- Joined
- Nov 23, 2014
- Messages
- 154
- Reaction score
- 45
- Location
- Los Angeles CA.
- VCDS Serial number
- C?ID=242342
Hello, is it possible to do tire rotation re-learning using VCDS? if it is so How?
thanks.
about the TPMS dtcs we already fix the issues.
thanks.
Friday,28,April,2017,10:23:13:23194
VIN: WAUEV74F68N064828 License Plate: TUN SQAD
Mileage: 190470km-118352mi Repair Order:
Address 65: Tire Pressure (4F0 910 273 B)
16:09:09 Group 001: Front Left Wheel Status I
Position No Display = Not yet recognized
31.0°C Wheel Temperature
2.56 bar Wheel Pressure (actual)
2.50 bar Wheel Pressure (specified)
16:09:09 Group 004: Front Right Wheel Status I
32.0°C Wheel Temperature
2.71 bar Wheel Pressure (actual)
2.40 bar Wheel Pressure (specified)
16:09:09 Group 007: Rear Left Wheel Status I
35.0°C Wheel Temperature
2.42 bar Wheel Pressure (specified)
16:11:55 Group 010: Rear Right Wheel Status I
33.0°C Wheel Temperature
2.54 bar Wheel Pressure (actual)
VIN: WAUEV74F68N064828 Mileage: 190470km-118352miles
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4F1 910 560 E HW: 4F1 907 560
Component: 4.2l V8/4V 0010
Revision: 74H04--- Serial number:
Coding: 01050009190F0120
Shop #: WSC 79416 028 603270
VCID: A502963A6CBB1C693A-80F0
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Mileage: 189801 km
Date: 2017.04.14
Time: 17:41:48
RPM: 2041 /min
Load: 14.5 %
Speed: 56.0 km/h
Temperature: 102.0°C
Temperature: 46.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.351 V
P0087 - 008 - Too Low - MIL ON
Fault Status: 11101000
Mileage: 190143 km
Date: 2017.04.19
Time: 17:18:25
RPM: 2252 /min
Load: 50.2 %
Speed: 46.0 km/h
Temperature: 101.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 A HW: 09L 927 156 C
Component: AG6 09L 4,2 FSI USA 0010
Revision: --H04--- Serial number: 4379197
Shop #: WSC 02325 758 00200
VCID: A600913611BD177133-80F2
001924 - Shift Monitoring
P0784 - 000 - 4-5 Shift - Intermittent
Fault Status: 00110000
Fault Frequency: 15
Mileage: 189519 km
Date: 2017.04.11
Time: 11:18:40
009988 - Transmission Friction Element / Clutch E
P2704 - 000 - Apply Time Implausible - Intermittent
Fault Frequency: 26
Mileage: 189525 km
Date: 2017.04.11
Time: 11:47:19
001923 - Shift Monitoring
P0783 - 000 - 3-4 Shift - Intermittent
Mileage: 190400 km
Date: 2017.04.27
Time: 07:43:05
001840 - Gear Ratio Monitoring
P0730 - 005 - Incorrect Gear Ratio - Intermittent
Fault Status: 00110101
Mileage: 190434 km
Date: 2017.04.27
Time: 17:32:23
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Coding: 0020840
VCID: E680D136D13DD771F3-80B2
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601600891061
Coding: 0000007
Shop #: WSC 02323 758 00200
VCID: A4048B3E6781E5612D-80F0
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 D HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 361FR077516427
Coding: 0000003
Shop #: WSC 22164 444 13916
Subsystem 2 - Serial number: 00000000889780
Subsystem 3 - Serial number: 0110.10.070000000100010931ÿ
Subsystem 4 - Serial number: 010931ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030292280
Coding: 0536616
VCID: 9C74B3DE5FF1DDA195-80C8
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Coding: 0113123
Shop #: WSC 02335 785 00200
VCID: B02C776E237949C1D9-80E4
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: A71E9C32D6B70E7908-80F2
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0171526
Coding: 0000100
VCID: AF2E74123E475639C0-80FA
Reset counter: 180
Mileage: 190273 km
Date: 2017.04.24
Time: 17:05:55
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 6N AIRBAG AUDI8RH30 0300
Revision: 15H30000 Serial number: 00359D0G7WA9
Coding: 0013902
VCID: AA18650605A5331117-80FE
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME2964213E2
Subsystem 3 - Serial number: 6342CSME29641622.
Subsystem 4 - Serial number: 6352QSME42320E19C
Subsystem 5 - Serial number: 6362QSME3B2B417BS
Subsystem 6 - Serial number: 63734SME43764F3DD
Subsystem 7 - Serial number: 63834SME41114845U
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90025072750026
Coding: 0012141
Shop #: WSC 22164 444 69314
VCID: A71E9C3216B70E7908-80F2
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 983
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 72X55K3A7
Coding: 2129288
Shop #: WSC 05300 758 69175
VCID: A3068822628FE25954-80F6
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B07A04826C
Coding: F5D5DE77707A0600
Shop #: WSC 02334 758 00200
VCID: AD126E1A344B2429F2-80F8
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3499363
VCID: 987CAFCEABC9B181B1-80CC
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: E18AC22A3813B04906-80B4
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H50 0990
Revision: 00000000 Serial number: 395J.077504825
Shop #: WSC 22164 444 84353
VCID: B12A726A287340C9D6-80E4
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: 7…
Coding: 0051947
Shop #: WSC 02327 758 00200
VCID: AC14631E0F512D21E5-80F8
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01070286300000
Coding: 4619293
01134 - Alarm Horn (H12)
Reset counter: 189
Mileage: 185192 km
Date: 2016.11.26
Time: 10:40:52
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000053197
Coding: 0000026
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000031872
Coding: 0012014
VCID: DEF0F9D6096D8FB13B-808A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: u
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0007022
Shop #: WSC 02324 758 00200
VCID: A00C872E7399F94149-80F4
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
VCID: A91A9A0A00A338091E-80FC
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 394JX077820704
VCID: AE106916394D5F31CB-80FA
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000154605
Shop #: WSC 22164 444 72964
Component: von VA0 360921L0ZK
Coding: 34463039313531303544205641303336303932314C305A4B
Shop #: WSC 12345 210 01865
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0051754
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700057471
Coding: 0062422
VCID: A2088D267D95EB515F-80F6
Fault Status: 10100100
Reset counter: 193
Mileage: 189520 km
Date: 2017.04.11
Time: 11:19:25
(no units): 69.0
Voltage: 14.50 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Reset counter: 0
(no units): 0.0
Temperature: 40.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000709240154
Shop #: WSC 12336 024 394758
VCID: B4247B7ED76175E1BD-80E0
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J79201S
Coding: 1000304
Shop #: WSC 02335 758 00200
VCID: DDF2FEDA046B94A922-8088
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0051754
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Revision: 00H09000 Serial number: 06220728415302
Coding: 0021306
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005010942
Coding: 0010900
End----------(Elapsed Time: 02:37, VBatt start/end: 12.2V/12.2V)-----------
