Passat B5 starts and idles but no throttle until warm
tdidaho
C?ID=102042
I first posted about this issue several months ago and despite many suggestions from this forum I am still trying to solve this mysterious problem. Rain and frustration has hindered my efforts the past few months but I’m ready to dig in again and would appreciate any input.
My car is a 2005 B5.5 Passat TDI Wagon with a BHW engine. It has 140,000 miles on it and the engine ran perfectly last fall when I began a manual transmission swap. I opted to pull the engine and AT out of the car as a unit and while the engine was out of the car I had a shop do a BSM delete and new timing belt and water pump. I also installed a new coolant manifold, water temp sensor, and engine speed sensor. The transmission is an FHN from Dutch Auto Parts and the rest of the manual swap parts were from a 2002 Passat V6. I’m currently using an ECU with an immobilizer delete that works just fine in my friend’s Passat.
I completed the swap last October and the engine has not run normally since then. This is the current situation when I try to start it:
The cold car starts immediately but starts at a low rough idle, around 450 rpm, which increases to around 950 rpm over a couple of seconds at which point the engine usually shuts down. After a few tries like this instead of shutting down completely it will catch itself and idle very roughly at 450-500 rpm. At this point there is no throttle response (VCDS shows the TPS operating properly), the timing is at 13-14 BTDC, the Specified MAF (SMAF) is 650-850 while the Actual MAF (AMAF) is around 450, and the IQ is 33.8.
It will idle in this condition and gradually warm up. As the coolant temp rises the rpm slowly increases and gets smoother. The throttle remains unresponsive and the timing and SMAF are unchanged. When the coolant temp reaches 56-58 C everything changes-
the idle is smooth and stable at 850 rpm, the throttle is responsive, the timing is within normal specs (1.6 BTDC), the SMAF and AMAF are approximately the same in the 250-450 range, and the IQ is 4.7 The engine revs normally to redline and if I shut it down and restart it, the car runs normally.
The only codes on a VCDS Autoscan are related to the missing TCM which should not effect whether the engine runs properly or not. I have tried 3 coolant temp sensors, the last one from the VW dealer with no change. I’m confident that this is not an ECU issue and I’ve tried a different MAF sensor from my friend’s Passat without any change.
Anybody seen anything like this before? Calling all TDI geniuses to help me get this car on the road. Many thanks.
tdidaho
C?ID=102042
Thanks for your thoughts. The engine ran perfectly before the manual swap. Seems unlikely that something happened to the injectors or cam followers while the engine was out of the car. I'll post an autoscan later but as I said in my post NO codes other than missing TCM.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
You have an auto ECU with cold startup fuel enrichment maps designed to meet a certain baseline torque load. Even in Park or Neutral, that load included a spinning torque converter and a working ATF pump. You disappeared those things, PLUS you disappeared your balance shaft load. Just spit-balling here, but everything you've shared above could be consistent with the ECU running out of room to compensate, trying to clamp down on unexpectedly high RPM from the commanded IQ and timing.
Maps for auto vs. manual ECUs are subtly different, including startup behavior. That's why there are different ECUs (yes really just software) instead of just a coding bit. Why not reflash or replace your ECU with the manual variant, like you need to do anyway to get rid of your MIL, and see what that does for you.
Jason
ivagp
C?ID=95551
this isn't the first guy with the swap so i don't think coding or software is the issue. did u pull on a wire or connector pulling the trans out or in. have u checked torsion values cold and hot.
My recollection is that the TDI engine installed in the NAR 2005 Passat was mechanically unique, and it was never offered in combination with a manual trans. If I'm correct, that leaves things pretty much in the same spot as the 2001-2003 24V VR6 Eurovans, where there simply is no MT ECU or ECU software for that engine.
tdidaho
C?ID=102042
the auto-scan is request not necessarily just for the fault codes, but to see what all components are installed/recognized. :)
I'll get an autoscan later today
tdidaho
C?ID=102042
Jason
I have an ECU that is flashed for a manual transmission. It works once the car is warmed up but for some reason doesn't allow the car to idle poorly long enough to warm up. Plenty of people have done this swap and been able to start and run the engine with the stock AT tuning. It doesn't run well but it runs.
tdidaho
C?ID=102042
where do I check torsion value?
Maybe you set your belt wrong when doing your BSM.....escaped?
Maybe your review of measuring values for timing is just in fact not base values as in "basic settings"?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I'd definitely like to see the Auto-Scan then. Unless you're referring to codes stored somewhere other than the ECU, one of the above statements is false.
