was disabled but since then Bluetooth does not function. Dealership told the owner that the radio would never work and recommended to install the original radio. There were other errors in the scans after the car was returned from dealership and I have cleared those with coding. Now we only have 1 fault code: 0009 - Antenna for Satelite Radio
    Any help would be appreciated to get BT working and hopefully this helps someone else with their own retrofit.
    Thanks.
    Tim
    Here's a scan plus a little additional data from Module 5F:
    Thursday,04,May,2017,16:08:54:41258
    VCDS Version: 17.1.3.0 (x64)
    VIN: 3VWF17AT1GM610485   License Plate: KAT
    Mileage: 29130km-18100mi   Repair Order:
    Chassis Type: AT (7E0)
    Scan: 01 02 03 04 08 09 15 17 19 25 44 5F 61 0B
    VIN: 3VWF17AT1GM610485   Mileage: 29130km-18100miles
    Address 01: Engine (J623-CPRA)       Labels: 06K-907-425-V2.clb
       Part No SW: 06K 906 071 AL    HW: 06K 907 425 C
       Component: R4 1.8l TFS   H13 2441
       Revision: --H13---
       Coding: 001A0092242400170000
       Shop #: WSC 00066 790 00067
       ASAM Dataset: EV_ECM18TFS02006K906071AL 001004
       ROD: EV_ECM18TFS02006K906071AL.rod
       VCID: 75E1B243D4601CE9CA-8020
    Address 02: Auto Trans (J217)       Labels: 09G-927-749-V1.clb
       Part No SW: 09G 927 749 AL    HW: 09G 927 749 AL
       Component: AISIN AG6 G3  124 2942
       Coding: 000348
       ASAM Dataset: EV_TCMAQ250031 002009
       ROD: EV_TCMAQ250031_VW31.rod
       VCID: 0305DC9B8AB43259F4-8056
       Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
       Component: ESP MK60EC1   H46 0174
       Revision: 00H46001
       Coding: F14B4016492300FA8F0F02EC921E004121100012
       VCID: 74E78F47D71A05E1FD-8020
       Part No SW: 5C0 820 047 CQ    HW: 5C0 820 047 CQ
       Component: J301  Klimaanlage   0210
       Revision: 2001502S    Serial number: 00000002837697
       Shop #: WSC 00066 790 00230
       VCID: 71E98653680830C916-8024
    Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 189     HW: 7E0 937 189
       Component: BCM PQ25 MMI3 H80 0733
       Revision: BA080001    Serial number: 18003213150085
       Coding: 3BAC690808AB080000A52930240984C43DC2622F60004C70B20014022800
       VCID: 71E98653A80830C916-8024
       Subsystem 1 - Part No SW: 6R0 959 801 BE    HW: 6R0 959 801 BE  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  004 8662
       Serial number: KU0KU012061551631606
       Coding: 2010A4
       Subsystem 2 - Part No SW: 6R0 959 802 BL    HW: 6R0 959 802 BL  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  004 8662
       Serial number: KU0KU029061551801255
       Coding: 3010A4
       Part No SW: 5C0 959 655 AA    HW: 5C0 959 655 AA
       Component: AirbagVW10    500 0975
       Serial number: 003LYD027RXB
       Coding: 00004245
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 71E98653A00830C916-8024
       Serial number: 6940000Y150001DXBT0H
       Coding: 30304C
       Serial number: 3572MSME65443B52ZZZX
       Serial number: 3582MSME1F473B52ZZZ%
       Subsystem 4 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
       Serial number: 3556LSME1C147634ZZZW
       Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
       Serial number: 3566LSME7E397634ZZZ5
       Part No SW: 5C5 920 955     HW: 5C5 920 955
       Component: KOMBI         H52 0404
       Revision: X0052001    Serial number:
       Coding: 250A010000
       Shop #: WSC 00066 790 00326
       ASAM Dataset: EV_KombiUDSMM9RM10 A05803
       ROD: EV_KombiUDSMM9RM10_VW32.rod
       VCID: 6BD5943B8224DA192C-803E
       Part No SW: 7E0 909 901     HW: 7E0 937 189
       Component: GW-K-CAN TP20 H80 0733
       Revision: BA080001
       Coding: 402001
       VCID: 68DFEB379BD2F10141-803C
       Part No SW: 5K0 953 234     HW: 5C5 920 955
       Component: IMMO          H52 0404
