Disable orange light on driving mode button
VAG-Dave
Scotland
HC806344
**This is for a MK7 Golf**..sorry forgot to put in title....
Basically I want to turn of the function that the driving mode selection button (by gearstick) turns from white to orange if you have the car in any other mode other than normal.
Effectively making the button light up white only
I consider an orange light to be a warning that I have activated an on/off button, but that button is not an on/off, it is a selector button & I am fed up having a bright orange led staring at me!!
I briefly saw a post on golf forum that someone had turned it off, but no mention of how.
Now I can't find the post & goggle is not much help either.
I have look in all the modules, & the main "Driving profile select" coding lines are time parameters to adjust! I know I could go into the steering & engine etc. & permanently fix those modes for those parameters.
Still having a look, but if anyone knows without having to rip the switch apart...:banghead:
EDIT:-
Just had a play in central coding 09
long coding
Byte15
Bit 5 Drive selection button installed
Bit 7 Drive selection button w/o function light installed
My car had bit 5 ticked, bit7 not ticked, so untick 5 & tick 7 = orange light out but button no longer brings up choices on infotainment screen even with engine on.
So tick both boxes = button glows orange, & does not bring up choices on infotainment
:banghead:
Further edit:-
had a mess around in
19 CANgateway
longcoding
Byte8
bits 0,1,2,3,6 were ticked in my car...
Tried various combinations in CANgateway & central electronics....(19 & 09) but is seems that the 09 longcoding Byte15 bit5 has to ticked other wise it effectively cuts of the whole switch & does not bring up the menu on the infotainment screen! But in ticking this the orange light is lit on the button....
I'm out of ideas anyone else have anything???
DV52
C?ID=194404
EDIT:-
long coding
Byte15
:banghead:
Further edit:-
19 CANgateway
longcoding
Byte8
Dave:- thanks for the PM: Not sure if I entirely understand the changes that you have undertaken, but I recently went through a process of developing a more fulsome list of the Byte/Bit function for the BCM on my test-bench which has the following details:
 Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011309901220
To get the information, I thieved data from a number of diagnostic devices including my faithful HEX-NET cable and I confirmed the Byte/Bit associations by switching on/off each descriptor in each cable and then comparing the before/after effect on the BCM code-string. Anyhow, I include below the results of my Herculean labor for Byte 15.
If my table is correct, the sequence for your task should have been Byte 15 Bit 5 =1, Bit 7 =1. This should have retained the Drive selection button and it should have disabled the orange LED- I think!
TBAx
C?ID=287144
You need Byte 15 Bit 5 and 7 enabled.
VAG-Dave
Scotland
HC806344
& that didn't work either...button still lit up orange & the menu didn't even activate with that combination!
Any other ideas??
DV52
C?ID=194404
^^^^ Dave: any chance that you could post-up a current autoscan - please?
VAG-Dave
Scotland
HC806344
This I did the other day after messing around in module19 trying lines there. It generated a few fault codes which cleared after this scan as I had just returned the coding to "before".
Saturday,29,April,2017,21:09:29:00547
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZAUZFP55XXXX   License Plate:
Mileage: 15654km-9726mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F
VIN: WVWZZZAUZFP552995   Mileage: 15654km-9726miles
Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 F    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H10 7861
   Revision: WAH10---
   Coding: 01190072234405082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM14TFS01104E906016F 002011
   ROD: EV_ECM14TFS01104E906016F.rod
   VCID: 25413F5F24E32569BA-8070
   Revision: 00000000    Serial number: 62644000001579
   Coding: 04FA8AA12425296E0380060941C82920512494C0608294F3F4205078C009
   Shop #: WSC 00028 028 00067
   VCID: 45819FDFC4A3C5699A-8010
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 02120004200400011005004200101000
   VCID: 73E51107DAB70BD9E4-8026
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86582509140616
   Coding: 03000A66C24122FB0BA44080B11C07281000000000000000000000000000
   Shop #: WSC 00028 028 00080
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79F9232FF8DB7189AE-802C
   Component: WWS    140828  042 0551
   Serial number:         140909221237
   Component: RLHS  037 0059
   Serial number: S4Y14M09D19H22M35S19
   Coding: 06A8EE
   Serial number: 000000000ZY1421702PK
   Serial number: 00000000000060620911
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39311424603534
   Coding: 0071151001
   VCID: 3D71F73FAC738DA9C2-8068
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 13091403211821
   Coding: 00000300FE0739
   VCID: 387FE62B8351A88111-806C
   Component: AirbagVW20    014 0386
   Serial number: 003MLR08TR8G
   Coding: 98FCC0C0000000005C5400CF00C800000065
   Shop #: WSC 00028 028 00065
   VCID: 7F0DCD37E6FF5FB990-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169677B23091440735
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169676B22091441270
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 609 14
   Serial number: 35767000000BE799011.