Are you saying other people with the same swap have had the same problem, just less severe? That seems highly germane to our discussion.
I freely admit I can barely spell TDI, so I'm just throwing out a wild theory. But it would be interesting to test an added light load on the engine when it's in a rough cold idle phase. Like, let the clutch out just a touch in a high gear (obviously not for a very long time) to provide a little drag. If it smooths out the idle, then you know something.
Jason
I was going to say the same thing, good sleuthing........
Time to check the timing in basic settings........
EMMM donuts...........
tdidaho
C?ID=102042
Jason
Sorry about the confusion but I actually have 2 ECUs. One has been programed for a manual transmission and a Stage 2 tune. When I first tried to get the car running I was using this ECU. I purchased a second ECU that had not been altered other than an Immobilizer delete to rule out the ECU as the source of my problem. The ECU with the tune would start, idle roughly for a few seconds, then the rpms would pick up to about 950 and then the engine would suddenly shut down. I could never get it to warm up to the point where it ran properly. When I tried the stock ECU instead of the engine shutting down it managed to maintain a very slow and tenuous idle long enough to warm up.
No I'm not saying other people have had the same problem (I wish that were the case). What I'm saying is that many people who have completed this exact swap have had NO problem starting their engines with the original ECU and AT tune. Some have suggested that the problem is caused by trying to start a car with a manual transmission with an ECU that's programmed for an Automatic Transmission but I know that's not the issue. It won't drive well but the engine will start and run and will definitely have a functioning throttle.
I like your idea about adding a load; not something I've tried while the engine is running bad.
tdidaho
C?ID=102042
Here's the AutoScan.
Monday,01,May,2017,18:00:44:45368
VCDS Version: 17.1.3.0 (x64)
VIN: WVWCE63B95E126365   License Plate:
Mileage: 225040km-139833mi   Repair Order: 5/01/17
VIN: WVWCE63B95E126365   Mileage: 225040km-139833miles
Address 01: Engine        Labels: 038-906-016-BHW.lbl
   Part No SW: 038 997 016 N    HW: 028 101 198 2
   Component: R4 2,0L EDC G000AG  1388
   Revision: 12345678    Serial number: XXXXXXXXXXXXXX
   Coding: 0150034
   Shop #: WSC 24140 444 53484
   VCID: 2952F06083481A099E-515A
18034 - Powertrain Data Bus
            P1626 - 000 - Missing Message from TCU
                    Torque: 128.0 Nm
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Bin. Bits: 00001000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000100
Readiness: 1 1 1 1 1
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 04255
   Shop #: WSC 05311
   VCID: 254AFC50BF503E69BA-513C
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 35-00 -
            P1626 - 35-00 - Missing Message from TCU
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 05311
   VCID: 244CE154B46AC761AD-513C
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 05311
   VCID: 2F661E78EDAC743940-515A
   Part No: 3B0 920 929 C
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 15235
   VCID: 2756F658C55C2C7988-5120
   WVWCE63B95E126365     VWZ7Z0D1256844
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05311
   VCID: 70E4DD0430122BC119-5120
   Part No: 1C0 959 799 C
   Component: 80 Komfortger·t HLO 0004
   Coding: 00258
   Shop #: WSC 05311
   VCID: 3776261815FCBCF918-4B00
   Subsystem 1 - Part No: 1C1959801
   Component: 80 Tırsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 80 Tırsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 80 Tırsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 80 Tırsteuer.HR KLO 0202
End-------------------------(Elapsed Time: 04:42)--------------------------
tdidaho
C?ID=102042
The fault codes at address 46 are because I have the driver's door interior panel with switches removed. This scan is with the stock ECU and Immobilizer delete.
