Hi Ross-Tech team:
I am trying to make some VCDS Tweaks for a family member and got stuck with an "Unitialized Control Module" error.
The control module(s) accepted tweaks via the "Adaptation" channel, but when making tweaks via the "Long Coding Helper" (at the end of the session), it returns the "Unitialized Control Module" error code.
I tried the first two options given, but to no avail:
-- NO (for VCDS to try the values currently in the module;
-- YES (for VCDS to use default values 12345/123/12345;
What I didn't try is CANCEL (for manual entry of values), since I didn't know what values I could use.
I am hoping you can offer some suggestions, and i know Dana's adage of "No Scan, No Soup", so please see below the initial scan (before attempting any tweaks).
Thank you.
Thank you.
Wednesday,12,April,2017,11:35:02:39032
VCDS Version: 17.1.3.0 (x64)
VIN: 3VWDF71K25M639233 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62 72
VIN: 3VWDF71K25M639233 Mileage: 195160km-121266miles
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 06A 906 032 QE HW: Hardware No
Component: 2.5l R5/4V G 6607
Revision: 00000000 Serial number: VWZ7Z0E2143538
Coding: 0000003
Shop #: WSC 02147 444 13912
VCID: 71C70E2A683162C916-8024
18080 - Coolant Fan Control 1
P1672 - 004 - Open or Short to Ground - Intermittent - MIL ON
17698 - Coolant Temp Sensor at Radiator Outlet (G83)
P1290 - 002 - Signal too Small - Intermittent
Part No: 09G 927 750 AS
Component: AQ 250 6F 0649
Coding: 0000008
VCID: 022551E65D976951FF-8056
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
VCID: 3A55E90675C7E191E7-806E
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
VCID: 6CF91F5E4F138F2125-8038
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000081556
Coding: F40D8E02400418000014000000140000002077035C
VCID: 2F43C852BE85343940-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground
00975 - Heated Rear Window (Z1)
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0060
Revision: 00000000 Serial number: AUZ4Z7E3023801
VCID: 2B7BDC428A9D48196C-807E
00003 - Control Module
014 - Defective
Fault Status: 01101110
Reset counter: 89
Mileage: 180613 km
Time: 00:12:49
02788 - Internal Communications Error
Reset counter: 169
Mileage: 180613 km
Time: 00:07:05
Bin. Bits: 00000010
Bin. Bits: 00000000
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD01WP7M
Coding: 0012627
VCID: 2E7DD556B98F3D314B-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME08171803%
Subsystem 3 - Serial number: 6342MSME09784451A
Subsystem 4 - Serial number: 6351HSME066749155
Subsystem 5 - Serial number: 6361HSME06674D2CI
Subsystem 6 - Serial number: 63727SME065A502C0
Subsystem 7 - Serial number: 63827SME06505469$
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 AC HW: 1K0 953 549 AC
Component: J0527 010 0045
Coding: 0012041
VCID: 73CB0422122D50D9E4-8026
Component: E0221 007 0050
Part No: 1K0 920 971 C
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 2900105326018A
Coding: 3F7F03620F1002
VCID: 2977264A80615A099E-807C
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TP66X03
VCID: 78D1330E0B4B3381D1-802C
015 - Cannot Be Tested at this Time - Intermittent - MIL ON
Fault Status: 10111111
Reset counter: 169
Reset counter: 169
Reset counter: 169
Reset counter: 169
Component: IMMO 3HL 2120
01176 - Key
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 A HW: 3C0 959 760 A
Component: Sitzverstellung 0601
Revision: 00002000 Serial number: 00000000000000
02332 - Position Sensor for Backrest Adjustment (G440)
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
01915 - Lumbar Support Height Adjustment Sensor (G374)
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 364DFD3641DF05F103-8062
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 3041CB2EA3BB2BC159-8064
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
Component: LIN BACKUP HORN H02 1301
003 - Mechanical Failure
Fault Status: 01100011
Fault Frequency: 43
Reset counter: 89
Fault Status: 01110010
Fault Frequency: 26
Reset counter: 66
Fault Frequency: 26
Reset counter: 66
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000026495
VCID: 69F7664A40E19A095E-803C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 3753F03246D5FCF918-8062
00110 - Right Mirror Turn Signal Lamp (L132)
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 008 0014
Revision: 00008000 Serial number: VWZ4Z7E2012178
Coding: 0010010
Shop #: WSC 02147 444 60966
VCID: 20613B6EF35B9B41C9-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3147CE2AA8B122C956-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245C126ADB719D12F-8066
End-------------------------(Elapsed Time: 01:22)--------------------------
