Results 1 to 3 of 3
Thread: MY17 Škoda Kodiaq Edition 190 TDi DSG 4x4 (UK spec)
    Verified VCDS User Gizmo's Avatar
    Mar 2014
    S.E.Kent UK
    Monday,01,May,2017,11:08:04:36443VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
    VCDS Version: 17.4.1.1  HEX-NET CB: 0.4336.4
    Data version: 20170413 DS270.4
    VIN: TMBMK9NS4H8017066   License Plate: **17 ***
    Mileage: 150   Repair Order: 1
    Chassis Type: NS (3Q0)
    Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44
              47 52 55 5F 69 6C 6D 75 A5 BB BC CA
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DFHA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H25 3916
       Revision: B4H25---
       Coding: 0125001204771D083000
       Shop #: WSC 33361 790 00063
       ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
       ROD: EV_ECM20TDI01104L906026EJ_001.rod
       VCID: 76A02384C94966F72A-8022
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2014
       Revision: 00H06V07
       VCID: 3326DA909ABB33DFCD-8066
       Revision: 00000000    Serial number: 60817000001508
       Coding: 6007929F54210B734777070662C94906492AD0E2E046927DB86150F8E2AA4200002F641A1B13111435351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 77BE2E80CE431FFF31-8022
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0435660719
       Coding: 032C0C0F03
       VCID: 3C34F1ACB7E5FCA71C-8068
       Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
       Component: GEB.F.Heckoef  H17 0904
       Serial number: 58037761
    1077250 - Transport Mode Active
              U1105 00 [008] - -
                        Fault Frequency: 25
                        Reset counter: 42
                        Mileage: 9 km
                        Date: 2017.03.30
                        Time: 14:43:30
       Component: Sitzmemory    H08 0021
       Serial number: Y0006QBR21177
       Coding: 0014000000000500018281818181000000008181000000D400
       ASAM Dataset: EV_SeatMemorPasseSide 002021
       ROD: EV_SeatMemorPasseSide_VW37.rod
       Part No SW: 565 907 044 AD    HW: 565 907 044 AD
       Revision: 00001K00
       Coding: 16110104003410011105100D0010110A
       Shop #: WSC 73430 790 00063
       VCID: 5DF25C284CBFD5AF4B-8008
       Subsystem 4 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 60413724
              B10CD 00 [008] -  -
                        Fault Frequency: 16
                        Reset counter: 42
                        Mileage: 9 km
                        Date: 2017.03.30
                        Time: 14:43:51
                        Dynamic environmental data: 02 86
                        Voltage terminal 30: 12.6 V
                        CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0223
       Revision: --------    Serial number: 86581403170190
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017_VW27.rod
       VCID: 014A40589087514F0F-8054
       Subsystem 1 - Part No SW: 567 955 119     HW: 567 955 119
       Component: WWS326 170103  051 0905
       Serial number: 887253F0401700300225
       Coding: 065DDD
       Component: RLHS  042 0105
       Serial number: S4Y17M03D19H22M10S38
       Coding: 0088DF
       Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY170523HCP
       Serial number: 00000000000037810819
    527872 - Transport Mode Active
              U1105 00 [008] - -
                        Fault Frequency: 72
                        Reset counter: 42
                        Mileage: 9 km
                        Date: 2017.03.30
                        Time: 14:43:36
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0021
       Serial number: 000303177478040
       Coding: 0D31267A51
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3B36F2B0B2EBFB9F15-806E
    13679388 - Databus
                        Fault Frequency: 7
                        Reset counter: 60
                        Mileage: 9 km
                        Date: 2017.03.30
                        Time: 15:57:26
    Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
       Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0156
       Coding: 320147C950FF8728749C8065304085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001011
       ROD: EV_ACCMRRCONTIVW376_001_VW37.rod
    0110 - Transport Mode Active
              U1105 00 [008] - -
                        Fault Frequency: 27
                        Reset counter: 42
                        Mileage: 9 km
                        Date: 2017.03.30
                        Time: 14:43:32
                        Voltage terminal 15: 12.5 V
                        Control Module temperature: 35 ∞C
                        Longitudinal_acceleration_vehicle_reference: 0.03 m/s≤
       Serial number: 27021741350506
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 383CEDBC83DDD087F8-806C
       Part No SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
       Component: Airbag VW21   004 0306
       Revision: --------    Serial number: 003RAP5EZ2C4
       Coding: 98FCC0C0000000005C5400CF00C800000065
       ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X_VW27.rod
       VCID: 0C54616CA7C50C276C-8058
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 567857705A0059R01365
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 567857706A0059R00849
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 002 302 17
       Serial number: 35700000000A0CC0C22M
       Subsystem 4 - Part No SW: -----------    HW: 454 002 102 17
       Serial number: 3580000000086A20D22G
       Subsystem 5 - Part No SW: -----------    HW: 454 802 802 17
       Serial number: 351009E5D7D0F000000%
       Subsystem 6 - Part No SW: -----------    HW: 454 800 703 17
       Serial number: 35200E927890F000000V
       Subsystem 7 - Part No SW: -----------    HW: 454 800 203 17
       Serial number: 3550007F7D90D000000Y
       Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0245
       Revision: FF036036    Serial number: 20170322500173
       Coding: 6414
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
       ROD: EV_SMLSVALEOMQBLRH_VW37.rod
       VCID: 7CB431ACF7653CA75C-8028
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Reset counter: 63
                        Mileage: 1048574 km
                        Time: 00:00:00
                        Ubat 30 Voltage: 13.10 V
                        Internal error state: 0
                        LIN_Temp: 0
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 255
                        Slope: 133
                        kp: 18
                        OUT: 50
                        Temperatur Statisch: 30
                        Tsoll Wert 0: 34.00 ∞C
                        Tsoll Wert 1: 39.00 ∞C
                        Tsoll Wert 2: 44.00 ∞C
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 565 920 951     HW: 565 920 951
       Component: KOMBI         311 8311
       Coding: 27A4081CFF84A60001886B0B7001000800000000
       Shop #: WSC 73430 031 00063
       ROD: N/A
       VCID: 5AF857345D9122972E-800E
    No ASAM data for: "EV_DashBoardVDDMQBAB" ()
       Component: GW MQB High   515 5286
       Serial number: 23031710521005
       Coding: 030100344F087300EB03225E9E0F00010001070000000000000000000000
       Shop #: WSC 33361 790 00114
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F2ED6E07693173FA9-807A
       Subsystem 2 - Part No SW: 3V0 919 719 D    HW: 3V0 919 719 D
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000C1156250217
       Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
       Serial number: 758861000017031701B6
    8531970 - Quiescent Current
              U1406 00 [008] - Too High
                        Reset counter: 49
                        Mileage: 79 km
                        Date: 2017.04.20
                        Time: 02:11:56
                        Supply voltage: Terminal 30: 12.6 V
                        Terminal 15: OFF
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Serial number: HA1-00014.02.17
       Coding: 0101
       ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
       VCID: 4AD8A774ED3152179E-801E
       Serial number: 17000066577012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 71AA1098A02741CFFF-8024
    Address 36: Seat Mem. Drvr (J810)       Labels: None
       Serial number: Y0006QBS11805
       ROD: EV_SeatMemorDriveSide_002_VW48.rod
    Address 3C: Lane Change (J1086)       Labels: None
       Component: HRE_Master    H12 0071
       Serial number: 0433913037
       Coding: 02012203
       ROD: EV_HREntryHella_VW32.rod
       Lane Change Assistant 2:
       Component: TSG FS        010 0032
       Serial number: 0000246863683
       Coding: 00158820DE01048000001100
       VCID: 47DE9E40FE23AF7F81-8012
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 9307
       ROD: EV_SteerAssisMQB_013_VW37.rod
       VCID: 45C29448C42FBD6F73-8010
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1HJE01GAUJ
       Coding: 0323160000AA002AAA0000000000
       ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
       ROD: N/A
       VCID: 59FA48385897298F27-800C
    No ASAM data for: "EV_AMPMst16C4Gen2ALPI" (VW48)
    15360256 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 42
                        Mileage: 9 km
                        Date: 2017.03.30
                        Time: 14:47:26
       Component: TSG BFS       010 0032
       Serial number: 0000246545101
       Coding: 00158020DE01048000001100
       VCID: 46C09344F929B6777A-8012
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0070
       Coding: 03E602003D210901
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: N/A
       VCID: 41CA8058D007914F4F-8014
    No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VW52)
    Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
       Part No SW: 3V0 035 021 D    HW: 3V0 035 021
       Component: MU-H-LND-EU   H50 0942
       Serial number: A674C0HS022730
       Coding: 032316010000000051111202008808332F0300E6012081009E
       VCID: 281C3DFC537D400768-807C
       Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
       Component: ABT_Std-2_Nav  H35 8077
       Serial number: SKZ6ZET0771767
       Subsystem 2 - Part No SW: V03 959 801 JM    HW: -----------
       Component: ECE 2017  --- 0157
       Component: Gracenote2---  --- 1013
    Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0435603998
       Coding: 0100000202000000
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
       Component: Areaview 2    H13 0607
       Serial number: C854707JG011946
       Coding: 04231601A30FA00000604894
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
    Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: 31257774700000
       Coding: 1B88
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Part No SW: 5NA 035 284 A    HW: 5NA 035 284 A
       Component: OCULowMQBLGE  H13 0614
       Coding: 03231601EA423A0D3B1C9E020045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 003042
       ROD: EV_OCULowMQBLGE.rod
    12866050 - Terminal 15
              B1148 29 [008] - Signal Implausible
                        Reset counter: 42
                        Mileage: 9 km
                        Date: 2017.03.30
                        Time: 14:47:56
                        Voltage terminal 30: 13.4 V
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 19031711K21799
       Coding: 020307060000040100062355C050A90098000E200020
       ROD: EV_MFKBoschMQBB_VW36.rod
    Address BB: Door Rear Drv (J388)       Labels: None
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       011 0032
       Serial number: 0000234327541
       Coding: 001880208001048000001100
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 49DA9878E837590F97-801C
    Address BC: Door Rear Pass (J389)       Labels: None
       Component: TSG HBFS      011 0032
       Serial number: 0000234327488
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    Address CA: Sunroof (J245)       Labels: None
       Component: SAD_STG_1     013 0005
       Coding: 308040648202
       ROD: EV_SunRoofCONTIAU736.rod
       VCID: 3D32FCA8ACFFF5AF2B-8068
    End----------(Elapsed Time: 02:32, VBatt start/end: 12.5V/12.5V)-----------
    HEX-NET
    2016 Škoda Superb L&K (190CR)
    Pre-booked a VW ID.3 1st Edition
  2. Likes Uwe, Boki Ar liked this post
  3. #2
    Mar 2014
    S.E.Kent UK
    All DTCs cleared after the scan above, looks like the car was not scanned after the PDI
    HEX-NET
    Mar 2014
    S.E.Kent UK
    01 Admap:
    ;SW:04L-906-026-EJ HW:04L-907-309-P --- Engine
    ;Component:R4 2.0l TDI H25 3916 Coding:0125001204771D083000
    ;EV_ECM20TDI01104L906026EJ 4004 EV_ECM20TDI01104L906026EJ_001.rod
    ;Monday 1 May 2017 11:09:52:36443
    ;VCDS Version: Beta 17.4.1 Data version: 20170413 DS270.4
    ;VCID: 76A02384C94966F72A-8022
    IDE00001-Production mode 00 00 00 3
    IDE00263-Injector 1 correction value 7ZZIH1A 7
    IDE00264-Injector 2 correction value 7RRPD1B 7
    IDE00265-Injector 3 correction value AASLFNB 7
    IDE00266-Injector 4 correction value 8H8SCN8 7
    IDE01096-Particulate Filter Statistics 0 1
    IDE01711-Blocking of particle filter regeneration not active 1
    IDE01945-Engine run-in oil pressure active 1
    IDE02248-Individually adjustable maximum speed limit 300.0 km/h 2
    IDE02332-Deactivate production mode 00 00 00 3
    IDE02637-Adaptation for metering quantity measurement 4 1
    IDE04158-Activation of start-stop function active 1
    IDE04617-Protective function Enabled 1
    IDE06425-Roller test bench mode: functional not activated 1
    IDE07903-Adaptation of ash mass 0.13 g 2
    IDE08287-Bleeding of coolant circuit not active 1
    IDE10309-Adaptation of oxidation catalytic converter ageing 6400 s 2
    ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping Not blocked 1
    ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor Not blocked 1
    Elapsed Time: 00:05
    09 Admap:
    ;SW:5Q0-937-086-BH HW:5Q0-937-086-BH --- Cent. Elect.