tdidaho
C?ID=102042
This is the Controller Map from my car:
016-N HW:028-101-198-2 --- Engine
;Component:R04L 2 EDC G000AG C1o3d8i8ng:0150034
;Monday 27 March 2017 13:07:58:45368
17.1.3 (x64) Data version: 20170320 DS267.7
2952F06083481A099E-513C
Group Field 1 Data type Field 2 Data type Field 3 Data type Field 4 Data type
1 651 /min RPM 33.8 mg/str Inj. Quantity 11.2°KW Idle Stabilization37.8°C Temperature
2 651 /min RPM 0.00% Load 0 01 0 Bin. Bits 37.8°C Temperature
3 651 /min RPM 665.0 mg/str Mass Air / Rev. 430.0 mg/str Mass Air / Rev. 100.60% Duty Cycle
4 651 /min RPM 13.6 °BTDC Ign. Timing 11.2°KW Idle Stabilization0.0°KW Idle Stabilization
5 651 /min RPM 30.7 mg/str Inj. Quantity 48 (no units) 37.8°C Temperature
6 0.0 km/h Speed 1100 Bin. Bits 0.00% Load 10 Bin. Bits
7 28.8°C Temperature 0.00% Load 17.1°C Temperature 37.8°C Temperature
8 651 /min RPM 0.0 Nm Torque 186.0 Nm Torque 174.0 Nm Torque
9 651 /min RPM -1280.0 Nm Torque 410.0 Nm Torque 174.0 Nm Torque
10 425.0 mg/str Mass Air / Rev. 948.6 mbar Absolute Pres. 938.4 mbar Absolute Pres. 0.00% Load
11 651 /min RPM 1346.4 mbar Absolute Pres. 938.4 mbar Absolute Pres. 80.50% Duty Cycle
12 11111111 Bin. Bits 1.61 s Time 13.60 V Voltage 37.8°C Temperature
13 0.02 mg/str Inj. Quantity 0.00 mg/str Inj. Quantity 0.02 mg/str Inj. Quantity 0.00 mg/str Inj. Quantity
15 651 /min RPM 174.0 Nm Torque 3.20 l/h Fuel Consump. 0.0 Nm Torque
16 45.90% Load 0 Bin. Bits 0 Bin. Bits 13.60 V Voltage
17 10000001 Bin. Bits 110111 Bin. Bits 11100000 Bin. Bits 11100000 Bin. Bits
18 0 (no units) 0 (no units) 0 (no units) 0 (no units)
20 651 /min RPM 174.0 Nm Torque 1270.0 Nm Torque -1280.0 Nm Torque
21 0 Bin. Bits 10000100 Bin. Bits 0 Bin. Bits 100 Bin. Bits
22 1 (no units) 1 (no units) 0 (no units) 144 (no units)
23 -27 (no units) -35 (no units) -18 (no units) -18 (no units)
25 651 /min RPM 0 Bin. Bits 4 (no units) 0 (no units)
26 793E RPM
27 1 (no units) 0 Bin. Bits 0.0 km/h Speed 255.0 km/h Speed
28 0.304 V Voltage 0 01 0 Bin. Bits 0.00% Load
30 221 ohms Resistance 0.000 V Voltage 0.00% Lambda 0 (no units)
31 0 (no units) 1.60% Duty Cycle 4.964 V Voltage 0.000 V Voltage
32 0 (no units) 17.1°C Temperature 948.6 mbar Absolute Pres. 0.000 V Voltage
33 651 /min RPM 948.6 mbar Absolute Pres. 9.96 g/s Mass Flow
34 0 Bin. Bits 11001001 Bin. Bits 0 (no units) 0 (no units)
35 0 Bin. Bits 0 Bin. Bits 0 Bin. Bits 100000 Bin. Bits
36 0 Bin. Bits 100000 Bin. Bits 100000 Bin. Bits 100000 Bin. Bits
37 100000 Bin. Bits 0 Bin. Bits 0 Bin. Bits
38 0 Bin. Bits 0 Bin. Bits
39 651 /min RPM 33.8 mg/str Inj. Quantity 0.00 mg/str Inj. Quantity 10 Bin. Bits
40 651 /min RPM 33.8 mg/str Inj. Quantity 0 Bin. Bits 1 (no units)
41 100.60% Duty Cycle 0.00% Duty Cycle 0.00% Duty Cycle 0.00% Duty Cycle
42 0.00% Lambda 0 Bin. Bits 95.90% Duty Cycle 0.00% Duty Cycle
43 87.30% Duty Cycle 100.60% Lambda 0.00% Lambda 0 Bin. Bits
44 651 /min RPM 38.7°C Temperature 0 Bin. Bits 0.00% Lambda
50 651 /min RPM 33.8 mg/str Inj. Quantity 0.00 mg/str Inj. Quantity 10 Bin. Bits
51 651 /min RPM 315 /min RPM 48 (no units) 10000 Bin. Bits
52 0 (no units) 0 (no units) 0 (no units) 0 (no units)
55 0 (no units) 0 (no units) 100000 Bin. Bits 100000 Bin. Bits
56 100000 Bin. Bits 100000 Bin. Bits 100000 Bin. Bits 0xFF36 Hex Value
60 672 /min RPM 174.0 Nm Torque 38.7°C Temperature 0.00% Load
61 89.1°C Temperature 38.7°C Temperature 0.00% Load 0 Bin. Bits
62 38.7°C Temperature 17.1°C Temperature 17.1°C Temperature
63 0.00 bar Pressure 0.0 Nm Torque 144 (no units)
65 0.00% Load 38.7°C Temperature 0 Bin. Bits
66 29.7°C Temperature 3.00 l/h Fuel Consump.
