Results 1 to 10 of 10
Thread: How to program 2012 Audi Q5 for after-market Westfalia & Jaeger tail hitch
    Aug 2014
    Question How to program 2012 Audi Q5 for after-market Westfalia & Jaeger tail hitch
    Hi guys,
    Would you be able to help me properly code a newly installed Westfalia hitch for my 2012 Audi Q5.
    I check for ideas/hints on the forums but seems like the closest I found was the 2013 Q5 conversation that you recently had
    I am getting a TPMS and Stability Control program failures, and assuming that the reason is the fact I did not program all of the modules needed.
    On the instructions coming with the Jaeger trailer control module it asks for Software Version Management (SVM) coding, which unfortunately is not an option for owners of the USB Hex+Can cable. Otherwise you just run SVN with code 050200, and be done with it
    Cheers, and thanks!
    Aug 2014
    As a note: I ran an “all scan” with debug level of 2, and have the file ready, but refraining of posting it, as it's super long.
    Stoke on Trent, England
    Welcome to the forum.
    Post it in between code tags then it won't be that long. [CODE] Full Autoscan [/CODE]
    New User Keith
    Aug 2014
    Quote Originally Posted by Keithuk View Post
    Thanks Keithuk!
    Here is the Full Autoscan with Debug 2
    VCDS Version: Release 12.12.2 (x64)
    Data version: 20140212
    BV
    Friday,01,August,2014,03:50:02:02041
    Chassis Type: FP (8T0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 36 3C 42 46 47 52
              53 55 56 5F 62 69 6C 6D 72
    VIN:...   Mileage: 40830km/25370miles
    Address 01: Engine (J623-CALB)       Labels: 06E-907-559-CAL.clb
       Part No SW: 8R0 907 559 G    HW: 8F0 907 559 A
       Component: 3.2 SIMOS8.2  H08 0004
       Revision: --------
       Coding: 0121000A190F0A21
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
       ROD: EV_ECM32FSI.rod
       VCID: 448D34EFCF9C263EFFF-8011
    6628 - Function Restriction due to Faults in Other Modules
              U1113 00 [101] - -
                        Mileage: 40832 km
                        Date: 2014.08.01
                        Time: 02:23:56
    7193 - Function Restriction due to Faults in Other Modules
              U1113 00 [101] - -
                        Mileage: 40832 km
                        Date: 2014.08.01
                        Time: 02:23:56
    Readiness: 1110 1101
    Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
       Part No SW: 8R0 927 158 H    HW: 0B6 927 156
       Component: 0B6 32 FSIUSA H05 0006
       Revision: --H05---
       Coding: 001012
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL651211 001012
       ROD: EV_TCMAL651.rod
       VCID: 428132F7D588280ECD3-8017
    Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.CLB
       Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
       Component: ESP8 quattro  H06 0110
       Coding: 043D18
       VCID: 458B29EBCCA61F36E81-8010
                        Reset counter: 105
                        Mileage: 40832 km
                        Date: 2014.08.01
                        Time: 02:51:12
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x0041
                        Hex Value: 0x0396
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
       Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H10 0602
       Coding: 0D854000000000000000
       VCID: 830F77F302126106065-80D6
    Address 08: Auto HVAC (J255)       Labels: REDIR FAIL!
       Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01060620122377
       Coding: 46112000
       VCID: 7AF18A17F5D8A0CED53-802F
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.CLB
       Part No SW: 8K0 907 063 CE    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0410
       Revision: 10030001    Serial number: 00000001513663
       Coding: 26001091423CAF311F01090300001D0D0F9CE74802010161000000
       Shop #: WSC 06335 123 12345
       VCID: 74EDA42FD7BCD6BE8FF-8021
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 120526  H11 0050
       Coding: 01DD13
       Component: RLS  H04 0003
       Coding: 024D25
       Component: E1 - LDS  H03 0031
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.CLB
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0081
       Revision: 11001001    Serial number: 12511216100321
       Coding: 300108
       VCID: 78F5901FCBD4B2DEA37-802D
    Address 13: Auto Dist. Reg (J428)       Labels: REDIR FAIL!
       Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
       Component: ACC3          H09 0100
       Coding: 00C7AE
       VCID: 37775323864A7DA66AD-8062
                        Reset counter: 101
                        Mileage: 40784 km
                        Date: 2014.07.31
                        Time: 10:04:09
                        Temperature: 23.0°C
                        Voltage: 11.78 V
                        Hex Value: 0x005D
                        Lateral Accel.: 0.00 m/s^2
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 10
                        Reset counter: 105
                        Mileage: 40784 km
                        Date: 2014.07.31
                        Time: 10:04:09
                        Temperature: 23.0°C
                        Voltage: 11.78 V
                        Hex Value: 0x00BE
                        Reset counter: 105
                        Mileage: 40784 km
                        Date: 2014.07.31
                        Time: 10:04:09
                        Temperature: 23.0°C
                        Voltage: 11.78 V
                        Hex Value: 0x00C0
    Address 14: Susp. Elect. (J250)       Labels: NONE
       Part No SW: 8R0 907 364 C    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H09 0054
       Revision: 00000000    Serial number: 30051205420001
       Coding: 070181
       VCID: 3A714A17B55860CE953-806F
    Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Serial number: 003GPD90GLZ9
       Coding: 303333313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 479723E3FEAA0D261AD-8012
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R120000996E
       Serial number: 6334MSME70050A5DD
       Serial number: 6344MSME6E740C43O
       Serial number: 6352QSME3718434CJ
       Serial number: 6362QSME27170D6CQ
       Serial number: 63732SME3E122678%
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME69173F424
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.CLB
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372LET0001I
       Coding: 00003F
       VCID: 3E794607A9704CEEA9B-806B
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8R0-920-XXX-17.CLB
       Part No SW: 8R0 920 981 K    HW: 8R0 920 981 K
       Component: KOMBIINSTR.   H44 0640
       Revision: 00000000    Serial number: RSS46D44D
       Coding: 035622003F005604020101
       VCID: 428132F7DD88280ECD3-8017
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.CLB
       Part No SW: 8T0 907 468 AJ    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0120
       Revision: FC201059    Serial number: 5900F12524004A
       Coding: 00C303
       VCID: 891365DB203E3B564C9-80DC
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
    Address 1B: Active Steering (J792)       Labels: NONE
       Part No SW: 8K0 907 144 E    HW: 8K0 907 144 E
       Component: DYNAMIKLENK.  H06 0580
       Revision: 50001005    Serial number: --------------
       Coding: 820000
       VCID: 31636D3B682EA396249-8064
    Address 36: Seat Mem. Drvr (J136)       Labels: NONE
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000029817658
       Coding: 00581B00000000000000
    Address 3C: Lane Change        Labels: REDIR FAIL!
       Part No SW: 8R0 907 566 A    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH12 0040
       Revision: 00H12000    Serial number: 6PZ 009 014-05
       Coding: 0000007
       VCID: 3C7D4C0F7F6C5EFE87F-8069
       Subsystem 1 - Part No: 8R0 907 568 A
       Component: J0770_SWA_Slave_H10 0040
       Subsystem 2 - Serial number: 6PZ 009 014-25
       Subsystem 3 - Serial number: 5F24.05.1200H100003CX14929˙
       Subsystem 4 - Serial number: X14929˙
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.CLB
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000031657697
       Coding: 011D13205E00440004
       VCID: 4FA70BC31EDAD56652D-801A
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.CLB
       Revision: 00002001    Serial number: 0177685403
       Coding: 01260E3A20FA749784B005B200000000
       Shop #: WSC 06334 123 12345
       Component: GTO BF  H01 0080
       Component: J245EE20SKB13  H03 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H03 0220
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.CLB
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34804015684004
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.CLB
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000031279256
       VCID: 4E9916C719D0DC6E59B-801B
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.CLB
       Revision: 00000003    Serial number: 00000001129150
       VCID: 346D642F973C96BE4FF-8061
    Address 55: Xenon Range        Labels: 8T0-907-357.CLB
       Part No SW: 8H0 907 357 D    HW: 8H0 907 357 D
       Revision: 00H01001    Serial number:
       Coding: 0000022
       Shop #: WSC 06334 000 00000
       VCID: 336F673352329186565-8066
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
    Address 56: Radio (R)       Labels: REDIR FAIL!
       Part No SW: 4G0 035 082 C    HW: 4G0 035 082
       Component: Radio U SIRIU H53 0101
       Revision: AB001007    Serial number: 236F%0C7542379
       Coding: 020007010000000001
       VCID: 2045987F33C41A1EBB7-8075
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
       Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
       Component: H-BN-NA       H52 0165
       Revision: --------    Serial number: 490F/0C7680706
       Coding: 010200060105EBFF77000B0E000000030000
       VCID: 3973551BB05E6BD69C9-806C
       Component: NAR 2011  0505
       Component: DU7 High  H41 0104
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Component: CD-Database  2712
                        Reset counter: 105
                        Mileage: 40832 km
                        Date: 2014.08.01
                        Time: 03:07:38
                        Bin. Bits: 00000001 00000000
                        Bin. Bits: 00000000 00000000
    Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.CLB
       Revision:             Serial number: 0000031844766
       Coding: 010C13204000240004
       VCID: 46892EE7F1A0142EE1B-8013
    Address 69: Trailer (J345)       Labels: 8K0-907-383.CLB
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Component: ConWys Trailer H09 0100
       Revision: 1A001001    Serial number: 00000161077413
       Coding: 0100000000000000
       Shop #: WSC 00007 223 57222
       VCID: 36695E27814084AE71B-8063
    Address 6C: Back-up Cam.        Labels: 4L0-910-441.CLB
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H07---    Serial number: 525PA8-J23A3OY
       Coding: 1031010
       VCID: 346D642F573C96BE4FF-8061
    Address 6D: Trunk Elect. (J605)       Labels: REDIR FAIL!