    ;Component:BCM PQ37BOSCH 032 0223 Coding:
    ;EV_BodyContrModul1UDSBosc 17002 EV_BCMBOSCH_017_VW27.rod
    ;Monday 1 May 2017 11:10:21:36443
    ;VCID: 014A40589087514F0F-8054
    IDE00001-ENG99061-Production mode-Access control not active 3
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
    IDE00001-ENG112304-Production mode-Heckwischer not active 3
    IDE00001-ENG98647-Production mode-Interior lighting not active 3
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
    IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
    IDE00002-Transport mode active 1
    IDE00820-Activating and deactivating all development messages not active 1
    IDE01550-Service position 157.999843 ° 2
    IDE02152-Characteristics in production mode 2000 ms 4
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 10
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 10
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn normal 10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte active 10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen not active 10
    IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl not active 10
    IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl not active 10
    IDE02269-ENG11176-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit 200 ms 10
    IDE02269-ENG11175-Acknowledgement signals-ZV-Blinken_Dunkelzeit 200 ms 10
    IDE02269-ENG11174-Acknowledgement signals-ZV-Blinken_Hellzeit 200 ms 10
    IDE02332-Deactivate production mode 0 3
    IDE02488-DWA Interior monitoring 100% 1
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen active 8
    IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen not active 8
    IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1 8 s 8
    IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2 16 s 8
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer logikgesteuert 8
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck not active 8
    IDE02711-ENG23759-Rear Window Wiper-Zeit_wasch_min_heck 0 ms 8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -0.3 ° 16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 26.5 %/s 16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt both sides 16
    IDE03638-ENG116675-static AFS light-Lower speed threshold 0.0 km/h 16
    IDE03638-ENG116682-static AFS light-Maximaltemperatur 1.0 °C 16
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur 127.5 °C 16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 55 ° 16
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur 127.0 °C 16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 30 ° 16
    IDE03638-ENG116676-static AFS light-Upper speed threshold 40.0 km/h 16
    IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 16
    IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht 17 min 16
    IDE03787-Activate left/right hand drive switch-over not active 1
    IDE04927-IDE01446-Window heater-Running time of heated front window 600 s 11
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.0 °C 11
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.0 °C 11
    IDE04927-ENG11179-Window heater-Frontscheibenheizung _maximale_Dauer 0 s 11
    IDE04927-ENG10963-Window heater-Frontscheibenheizung_LED_direkt not installed 11
    IDE04927-ENG10946-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus not installed 11
    IDE04927-ENG126845-Window heater-FSH Automatik active 11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 11
    IDE04927-ENG10883-Window heater-heizbare Heckscheibe installed 11
    IDE04927-ENG10949-Window heater-Heizbare_Frontscheibe installed 11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH not active 11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 11
    IDE04927-ENG10890-Window heater-Waschduesenheizung installed 11
    IDE04927-ENG23738-Window heater-window heating front activation time pause 240 s 11
    IDE04928-MAS01577-Anti-theft device-Parking heater not installed 8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 8
    IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 8
    IDE04928-ENG10888-Anti-theft device-Anti-theft alarm system active 8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 8
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 8
    IDE04928-ENG10935-Anti-theft device-DWA_Einfachhorn_oder_Sounder Sounder_verbaut 8
    IDE04928-ENG10889-Anti-theft device-Heckscheibenbruchsensor not installed 8
    IDE04928-ENG10934-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet Yes 8
    IDE04928-ENG11177-Anti-theft device-OBD Alarm activ 8
    IDE04928-ENG10937-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv) No 8
    IDE04928-ENG10938-Anti-theft device-Sensor_fuer_Innenraumueberwachung Yes 8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 8
    IDE04928-ENG10936-Anti-theft device-tilt_sensor Yes 8
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm 2 sekunden verzoegerung 8
    IDE05143-MAS02985-Writing parameter-Value 130 5
    IDE05143-MAS04381-Writing parameter-Parameter address FE 00 00 5
    IDE05144-Read parameter address FE 00 00 3
    IDE05145-Light configuration 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 38 00 24 12 16 64 1E 00 64 00 00 00 00 00 00 04 42 00 25 13 17 64 1E 00 64 00 00 00 00 00 00 01 42 00 23 13 17 7F 1E 00 7F 00 00 00 00 00 00 01 38 00 22 12 16 7F 1E 00 7F 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 0A 08 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 09 08 7F 00 00 00 00 00 00 29 45 00 1E 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 224
    IDE05822-DWA Vehicle inclination sensor 100% 1
    IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C6 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 65 63 57 9B 25 44 3F 3A 69 58 95 1F 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 53 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 53 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 52 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 65 53 57 9B 25 24 0C FA 0A 34 95 1F 09 A3 21 03 00 02 02 02 02 02 02 B1 40 E1 28 FE 172
    IDE06089-ENG10904-Seat heater level current consumption allocation-Sitzheitzung_CAN Heizmatten am BCM 30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 33.00 °C 30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 32.00 °C 30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 33.00 °C 30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 32.00 °C 30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 38.00 °C 30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 37.00 °C 30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 38.00 °C 30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 37.00 °C 30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 43.00 °C 30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 42.00 °C 30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 43.00 °C 30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 42.00 °C 30
    IDE06089-ENG10905-Seat heater level current consumption allocation-Sitzheizungsfreigabe not installed 30
    IDE06425-Roller test bench mode: functional not active 1
    IDE06507-MAS13125-Button in center console-Function of button 1 Start-stop 8
    IDE06507-MAS13129-Button in center console-Function of button 2 Offroad 8
    IDE06507-MAS13132-Button in center console-Function of button 3 Driving program 8
    IDE06507-MAS13135-Button in center console-Function of button 4 not coded/not installed 8
    IDE06507-ENG09171-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED LED installed 8
    IDE07007-ENG11181-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich not active 8
    IDE07007-ENG11180-A/C heater function via remote control-Abbruch_Hupen_RSt not active 8
    IDE07007-ENG11183-A/C heater function via remote control-Aktivierung_Drehzahlanzeige not active 8
    IDE07007-ENG11182-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik not active 8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt not active 8
    IDE07007-ENG115720-A/C heater function via remote control-Remotestart not installed 8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung not active 8
    IDE07356-Position during interval mode 21.999978 ° 2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein active 6
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 9
    IDE08786-ENG10884-Assistance light functions-Humidity sensor installed 9
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 9
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 9
    IDE08786-ENG11156-Assistance light functions-Maskierung_Regenfunktion not active 9
    IDE08786-ENG10913-Assistance light functions-Regen_Lichtsensor LIN_REGEN_LICHT_SENSOR 9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor not installed 9
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.40 s 19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 1 19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 4 19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 5 19
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 19
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 4 19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum 20% 19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer 30% 19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn 0% 19
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 19
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 19
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 19
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 19
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen active 19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen active 19
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen active 19
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 19
    IDE09731-ENG11161-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen not active 19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten not active 19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM not active 19
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 19
    IDE09731-ENG10959-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht not installed 19
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 19
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 19
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 19
    IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel not installed 19
    IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel not installed 19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 19
    IDE09731-ENG11112-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G not installed 19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel active 19
    IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI active 5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 5
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen active 5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus active 5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 5
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 5
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 5
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 5
    IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI not active 5
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 5
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 5
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 30% 17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 30% 17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 50% 17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 50% 17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 50% 17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 50% 17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 50% 17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 50% 17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 70% 17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 70% 17
    IDE09761-ENG10952-Seat fan charac. curve-Sitzlueftung installed 17
    IDE09761-ENG11111-Seat fan charac. curve-Sitzlueftung_reduzierbar installed 17
    IDE09761-ENG10953-Seat fan charac. curve-Sitzpneumatik not installed 17
    IDE10298-Alternating park position 1 0.000000 ° 2
    IDE10299-Alternating park position 2 18.296685 ° 2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit 1 256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach 0 256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum 1 256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel 0 256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher 1 256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko 1 256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd 1 256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer 0.37 256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI 11 256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2 110000 256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3 0 256
    IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4 0 256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0 256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 1100 256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3 0 256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4 0 256
    IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab 1 256
    IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf 1 256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 11001 256
    IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay 0 256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit 100% 256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach 0% 256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum 100% 256
    IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht 100% 256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel 0% 256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher 100% 256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko 100% 256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd 100% 256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren 100% 256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit 100% 256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach 0% 256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum 100% 256
    IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht 100% 256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel 0% 256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher 100% 256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko 100% 256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd 100% 256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren 100% 256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit 100% 256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach 0% 256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum 100% 256
    IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht 100% 256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel 0% 256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher 100% 256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko 100% 256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd 100% 256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren 100% 256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit 100% 256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach 0% 256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum 100% 256
    IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht 100% 256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel 0% 256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher 100% 256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko 100% 256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd 100% 256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren 100% 256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit 100% 256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach 0% 256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum 100% 256
    IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht 100% 256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel 0% 256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher 100% 256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko 100% 256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd 100% 256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren 100% 256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit 100% 256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach 0% 256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum 0% 256
    IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht 100% 256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel 0% 256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher 100% 256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko 100% 256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd 100% 256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren 0% 256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit 100% 256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach 0% 256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum 40% 256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht 10% 256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel 0% 256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher 100% 256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko 100% 256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd 100% 256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren 37% 256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit 100% 256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach 0% 256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum 127% 256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht 127% 256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel 0% 256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher 100% 256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko 100% 256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd 100% 256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren 127% 256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit 126% 256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach 0% 256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum 125% 256
    IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht 0% 256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel 0% 256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher 126% 256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko 126% 256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd 126% 256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren 125% 256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit 100% 256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach 0% 256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum 127% 256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht 127% 256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel 0% 256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher 100% 256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko 100% 256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd 100% 256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren 127% 256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit 100% 256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach 0% 256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum 125% 256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht 127% 256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel 0% 256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher 100% 256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko 100% 256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd 100% 256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren 125% 256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit 100% 256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach 0% 256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum 100% 256
    IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht 100% 256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel 0% 256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher 100% 256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko 100% 256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd 100% 256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren 100% 256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit 100% 256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach 0% 256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum 40% 256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht 10% 256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel 0% 256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher 100% 256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko 100% 256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd 100% 256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren 37% 256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit 100% 256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach 0% 256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum 40% 256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht 10% 256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel 0% 256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher 100% 256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko 100% 256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd 100% 256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren 37% 256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit 100% 256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach 0% 256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum 40% 256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht 10% 256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel 0% 256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher 100% 256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko 100% 256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd 100% 256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren 37% 256
    IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte 0 ms 256
    IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit 0.0 s 256
    IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach 0.0 s 256
    IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum 0.0 s 256
    IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht 0.0 s 256
    IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko 0.0 s 256
    IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren 0.0 s 256
    IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit 0.0 s 256
    IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach 0.0 s 256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum 1.0 s 256
    IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht 0.0 s 256
    IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko 0.0 s 256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren 0.0 s 256
    IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit 0.0 s 256
    IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach 0.0 s 256
    IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum 0.0 s 256
    IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht 0.0 s 256
    IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko 0.0 s 256
    IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren 0.0 s 256
    IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit 0.0 s 256
    IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach 0.0 s 256
    IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum 0.0 s 256
    IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht 0.0 s 256
    IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko 0.0 s 256
    IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren 0.0 s 256
    IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit 0.0 s 256
    IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach 0.0 s 256
    IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum 0.0 s 256
    IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht 0.0 s 256
    IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko 0.0 s 256
    IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren 0.0 s 256
    IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit 0.0 s 256
    IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach 0.0 s 256
    IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum 0.0 s 256
    IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht 0.0 s 256
    IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko 0.0 s 256
    IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren 0.0 s 256
    IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit 0.0 s 256
    IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach 0.0 s 256
    IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum 0.0 s 256
    IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht 0.0 s 256
    IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko 0.0 s 256
    IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren 0.0 s 256
    IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen 0 256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1 71 30
    IDE11714-ENG02360-Ambient light color list-Blauwert Farbe 10 0 30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2 0 30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3 6 30
    IDE11714-ENG02342-Ambient light color list-Blauwert Farbe 4 2 30
    IDE11714-ENG02345-Ambient light color list-Blauwert Farbe 5 106 30
    IDE11714-ENG02348-Ambient light color list-Blauwert Farbe 6 182 30
    IDE11714-ENG02351-Ambient light color list-Blauwert Farbe 7 254 30
    IDE11714-ENG02354-Ambient light color list-Blauwert Farbe 8 153 30
    IDE11714-ENG02357-Ambient light color list-Blauwert Farbe 9 4 30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1 231 30
    IDE11714-ENG02359-Ambient light color list-Gruenwert Farbe 10 132 30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2 200 30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3 73 30
    IDE11714-ENG02341-Ambient light color list-Gruenwert Farbe 4 9 30
    IDE11714-ENG02344-Ambient light color list-Gruenwert Farbe 5 134 30
    IDE11714-ENG02347-Ambient light color list-Gruenwert Farbe 6 140 30
    IDE11714-ENG02350-Ambient light color list-Gruenwert Farbe 7 110 30
    IDE11714-ENG02353-Ambient light color list-Gruenwert Farbe 8 255 30
    IDE11714-ENG02356-Ambient light color list-Gruenwert Farbe 9 245 30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1 120 30
    IDE11714-ENG02358-Ambient light color list-Rotwert Farbe 10 57 30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2 255 30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3 173 30
    IDE11714-ENG02340-Ambient light color list-Rotwert Farbe 4 255 30
    IDE11714-ENG02343-Ambient light color list-Rotwert Farbe 5 255 30
    IDE11714-ENG02346-Ambient light color list-Rotwert Farbe 6 106 30
    IDE11714-ENG02349-Ambient light color list-Rotwert Farbe 7 0 30
    IDE11714-ENG02352-Ambient light color list-Rotwert Farbe 8 29 30
    IDE11714-ENG02355-Ambient light color list-Rotwert Farbe 9 58 30
    IDE11944-ENG10942-Keyless access and start authorization-Elektische_Lenkradverriegelung installed 3
    IDE11944-ENG10876-Keyless access and start authorization-Kessy installed 3
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen not active 3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen active 3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung active 3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung active 3
    MAS01490-ENG10955-Energy management-Energiemanagement Abschaltung active 5
    MAS01490-ENG116830-Energy management-Energy_Management_Adaptation Energy management active 5
    MAS01490-ENG11184-Energy management-Hochvoltfahrzeug not installed 5
    MAS01490-ENG10878-Energy management-Hybrid vehicle No 5
    MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement not active 5
    MAS01490-ENG10906-Energy management-Recuperation active 5
    MAS01490-ENG10965-Energy management-Zweitbatterie not installed 5
    MAS05055-lower turn position 20.692287 ° 2
    MAS05056-upper turn position 159.999841 ° 2
    MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 1200 lx 24
    MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 2200 lx 24
    MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle 59395 lx 24
    MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO 600 lx 24
    MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten 1200 lx 24
    MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten 2200 lx 24
    MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 50 00 24
    MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell 2000 lx 24
    MAS08228-ENG11158-Light sensor-HMI_Exterior_light_on_highway not active 24
    MAS08228-ENG11159-Light sensor-HMI_Exterior_light_on_rain not active 24
    MAS08228-ENG11160-Light sensor-HMI_exterior_light_sensitivity frueh 24
    MAS08228-ENG11157-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF not active 24
    MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe not active 24
    MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung 37905 mV 24
    MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke 225300 lx 24
    MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung 53255 mV 24
    MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke 0 lx 24
    MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung 2 24
    ENG10611-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren active 4
    ENG10611-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT active 4
    ENG10611-ENG10903-Allwetterlicht_Spoiler-tt_spoiler not installed 4
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 multicolor 30
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 multicolor 30
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 1 60
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 2 60
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 3 60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 4 60
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 5 60
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 6 60
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 7 60
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 8 60
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 4 60
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 5 60
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 8 60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 9 60
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 12 60
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 13 60
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 16 60
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 17 60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 installed 60
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 installed 60
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 installed 60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 installed 60
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 installed 60
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 installed 60
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 installed 60
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 installed 60
    ENG10577-ENG122212-Außenlicht_Blinker-ABBA_Blinken not active 10
    ENG10577-ENG02307-Außenlicht_Blinker-Abbruch Komfortblinken active 10
    ENG10577-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger separte 10
    ENG10577-ENG121966-Außenlicht_Blinker-Crash flashing not active 10
    ENG10577-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken not active 10
    ENG10577-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung not active 10
    ENG10577-ENG11122-Außenlicht_Blinker-dynamisch_blinken_10 not active 10
    ENG10577-ENG11123-Außenlicht_Blinker-Dynamische_Blink_Delay 50 ms 10
    ENG10577-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken not active 10
    ENG10577-ENG115774-Außenlicht_Blinker-Komfortblinken active 10
    ENG10577-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen 3 10
    ENG10577-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken not active 10
    ENG10577-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2 not active 10
    ENG10577-ENG121967-Außenlicht_Blinker-Panic flashing not active 10
    ENG10577-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links not active 10
    ENG10577-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts not active 10
    ENG10577-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken not active 10
    ENG10577-ENG121968-Außenlicht_Blinker-Taxi alarm flashing not active 10
    ENG10577-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 10
    ENG10577-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken not active 10
    ENG10577-ENG10957-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz active 10
    ENG10577-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS not active 10
    ENG10577-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN not active 10
    ENG10577-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf not active 10
    ENG10577-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu not active 10
    ENG10575-ENG10914-Außenlicht_Front-Abblendlicht_Leuchtentyp H7 9
    ENG10575-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze 50 km/h 9
    ENG10575-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze 50 km/h 9
    ENG10575-ENG115833-Außenlicht_Front-Fahrlicht bei Tag Daytime running lights 9
    ENG10575-ENG11121-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL 5 km/h 9
    ENG10575-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich active 9
    ENG10575-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 9
    ENG10575-ENG11119-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument not active 9
    ENG10575-ENG11118-Außenlicht_Front-Signaturlicht_verbaut not installed 9
    ENG10575-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht active 9
    ENG10575-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 9
    ENG10575-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 9
    ENG10575-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO not active 9
    ENG10575-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 9
    ENG10575-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte not active 9
    ENG10575-ENG11120-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit not active 9
    ENG10575-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 9
    ENG10575-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 9
    ENG10576-ENG10915-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht No 5
    ENG10576-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit 0 km/h 5
    ENG10576-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA active 5
    ENG10576-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion not active 5
    ENG10576-ENG10932-Aussenlicht_Heck-Umgreifende_Heckklappe not installed 5
    ENG10584-ENG10948-Außenlicht_uebergreifend-All-weather lights not installed 18
    ENG10584-ENG02309-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung abschaltbar über Energiemanagement 18
    ENG10584-ENG02308-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung abschaltbar über Energiemanagement 18
    ENG10584-ENG11116-Außenlicht_uebergreifend-bewusstes Standlicht Aktive Begrenzung 18
    ENG10584-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten Low beam 18
    ENG10584-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus automatic 18
    ENG10584-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis Driver door 18
    ENG10584-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach not active 18
    ENG10584-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 18
    ENG10584-ENG02310-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer Faktor fuer x5 Minuten 18
    ENG10584-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung 46400 lx 18
    ENG10584-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung 12 lx 18
    ENG10584-ENG11117-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige No 18
    ENG10584-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 18
    ENG10584-ENG11113-Außenlicht_uebergreifend-LCM_blinker false 18
    ENG10584-ENG10920-Außenlicht_uebergreifend-LDS_mit_AFL Yes 18
    ENG10584-ENG10919-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht Yes 18
    ENG10584-ENG10918-Außenlicht_uebergreifend-LDS_mit_Nebellicht Yes 18
    ENG10584-ENG10921-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung Yes 18
    ENG10584-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus Enabled 18
    ENG10584-ENG10917-Außenlicht_uebergreifend-Lichtdrehschalter (LDS) discrete 18
    ENG10584-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten klemmenabhaengig 18
    ENG10584-ENG10962-Außenlicht_uebergreifend-Light_Control_Module installed 18
    ENG10584-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 18
    ENG10584-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome 10 seconds 18
    ENG10584-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 18
    ENG10584-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung active 18
    ENG10584-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP active 18
    ENG10584-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert One-sided 18
    ENG10584-ENG126816-Außenlicht_uebergreifend-Standlicht aus active 18
    ENG10584-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht active 18
    ENG10584-ENG02311-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit 24 s 18
    ENG10584-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte not active 18
    ENG126647-ENG98399-debug_light_function-Activation 0 11
    ENG126647-ENG101417-debug_light_function-Adresse 0 11
    ENG126647-ENG126820-debug_light_function-Bitmask 0 11
    ENG126647-ENG126821-debug_light_function-Divisor 0 11
    ENG126647-ENG98827-debug_light_function-Offset 0 11
    ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
    ENG10603-ENG115658-Dimmunt_KL_58xs_PWM-x0 0.00% 6
    ENG10603-ENG101574-Dimmunt_KL_58xs_PWM-X1 50.00% 6
    ENG10603-ENG99557-Dimmunt_KL_58xs_PWM-X2 100.00% 6
    ENG10603-ENG115659-Dimmunt_KL_58xs_PWM-y0 0.00% 6
    ENG10603-ENG99777-Dimmunt_KL_58xs_PWM-Y1 50.00% 6
    ENG10603-ENG100480-Dimmunt_KL_58xs_PWM-Y2 100.00% 6
    ENG10578-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP present 6
    ENG10578-ENG10901-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung AFS: FLA: Fernlicht ueber AFS 6
    ENG10578-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset active 6
    ENG10578-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent present 6
    ENG10578-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung present 6
    ENG10610-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA not active 6
    ENG10610-ENG11178-Front_wiper-Anfahrzeit_servicestellung 800 ms 6
    ENG10610-ENG115836-Front_wiper-Frontwischer Notlaufprogramm active 6
    ENG10610-ENG116614-Front_wiper-Frontwischer Referenzlauf active 6
    ENG10610-ENG02322-Front_wiper-Frontwischer_Abtauposition not active 6
    ENG10610-ENG10894-Front_wiper-Frontwischertyp LIN 6
    ENG10610-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 6
    ENG10610-ENG116615-Front_wiper-Menuesteuerung Frontwischer not active 6
    ENG10610-ENG23634-Front_wiper-Mindestwaschzeit_Frontwischer 0 ms 6