67 114.0°C Temperature
74 651 /min RPM 114.0°C Temperature 1 (no units) 0.0 mg/str Inj. Quantity
75 114.0°C Temperature
80 BPG-810 27.01.0 5 12345678 1888 0867
81 XXXXXXXXXXXXX XXXX XXXXXXXXXXXXXX 1234567
82 5348444424140 <> 78 79 <>
86 11001100 Bin. Bits 11111010 Bin. Bits 11011111 Bin. Bits 101000 Bin. Bits
87 11111111 Bin. Bits 11111100 Bin. Bits 0 Bin. Bits
89 10000001 Bin. Bits
90 672 /min RPM 33.8 mg/str Inj. Quantity 665.0 mg/str Mass Air / Rev. 0 Bin. Bits
91 127 (no units) -128 (no units) 665.0 mg/str Mass Air / Rev. 26 (no units)
93 0 Bin. Bits 1.02 (no units) 7.2 (no units) 7.2 (no units)
125 Transm. 0 ABS 1 Instruments 1 Airbag 1
131 144 (no units) 33.8 mg/str Inj. Quantity 38.7°C Temperature
133 651 /min RPM 390.0 mg/str Mass Air / Rev. 948.6 mbar Absolute Pres. 0 (no units)
134 45.10% Load 13.53 V Voltage
140 110111 Bin. Bits 11100000 Bin. Bits
213 672 /min RPM 0.00% Load 0.0 km/h Speed 0 (no units)
225 255 (no units) 0 (no units) 0 (no units) 0 (no units)
226 0 (no units) 0 (no units) 0 (no units)
227 0 (no units) 0 (no units) 0 (no units) 0 (no units)
228 0 (no units) 0 (no units)
229 0 (no units) 0 (no units)
tdidaho
C?ID=102042
And this is the Controller Map from a properly running 2005 Passat B5.5 recorded at the same coolant temp:
016-T HW:028-101-198-2 --- Engine
;Component:R04L 2 EDC G000A CGo d0i3n1g4:0150034
;Saturday 25 March 2017 13:45:04:45368
2F661E78BDAC743940-515A
1 861 /min RPM 7.4 mg/str Inj. Quantity 6.1°KW Idle Stabilization37.8°C Temperature
2 861 /min RPM 0.00% Load 0 01 0 Bin. Bits 37.8°C Temperature
3 861 /min RPM 285.0 mg/str Mass Air / Rev. 280.0 mg/str Mass Air / Rev. 79.30% Duty Cycle
4 861 /min RPM 3.1 °BTDC Ign. Timing 6.6°KW Idle Stabilization-3.9°KW Idle Stabilization
5 861 /min RPM 15.6 mg/str Inj. Quantity 48 (no units) 37.8°C Temperature
6 0.0 km/h Speed 1000 Bin. Bits 0.00% Load 10 Bin. Bits
7 37.8°C Temperature 0.00% Load 28.8°C Temperature 37.8°C Temperature
8 840 /min RPM 0.0 Nm Torque 196.0 Nm Torque 140.0 Nm Torque
9 861 /min RPM -1280.0 Nm Torque 410.0 Nm Torque 140.0 Nm Torque
10 295.0 mg/str Mass Air / Rev. 1009.8 mbar Absolute Pres. 999.6 mbar Absolute Pres. 0.00% Load
11 861 /min RPM 1071.0 mbar Absolute Pres. 999.6 mbar Absolute Pres. 80.50% Duty Cycle
12 11111111 Bin. Bits 0.00 s Time 14.29 V Voltage 37.8°C Temperature
13 -0.59 mg/str Inj. Quantity 0.02 mg/str Inj. Quantity 0.45 mg/str Inj. Quantity 0.09 mg/str Inj. Quantity
15 861 /min RPM 40.0 Nm Torque 0.60 l/h Fuel Consump. 0.0 Nm Torque
16 40.80% Load 0 Bin. Bits 0 Bin. Bits 14.29 V Voltage
17 10000001 Bin. Bits 1000111 Bin. Bits 11100000 Bin. Bits 10000000 Bin. Bits
20 861 /min RPM 40.0 Nm Torque 1270.0 Nm Torque -1280.0 Nm Torque
21 0 Bin. Bits 100 Bin. Bits 0 Bin. Bits 100 Bin. Bits
22 1 (no units) 1 (no units) 0 (no units) 16 (no units)
