2009 Jetta cruise control problem
Otto
C?ID=178462
Yesterday I noticed my cruise control stopped working. I ran the diagnostic tool for errors and here is what I received. I am not very familiar with deciphering but, my guess would be that the CCS module is bad. Any assistance would be great before I decide - Thx.
Saturday,02,August,2014,13:58:19:51916
VCDS Version: 12.12.2.0
Data version: 20140212
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRM71K49M058995   Mileage: 88810km/55183miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9205
   Revision: G6H02---    Serial number: VWX7Z0H82490CJ
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 3B75E7DD7AAF6CC68E5-806E
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -
                    Mileage: 88818 km
                    Time: 23:25:19
                    Load: 0.0 %
                    Temperature: 29.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.065 V
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09G-927-750.lbl
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 7DF129C5243BA2F6F01-8028
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D49270002881402ED921E00413000
   VCID: 74E70CE1D771E3BE8FF-8021
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78FF38D10B1987DEA37-802D
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001080695
   Coding: 14058E234004150007140000001400000008730B5C000120000000000000
   VCID: 326BCAF9ADE5AD8E5D3-8067
   Component: Wischer 290908 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0427278
   Coding: 0000100
   VCID: 3365CFFD52FFA486565-8066
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M06XJN.
   Coding: 0013889
   VCID: 6CD714814F413B7E57F-8039
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3754603CB
   Subsystem 3 - Serial number: 6342MSME3E136E57P
   Subsystem 4 - Serial number: 6351HSME181B37198
   Subsystem 5 - Serial number: 6361HSME18005150V
   Subsystem 6 - Serial number: 63727SME133B4348/
   Subsystem 7 - Serial number: 63827SME16385A475
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Component: J0527           051 0101
   Coding: 0010021
   VCID: 8305DF3DC2DF5406065-80D6
00576 - Terminal 15
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H82490CJ
   Coding: 0023203
   VCID: 3C77E4C17FA16BFE87F-8069
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 110808F2001704
   Coding: ED807F070003021002
   VCID: 3561F1E55C8BBAB6781-8060
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000930288918
   Coding: 0001205
   VCID: 6FED038D7E57C06672D-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A5BD2998535E54EE53-807F
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 RDK 052 0221
   Coding: 12900F880186083F2904058FB0880F0488DCA0
   Shop #: WSC 00066 123 12345
   VCID: 8407DC21C7D1533E3FF-80D1
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08072219015504
   Coding: 0001204
   VCID: 70EF00F16369DF9E6B7-8025
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2235658
   Coding: 0010401
   VCID: 29592D958033EE56EC9-807C
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003423898
   Coding: 0001168
   VCID: 76E336E9010DF1AEB1B-8023
   Component:    RDK              0450
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003465808
   Coding: 0001168
   VCID: 77FD3BED060788A6AAD-8022
Otto
C?ID=178462
Thanks for the welcome.
I have read that the brake light switch can be an issue. My car is an automatic trans - BTW. I was think more like a control module because the Cruise contril light does not come on when the turn the lever on from controlling the cruise. What do you think?
Otto
C?ID=178462
Does the 2009 Jetta have 2 brake light switches? I am thinking one on the master cylinder and one on the brake pedal. Not sure.... any help would be great.
Keithuk
Stoke on Trent, England
C?ID=122432
I would have thought just the one on the brake pedal, you need a wring diagram.
Otto
C?ID=178462
A wiring diagram or better yet, instructions on replacing the switch would be great.
Mari
C?ID=150535
Your faultcodes
00576 - Terminal 15
When the ingnition switch isn't working correct, you can get all kinds of faults.
My faultcodes:
00576 - Terminal 15
I had faults in HVAC and a few other modules, replaced the ignition switch and 99% of the faults I had were gone. If this solves your problem with CC I really don't know, but the faults of the ignition switch are serious enough to get it fixed!
Keithuk
C?ID=122432
I had a friend say his cruise control wasn't working (2008 Golf GTI Edition 30) and the speedo symbol doesn't show on the dash. so he brought it over for a AutoScan.