    ENG10610-ENG115771-Front_wiper-Regensensor aktivieren Deactivating 6
    ENG10610-ENG23718-Front_wiper-Timer_DWP_SRA_delay 0 ms 6
    ENG10610-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz active 6
    ENG10610-ENG116618-Front_wiper-Traenenwischen Front Status not active 6
    ENG10610-ENG115770-Front_wiper-Variable Regensensoraktivierung active 6
    ENG10610-ENG126844-Front_wiper-Washer_Tipwiping_Variant not active 6
    ENG10610-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube not active 6
    ENG10610-ENG116612-Front_wiper-Wischer stop bei KL15 aus active 6
    ENG10610-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 6
    ENG99457-ENG117394-Head area heater-blower_speed 1 2
    ENG99457-ENG98971-Head area heater-Temperature -2 2
    ENG10573-MAS00211-HW_Verbau-Insufficient brake fluid installed 8
    ENG10573-MAS00212-HW_Verbau-Insufficient washer fluid installed 8
    ENG10573-MAS00213-HW_Verbau-Insufficient coolant installed 8
    ENG10573-MAS00214-HW_Verbau-Brake pad wear installed 8
    ENG10573-ENG10954-HW_Verbau-Druckklappe not installed 8
    ENG10573-ENG10891-HW_Verbau-Elektrische Laderaumabdeckung aktiv not active 8
    ENG10573-ENG10940-HW_Verbau-Elektrische_Laderaumabdeckung not installed 8
    ENG10573-ENG10880-HW_Verbau-Exterior temp. sensor installed 8
    ENG10573-ENG10933-HW_Verbau-Kontaktschalter_fuer_Motorhaube installed 8
    ENG10573-ENG11114-HW_Verbau-Ladesteckerverriegelung not installed 8
    ENG10573-ENG10964-HW_Verbau-PTC Zuheizer not installed 8
    ENG10573-ENG115809-HW_Verbau-Signalhorn ohne KL15 active 8
    ENG10573-ENG10931-HW_Verbau-Status_Tankdeckelverriegelung not active 8
    ENG10588-ENG115658-Kennlinie_sLWR_Soll-x0 -100.00% 30
    ENG10588-ENG101574-Kennlinie_sLWR_Soll-X1 -100.00% 30
    ENG10588-ENG99557-Kennlinie_sLWR_Soll-X2 -100.00% 30
    ENG10588-ENG102140-Kennlinie_sLWR_Soll-X3 -100.00% 30
    ENG10588-ENG102936-Kennlinie_sLWR_Soll-X4 -100.00% 30
    ENG10588-ENG103548-Kennlinie_sLWR_Soll-X5 -100.00% 30
    ENG10588-ENG113992-Kennlinie_sLWR_Soll-X6 -100.00% 30
    ENG10588-ENG115661-Kennlinie_sLWR_Soll-x7 -100 30
    ENG10588-ENG115662-Kennlinie_sLWR_Soll-x8 -100.00% 30
    ENG10588-ENG115663-Kennlinie_sLWR_Soll-x9 -100.00% 30
    ENG10588-ENG115659-Kennlinie_sLWR_Soll-y0 0.00% 30
    ENG10588-ENG99777-Kennlinie_sLWR_Soll-Y1 0.00% 30
    ENG10588-ENG100480-Kennlinie_sLWR_Soll-Y2 0.00% 30
    ENG10588-ENG100773-Kennlinie_sLWR_Soll-Y3 0.00% 30
    ENG10588-ENG100631-Kennlinie_sLWR_Soll-Y4 0.00% 30
    ENG10588-ENG102174-Kennlinie_sLWR_Soll-Y5 0.00% 30
    ENG10588-ENG113993-Kennlinie_sLWR_Soll-Y6 0.00% 30
    ENG10588-ENG115665-Kennlinie_sLWR_Soll-y7 0.00% 30
    ENG10588-ENG115666-Kennlinie_sLWR_Soll-y8 0.00% 30
    ENG10588-ENG115667-Kennlinie_sLWR_Soll-y9 0.00% 30
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 0 16
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 0 16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 0 16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 not active 16
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 not active 16
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
    ENG10585-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15 maximize 16
    ENG10585-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15 maximize 16
    ENG10585-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15 maximize 16
    ENG10585-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15 100 16
    ENG10585-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15 0 16
    ENG10585-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15 0 16
    ENG10585-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15 0 16
    ENG10585-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15 0 16
    ENG10585-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15 0 16
    ENG10585-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15 36 - LED Kleinleistung 16
    ENG10585-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15 Always 16
    ENG10585-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15 not active 16
    ENG10585-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15 not active 16
    ENG10585-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15 not active 16
    ENG10585-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15 not active 16
    ENG10585-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15 not active 16
    ENG10585-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15 not active 16
    ENG10585-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15 not active 16
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 45 16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 41 - LED Kleinleistung 16
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Versorgungsbedarf der LCM Module 16
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 not active 16
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 0 16
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 0 16
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 0 16
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 not active 16
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 not active 16
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 not active 16
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 0 16
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 0 16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 0 16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 not active 16
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 not active 16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 0 16
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 0 16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 0 16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 not active 16
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 not active 16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 127 16
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 27 16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 3F 16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 43 - allgemeine LED 16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always 16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 Parking light right 16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 127 16
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 26 16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 35 16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 43 - allgemeine LED 16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always 16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 127 16
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 127 16
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 0 16
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 0 16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 0 16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 not active 16
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 not active 16
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 127 16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 0 16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 2B 16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 9 16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 not active 16
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 not active 16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 127 16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 0 16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 2D 16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 19 16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten 16
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 not active 16
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 not active 16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 32 16
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 34 - LED Bremsleuchten 16
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 Quittierungsfunktion 1 16
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 127 16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 0 16
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29 16
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 43 - allgemeine LED 16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 not active 16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active 16
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 127 16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 0 16
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A 16
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 43 - allgemeine LED 16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 Parking light right 16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 not active 16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active 16
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 127 16
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 43 - allgemeine LED 16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt 16
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 0 16
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 0 16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 0 16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 not active 16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always 16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 not active 16
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 127 16
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 43 - allgemeine LED 16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 127 16
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 43 - allgemeine LED 16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 100 16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 24 16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 38 16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Nebellicht links 16
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 Abbiegelicht links 16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Coming Home oder Leaving Home aktiv 16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active 16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 100 16
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 3 16
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 Ambientelicht 1 16
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 4 16
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 Ambientelicht 2 16
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 5 16
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 Ambientelicht 3 16
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 6 16
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 Ambientelicht 4 16
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 100 16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 25 16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 42 16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Nebellicht rechts 16
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 Abbiegelicht rechts 16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Coming Home oder Leaving Home aktiv 16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active 16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 23 16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 42 16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Nebellicht rechts 16
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 Abbiegelicht rechts 16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Coming Home oder Leaving Home aktiv 16
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active 16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 22 16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 38 16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Nebellicht links 16
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 Abbiegelicht links 16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Coming Home oder Leaving Home aktiv 16
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active 16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 5 - LED Abblendlicht 16
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 5 - LED Abblendlicht 16
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 127 16
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 4B 16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 44 16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 5 - LED Abblendlicht 16
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Versorgungsbedarf der LCM Module 16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 not active 16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 Parking light right 16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 127 16
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 49 16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3A 16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 5 - LED Abblendlicht 16
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Versorgungsbedarf der LCM Module 16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 not active 16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
    ENG10589-Leuchtenkonfiguration_Aussenlich_Heck 26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 24 00 20 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1C 00 2F 1A 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 192
    ENG10590-Leuchtenkonfiguration_Sonstiges 2B 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00 128
    ENG10586-ENG11125-Leuchtweitenregulierung-1_Sensor_LWR 1-Sensor_LWR 62
    ENG10586-ENG11147-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges 2700 mm 62
    ENG10586-ENG11146-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4 5.00 mm/% 62
    ENG10586-ENG11145-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn 3.00 mm/% 62
    ENG10586-ENG11129-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe not active 62
    ENG10586-ENG11139-Leuchtweitenregulierung-Ansteuerung_obere_grenze 100.00% 62
    ENG10586-ENG11138-Leuchtweitenregulierung-Ansteuerung_untere_grenze 0.00% 62
    ENG10586-ENG11137-Leuchtweitenregulierung-diagnose_soll_toleranz 15% 62
    ENG10586-ENG11131-Leuchtweitenregulierung-Entprellung_Fehlerlampe 10.0 s 62
    ENG10586-ENG11142-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1 5.00 mm/% 62
    ENG10586-ENG11144-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2 5.00 mm/% 62
    ENG10586-ENG11141-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1 3.00 mm/% 62
    ENG10586-ENG11143-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2 3.00 mm/% 62
    ENG10586-ENG11126-Leuchtweitenregulierung-Fahrwerk_Variante Verbundlenkerhinterachse 62
    ENG10586-ENG11132-Leuchtweitenregulierung-Fail_Safe_sLWR 0.00% 62
    ENG10586-ENG11151-Leuchtweitenregulierung-fFiltEinf 0.03 Hz 62
    ENG10586-ENG11140-Leuchtweitenregulierung-Lineare_Abbildung 0 62
    ENG10586-ENG11130-Leuchtweitenregulierung-Logik_PWM_Signal Negative 62
    ENG10586-ENG23630-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1 0 mm 62
    ENG10586-ENG23631-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2 0 mm 62
    ENG10586-ENG23632-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3 0 mm 62
    ENG10586-ENG23633-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4 0 mm 62
    ENG10586-ENG11148-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand 550 mm 62
    ENG10586-ENG11149-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe 680 mm 62
    ENG10586-ENG11154-Leuchtweitenregulierung-lwr_pwm_obere_schwelle 95.00% 62
    ENG10586-ENG11153-Leuchtweitenregulierung-lwr_pwm_untere_schwelle 5.00% 62
    ENG10586-ENG11155-Leuchtweitenregulierung-max_v_slwr 255 km/h 62
    ENG10586-ENG11150-Leuchtweitenregulierung-pa_fDynFiltStatLwr 100 Hz 62
    ENG10586-ENG11152-Leuchtweitenregulierung-pa_fFiltSwNeigung 0.03 Hz 62
    ENG10586-ENG11128-Leuchtweitenregulierung-Quelle_Hoehenwerte BCM 62
    ENG10586-ENG10970-Leuchtweitenregulierung-sensor_headlight_range_control_installed not installed 62
    ENG10586-ENG11127-Leuchtweitenregulierung-sLWR_bei_Abblendlicht active 62
    ENG10586-ENG11136-Leuchtweitenregulierung-sLWR_Hysterese 0.00% 62
    ENG10586-ENG23704-Leuchtweitenregulierung-sLWR_nach_Motorstart not active 62
    ENG10586-ENG11135-Leuchtweitenregulierung-sLWR_SW_Grad 1000.0 %/s 62
    ENG10586-ENG11134-Leuchtweitenregulierung-sLWR_Touristenlicht 0.00% 62
    ENG10586-ENG11124-Leuchtweitenregulierung-sLWR_verbaut not installed 62
    ENG10586-ENG11133-Leuchtweitenregulierung-Zyklus_sLWR 0.00 s 62
    ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1 not active 1
    ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2 not active 1
    ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 not active 1
    ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4 not active 1
    ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5 not active 1
    ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6 not active 1
    ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ not active 1
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
    ENG10587-ENG115658-lwr_ofs_RSw_Ah1S-x0 -3.71% 20
    ENG10587-ENG101574-lwr_ofs_RSw_Ah1S-X1 -2.96% 20
    ENG10587-ENG99557-lwr_ofs_RSw_Ah1S-X2 -2.04% 20
    ENG10587-ENG102140-lwr_ofs_RSw_Ah1S-X3 -1.48% 20
    ENG10587-ENG102936-lwr_ofs_RSw_Ah1S-X4 -0.37% 20
    ENG10587-ENG115659-lwr_ofs_RSw_Ah1S-y0 -0.2 20
    ENG10587-ENG99777-lwr_ofs_RSw_Ah1S-Y1 -0.1 20
    ENG10587-ENG100480-lwr_ofs_RSw_Ah1S-Y2 -0.05 20
    ENG10587-ENG100773-lwr_ofs_RSw_Ah1S-Y3 -0.01 20
    ENG10587-ENG100631-lwr_ofs_RSw_Ah1S-Y4 0 20
    ENG124714-ENG10972-OCU-DWA_push active 8
    ENG124714-ENG11188-OCU-Honk DWA_Ausgabe_Fanfare active 8
    ENG124714-ENG124714-OCU- installed 8
    ENG124714-ENG11189-OCU-Remote HuF Abbruch 20 km/h 8
    ENG124714-ENG11190-OCU-Remote HuF Hupfrequenz 3 8
    ENG124714-ENG02319-OCU-Remote Lock Unlock Timer s1 80 s 8
    ENG124714-ENG02320-OCU-Remote Lock Unlock Timer s3 20.0 ms 8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock Via BAP / Fazit 8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar active 16
    ENG98831-ENG02329-Personalization-Anzahl_Benutzerkonten 4 16
    ENG98831-ENG02330-Personalization-Automatische_ Schluesselzuordnung not active 16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar active 16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv active 16
    ENG98831-ENG10922-Personalization-Personalisierung_Profilfunkion profiles_active 16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar active 16
    ENG98831-ENG10958-Personalization-Profil_Variante Konto (v. 1.x) 16
    ENG98831-ENG02332-Personalization-PSO_FSG_Setup2_Bit_1 active 16
    ENG98831-ENG02333-Personalization-PSO_FSG_Setup2_Bit_2 active 16
    ENG98831-ENG02334-Personalization-PSO_FSG_Setup2_Bit_3 active 16
    ENG98831-ENG02335-Personalization-PSO_FSG_Setup2_Bit_4 not active 16
    ENG10574-MAS01065-Querschnitts_funktionen-Brand VW 5
    ENG10574-ENG10908-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll active 5
    ENG10574-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung active 5
    ENG10574-ENG10895-Querschnitts_funktionen-Codierungsabsicherung not active 5
    ENG10574-ENG10956-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21 not active 5
    ENG10574-ENG11115-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus Pin 31 5
    ENG10574-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben active 5
    ENG10574-ENG10892-Querschnitts_funktionen-Lenkungsanordnung Right 5
    ENG10574-ENG10943-Querschnitts_funktionen-Personalisierungsuebernahme not_installed 5
    ENG10574-ENG10911-Querschnitts_funktionen-Schnittstelle_TrackingSystem not active 5
    ENG10574-ENG10893-Querschnitts_funktionen-Verkehrsseite Left 5
