Results 11 to 20 of 30
Thread: Tiguan 2013 Bi-xenon retrofit (No AFS)
    Apr 2017
    Greece
    module worked!
    I noticed the email conversation related to the G85 problem
    .. between the OP and Peter in our tech team. I decided to reply here because I agree with m87a.
    The oldest scan I have from this car showed:
       Part No SW: 5K0 953 501 BD    HW: 5K0 953 569 J
       Revision: FF010041    Serial number: 20121006300001
       Coding: 5180040000
       VCID: 6DDA1945BC5C252932-8038
    and the GVL reported 04-Steering Angle -- Status: OK 0000 at that time.
    I haven't noticed a VW scan with Audi SWCM software (8X0 part number) but it doesn't sound like that is compatible and m87a is knowledgeable in this area. Since 03 is coded identically to the last known good scan and we know 5N1 44 modules do not have an internal G85 my only suggestion would be to code the installed 16 to the original value of: 5180040000
    If 16 accepts the original coding the G85 problem *might* be resolved but if it rejects the original coding I would consider it incorrect for this car.
    Dear Dana,
    I've followed your instructions and module worked!
    Thank you so much!!!
  2. Likes Uwe, m87a, Dana liked this post
  3. #12
    Apr 2017
    Greece
    High beams not working!
    Right after I've changed the BCM (5K0 937 087 AB), test everything again, FOBs worked, Xenons worked BUT high beams won't. I've tried almost everything read on threads but no luck. I'm using Kufatec's adapters.
    Also MFD settings menu and audio menu disappeared! ????
    Any Help?? -Scan follows:
    Sunday,21,May,2017,15:46:25:52699
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVGZZZ5NZDW043218   License Plate: NEW-8554
    Mileage: 117770km-73178mi   Repair Order:
    Chassis Type: 5N (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4C 52 53 56 61 62 72 77
    VIN: WVGZZZ5NZDW043218   Mileage: 117770km-73178miles
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 LE    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H28 4571
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00190012040401080000
       ASAM Dataset: EV_ECM20TDI01103L906018LE 003009
       ROD: EV_ECM20TDI01103L906018LE.rod
       VCID: 78F43811C31E9081D1-802C
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AR    HW: 5N0 614 109 AR
       Component: J104   C6 450M VD5B 0006
       Revision: --H07---    Serial number: 00000006258606
       Coding: 0037947
       VCID: 7BFE271D3A28BB99BC-802E
       Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004003
       VCID: 79F23D15F8148989AE-802C
       Part No SW: 5K0 937 087 AB    HW: 5K0 937 087 AB
       Component: BCM PQ35 H    122 0174
       Revision: BE122001
       Coding: 46180A38802502C0008800C0340089E84B75AB88436D8160E480C7240041
       Shop #: WSC 00020 790 12345
       VCID: 75EA3125DC0CEDE9CA-8020
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 08101  013 0204
       Serial number: N1955119   204!
       Coding: 009795
       Component: RLS 051012 05  54  0403
       Coding: 02304D
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 91
                        Mileage: 117770 km
                        Date: 2017.05.21
                        Time: 20:56:22
                            Term 15 On
                        Voltage: 11.55 V
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20J VW10 HI   2118
       Revision: 24017000    Serial number: 003L7PLTU4Q.