In Engine Long Coding cruise control was ticked so I unticked it and clicked DoIt then went back and ticked it then DoIt.
Nothing showed up only 00888 - Wiper Switch for Intermittent Operation (E22) - Defective - Intermittent
He said the intermittent wiper works which it did.
I tried to check the brake light switch in Advanced Measuring Values and all 3 light showed operation. I tried to check the clutch pedal switch but I couldn't see it listed on Engine. I clicked on Drivetrain 12 - Clutch but it kept on saying No Response from Controller. I disconnected and switched everything off but the same message showed on 12 - Clutch.
I took the pedal cover off to look at the clutch pedal switch and I couldn't see it anywhere and there are no wires anywhere near.. I can't see how the cruise control can work properly without the clutch pedal switch on a 6speed manual. There is CCS position when ticked it only showed something like 001000 all the time where the cruise was switched on or off and the resume was switched on or off what does the 001000 mean?
I looked for the CCS speedo symbol to be tested in Advanced Measuring Values but I couldn't see that listed either.
Oh slightly annoying thing in Advanced Measuring Values the components aren't listed alphabetically it would be nice if they were.
Sunday,24,August,2014,12:34:09:21184
Dealer/Shop Name: Keith Stanier
VIN: WVWZZZ1KZ8W080850   License Plate: 2008 GTI ED30
Mileage: 143570km-89210mi   Repair Order:
VIN: WVWZZZ1KZ8W080850   Mileage: 143570km/89210miles
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G73NE7VQ
   Coding: 0403000318070160
   Shop #: WSC 04096 557 00059
   VCID: 3778A660461F44A66AD-8062
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 73E0527012E7E886965-8026
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79FC6058308B92D6DC9-802C
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Revision: 00H54000    Serial number: 01000007397800
   Coding: E58D8F2700041500471400001400000000087F075C000100000000000000
   Shop #: WSC 01287 785 00200
   VCID: 71EC587868FBDA96649-8024
   Component: Wischer 260707 021  0501
   Coding: 00038805
   Shop #: WSC 01287
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     150807 046  0204
   Coding: 00208933
   Shop #: WSC 01287
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1DP8U/
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D74B44864236EF6B01-8068
   Subsystem 1 - Part No: 1K0 909 605 T
   Subsystem 2 - Serial number: 6332MSME22622F549
No Faults Found
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   VCID: 74E2516C17E9EFBE8FF-8021
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G73NE7VQ
   Coding: 0003403
   Shop #: WSC 00132 210 83585
   VCID: F1ECD878E8FB5A96E49-80A4
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 220707F1000774
   Coding: E9807F060002020003
   VCID: 306A9D7CA371939E2B7-8065
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000692
   VCID: 387AA55C4B014BDE637-806D
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3666AB644115BDAE71B-8063
   Coding: 819002005103087F2D04840570085FC690FC00
   VCID: 830082B0C2475806065-80D6
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Coding: 0000692
   VCID: 397CA058700B52D69C9-806C
   Part No SW: 1K0 035 186 AD    HW: 1K0 035 186 AD
   Component: Radio BVX       035 0047
   Revision: 00035000    Serial number: VWZ1Z2G4853168
   Coding: 0020202
   VCID: 68DA351C5B211B5E337-803D
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Component: Tuer-SG         006 1207
   Coding: 0000144
golfi_vend
Tartu, Estonia
C?ID=195131
If i remember correctly, some active faults in ECU, disable the CCS function. Your Ignition switch is bad anyways. So why not replace it?
Keithuk
C?ID=122432
I did disable CCS as I've said then enabled it again, that's what someone did when their CCS wasn't working and there's worked afterwards.
Why do you say the ignition switch needs replacing when there was only one error code for intermittent wiper?
golfi_vend
Tartu, Estonia
C?ID=195131
Actually i was replying to "otto".
For your case, was CCS turned on when looking measurements under 16- Steering Wheel?
