Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Tiguan 2013 Bi-xenon retrofit (No AFS)
    Apr 2017
    Greece
    Unhappy Tiguan 2013 Bi-xenon retrofit (No AFS)
    Dear members,
    I decided to retrofit my Tiguan with bi-xenon (No AFS). This is the third time I'm doing such retrofit, I've done one for my Golf V GTI and one for my golf MK6 GTI. Both of them went fine!
    This time, I'm facing couple of problems...
    I've followed this thread: http://forums.ross-tech.com/showthre...FS-retrofitted DRL's function properly but Xenons won't work. High beams either. I've run numerous tests with no luck. I'm using Kufatec adapters. Originally they came with no cable from pin 11 going to BCM pins 48,49 gold connector, but I've tried that version too. I've changed my BCM to a highline one. No luck....
    I've also seen threads like this: http://forums.vwvortex.com/showthrea...t-(without-AFS that incorporate messing with pin changes on the BCM.
    Which method is the right one?
    What could I do?
    My scan follows :
    (I've also changed slip ring and steering wheel adding MFSW option. That works, but I didn't manage to fix G85 issue yet)
    Monday,01,May,2017,20:22:36:52699
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVGZZZ5NZDW043218   License Plate: 8554
    Mileage: 117720km-73147mi   Repair Order:
    Chassis Type: 5N (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4C 52 53 56 61 62 72 77
    VIN: WVGZZZ5NZDW043218   Mileage: 117720km-73147miles
    04-Steering Angle -- Status: Cannot be reached 1100
    4C-Tire Pressure II -- Status: Not registered 0001
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 LE    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H28 4571
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00190012040401080000
       ASAM Dataset: EV_ECM20TDI01103L906018LE 003009
       ROD: EV_ECM20TDI01103L906018LE.rod
       VCID: 78F43811C31E9081D1-802C
    4729 - Steering Effort Control Module
              U0130 00 [039] - No Communications
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:56
                        Coolant temperature: 59 C
                        Intake air temperature: 27 C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 12.180 V
                        Limitation: accelerator pedal: 126.6 Nm
                        CAN status - engine control module-Bit 0: 0
                        Cruise Control System (CCS): status-Bit 0: 0
                        CAN status - transmission control module-Bit 0: 0
                        CAN status - brake control module 1-Bit 0: 0
                        CAN status - brake control module 2-Bit 0: 0
                        selected gear-Bit 0: 0
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AR    HW: 5N0 614 109 AR
       Component: J104   C6 450M VD57 0006
       Revision: --H07---    Serial number: 00000006258606
       Coding: 0037947
       VCID: 7BFE271D3A28BB99BC-802E
       Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004003
       VCID: 79F23D15F8148989AE-802C
       Part No SW: 5K0 937 087 T    HW: 5K0 937 087 T
       Component: BCM PQ35 H    021 0068
       Revision: BK021001
       Coding: 46180A38802502C040C000C0340089684B55AB88436D8160E484C7040041
       VCID: 468886E9F16A367193-8012
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 08101  013 0204
       Serial number: N1955119   204!
       Coding: 009795
       Component: RLS 051012 05  54  0403
       Coding: 02304D
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:58
                        Voltage: 12.20 V
                010 - Open or Short to Plus
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:58
                        Fault Status: 01101010
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:40:01
                        Voltage: 12.20 V
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:40:01
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20J VW10 HI   2118
       Revision: 24017000    Serial number: 003L7PLTU4Q.
       Coding: 0012362
       VCID: 7CFC24013F26BCA1B5-8028
       Subsystem 1 - Serial number: 6332MTS661652712
       Subsystem 2 - Serial number: 6342MTS670032702
       Subsystem 3 - Serial number: 6351HTS6P6IVBBKR
       Subsystem 4 - Serial number: 6361HTS6CUTADBKR
    Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
       Part No SW: 8X0 953 501 Q    HW: 5K0 953 569 AP
       Revision: FF010018    Serial number: 20140409200806
       Coding: 108A140000
       Shop #: WSC 00049 770 00118
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 489488D1F37E200161-801C
       Component: E221__MFL-TAS  H31 0033
       Coding: 820000
    226839 - Turn Signal Switch
              B1144 11 [009] - Short to Ground
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:56
       Part No SW: 5N0 920 883 A    HW: 5N0 920 883 A
       Component: KOMBI         H05 0505
       Coding: 111F00
       VCID: 3260CA3965E2BAD12F-8066
       Part No SW: 7N0 907 530 AC    HW: 7N0 907 530 AC
       Component: J533  Gateway H48 1633
       Revision:   H48       Serial number: 270912F2000492
       Coding: 356002
       VCID: 71E20535A864C1C916-8024
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:57
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:57
       Component: IMMO          H05 0505
       VCID: 6AD012598DB2321157-803E
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0503
       Revision: 13110009    Serial number: 0005716407
       Coding: 0200BC
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 3874F811839E508111-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1504
       Serial number: 00000007278896
       Coding: 000090
       Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.285 1101
       Revision: 1AH03837    Serial number: 00122690267701
       Coding: 0000258
       VCID: 3D7AE90564BC75A9C2-8068
                        Fault Status: 11100100
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:56
                        (no units): 4.0
                        Voltage: 12.10 V
    02546 - Steering Limit Stop
                        Reset counter: 87
                        Mileage: 117729 km
                        Date: 2017.05.01
                        Time: 03:39:56
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0005756361
       Coding: 0200BC
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 3972FD15B8944989EE-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  008 1504
       Serial number: 00000007283631
       Coding: 000090
       Revision:   H19       Serial number: 00000000511436
       Coding: 0026167
       VCID: 3668F629418AA6F103-8062
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5ND 035 190 B    HW: 5ND 035 190 B
       Component: RCD510USBRVC  003 0003
       Revision: -----001    Serial number: VWZ4Z3R8092332
       Coding: 0100042504000C
       Shop #: WSC 79107 123 12345
       VCID: 3B7EE71DBAA87B99FC-806E
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AC
       Component: Batt.regelung H48 1633
       Coding: 030F1859
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900271979
    Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000A10634076
       Coding: 412120
       Shop #: WSC 00078 790 00199
       VCID: 2A50D2594532F21197-807E
    End-------------------------(Elapsed Time: 02:26)--------------------------
    Please Help !!