       Coding: 0012362
       VCID: 7CFC24013F26BCA1B5-8028
       Subsystem 1 - Serial number: 6332MTS661652712
       Subsystem 2 - Serial number: 6342MTS670032702
       Subsystem 3 - Serial number: 6351HTS6P6IVBBKR
       Subsystem 4 - Serial number: 6361HTS6CUTADBKR
    Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
       Part No SW: 8X0 953 501 Q    HW: 5K0 953 569 AP
       Revision: FF010018    Serial number: 20140409200806
       Coding: 518A040000
       Shop #: WSC 00049 770 00118
       VCID: 489488D1F37E200161-801C
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0033
       Coding: 820000
       Part No SW: 5N0 920 883 A    HW: 5N0 920 883 A
       Component: KOMBI         H05 0505
       Coding: 111F00
       VCID: 3260CA3965E2BAD12F-8066
       Part No SW: 7N0 907 530 AC    HW: 7N0 907 530 AC
       Component: J533  Gateway H48 1633
       Revision:   H48       Serial number: 270912F2000492
       Coding: 356002
       VCID: 71E20535A864C1C916-8024
       Component: IMMO          H05 0505
       VCID: 6AD012598DB2321157-803E
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0503
       Revision: 13110009    Serial number: 0005716407
       Coding: 0200BC
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 3874F811839E508111-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1504
       Serial number: 00000007278896
       Coding: 000090
       Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.285 1101
       Revision: 1AH03837    Serial number: 00122690267701
       Coding: 0000258
       VCID: 3D7AE90564BC75A9C2-8068
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0005756361
       Coding: 0200BC
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 3972FD15B8944989EE-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  008 1504
       Serial number: 00000007283631
       Coding: 000090
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000511436
       Coding: 0026167
       VCID: 3668F629418AA6F103-8062
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5ND 035 190 B    HW: 5ND 035 190 B
       Component: RCD510USBRVC  003 0003
       Revision: -----001    Serial number: VWZ4Z3R8092332
       Coding: 0100042504000C
       Shop #: WSC 79107 123 12345
       VCID: 3B7EE71DBAA87B99FC-806E
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AC
       Component: Batt.regelung H48 1633
       Coding: 030F1859
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900271979
    Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000A10634076
       Coding: 412120
       Shop #: WSC 00078 790 00199
       VCID: 2A50D2594532F21197-807E
    End-------------------------(Elapsed Time: 02:34)--------------------------
  4. #13
    Jan 2015
    Bosnia and Herzegovina
    for high beam check if in kufatec adapter from old connector pin4 goes to pin11 or if there are 2 extra wires in new connector pin11 which needs to be connected to bcm, this depends on the adapter how is it wired but also on your car, current wiring
    pin11 controls high beams or solenoids
  5. #14
    Apr 2017
    Greece
    High beams won't work
    Quote Originally Posted by m87a View Post
    Hello m87a! thanks for replying again!
    Kufatec adapter (and current wiring):
    Old Pin 1 goes to new pin 4
    Old Pin 2 goes to none
    Old Pin 3 goes to new pin 14
    Old Pin 4 goes to new pin 12
    Old Pin 5 goes to new pin 5
    Old Pin 6 goes to new pin 6
    Old Pin 7 goes to new pin 7 to Ground
    Old pin 8 goes to new 11. There are no extra pin 11 cables to BCM
    Old Pin 9 goes to new pin 9
    Old Pin 10 goes to new pin 10
    Do you also have any idea why MFD and audio settings gone away from MFD after replacing BCM? -same coding-
    By the way that Audi A1 slip ring worked right after Dana's instructions...
    Best regards,
    Nikolaos
  6. #15
    Jan 2015
    sorry pin4 to pin12 not 11 my mistake
    ok you need to move these 2 wires on cecm
    from
    T52A (black connector) pin5 to T52C (brown) pin48 &
    T52C (brown) pin46 to T52C (brown) to pin49
    with this high beam will work
  7. #16
    Apr 2017
    Greece
    High beams still not working!
    from
    Dear m87a, thnaks for the tip, but I've done all described without success!
    Any other tips? What about coding ?
    Dana??
  8. #17
    Jan 2015
    do you have physically pin11 on headlights??? because Tiguan also came with inteligent adaptive light which doesn't have pin 11 for high beam, instead it's operated via can wires, AFS can module controls low/hiogh beam and adapt it
  9. #18
    Apr 2017
    Greece
    I have no AFS installed. I've tried already direct cable from pin 11 to CECM pins 48 and 49 with no luck!
  10. #19
    Jan 2015
    it's not about AFS it's wheather your headlights have pin 11 in connector, meaning solenoid for high beam if not they are intelligent headlights and you cant get them to operate highbeam without AFS ok? check headlight connector is pin 11 present
  11. Likes Dana liked this post
  12. #20
    Apr 2017
    Greece
    Thanks for your response m87a!!!
    Indeed my lights have no pin 11 ! So what could I do??? Any suggestions???? How could I immitate AFS? Could I just install the controller without the sensor? If so, what kind of cabling modification should I do?
    Best regards,
    Nicolas!
    Thanks so much for your help!