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 10
    ENG115729-ENG10877-Scheinwerferreinigung-Headlamp washer system installed 10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel active 10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit 2000 ms 10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit 800 ms 10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit 0 ms 10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit 0 ms 10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit 600 ms 10
    ENG10612-SFT09729-Slave_systems_identification-Control Unit For Wiper Motor Not available 6
    ENG10612-SFT09730-Slave_systems_identification-Rain Light Recognition Sensor Not available 6
    ENG10612-SFT09731-Slave_systems_identification-Light switch Not available 6
    ENG10612-SFT09732-Slave_systems_identification-Garage door opener control module Not available 6
    ENG10612-SFT09733-Slave_systems_identification-Garage Door Opener Operating Unit Not available 6
    ENG10612-SFT09750-Slave_systems_identification-Sensor For Anti Theft Alarm System Not available 6
    ENG10612-SFT09752-Slave_systems_identification-Alarm horn Not available 6
    ENG10612-SFT09760-Slave_systems_identification-Sun Roof Not available 6
    ENG10612-SFT09766-Slave_systems_identification-Ceiling Light Module Not available 6
    ENG10612-SFT09784-Slave_systems_identification-Roof Blind Not available 6
    ENG10612-SFT09803-Slave_systems_identification-Relative Air Humidity Interior Sender Not available 6
    ENG10612-SFT09822-Slave_systems_identification-Neck Heating Left Not available 6
    ENG10612-SFT09823-Slave_systems_identification-Neck Heating Right Not available 6
    ENG10612-SFT09921-Slave_systems_identification-Seat Backrest Fan 1 Front Left Not available 6
    ENG10612-SFT09923-Slave_systems_identification-Seat Cushion Fan 1 Front Left Not available 6
    ENG10612-SFT09925-Slave_systems_identification-Seat Backrest Fan 1 Front Right Not available 6
    ENG10612-SFT09927-Slave_systems_identification-Seat Cushion Fan 1 Front Right Not available 6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker SMLS 4
    ENG116588-ENG116588-Sonderfunktionen- not enabled 4
    ENG116588-ENG10907-Sonderfunktionen-Sonderfunktionen 1 not installed 4
    ENG10563-ENG116658-Spiegelverstellung-Funk Spiegelanklappen active 5
    ENG10563-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus by look command via remote control key 5
    ENG10563-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen active 5
    ENG10563-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung active 5
    ENG10563-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung active 5
    ENG10563-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel not active 5
    ENG10563-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung active 5
    ENG10563-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt active 5
    ENG10563-ENG02339-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung active 5
    ENG10563-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron active 5
    ENG10606-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0 0.0 lx 10
    ENG10606-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1 8.0 lx 10
    ENG10606-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2 50.0 lx 10
    ENG10606-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3 80.0 lx 10
    ENG10606-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4 100.0 lx 10
    ENG10606-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0 6 10
    ENG10606-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1 6 10
    ENG10606-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2 20 10
    ENG10606-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3 50 10
    ENG10606-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4 100 10
    ENG10607-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0 0.0 lx 10
    ENG10607-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1 8.0 lx 10
    ENG10607-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2 50.0 lx 10
    ENG10607-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3 80.0 lx 10
    ENG10607-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4 100.0 lx 10
    ENG10607-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0 6 10
    ENG10607-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1 6 10
    ENG10607-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2 20 10
    ENG10607-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3 50 10
    ENG10607-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4 100 10
    ENG10594-ENG115658-Suchbeleuchtung_Abdimmen-x0 0 ms 22
    ENG10594-ENG101574-Suchbeleuchtung_Abdimmen-X1 200 ms 22
    ENG10594-ENG115664-Suchbeleuchtung_Abdimmen-x10 2000 ms 22
    ENG10594-ENG99557-Suchbeleuchtung_Abdimmen-X2 400 ms 22
    ENG10594-ENG102140-Suchbeleuchtung_Abdimmen-X3 600 ms 22
    ENG10594-ENG102936-Suchbeleuchtung_Abdimmen-X4 800 ms 22
    ENG10594-ENG103548-Suchbeleuchtung_Abdimmen-X5 1000 ms 22
    ENG10594-ENG113992-Suchbeleuchtung_Abdimmen-X6 1200 ms 22
    ENG10594-ENG115661-Suchbeleuchtung_Abdimmen-x7 1400 ms 22
    ENG10594-ENG115662-Suchbeleuchtung_Abdimmen-x8 1600 ms 22
    ENG10594-ENG115663-Suchbeleuchtung_Abdimmen-x9 1800 ms 22
    ENG10594-ENG115659-Suchbeleuchtung_Abdimmen-y0 100.00% 22
    ENG10594-ENG99777-Suchbeleuchtung_Abdimmen-Y1 72.00% 22
    ENG10594-ENG115668-Suchbeleuchtung_Abdimmen-y10 0.00% 22
    ENG10594-ENG100480-Suchbeleuchtung_Abdimmen-Y2 48.00% 22
    ENG10594-ENG100773-Suchbeleuchtung_Abdimmen-Y3 33.00% 22
    ENG10594-ENG100631-Suchbeleuchtung_Abdimmen-Y4 18.00% 22
    ENG10594-ENG102174-Suchbeleuchtung_Abdimmen-Y5 12.00% 22
    ENG10594-ENG113993-Suchbeleuchtung_Abdimmen-Y6 8.00% 22
    ENG10594-ENG115665-Suchbeleuchtung_Abdimmen-y7 6.00% 22
    ENG10594-ENG115666-Suchbeleuchtung_Abdimmen-y8 4.00% 22
    ENG10594-ENG115667-Suchbeleuchtung_Abdimmen-y9 2.00% 22
    ENG10591-ENG11168-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM 0.00 s 21
    ENG10591-ENG11164-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM 0.00 s 21
    ENG10591-ENG11166-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM 0.00 s 21
    ENG10591-ENG11167-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM 0.00 s 21
    ENG10591-ENG11165-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM 0.00 s 21
    ENG10591-ENG10916-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung HMI 21
    ENG10591-ENG11170-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen 0.0 s 21
    ENG10591-ENG11169-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen 0.0 s 21
    ENG10591-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe not active 21
    ENG10591-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten not_active 21
    ENG10591-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung active 21
    ENG10591-ENG11171-Suchbeleuchtung_allgemein-pa_Hysterese_RLS 0 21
    ENG10591-ENG11163-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM 0.00 s 21
    ENG10591-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert 100% 21
    ENG10591-ENG11162-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl Fotosensor_Kombi 21
    ENG10591-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung Always active 21
    ENG10591-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor 0.1 21
    ENG10591-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert 20.00% 21
    ENG10595-ENG115658-Suchbeleuchtung_Fotosensor-x0 0 22
    ENG10595-ENG101574-Suchbeleuchtung_Fotosensor-X1 50 22
    ENG10595-ENG115664-Suchbeleuchtung_Fotosensor-x10 0 22
    ENG10595-ENG99557-Suchbeleuchtung_Fotosensor-X2 100 22
    ENG10595-ENG102140-Suchbeleuchtung_Fotosensor-X3 200 22
    ENG10595-ENG102936-Suchbeleuchtung_Fotosensor-X4 253 22
    ENG10595-ENG103548-Suchbeleuchtung_Fotosensor-X5 0 22
    ENG10595-ENG113992-Suchbeleuchtung_Fotosensor-X6 0 22
    ENG10595-ENG115661-Suchbeleuchtung_Fotosensor-x7 0 22
    ENG10595-ENG115662-Suchbeleuchtung_Fotosensor-x8 0 22
    ENG10595-ENG115663-Suchbeleuchtung_Fotosensor-x9 0 22
    ENG10595-ENG115659-Suchbeleuchtung_Fotosensor-y0 0 lx 22
    ENG10595-ENG99777-Suchbeleuchtung_Fotosensor-Y1 50 lx 22
    ENG10595-ENG115668-Suchbeleuchtung_Fotosensor-y10 0 lx 22
    ENG10595-ENG100480-Suchbeleuchtung_Fotosensor-Y2 100 lx 22
    ENG10595-ENG100773-Suchbeleuchtung_Fotosensor-Y3 200 22
    ENG10595-ENG100631-Suchbeleuchtung_Fotosensor-Y4 500 22
    ENG10595-ENG102174-Suchbeleuchtung_Fotosensor-Y5 0 22
    ENG10595-ENG113993-Suchbeleuchtung_Fotosensor-Y6 0 lx 22
    ENG10595-ENG115665-Suchbeleuchtung_Fotosensor-y7 0 lx 22
    ENG10595-ENG115666-Suchbeleuchtung_Fotosensor-y8 0 lx 22
    ENG10595-ENG115667-Suchbeleuchtung_Fotosensor-y9 0 lx 22
    ENG10593-ENG115658-Suchbeleuchtung_Hochdimmen-x0 0 ms 22
    ENG10593-ENG101574-Suchbeleuchtung_Hochdimmen-X1 200 ms 22
    ENG10593-ENG115664-Suchbeleuchtung_Hochdimmen-x10 2000 ms 22
    ENG10593-ENG99557-Suchbeleuchtung_Hochdimmen-X2 400 ms 22
    ENG10593-ENG102140-Suchbeleuchtung_Hochdimmen-X3 600 ms 22
    ENG10593-ENG102936-Suchbeleuchtung_Hochdimmen-X4 800 ms 22
    ENG10593-ENG103548-Suchbeleuchtung_Hochdimmen-X5 1000 ms 22
    ENG10593-ENG113992-Suchbeleuchtung_Hochdimmen-X6 1200 ms 22
    ENG10593-ENG115661-Suchbeleuchtung_Hochdimmen-x7 1400 ms 22
    ENG10593-ENG115662-Suchbeleuchtung_Hochdimmen-x8 1600 ms 22
    ENG10593-ENG115663-Suchbeleuchtung_Hochdimmen-x9 1800 ms 22
    ENG10593-ENG115659-Suchbeleuchtung_Hochdimmen-y0 0.00% 22
    ENG10593-ENG99777-Suchbeleuchtung_Hochdimmen-Y1 1.00% 22
    ENG10593-ENG115668-Suchbeleuchtung_Hochdimmen-y10 100.00% 22
    ENG10593-ENG100480-Suchbeleuchtung_Hochdimmen-Y2 3.00% 22
    ENG10593-ENG100773-Suchbeleuchtung_Hochdimmen-Y3 5.00% 22
    ENG10593-ENG100631-Suchbeleuchtung_Hochdimmen-Y4 11.00% 22
    ENG10593-ENG102174-Suchbeleuchtung_Hochdimmen-Y5 22.00% 22
    ENG10593-ENG113993-Suchbeleuchtung_Hochdimmen-Y6 40.00% 22
    ENG10593-ENG115665-Suchbeleuchtung_Hochdimmen-y7 80.00% 22
    ENG10593-ENG115666-Suchbeleuchtung_Hochdimmen-y8 95.00% 22
    ENG10593-ENG115667-Suchbeleuchtung_Hochdimmen-y9 100.00% 22
    ENG10597-ENG115658-Suchbeleuchtung_KL 58xs max-x0 0 lx 8
    ENG10597-ENG101574-Suchbeleuchtung_KL 58xs max-X1 8 lx 8
    ENG10597-ENG99557-Suchbeleuchtung_KL 58xs max-X2 50 lx 8
    ENG10597-ENG102140-Suchbeleuchtung_KL 58xs max-X3 500 lx 8
    ENG10597-ENG115659-Suchbeleuchtung_KL 58xs max-y0 100 8
    ENG10597-ENG99777-Suchbeleuchtung_KL 58xs max-Y1 100 8
    ENG10597-ENG100480-Suchbeleuchtung_KL 58xs max-Y2 100 8
    ENG10597-ENG100773-Suchbeleuchtung_KL 58xs max-Y3 100 8
    ENG10596-ENG115658-Suchbeleuchtung_KL 58xs min-x0 0 lx 8
    ENG10596-ENG101574-Suchbeleuchtung_KL 58xs min-X1 8 lx 8
    ENG10596-ENG99557-Suchbeleuchtung_KL 58xs min-X2 50 lx 8
    ENG10596-ENG102140-Suchbeleuchtung_KL 58xs min-X3 510 lx 8
    ENG10596-ENG115659-Suchbeleuchtung_KL 58xs min-y0 6 8
    ENG10596-ENG99777-Suchbeleuchtung_KL 58xs min-Y1 6 8
    ENG10596-ENG100480-Suchbeleuchtung_KL 58xs min-Y2 100 8
    ENG10596-ENG100773-Suchbeleuchtung_KL 58xs min-Y3 100 8
    ENG10602-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0 0.00% 12
    ENG10602-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1 6.00% 12
    ENG10602-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2 16.00% 12
    ENG10602-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3 30.00% 12
    ENG10602-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4 60.00% 12
    ENG10602-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5 100.00% 12
    ENG10602-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0 10 12
    ENG10602-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1 10 12
    ENG10602-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2 100 12
    ENG10602-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3 150 12
    ENG10602-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4 220 12
    ENG10602-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5 253 12
    ENG10601-ENG115658-Suchbeleuchtung_KL_58xd_max-x0 0 lx 10
    ENG10601-ENG101574-Suchbeleuchtung_KL_58xd_max-X1 8 lx 10
    ENG10601-ENG99557-Suchbeleuchtung_KL_58xd_max-X2 200 lx 10
    ENG10601-ENG102140-Suchbeleuchtung_KL_58xd_max-X3 300 lx 10
    ENG10601-ENG102936-Suchbeleuchtung_KL_58xd_max-X4 500 lx 10
    ENG10601-ENG115659-Suchbeleuchtung_KL_58xd_max-y0 16 10
    ENG10601-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1 16 10
    ENG10601-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2 100 10
    ENG10601-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3 100 10
    ENG10601-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4 100 10
    ENG10600-ENG115658-Suchbeleuchtung_KL_58xd_min-x0 0 lx 10
    ENG10600-ENG101574-Suchbeleuchtung_KL_58xd_min-X1 8 lx 10
    ENG10600-ENG99557-Suchbeleuchtung_KL_58xd_min-X2 220 lx 10
    ENG10600-ENG102140-Suchbeleuchtung_KL_58xd_min-X3 300 lx 10
    ENG10600-ENG102936-Suchbeleuchtung_KL_58xd_min-X4 500 lx 10
    ENG10600-ENG115659-Suchbeleuchtung_KL_58xd_min-y0 6 10
    ENG10600-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1 6 10
    ENG10600-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2 100 10
    ENG10600-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3 100 10
    ENG10600-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4 100 10
    ENG10605-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0 0 12
    ENG10605-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1 10 12
    ENG10605-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2 50 12
    ENG10605-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3 100 12
    ENG10605-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4 220 12
    ENG10605-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5 253 12
    ENG10605-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0 2.00% 12
    ENG10605-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1 2.00% 12
    ENG10605-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2 6.00% 12
    ENG10605-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3 10.00% 12
    ENG10605-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4 80.00% 12
    ENG10605-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5 100.00% 12
    ENG10598-ENG115658-Suchbeleuchtung_KL_58xt min-x0 0 lx 8
    ENG10598-ENG101574-Suchbeleuchtung_KL_58xt min-X1 8 lx 8
    ENG10598-ENG99557-Suchbeleuchtung_KL_58xt min-X2 50 lx 8
    ENG10598-ENG102140-Suchbeleuchtung_KL_58xt min-X3 500 lx 8
    ENG10598-ENG115659-Suchbeleuchtung_KL_58xt min-y0 6 8
    ENG10598-ENG99777-Suchbeleuchtung_KL_58xt min-Y1 6 8
    ENG10598-ENG100480-Suchbeleuchtung_KL_58xt min-Y2 100 8
    ENG10598-ENG100773-Suchbeleuchtung_KL_58xt min-Y3 100 8
    ENG10599-ENG115658-Suchbeleuchtung_KL_58xt_max-x0 0 lx 8
    ENG10599-ENG101574-Suchbeleuchtung_KL_58xt_max-X1 8 lx 8
    ENG10599-ENG99557-Suchbeleuchtung_KL_58xt_max-X2 50 lx 8
    ENG10599-ENG102140-Suchbeleuchtung_KL_58xt_max-X3 500 lx 8
    ENG10599-ENG115659-Suchbeleuchtung_KL_58xt_max-y0 100 8
    ENG10599-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1 100 8
    ENG10599-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2 100 8
    ENG10599-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3 100 8
    ENG10604-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0 0.00% 6
    ENG10604-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1 50.00% 6
    ENG10604-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2 100.00% 6
    ENG10604-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0 0.00% 6
    ENG10604-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1 50.00% 6
    ENG10604-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2 100.00% 6
    ENG10608-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0 0 lx 12
    ENG10608-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1 200 lx 12
    ENG10608-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2 400 lx 12
    ENG10608-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3 600 lx 12
    ENG10608-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4 800 lx 12
    ENG10608-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5 1020 lx 12
    ENG10608-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0 0 12
    ENG10608-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1 84 12
    ENG10608-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2 166 12
    ENG10608-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3 250 12
    ENG10608-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4 370 12
    ENG10608-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5 500 12
    ENG10592-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0 0 ms 10
    ENG10592-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1 2000 ms 10
    ENG10592-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2 3000 ms 10
    ENG10592-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3 4000 ms 10
    ENG10592-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4 5100 ms 10
    ENG10592-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0 1.00% 10
    ENG10592-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1 5 10
    ENG10592-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2 15 10
    ENG10592-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3 40 10
    ENG10592-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4 100 10
    ENG10560-ENG116647-Sunroof-SAD Komfort oeffnen not active 4
    ENG10560-ENG116646-Sunroof-SAD Komfort schliessen not active 4
    ENG10560-ENG116645-Sunroof-SAD Richtung Komfortoeffnen tilting 4
    ENG10560-ENG10898-Sunroof-Schiebedachmodul_MD_1 installed 4
    ENG10560-ENG10899-Sunroof-Schiebedachmodul_MD_3 not installed 4
    ENG10560-ENG10900-Sunroof-Schiebedachmodul_MD_Rollo installed 4
    ENG10560-ENG10950-Sunroof-Verortung Schiebedachmodule CAN 4
    ENG10562-ENG10941-Verdecksteuergeraet-Cabrio_Verdeck not_installed 9
    ENG10562-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck active 9
    ENG10562-ENG128459-Verdecksteuergeraet-easycloselight_aktiv not active 9
    ENG10562-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb not active 9
    ENG10562-ENG11187-Verdecksteuergeraet-Kick_and_close installed 9
    ENG10562-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global active 9
    ENG10562-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen active 9
    ENG10562-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen active 9
    ENG10562-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf not active 9
    ENG10562-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen active 9
    ENG10562-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung nur wenn mind. 1 Raste zu 9
    ENG10562-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden Always 9
    ENG10562-ENG10939-Verdecksteuergeraet-trunk_lid_conrol_unit installed 9
    ENG10562-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach not active 9
    ENG10562-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung active 9
    ENG10562-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy active 9
    ENG10562-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder active 9
    ENG10562-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung active 9
    ENG10562-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy active 9
    ENG10562-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder active 9
    ENG10562-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal active 9
    ENG10562-ENG11186-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba active 9
    ENG10562-ENG11185-Verdecksteuergeraet-Virtuelles_Pedal_Verbau installed 9
    ENG122979-ENG10882-Vernetzung-A/C electronics installed 8
    ENG122979-ENG10896-Vernetzung-Anhaengeranschlussgeraet installed 8