    Jan 2015
    Bosnia and Herzegovina
    i'm not sure but your new MFSW (slip rign) module doesn't support G85, which is why you cant sort it out, you have audi module btw
    for low beam it should work immediately, i would test it directly from battery pin 5 ground (-) and pin 6 positive (+), and you should have low beam on, for high beam solenoid is pin 11 + (also check if you have pin 11 in headlights connector) if it works check fuses, wires, adapter etc...
  3. Likes Uwe, Dana liked this post
    Apr 2017
    Greece
    Thanks for replying!
    Quote Originally Posted by m87a View Post
    I'll test everything again!
    I've checked for slip ring compatibility and tables show that it is compatible! Any hint on that ?
    Jan 2015
    for slip ring it has audi software on it specifically Audi A1, because of that you have no communication with steering angle sensor
    Apr 2017
    Greece
    G85 issues...
    Thanks for replying again....
    How you can tell that software is for Audi? Is is possible to change/flash it?
    Do you know which slip ring is appropriate for my Tiguan ?
    Jan 2015
    no you change software in slip ring, you need to compare with original one which came with car, you need with steering wheel angle sensor etc....
  8. Likes Dana liked this post
    United States
    I noticed the email conversation related to the G85 problem
    .. between the OP and Peter in our tech team. I decided to reply here because I agree with m87a.
    The oldest scan I have from this car showed:
       Part No SW: 5K0 953 501 BD    HW: 5K0 953 569 J
       Revision: FF010041    Serial number: 20121006300001
       Coding: 5180040000
       VCID: 6DDA1945BC5C252932-8038
    and the GVL reported 04-Steering Angle -- Status: OK 0000 at that time.
    I haven't noticed a VW scan with Audi SWCM software (8X0 part number) but it doesn't sound like that is compatible and m87a is knowledgeable in this area. Since 03 is coded identically to the last known good scan and we know 5N1 44 modules do not have an internal G85 my only suggestion would be to code the installed 16 to the original value of: 5180040000
    If 16 accepts the original coding the G85 problem *might* be resolved but if it rejects the original coding I would consider it incorrect for this car.
  10. Likes m87a liked this post
  11. #8
    Apr 2017
    Greece
       Coding: 5180040000
    ________________________________________
    Dear Dana and m87a, I really thank you for your responses!
    Dear Dana do you know which is the right slip ring part number to fit my car??
    Best regards,
    Nikolaos
  12. #9
    Jan 2015
    you can try these, of course you buy these on your own, no guarantee because i don't know what did your car have before and now, also if you try to retrofit MFSW you need to change stalks ( wiper stalk to delete trip computer up/down/ok buttons) which causes issues with coding mfsw
    5K0 953 569 R
    5K0 953 569 AB
    5K0 953 569 AK no cruise control
    also try to find with list be aware there are audi and skoda/seat modules with same hardware different firmware (software) which can't be flashed
  13. Likes Dana liked this post
  14. #10
    United States
    PL24 notes using a scan tool to determine the original module:
    http://ft.trillian.im/7a467daf265128...SV7QUSP7VZ.jpg
    .. but ETKA shows this path from what I believe was the original: 5K0 953 569 J > 5K0 953 569 H > 5K0 953 569 AL
    You may want to research that list in addition to the ones m87a came up with.
    P.S. My 2012 SEL is WVGBV7AX1CW000438 and a scan from is lives in post #18 here http://forums.ross-tech.com/showthre...ll=1#post13575
    The MFSW and Xenon (facelift with LED DRL) were factory equipped.
  15. Likes m87a, Uwe liked this post