   Subsystem 4 - Part No SW: -----------    HW: 480 002 209 14
   Serial number: 3586700000048A88111R
   Subsystem 5 - Part No SW: -----------    HW: 480 401 709 14
   Serial number: 3516502AB176A6B3702A
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 14
   Serial number: 3526502BB176A6B2C2DT
   Subsystem 7 - Part No SW: -----------    HW: 480 401 409 14
   Serial number: 3556502BD175A8D3137M
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20140924400079
   Coding: 0C00
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41898BCFD08BE949A6-8014
   Part No SW: 5G1 920 950     HW: 5G1 920 950
   Component: KOMBI         304 4270
   Coding: 27A411002F80A60001887E011400000000000000
   VCID: 66C378539965EE7173-8032
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 18091410800272
   Coding: 030100042B085700EF00025E080F00010001050000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 428B84C3D58DF251BF-8016
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140002037610024382
   Coding: 2CFFFF
   Serial number: 8991084403
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000118719572
   Coding: 003F0220D001028000001000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000006622716
   Coding: 0D0000
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401PDA6
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001005
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 63C561476A579B5994-8036
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000118732755
   Coding: 003F0020DE01028000801000
   VCID: 448782DBCF99FC618D-8010
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000006626660
   Coding: 050000
   Coding: 069E00000B000200
   VCID: 408F8ECBDB81E041A9-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    041 0430
   Serial number: V7F02009141726
   Coding: 027302010000000011111202000800031F0200B60100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 67DD75579E6FF77948-8032
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS403NCT
   Subsystem 2 - Part No SW: 5G0 919 866 AE    HW: -----------
   Component:  ECE 2017  --- 0064
6669 - Optical Data Bus for Digital Sound System
          U10CC 00 [008] - Intermittent Disruption
                    Reset counter: 204
                    Mileage: 15654 km
                    Date: 2017.04.29
                    Time: 20:37:26
                    Voltage terminal 30: 12.9 V
                    Temperature of MOST transceiver-Maximum value: -50 °C
                    Temperature of MOST transceiver-Minimum value: -2 °C
                    Temperature of MOST transceiver-Current: 16 °C
6935 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 204
                    Mileage: 15654 km
                    Date: 2017.04.29
                    Time: 21:01:43
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 204
                    Mileage: 15654 km
                    Date: 2017.04.29
                    Time: 21:01:46
                    BAP-BAP_Function_ID: 02
End-------------------------(Elapsed Time: 04:06)--------------------------
Qassem
Kuwait
C?ID=325382
Did the driving mode works again like before , I have an issue , driving mode lights up and turns off right away, and driving modes not showing , neither on the main screen nor in the instrument cluster.
Please advise back
iichel
Netherlands, eastern part
C?ID=284912
Why not disconnect the wire that shows the yellow light?
iroc86
New Mexico, USA
C?ID=337264
Just last night I was looking through the adaptation channels for [09-Cent. Elect.] and found the following items that might be of interest. I'm not sure what parameters are allowed, but you might want to give it a shot. (This is from my '18 NAR Alltrack, so yours may be a bit different.)
Button in center console-Function of button 1
  >> not coded / not installed
Button in center console-Function of button 2
Button in center console-Function of button 3
  >> Driving program
Button in center console-Function of button 4
Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED
  >> LED installed
The last one may be the ticket. It roughly translates as "Button in center console add-on coding drive profile button has no LED." There may be an option to tell it there's no LED installed, but I haven't tried it myself.
iroc86
New Mexico, USA
C?ID=337264
Quick follow-up: I just tested this on my '18 Alltrack. Worked like a charm. Set it to "LED not installed." The Drive Mode button still functions the way it's supposed to, but the orange light is gone.
tomer
Israel
C?ID=324798
Octavia RS 2017 mkIII - enabled bit7 and annoying orange led turned off