    ENG122979-ENG10902-Vernetzung-Bremsen_Steuergeraet installed 8
    ENG122979-ENG10881-Vernetzung-Getriebesteuergeraet installed 8
    ENG122979-ENG99457-Vernetzung-Head area heater not installed 8
    ENG122979-ENG10968-Vernetzung-Kunden_spezifisches_Funktions_SG not installed 8
    ENG122979-ENG10897-Vernetzung-UGDO not installed 8
    ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
    ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
    ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
    ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
    ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
    ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
    ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
    ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
    ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
    ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
    ENG10579-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB not active 7
    ENG10579-ENG02315-ZV allgemein-Deaktivierung_Laderaumschliessung_extern not active 7
    ENG10579-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 7
    ENG10579-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein not active 7
    ENG10579-ENG115754-ZV allgemein-Funk bei Klemme 15 ein not active 7
    ENG10579-ENG10909-ZV allgemein-Lock_Unlock_Taster_direkt installed 7
    ENG10579-ENG10947-ZV allgemein-Lock_Unlock_Toggle_Taster installed 7
    ENG10579-ENG02316-ZV allgemein-LS_Taster_Togglefunktion not active 7
    ENG10579-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung active 7
    ENG10579-ENG115755-ZV allgemein-Notschließfunktion active 7
    ENG10579-ENG02317-ZV allgemein-Nutzfahrzeug_Schliessung not active 7
    ENG10579-ENG10885-ZV allgemein-Radio freq. 434.42MHz 7
    ENG10579-ENG10886-ZV allgemein-Tankschloss Bidirectional 7
    ENG10579-ENG02318-ZV allgemein-Wiederverriegelung_Laderaum Freigabe_Softtouch 7
    ENG10579-ENG116623-ZV allgemein-ZV Tuerentriegelung Einzeltuerentriegelung 7
    ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion not installed 7
    ENG10582-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck active 3
    ENG10582-ENG116621-ZV Autolock-automatisches Entriegeln active 3
    ENG10582-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit active 3
    ENG10582-ENG116706-ZV Autolock-Autounlock NAR not active 3
    ENG10582-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 3
    ENG10582-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock adjustable 3
    ENG10583-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 4
    ENG10583-ENG116661-ZV Crash-SAD PreCrash Konturschliessen active 4
    ENG10583-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash not active 4
    ENG10581-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels active 7
    ENG10581-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 7
    ENG10581-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 7
    ENG10581-ENG10944-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster via_CAN 7
    ENG10581-ENG02314-ZV Heck-Heckfreigabe_Ohne_Verzoegerung not active 7
    ENG10581-ENG11173-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen not active 7
    ENG10581-ENG10926-ZV Heck-Heckschloss_mit_Vorraste Yes 7
    ENG10581-ENG10923-ZV Heck-Heckschloss_Steuerung Kontaktsteuerung mit Mindestansteuerzeit 7
    ENG10581-ENG06090-ZV Heck-Mindestbetaetigung_HDF_Innentaster 0.0 s 7
    ENG10581-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 7
    ENG10581-ENG10910-ZV Heck-Tausch_Tank_Hecktreiberausgang No 7
    ENG10581-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel active 7
    ENG10581-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen not active 7
    ENG10581-ENG10925-ZV Heck-ZV_Heck_Schlosstyp 1 or 2 notch rear actuator 7
    ENG10609-IDE02021-ZV Komfort-Comfort closing active 8
    ENG10609-IDE02022-ZV Komfort-Comfort opening active 8
    ENG10609-ENG10912-ZV Komfort-elektrischer_Fensterheber_hinten Yes 8
    ENG10609-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen active 8
    ENG10609-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen active 8
    ENG10609-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit 600 s 8
    ENG10609-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus active 8
    ENG10609-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
    ENG10609-ENG116652-ZV Komfort-Funk Komfort oeffnen active 8
    ENG10609-ENG116651-ZV Komfort-Funk Komfort schliessen active 8
    ENG10609-ENG115670-ZV Komfort-Komfortbedienung global active 8
    ENG10609-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer not active 8
    ENG10609-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar adjustable 8
    ENG10609-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen not active 8
    ENG10609-ENG125656-ZV Komfort-Regenschliessen_art once 8
    ENG10609-ENG125655-ZV Komfort-Regenschliessen_ein_aus not active 8
    ENG10609-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen active 8
    ENG10609-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen active 8
    ENG10580-ENG10927-ZV Türkonfiguration-Fond_Schloss Tuersteuergeraet im Fond verbaut oder keine Fondtuer 5
    ENG10580-ENG10971-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal nicht invertiert 5
    ENG10580-ENG10967-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite not installed 5
    ENG10580-ENG10966-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite not installed 5
    ENG10580-ENG10929-ZV Türkonfiguration-Schiebetuer_links No 5
    ENG10580-ENG10930-ZV Türkonfiguration-Schiebetuer_rechts No 5
    ENG10580-ENG10969-ZV Türkonfiguration-Schiebetueren_Crafter not installed 5
    ENG10580-ENG11172-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM Driver side 5
    ENG10580-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 5
    ENG10580-ENG10928-ZV Türkonfiguration-Schlosstyp_NAR No 5
    ENG10580-ENG10887-ZV Türkonfiguration-Viertuerer Yes 5
    Elapsed Time: 02:00
    17 Admap:
    ;SW:565-920-951 HW:565-920-951 --- Instruments
    ;Component:KOMBI 311 8311 Coding:27A4081CFF84A60001886B0B7001000800000000
    ;EV_DashBoardVDDMQBAB 9051 EV_DashBoardVDDMQBAB_009_VW26.rod
    ;Monday 1 May 2017 11:12:47:36443
    ;VCDS Version: Beta 17.4.1 Data version: 20170413 DS270.4
    ;VCID: 5AF857345D9122972E-800E
    IDE00295-Oil temperature display On 1
    IDE00301-Distance 241 km 3
    IDE00342-ESI: Resetting ESI no warning 1
    IDE00343-Language version English 1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK Manual reset: not possible 3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel MFA3-Reset 3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas MFA3-Reset 3
    IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection MFA3-Reset 3
    IDE00499-Display correction of consumptions and operating range 100% 1
    IDE00500-Hour 11 H 1
    IDE00501-Minute 12 min 1
    IDE00502-Year 2017 yr 2
    IDE00503-Month 5 mon 1
    IDE00504-Day 1 d 1
    IDE00510-ESI: distance driven from inspection 228 km 3
    IDE00511-ESI: time from inspection 18 d 2
    IDE00512-ESI: minimum value km-driving distance/inspection 15000 km 2
    IDE00513-ESI: maximum value km-driving distance/inspection 30000 km 2
    IDE00514-ESI: maximum value of time between inspections 730 d 2
    IDE00515-ESI: oil quality poor oil quality 1
    IDE00517-ESI: soot entry 500 km 2
    IDE00518-ESI: thermal load 300 km 2
    IDE00819-Day counter 34 d 2
    IDE00820-Activating and deactivating all development messages not active 1
    IDE00827-ESI: minimum value of time between inspections 365 d 2
    IDE01153-SIA: maximum value of distance to service 15000 km 2
    IDE01154-SIA: maximum value of time to service 365 d 2
    IDE02489-Display depiction Version 2 1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration -12.8 l 5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1 -12.8 l 5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2 -12.8 l 5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3 12.7 l 5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4 12.7 l 5
    IDE03329-Driving profiled for range remaining 8.3 l/100km 2
    IDE03346-IDE00301-Units adjusted-Distance miles 3
    IDE03346-MAS01230-Units adjusted-Date dd_mm_yy 3
    IDE03346-MAS01456-Units adjusted-Speed Miles per hour 3
    IDE03346-MAS02201-Units adjusted-Temperature Degrees Celsius 3
    IDE03346-MAS02957-Units adjusted-Time 24h 3
    IDE03346-MAS03032-Units adjusted-Volume gallons (UK) 3
    IDE03346-MAS03034-Units adjusted-Pressure bar 3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas) kg per 100 km 3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas) Miles per gallon (UK) 3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive kWh per 100 km 3
    IDE03348-MAS01456-Speed warning-Speed 0 2
    IDE03348-MAS01561-Speed warning-Unit Miles per hour 2
    IDE03348-IDE03348-Speed warning- not active 2
    IDE03349-FIX: Max. distance until next mileage-related inspection 32200 km 2
    IDE03350-FIX: Maximum time until next time-dependent inspection 730 d 2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection 200 km 2
    IDE03352-FIX: Time since last time-dependent inspection 18 d 2
    IDE03372-Source for synchronization of time GPS 1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function On 5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time 10 s 5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic On 5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless On 5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed 20 km/h 5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time 40 s 5
    IDE03568-ENG104099-Service-key settings-p_write_distance 20 km 5
    IDE03867-Deactivate seat belt warning No 1
    IDE05930-Service notification in days 30 d 1
    IDE05931-FIX: Reset value for next mileage-dependent inspection 30000 km 2
    IDE05932-FIX: Reset value for next time-dependent inspections 365 d 2
    IDE05971-Vehicle Positioning System Interface Control Module not installed 1
    IDE06425-Roller test bench mode: functional not activated 1
    IDE06588-Ignition active message: actuator Driver door 1
    IDE06922-No-voltage display No display 1
    IDE07221-Cylinder shut-off Display 1
    IDE11086-Service notification 30 d 1
    MAS03685-Digital speedometer Display 1
    ENG117917-BAP_Debug_Mode_Release not_released 1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1 OFF 20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10 OFF 20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11 OFF 20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12 OFF 20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13 OFF 20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14 OFF 20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15 OFF 20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16 OFF 20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17 OFF 20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18 OFF 20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19 OFF 20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2 OFF 20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20 OFF 20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21 OFF 20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22 OFF 20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23 OFF 20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24 OFF 20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25 OFF 20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26 OFF 20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27 OFF 20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28 OFF 20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29 OFF 20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3 OFF 20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30 OFF 20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31 OFF 20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32 OFF 20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33 OFF 20
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34 OFF 20
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35 OFF 20
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36 OFF 20
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37 OFF 20
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38 OFF 20
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39 OFF 20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4 OFF 20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5 OFF 20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6 OFF 20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7 OFF 20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8 OFF 20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9 OFF 20
    ENG119875-defuel_threshold 9 l 1
    ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1 0 12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2 32 12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3 66 12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4 96 12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5 DC 12
    ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6 FD 12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1 0 12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2 0 12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3 0 12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4 0A 12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5 32 12
    ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6 64 12
    ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1 0 12
    ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2 0A 12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3 46 12
    ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4 64 12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5 DC 12
    ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6 FD 12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1 3 12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2 3 12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3 11 12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4 1F 12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5 5A 12
    ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6 64 12
    ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1 0 12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2 0A 12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3 46 12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4 64 12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5 DC 12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6 FD 12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1 3 12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2 3 12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3 11 12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4 1E 12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5 5A 12
    ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6 64 12
    ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1 0 12
    ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2 0A 12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3 32 12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4 64 12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5 96 12
    ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6 FD 12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1 5 12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2 5 12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3 0C 12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4 17 12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5 32 12
    ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6 64 12
    ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1 00 00 20
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2 00 32 20
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3 00 64 20
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4 00 C8 20
    ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5 01 F4 20
    ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1 00 00 20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2 00 3C 20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3 00 B4 20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4 00 DC 20
    ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5 00 FD 20
    ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1 0 12
    ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2 0A 12
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3 46 12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4 64 12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5 DC 12
    ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6 FD 12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1 1 12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2 1 12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3 6 12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4 0C 12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5 46 12
    ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6 64 12
    ENG119874-Gas_functionality not active 1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim terminal_58xd_log_bus_parkinglight 1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm parking_light 1
    ENG119882-init_fuel_algorithm No 1
    ENG130585-Leaving_warning_delay 1.6 s 1
    ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0 15 s 16
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature 4 °C 16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature 6 °C 16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta 25 °C 16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0 5.0 km 16
    ENG102605-ENG103631-outside_temperature-P_speed_threshold 20 km/h 16
    ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off 180 min 16
    ENG102605-ENG104179-outside_temperature-p_tendency_damping 15 s 16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold 1.0 °C 16
    ENG102605-ENG100500-outside_temperature-p_time_constant_pt1 40 s 16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping 2 16
    ENG119825-Picture_Upload_Download not active 1
    ENG119876-Service_Key_Clear_All_Counter Yes 1
    ENG130584-Statistic_phev_mileage 5 km 1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms 2 18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms 5 s 18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt 35 s 18
    ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF 300 ms 18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms 255 s 18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms 5 s 18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms 6 s 18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms 20 s 18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms 900 s 18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms 10 s 18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms 3 s 18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms 10 s 18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ 0.40 s 18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse 3 18
    ENG109442-ENG101663-time_parameter_display-tDD15_off 0.6 18
    ENG109442-ENG103975-time_parameter_display-tDD15_on 0 18
    ENG109442-ENG100026-time_parameter_display-tDDWUP 0 18
    ENG112418-ENG112412-total_range_gas-consumption_factor 0 4
    ENG112418-ENG112411-total_range_gas-consumption_profile consumption_profile_calculation 4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor consumption_factor_CAN 4
    ENG112418-ENG99298-total_range_gas-State not active 4
    Elapsed Time: 00:24
    5F Admap:
    ;SW:3V0-035-021-D HW:3V0-035-021 --- Information Electr.