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B7F4F13BA6259C68E5-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.CLB
       Revision:             Serial number: 0000031855161
  5. Likes otto liked this post
    Aug 2014
    Anyone with an idea is welcome, don’t be shy to answer
    ECU Coding
    [03] 04BD18 (First Secure access)
    [10] 310108 (First Secure access)
    [13] 00C7A7
    [3C] 0010007
    You have removed VIN, i think the car is not prepared for Trailer.
    If you can see the license plate of a car then you also can look up VIN, here in Denmark. Also the VIN is often in the window of the car.
  8. Likes Dana liked this post
    Aug 2014
    NEtech, thanks. I will try with the codes you posted.
    I removed the VIN from the scan as I didn’t wanted to get into the search engines that crawl the internet these days
    The can was prewired from the factory for trailer installation, so I only plugged-in into that, following the instruction that came from Wesfalia and Jaeger controller - link
    I also modify the programming base on the thread I posted on the original post, and added the 69 trailer module into the gateways.
    So, I will give it a try with your codes, and reply here with the results.
    Cheers.
  10. #8
    Aug 2014
    NEtech, thanks for the codes. I applied all of them, and also used the BETA release of the Ross-Tech software, which had the bit/options specified into the coding.
    My TPMS and Stability is back to normal, and the car now acts as should. The Adaptive control, didn't work immediately after I applied the codes, but today after a short drive all readiness codes passed and the Adaptive cruise control, is buck to normal operation.
    Cheers, and thanks.
    I will post all of my modules so that other with '12 Q5 can use it.
  11. Likes jakematic, Santos, Uwe liked this post
  12. #9
    Aug 2014
    Exclamation
    Thanks again NEtech.
    Here is my all modules coding from the car after installing the hitch and following the coding procedures as described earlier in the thread.
    VCDS Version: Beta 14.7.2 (x64)
    Data version: 20140714
    BV
    Monday,11,August,2014,18:26:21:02041
    VIN: WA1WKBFP9CA126841   Mileage: 41030km-25494miles
       Revision: --------
       VCID: 448D34EFCF9C261AE7-8011
    Readiness: 0000 1100
       Revision: --H05---
       Coding: 001012
       VCID: 428132F7D588282AD5-8017
    Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
       Coding: 04BD18
       VCID: 458B29EBCCA61F12F0-8010
       VCID: 030FF7F38212E1229E-8056
       Coding: 46112000
       VCID: 7AF18A17F5D8A0EACD-802F
       VCID: 74EDA42FD7BCD69A97-8021
       Coding: 01DD13
       Coding: 024D25
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Coding: 310108
       VCID: 78F5901FCBD4B2FABB-802D
    Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
       Coding: 00C7A7
       VCID: 37775323864A7D8272-8062
    Address 14: Susp. Elect. (J250)       Labels: None
       Coding: 070181
       VCID: 3A714A17B55860EA8D-806F
       VCID: 479723E3FEAA0D0202-8012
       Coding: 00003F
       VCID: 3E794607A9704CCAB1-806B
    Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
       VCID: 428132F7DD88282AD5-8017
       Coding: 00C303
       VCID: 0913E5DBA03EBB72D4-805C
       Coding: 820000
       VCID: 31636D3B682EA3B23C-8064
       Coding: 0010007
       VCID: 3C7D4C0F7F6C5EDA9F-8069
       VCID: 4FA70BC31EDAD5424A-801A
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       VCID: 4E9916C719D0DC4A41-801B
       VCID: 346D642F973C969A57-8061
    Address 55: Headlight Range        Labels: 8T0-907-357.clb
       Coding: 0000022
       VCID: 336F6733523291A24E-8066
       VCID: 2045987F33C41A3AA3-8075
       VCID: 3973551BB05E6BF284-806C
                        Reset counter: 121
                        Mileage: 41011 km
                        Date: 2014.08.11
                        Time: 13:06:45
       VCID: 46892EE7F1A0140AF9-8013
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       VCID: 36695E278140848A69-8063
       Coding: 1031010
       VCID: 346D642F573C969A57-8061
       VCID: 3B7F4F13BA6259E296-806E
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
    End-------------------------(Elapsed Time: 05:08)--------------------------
    Note: Never mind my error in module 5F, it's due to some other issue (not sure what exactly) but I had it from before hitch install/coding.
    Cheers!
  13. Likes Uwe, Dana liked this post
  14. #10
    Jul 2014
    Australia
    Quote Originally Posted by Bojole View Post
    ...and how did you go ? Is the audi working all good no issues now ?
    PS I have a '14 q5 with the westfalia installed , hasnt been coded - and has the same issues with traction control/auto hold/TPMS etc