23 1 (no units) 1 (no units) -17 (no units) -7 (no units)
25 861 /min RPM 0 Bin. Bits 4 (no units) 0 (no units)
26 B023 RPM
30 205 ohms Resistance 0.000 V Voltage -0.50% Lambda 1 (no units)
32 0 (no units) 27.9°C Temperature 1009.8 mbar Absolute Pres. 0.000 V Voltage
33 861 /min RPM 1009.8 mbar Absolute Pres. 7.11 g/s Mass Flow
34 0 Bin. Bits 11001001 Bin. Bits 52 (no units) 0 (no units)
39 861 /min RPM 7.1 mg/str Inj. Quantity -1.58 mg/str Inj. Quantity 10 Bin. Bits
40 861 /min RPM 7.1 mg/str Inj. Quantity 0 Bin. Bits 1 (no units)
41 100.60% Duty Cycle 22.30% Duty Cycle 21.50% Duty Cycle 15.10% Duty Cycle
42 -5.10% Lambda 0 Bin. Bits 95.90% Duty Cycle 21.50% Duty Cycle
43 81.30% Duty Cycle 100.60% Lambda 0.00% Lambda 0 Bin. Bits
44 861 /min RPM 37.8°C Temperature 0 Bin. Bits 0.00% Lambda
50 861 /min RPM 6.9 mg/str Inj. Quantity -1.48 mg/str Inj. Quantity 10 Bin. Bits
51 861 /min RPM 420 /min RPM 48 (no units) 10000 Bin. Bits
56 100000 Bin. Bits 100000 Bin. Bits 100000 Bin. Bits 0xFF00 Hex Value
60 861 /min RPM 38.0 Nm Torque 37.8°C Temperature 0.00% Load
61 89.1°C Temperature 37.8°C Temperature 0.00% Load 0 Bin. Bits
62 37.8°C Temperature 27.9°C Temperature 27.9°C Temperature
63 0.00 bar Pressure 0.0 Nm Torque 16 (no units)
65 0.00% Load 37.8°C Temperature 0 Bin. Bits
66 38.7°C Temperature 0.60 l/h Fuel Consump.
67 138.0°C Temperature
74 861 /min RPM 138.0°C Temperature 1 (no units) 0.0 mg/str Inj. Quantity
75 138.0°C Temperature
80 BPG-810 05.01.0 5 12345678 1888 1221
81 WVWCE63B75E1 32391 VWZ7Z0E1415451 1234567
82 1387244426111 <> 78 79 <>
86 11001100 Bin. Bits 11111000 Bin. Bits 10011111 Bin. Bits 101000 Bin. Bits
87 11111111 Bin. Bits 11111100 Bin. Bits 1001111 Bin. Bits
90 861 /min RPM 7.1 mg/str Inj. Quantity 285.0 mg/str Mass Air / Rev. 0 Bin. Bits
91 127 (no units) -128 (no units) 285.0 mg/str Mass Air / Rev. -1 (no units)
93 11 Bin. Bits 1.5 (no units) 6 (no units) 9.6 (no units)
125 Transm. 1 ABS 1 Instruments 1 Airbag 1
131 16 (no units) 7.1 mg/str Inj. Quantity 38.7°C Temperature
133 861 /min RPM 290.0 mg/str Mass Air / Rev. 999.6 mbar Absolute Pres. 0 (no units)
134 40.00% Load 14.29 V Voltage
140 1000111 Bin. Bits 10000000 Bin. Bits
213 861 /min RPM 0.00% Load 0.0 km/h Speed 0 (no units)
225 0 (no units) 0 (no units) 0 (no units) 1 (no units)
Timing...........Timing .........anyone ........Timing!
Show a log of timing cold within basic settings logged.........chances are once it is entered the car will stall from being out at baseline time.
tdidaho
C?ID=102042
Thanks Uwe for the editing. I was trying to put those scans in scrollable windows but couldn't figure it out. Is there somewhere on the Ross-Tech site that explains these things?
Yes the timing when cold is very wack- 13.6 BTDC. Any ideas what would cause that? It does return to normal when warm.
BTW- torsion when warm and cold is 0.0.