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW21.rod
       VCID: 6ADB913F8DDEC31157-803E
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 69     3501
       Revision: 00H22000
       VCID: 39797E7370F8B889EE-806C
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 5C0 035 200     HW: 5C0 035 200
       Component: MU-S-S-US     H22 0245
       Serial number: VWZAZ2R0680227
       Coding: 02230400AA00000001220001001000001F0100C00000000000
       Shop #: WSC 00066 790 00017
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 52AB29DF054E6BD10F-8006
              B10F4 13 [009] - Open Circuit
                        Reset counter: 246
                        Mileage: 26865 km
                        Date: 2017.03.30
                        Time: 00:38:43
                        Voltage terminal 30: 12.7 V
                        SDARS_tuner_status_2-Antenna current: 0 mA
                        SDARS_tuner_status_2-Reception quality: Not available
                        SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: Initial_value_forMPFA_not_coded
                        SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: FF
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7E0 907 534     HW: 7E0 937 189
       Component: Batt.regelung H80 0733
       Coding: E1200A59
    End-------------------------(Elapsed Time: 02:29)--------------------------
    Thursday,04,May,2017,16:10:23:41258
                    Address 5F: Information Electr.  (5C0 035 200 )
    16:10:17
      IDE02508-MAS00951   Bluetooth: Visibility-Bluetooth Not available
      IDE02508-MAS03001   Bluetooth: Visibility-Mode Bluetooth not available
      IDE04768   Bluetooth device address AC 7A 4D C6 A0 6B
      MAS00951-IDE04058   Bluetooth-Bluetooth: devices found 0
      MAS00951-MAS04324   Bluetooth-Bluetooth: connected devices 0
      MAS00951-MAS04325   Bluetooth-Bluetooth: Paired devices 0
      MAS04324   Bluetooth: connected devices SDAP
      MAS04324   Bluetooth: connected devices 0
      MAS04325   Bluetooth: Paired devices SDAP
      MAS04325   Bluetooth: Paired devices 0
    Thursday,04,May,2017,16:10:56:41258
    Control Module Part Number: 5C0 035 200
      Component and/or Version: MU-S-S-US     H22 0245
               Software Coding: 02230400AA00000001220001001000001F0100C00000000000
                Work Shop Code: WSC 00066
    Advanced Identification/FAZIT
         Identification: YD5-001
         Date: 02.12.15
         Manufacturer number: 0033
         Test stand number: 0398
    Flash Status
         Programming Attempts(application): 0/0
         Programming Attempts(data): 65535/0/1
         Successful Attempts(data): 65535/0/1
         Flash Date: 00.01.01
         Flash Tool Code(data): 00017 790 00066
    Misc.
         Hardware number: 5C0 035 200
         Workshop System Name: J794
         Equipment/PR Code: FFFFFFFFFFFFFFFF
         Dataset Number: 5K7CV1v__A_
         Dataset Version: 0001
         ASAM Dataset Revision: 001022
    Car Info
         Chassis Number: 3VWF17AT1GM610485
    VCDS Info:
    Mar 2015
    Poland
    If you have not manged it yet then pls contact me on PM
    May 2016
    Wuxi, P.R.C.
    There are two ways to make it work fine
    Best Regards,
    Don Wang
    Volkswagen Automobile Co. Ltd.
    Technical Chief
    Automotive Technology Service, Hong Kong, P.R.C.
    Skype: 13023333793
    Office Line: +8613023333793
    WhatsApp: +8613023333793
    QQ/WeChat: 13023333793
    Email: don.wang@yandex.com
    Instagram: www.instagram.com/vag_function_activation
    Website: www.facebook.com/TechnicalRetrofit
  4. Likes cbx750p liked this post
    Quote Originally Posted by Don View Post
    And they are????????
    Please specify...
  6. Likes Uwe liked this post
    Oct 2014
    Singapore
    I am ALL EARS and EYES to what you have to share....
  8. Likes Uwe liked this post