    ;Component:MU-H-LND-EU H50 0942 Coding:032316010000000051111202008808332F0300E6012081009E
    ;EV_MUHig4CGen2HBAS 1001 EV_MUHig4CGen2HBAS_SK37.rod
    ;Monday 1 May 2017 11:14:03:36443
    ;VCID: 281C3DFC537D400768-807C
    IDE00001-Production mode 00 00 00 3
    IDE00346-Summertime-automatic manual 1
    IDE00759-Base volume of speech output 50% 1
    IDE00760-Microphone sensitivity 0 dB 1
    IDE00768-Country identification: country of sale GB 2
    IDE00769-Number 1 for Info call FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE00770-Number 1 for roadside assistance FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages OFF 1
    IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages OFF 1
    IDE00845-Wheel circ. 0 mm 2
    IDE01996-ENG99724-Installation list: specified installations-ECU coded Yes 3
    IDE01996-ENG99724-Installation list: specified installations-ECU coded No 3
    IDE01996-ENG06573-Installation list: specified installations-ECU coded 2 No 3
    IDE02121-CD eject button Enabled 1
    IDE02122-Developer mode not activated 1
    IDE02330-Number 2 for Info call FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE02331-Number 2 for roadside assistance FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
    IDE02332-Deactivate production mode 0 3
    IDE02476-MAS03001-Electrical test of loudspeakers-Mode automatic 49
    IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency 19000 Hz 49
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume 22 49
    IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz 49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume 22 49
    IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz 49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume 22 49
    IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz 49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume 22 49
    IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz 49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume 22 49
    IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz 49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume 22 49
    IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz 49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume 22 49
    IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz 49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume 22 49
    IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency 19000 Hz 49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume 22 49
    IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency 19000 Hz 49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume 22 49
    IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency 19000 Hz 49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume 22 49
    IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency 19000 Hz 49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume 22 49
    IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency 19000 Hz 49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume 22 49
    IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency 19000 Hz 49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume 22 49
    IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency 19000 Hz 49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume 22 49
    IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency 19000 Hz 49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume 22 49
    IDE02502-Confirmation of installation change 1D 12 2
    IDE02506-MAS03229-Copy multimedia data-Data medium On 1
    IDE02506-MAS03230-Copy multimedia data-Optical drive OFF 1
    IDE02607-Wheel pulse 0 2
    IDE02699-Number 1 for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
    IDE02701-Number 1 (roaming) for roadside assistance 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23
    IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo 0 8
    IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP 15 8
    IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo 0 8
    IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP 15 8
    IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo 0 8
    IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP 11 8
    IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo 0 8
    IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP 8 8
    IDE03471-ENG117847-Vehicle configuration-advanced_range_display OFF 30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO On 30
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call OFF 30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL On 30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts On 30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other On 30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts OFF 30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other OFF 30
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1 Not Present 30
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2 Not Present 30
    IDE03471-ENG127492-Vehicle configuration-LGI OFF 30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul activated 30
    IDE03471-ENG07590-Vehicle configuration-Mirror_link function_on_hmi_on 30
    IDE03471-ENG117843-Vehicle configuration-my_audi OFF 30
    IDE03471-ENG117845-Vehicle configuration-online_dictation OFF 30
    IDE03471-ENG127495-Vehicle configuration-online_media OFF 30
    IDE03471-ENG117840-Vehicle configuration-online_navigation OFF 30
    IDE03471-ENG117837-Vehicle configuration-online_POI OFF 30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice OFF 30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services OFF 30
    IDE03471-ENG117841-Vehicle configuration-online_street_view OFF 30
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit OFF 30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode only data service act. 30
    IDE03471-ENG117844-Vehicle configuration-picture_navi On 30
    IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi OFF 30
    IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo OFF 30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version PSD_1.5 30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI OFF 30
    IDE03471-ENG07589-Vehicle configuration-RSE_software_component activated 30
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input FBAS 30
    IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation no restriction 30
    IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag no_region 30
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch present 30
    IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi activated 30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode 1 30
    IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold OFF 30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling OFF 30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone On 30
    IDE03471-ENG126994-Vehicle configuration-TPEG_availability OFF 30
    IDE03471-ENG06575-Vehicle configuration-UOTA On 30
    IDE03471-ENG117852-Vehicle configuration-UPnP On 30
    IDE03471-ENG117836-Vehicle configuration-VZAPro OFF 30
    IDE03471-ENG127494-Vehicle configuration-VZO OFF 30
    IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI On 30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot On 30
    IDE03580-Country code for mobile network 0 2
    IDE03902-Automatic ring break diagnostic No automatic start 1
    IDE04295-Bluetooth: Preferred connection profile for phone book data PBAP 1
    IDE04298-MAS01779-Vehicle dimensions-Length 0 mm 6
    IDE04298-MAS01780-Vehicle dimensions-Width 0 mm 6
    IDE04298-MAS02230-Vehicle dimensions-Height 0 mm 6
    IDE04331-Selection of release codes for a SWaP function FF FF FF FF 4
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code 2 2
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code 2 2
    IDE04521-Sporadic ring break detection Visual 1
    IDE04522-Awakening ability on optical databus OFF 1
    IDE04549-Telephone data services On 1
    IDE04550-Bluetooth: Sniff mode On 1
    IDE05111-Fee-based traffic information (TMC) 32771 2
    IDE05113-Infotainment Recorder activated 1
    IDE06697-Audio management mute function Muting of audio sources 1
    IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G 0 16
    IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G 0 16
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner -128 40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio -128 40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM) -128 40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM) -128 40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB) -128 40
    IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB -128 40
    IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP -128 40
    IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay -128 40
    IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter -128 40
    IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN -128 40
    IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray -128 40
    IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice -128 40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA -128 40
    IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud -128 40
    IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD -128 40
    IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI -128 40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP -128 40
    IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP -128 40
    IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink -128 40
    IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP -128 40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB -128 40
    IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice -128 40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM -128 40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep -128 40
    IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging -128 40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen -128 40
    IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning -128 40
    IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav -128 40
    IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS -128 40
    IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online -128 40
    IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal -128 40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI -128 40
    IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN -128 40
    IDE10480-MAS10741-Interface for external media: activation-Connection 1 activated 4
    IDE10480-MAS10742-Interface for external media: activation-Connection 2 not activated 4
    IDE10480-MAS10743-Interface for external media: activation-Connection 3 not activated 4
    IDE10480-MAS10744-Interface for external media: activation-Connection 4 not activated 4
    IDE10604-Menu entries for mobile online services activated 1
    IDE10668-Internal SIM card: use Never 1
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold 37 dBµV 3
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation 32 dB 3
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo 15.0 s 3
    IDE11105-Brand-specific display of connect application 256
    IDE11122-Country identification: country of sale HMI -- 2
    IDE11153-IDE11153-Surroundings display: virtual camera positions- 32767 330
    IDE11153-IDE11153-Surroundings display: virtual camera positions- 65535 330
    IDE11153-IDE11153-Surroundings display: virtual camera positions- 4294967295 330
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0 non_blocked 21
    IDE11502-ENG127602-Locked menu contents-FB_CAR_1 non_blocked 21
    IDE11502-ENG127611-Locked menu contents-FB_CAR_10 non_blocked 21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11 non_blocked 21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12 non_blocked 21
    IDE11502-ENG127614-Locked menu contents-FB_CAR_13 non_blocked 21
    IDE11502-ENG127615-Locked menu contents-FB_CAR_14 non_blocked 21
    IDE11502-ENG127616-Locked menu contents-FB_CAR_15 non_blocked 21
    IDE11502-ENG127617-Locked menu contents-FB_CAR_16 non_blocked 21
    IDE11502-ENG127618-Locked menu contents-FB_CAR_17 non_blocked 21
    IDE11502-ENG127619-Locked menu contents-FB_CAR_18 non_blocked 21
    IDE11502-ENG127620-Locked menu contents-FB_CAR_19 non_blocked 21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2 non_blocked 21
    IDE11502-ENG127621-Locked menu contents-FB_CAR_20 non_blocked 21
    IDE11502-ENG127622-Locked menu contents-FB_CAR_21 non_blocked 21
    IDE11502-ENG127623-Locked menu contents-FB_CAR_22 non_blocked 21
    IDE11502-ENG127624-Locked menu contents-FB_CAR_23 non_blocked 21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3 non_blocked 21
    IDE11502-ENG127605-Locked menu contents-FB_CAR_4 non_blocked 21
    IDE11502-ENG127606-Locked menu contents-FB_CAR_5 non_blocked 21
    IDE11502-ENG127607-Locked menu contents-FB_CAR_6 non_blocked 21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7 non_blocked 21
    IDE11502-ENG127609-Locked menu contents-FB_CAR_8 non_blocked 21
    IDE11502-ENG127610-Locked menu contents-FB_CAR_9 non_blocked 21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0 non_blocked 21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1 non_blocked 21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10 non_blocked 21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11 non_blocked 21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12 non_blocked 21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13 non_blocked 21
    IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14 non_blocked 21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15 non_blocked 21
    IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16 non_blocked 21
    IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17 non_blocked 21
    IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18 non_blocked 21
    IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19 non_blocked 21
    IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2 non_blocked 21
    IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20 non_blocked 21
    IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21 non_blocked 21
    IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22 non_blocked 21
    IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23 non_blocked 21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3 non_blocked 21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4 non_blocked 21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5 non_blocked 21
    IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6 non_blocked 21
    IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7 non_blocked 21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8 non_blocked 21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9 non_blocked 21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0 non_blocked 21
    IDE11502-ENG127626-Locked menu contents-FB_MISC_1 non_blocked 21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10 non_blocked 21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11 non_blocked 21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12 non_blocked 21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13 non_blocked 21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14 non_blocked 21
    IDE11502-ENG127640-Locked menu contents-FB_MISC_15 non_blocked 21
    IDE11502-ENG127641-Locked menu contents-FB_MISC_16 non_blocked 21
    IDE11502-ENG127642-Locked menu contents-FB_MISC_17 non_blocked 21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18 non_blocked 21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19 non_blocked 21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2 non_blocked 21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20 non_blocked 21
    IDE11502-ENG127646-Locked menu contents-FB_MISC_21 non_blocked 21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22 non_blocked 21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23 non_blocked 21
    IDE11502-ENG127649-Locked menu contents-FB_MISC_24 non_blocked 21
    IDE11502-ENG127650-Locked menu contents-FB_MISC_25 non_blocked 21
    IDE11502-ENG127651-Locked menu contents-FB_MISC_26 non_blocked 21
    IDE11502-ENG127652-Locked menu contents-FB_MISC_27 non_blocked 21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28 non_blocked 21
    IDE11502-ENG127654-Locked menu contents-FB_MISC_29 non_blocked 21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3 non_blocked 21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30 non_blocked 21
    IDE11502-ENG127656-Locked menu contents-FB_MISC_31 non_blocked 21
    IDE11502-ENG127657-Locked menu contents-FB_MISC_32 non_blocked 21
    IDE11502-ENG127658-Locked menu contents-FB_MISC_33 non_blocked 21
    IDE11502-ENG127659-Locked menu contents-FB_MISC_34 non_blocked 21
    IDE11502-ENG127660-Locked menu contents-FB_MISC_35 non_blocked 21
    IDE11502-ENG127661-Locked menu contents-FB_MISC_36 non_blocked 21
    IDE11502-ENG127662-Locked menu contents-FB_MISC_37 non_blocked 21
    IDE11502-ENG127663-Locked menu contents-FB_MISC_38 non_blocked 21
    IDE11502-ENG127664-Locked menu contents-FB_MISC_39 non_blocked 21
    IDE11502-ENG127629-Locked menu contents-FB_MISC_4 non_blocked 21
    IDE11502-ENG127665-Locked menu contents-FB_MISC_40 non_blocked 21
    IDE11502-ENG127666-Locked menu contents-FB_MISC_41 non_blocked 21
    IDE11502-ENG127667-Locked menu contents-FB_MISC_42 non_blocked 21
    IDE11502-ENG127668-Locked menu contents-FB_MISC_43 non_blocked 21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44 non_blocked 21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45 non_blocked 21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46 non_blocked 21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47 non_blocked 21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5 non_blocked 21
    IDE11502-ENG127631-Locked menu contents-FB_MISC_6 non_blocked 21
    IDE11502-ENG127632-Locked menu contents-FB_MISC_7 non_blocked 21
    IDE11502-ENG127633-Locked menu contents-FB_MISC_8 non_blocked 21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9 non_blocked 21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0 non_blocked 21
    IDE11502-ENG127562-Locked menu contents-FB_NAV_1 non_blocked 21
    IDE11502-ENG127571-Locked menu contents-FB_NAV_10 non_blocked 21
    IDE11502-ENG127572-Locked menu contents-FB_NAV_11 non_blocked 21
    IDE11502-ENG127573-Locked menu contents-FB_NAV_12 non_blocked 21
    IDE11502-ENG127574-Locked menu contents-FB_NAV_13 non_blocked 21
    IDE11502-ENG127575-Locked menu contents-FB_NAV_14 non_blocked 21
    IDE11502-ENG127576-Locked menu contents-FB_NAV_15 non_blocked 21
    IDE11502-ENG127577-Locked menu contents-FB_NAV_16 non_blocked 21
    IDE11502-ENG127578-Locked menu contents-FB_NAV_17 non_blocked 21
    IDE11502-ENG127579-Locked menu contents-FB_NAV_18 non_blocked 21
    IDE11502-ENG127580-Locked menu contents-FB_NAV_19 non_blocked 21
    IDE11502-ENG127563-Locked menu contents-FB_NAV_2 non_blocked 21
    IDE11502-ENG127581-Locked menu contents-FB_NAV_20 non_blocked 21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21 non_blocked 21
    IDE11502-ENG127583-Locked menu contents-FB_NAV_22 non_blocked 21
    IDE11502-ENG127584-Locked menu contents-FB_NAV_23 non_blocked 21
    IDE11502-ENG127585-Locked menu contents-FB_NAV_24 non_blocked 21
    IDE11502-ENG127586-Locked menu contents-FB_NAV_25 non_blocked 21
    IDE11502-ENG127587-Locked menu contents-FB_NAV_26 non_blocked 21
    IDE11502-ENG127588-Locked menu contents-FB_NAV_27 non_blocked 21
    IDE11502-ENG127589-Locked menu contents-FB_NAV_28 non_blocked 21
    IDE11502-ENG127590-Locked menu contents-FB_NAV_29 non_blocked 21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3 non_blocked 21
    IDE11502-ENG127591-Locked menu contents-FB_NAV_30 non_blocked 21
    IDE11502-ENG127592-Locked menu contents-FB_NAV_31 non_blocked 21
    IDE11502-ENG127593-Locked menu contents-FB_NAV_32 non_blocked 21
    IDE11502-ENG127594-Locked menu contents-FB_NAV_33 non_blocked 21
    IDE11502-ENG127595-Locked menu contents-FB_NAV_34 non_blocked 21
    IDE11502-ENG127596-Locked menu contents-FB_NAV_35 non_blocked 21
    IDE11502-ENG127597-Locked menu contents-FB_NAV_36 non_blocked 21
    IDE11502-ENG127598-Locked menu contents-FB_NAV_37 non_blocked 21
    IDE11502-ENG127599-Locked menu contents-FB_NAV_38 non_blocked 21
    IDE11502-ENG127600-Locked menu contents-FB_NAV_39 non_blocked 21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4 non_blocked 21
    IDE11502-ENG127566-Locked menu contents-FB_NAV_5 non_blocked 21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6 non_blocked 21
    IDE11502-ENG127568-Locked menu contents-FB_NAV_7 non_blocked 21
    IDE11502-ENG127569-Locked menu contents-FB_NAV_8 non_blocked 21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9 non_blocked 21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0 non_blocked 21
    IDE11502-ENG127546-Locked menu contents-FB_PHONE_1 non_blocked 21
    IDE11502-ENG127555-Locked menu contents-FB_PHONE_10 non_blocked 21
    IDE11502-ENG127556-Locked menu contents-FB_PHONE_11 non_blocked 21
    IDE11502-ENG127557-Locked menu contents-FB_PHONE_12 non_blocked 21
    IDE11502-ENG127558-Locked menu contents-FB_PHONE_13 non_blocked 21
    IDE11502-ENG127559-Locked menu contents-FB_PHONE_14 non_blocked 21
    IDE11502-ENG127560-Locked menu contents-FB_PHONE_15 non_blocked 21
    IDE11502-ENG127547-Locked menu contents-FB_PHONE_2 non_blocked 21
    IDE11502-ENG127548-Locked menu contents-FB_PHONE_3 non_blocked 21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4 non_blocked 21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5 non_blocked 21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6 non_blocked 21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7 non_blocked 21
    IDE11502-ENG127553-Locked menu contents-FB_PHONE_8 non_blocked 21
    IDE11502-ENG127554-Locked menu contents-FB_PHONE_9 non_blocked 21
    IDE11502-ENG127505-Locked menu contents-FB_TUNER_0 non_blocked 21
    IDE11502-ENG127506-Locked menu contents-FB_TUNER_1 non_blocked 21
    IDE11502-ENG127515-Locked menu contents-FB_TUNER_10 non_blocked 21
    IDE11502-ENG127516-Locked menu contents-FB_TUNER_11 non_blocked 21
    IDE11502-ENG127517-Locked menu contents-FB_TUNER_12 non_blocked 21
    IDE11502-ENG127518-Locked menu contents-FB_TUNER_13 non_blocked 21
    IDE11502-ENG127519-Locked menu contents-FB_TUNER_14 non_blocked 21
    IDE11502-ENG127520-Locked menu contents-FB_TUNER_15 non_blocked 21
    IDE11502-ENG127507-Locked menu contents-FB_TUNER_2 non_blocked 21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3 non_blocked 21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4 non_blocked 21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5 non_blocked 21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6 non_blocked 21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7 non_blocked 21
    IDE11502-ENG127513-Locked menu contents-FB_TUNER_8 non_blocked 21
    IDE11502-ENG127514-Locked menu contents-FB_TUNER_9 non_blocked 21
    IDE11638-Bluetooth Audio Codec FF 1
    MAS00951-Bluetooth On 1
    MAS02809-MAS02870-Check tone frequency-High note frequency range 4000 Hz 6
    MAS02809-MAS02871-Check tone frequency-Medium note frequency range 1000 Hz 6
    MAS02809-MAS02872-Check tone frequency-Low note frequency range 100 Hz 6
    MAS03690-Telephone Data & language service active 1
    MAS03782-WLAN On 1
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off OFF 12
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time 0.00 ms 12
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off OFF 12
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time 0.00 ms 12
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off OFF 12
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time 0.00 ms 12
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off OFF 12
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time 0.00 ms 12
    ENG117920-Audio_Managment_Soundset_Menu OFF 1
    ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization not activated 60
    ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer not activated 60
    ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off not activated 60
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high activated 60
    ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill not activated 60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC activated 60
    ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer not activated 60
    ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off not activated 60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high activated 60
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill not activated 60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key not activated 60
    ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer not activated 60
    ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off not activated 60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high activated 60
    ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill not activated 60
    ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue not activated 60
    ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer not activated 60
    ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off not activated 60
    ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high not activated 60
    ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill not activated 60
    ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper not activated 60
    ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer not activated 60
    ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off not activated 60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high activated 60
    ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill not activated 60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination activated 60
    ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer not activated 60
    ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off not activated 60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high activated 60
    ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill not activated 60
    ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope not activated 60
    ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer not activated 60
    ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off not activated 60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high activated 60
    ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill not activated 60
    ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification not activated 60
    ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer not activated 60
    ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off not activated 60
