Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 122
Thread: Passat B5 starts and idles but no throttle until warm
  1. #21
    Timing belt being out will cause this ...........wouldn't hurt to set it up again.
    Doesn't take much when failing to account for the belt slack........
  2. #22
    Quote Originally Posted by tdidaho View Post
    Thanks Uwe for the editing. I was trying to put those scans in scrollable windows but couldn't figure it out. Is there somewhere on the Ross-Tech site that explains these things?
    CODE tags as explained here.
  3. #23
    Jan 2017
    Would this be consistent with timing being off when cold but normal when warmed up?
  4. #24
    Yup and from your work steps as described for the BSM.
    Did you install a new belt?
  5. #25
    Jan 2017
    Yes, a new belt was installed. However I don't have 100% confidence in the mechanic who did the job. Turns out he forgot to plug the oil feed hole for the BSM which I had to go back and do myself. He also screwed up an ECU doing the tune as a Malone dealer. Basically, I got conned. I hired him to do 3 things and I know for a fact he screwed up 2 things. I'd say it's possible, maybe even likely that he screwed up the third (new timing belt) as well.
  6. Likes jyoung8607 liked this post
  7. #26
    Sounds like it smells as if you should leave it "alone" I mean that person who un-helped you....
    Time to RTFB a belt and check basics ........people screw this up pretty routine and call themselves "professionals".
  8. #27
    Jan 2017
    Finally got around to checking the timing belt today. All is as it should be. So back to square zero. Any other suggestions out there?
  9. #28
    Have you tried a stock ecu and or flash to see if anti tuning or the config is being blocked from performing due to horseshit code or swap work........or deletes?
  10. Likes Zenerdiode liked this post
  11. #29
    Jan 2017
    As I wrote before I have 2 ECUs that I do trust and that don't seem to make a difference in how the car runs. One is a completely stock (with AT tune) that has had the Immobilizer deleted so it will work in my car, and the other has been re-tuned (MT and Stage 2 tune) and adapted to the immobilizer. Both ECUs have been programmed by highly competent and reputable tuners.
    Regardless which ECU I use the car starts and runs poorly with very advanced timing and no throttle response until it warms to 56-58C at which point the timing suddenly becomes normal, the throttle works, and the car runs and revs as it should. Swapping the ECUs have no effect on this pattern.
  12. #30
    It's FOD until verified stock...........JPPSG NJA Title 3 Section 2
    Recheck your cam-belt work..............
    Additionally see JPPSG NJA Title 3 section 1