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high activated 60
    ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill not activated 60
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating not activated 60
    ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer not activated 60
    ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off not activated 60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high activated 60
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill not activated 60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv activated 60
    ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer not activated 60
    ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off not activated 60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high activated 60
    ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill not activated 60
    ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management not activated 60
    ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer not activated 60
    ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off not activated 60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high activated 60
    ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill not activated 60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE activated 60
    ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer not activated 60
    ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off not activated 60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high activated 60
    ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill not activated 60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer activated 60
    ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer not activated 60
    ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off not activated 60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high activated 60
    ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill not activated 60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function activated 60
    ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer not activated 60
    ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off not activated 60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high activated 60
    ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill not activated 60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror activated 60
    ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer not activated 60
    ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off not activated 60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high activated 60
    ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill not activated 60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking activated 60
    ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer not activated 60
    ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off not activated 60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high activated 60
    ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill not activated 60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master activated 60
    ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer not activated 60
    ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off not activated 60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high activated 60
    ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill not activated 60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma activated 60
    ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer not activated 60
    ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off not activated 60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high activated 60
    ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill not activated 60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration activated 60
    ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer not activated 60
    ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off not activated 60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high activated 60
    ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill not activated 60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock activated 60
    ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer not activated 60
    ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off not activated 60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high activated 60
    ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill not activated 60
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass activated 60
    ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer not activated 60
    ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off not activated 60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high activated 60
    ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill not activated 60
    ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist not activated 60
    ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer not activated 60
    ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off not activated 60
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high activated 60
    ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill not activated 60
    ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration not activated 60
    ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer not activated 60
    ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off not activated 60
    ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high not activated 60
    ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill not activated 60
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school not activated 60
    ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer not activated 60
    ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off not activated 60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high activated 60
    ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill not activated 60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall activated 60
    ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer not activated 60
    ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off not activated 60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high activated 60
    ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill not activated 60
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist not activated 60
    ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer not activated 60
    ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off not activated 60
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high not activated 60
    ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill not activated 60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI activated 60
    ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer not activated 60
    ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off not activated 60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high activated 60
    ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill not activated 60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination activated 60
    ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer not activated 60
    ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off not activated 60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high activated 60
    ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill not activated 60
    ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display not activated 60
    ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer not activated 60
    ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off not activated 60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high activated 60
    ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill not activated 60
    ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid not activated 60
    ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer not activated 60
    ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off not activated 60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high activated 60
    ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill not activated 60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant activated 60
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer not activated 60
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off not activated 60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high activated 60
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill not activated 60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning activated 60
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer not activated 60
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off not activated 60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high activated 60
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill not activated 60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker not activated 60
    ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer not activated 60
    ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off not activated 60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high activated 60
    ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill not activated 60
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision not activated 60
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer not activated 60
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off not activated 60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high activated 60
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill not activated 60
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level not activated 60
    ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer not activated 60
    ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off not activated 60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high activated 60
    ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill not activated 60
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc activated 60
    ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer not activated 60
    ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off not activated 60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high activated 60
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill not activated 60
    ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist not activated 60
    ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer not activated 60
    ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off not activated 60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high activated 60
    ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill not activated 60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk activated 60
    ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer not activated 60
    ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off not activated 60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high activated 60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill not activated 60
    ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment not activated 60
    ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer not activated 60
    ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off not activated 60
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high activated 60
    ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill not activated 60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load activated 60
    ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer not activated 60
    ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off not activated 60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high activated 60
    ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill not activated 60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification activated 60
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer not activated 60
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off not activated 60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high activated 60
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill not activated 60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration activated 60
    ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer not activated 60
    ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off not activated 60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high activated 60
    ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill not activated 60
    ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic not activated 60
    ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer not activated 60
    ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off not activated 60
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high activated 60
    ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill not activated 60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia activated 60
    ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer not activated 60
    ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off not activated 60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high activated 60
    ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill not activated 60
    ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view not activated 60
    ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer not activated 60
    ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off not activated 60
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high activated 60
    ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill not activated 60
    ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions not activated 60
    ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer not activated 60
    ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off not activated 60
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high activated 60
    ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill not activated 60
    ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler not activated 60
    ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer not activated 60
    ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off not activated 60
    ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high not activated 60
    ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill not activated 60
    ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI not activated 60
    ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer not activated 60
    ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off not activated 60
    ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high activated 60
    ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill not activated 60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons activated 60
    ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer not activated 60
    ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off not activated 60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high activated 60
    ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill not activated 60
    ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant not activated 60
    ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer not activated 60
    ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off not activated 60
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high activated 60
    ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill not activated 60
    ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner not activated 60
    ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer not activated 60
    ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off not activated 60
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high activated 60
    ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill not activated 60
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo not activated 60
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer not activated 60
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off not activated 60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high activated 60
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill not activated 60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating activated 60
    ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer not activated 60
    ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off not activated 60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high activated 60
    ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill not activated 60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin activated 60
    ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer not activated 60
    ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off not activated 60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high activated 60
    ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill not activated 60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition activated 60
    ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer not activated 60
    ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off not activated 60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high activated 60
    ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill not activated 60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows activated 60
    ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer not activated 60
    ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off not activated 60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high activated 60
    ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill not activated 60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper activated 60
    ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer not activated 60
    ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off not activated 60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high activated 60
    ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill not activated 60
    ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol not activated 60
    ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer not activated 60
    ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off not activated 60
    ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high not activated 60
    ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill not activated 60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05 activated 64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus Databus extended 64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06 not activated 64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus Suspension data bus 64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D not activated 64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus CAB_9 64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24 not activated 64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus Comfort data bus 64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03 not activated 64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus Comfort data bus 64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B activated 64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus Terminal 15 64
    ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25 not activated 64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus Comfort data bus 64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23 activated 64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus Databus Infotainment 64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26 activated 64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus Suspension data bus 64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D activated 64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus Comfort data bus 64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17 activated 64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus Databus Infotainment 64
    ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16 not activated 64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus Comfort data bus 64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01 activated 64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus Comfort data bus 64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02 activated 64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus Comfort data bus 64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11 activated 64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus Comfort data bus 64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15 not activated 64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus Databus Infotainment 64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10 activated 64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus Comfort data bus 64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33 activated 64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus Comfort data bus 64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C Databus extended 64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C not activated 64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37 activated 64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus Comfort data bus 64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09 activated 64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus Comfort data bus 64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04 not activated 64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus Comfort data bus 64
    ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D not activated 64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus Databus drivetrain 64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08 activated 64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus Comfort data bus 64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19 activated 64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus Databus extended 64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F activated 64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus Comfort data bus 64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34 not activated 64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34 CAB_9 64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E activated 64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus Comfort data bus 64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18 not activated 64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus CAB_9 64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A activated 64
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus Terminal 15 64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20 not activated 64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus Comfort data bus 64
    ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A not activated 64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A Databus extended 64
    ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39 not activated 64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39 Databus Infotainment 64
    ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E not activated 64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus Comfort data bus 64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F activated 64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus Databus drivetrain 64
    ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B not activated 64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B Comfort data bus 64
    ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F not activated 64
    ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F Comfort data bus 64
    ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E not activated 64
    ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E Comfort data bus 64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12 activated 64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus Comfort data bus 64
    ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E not activated 64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus CAB_9 64
    ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35 not activated 64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35 Databus Infotainment 64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27 activated 64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus Databus Infotainment 64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A activated 64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus Databus extended 64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07 activated 64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus Suspension data bus 64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 activated 64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus Databus extended 64
    ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36 not activated 64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36 Terminal 15 64
    ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C not activated 64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus Comfort data bus 64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14 not activated 64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus Terminal 15 64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13 activated 64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus Comfort data bus 64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B activated 64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus Suspension data bus 64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22 activated 64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus Databus Infotainment 64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C activated 64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus Comfort data bus 64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key Not available 8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus Comfort data bus 8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school Not available 8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus Not available 8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL Available 8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus Databus Infotainment 8
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level Not available 8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus Databus drivetrain 8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering Available 8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus Terminal 15 8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN Available 8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus Comfort data bus 8
