Hello, vehicle has come to me from another garage that has replaced the parking brake ECU but have forgotten to write down the ABS coding. Could someone please tell me what my code should be from the auto scan. Many thanks. David.
Tuesday,11,April,2017,18:44:29:58506
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ3CZ7P099179 License Plate: KS56UUB
Mileage: 119130km-74023mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ7P099179 Mileage: 119130km-74023miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 LR HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9248
Revision: --H06--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 00028 028 00001
VCID: 7AF0E3BF353BD391A7-802E
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Fault Status: 01110000
Mileage: 119123 km
Time: 07:58:41
RPM: 882 /min
Voltage: 14.59 V
Bin. Bits: 00001101
Temperature: 15.3°C
Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Mileage: 119123 km
Time: 07:58:41
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Mileage: 119123 km
Time: 07:58:41
RPM: 882 /min
Voltage: 14.59 V
Bin. Bits: 00001101
Temperature: 15.3°C
Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Mileage: 119123 km
Time: 07:58:41
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 HW: 3C0 614 109
Component: ESP 440 C4 H018 0001
Revision: H018 Serial number: 0668165604
Shop #: WSC 00671 210 95609
VCID: 5BBE863B9AC10A99DC-800E
Part No: 1K0 820 047 GK
Component: Climatic PQ35 120 0606
VCID: 73EECE9B1251A2D9E4-8026
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006050253
Coding: 00800F0700041A00470A00000F000000000859435C0001
VCID: 6BDED6FB4A617A192C-803E
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 141106 022 0601
Coding: 00046997
Shop #: WSC 00028
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0C AIRBAG VW8 031 2522
Revision: 11031000 Serial number: 003B1PP381TK
Coding: 0012355
VCID: 30640197A3C7D9C159-8064
Subsystem 1 - Serial number: 6332MSME14290E40
Subsystem 2 - Serial number: 6342MSME15214270
Subsystem 3 - Serial number: 6351HTS6GIE4H8A6
Subsystem 4 - Serial number: 6361HTS6GIEG1P37
Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507AH
Coding: 0000013
VCID: 356A30835CA5FCE90A-8060
Part No SW: 3C0 920 960 K HW: 3C0 920 960 K
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007405
Shop #: WSC 00488 210 71781
VCID: 2B5E16FB8AE1BA196C-807E
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06B0309EC
Coding: 3DFD0C04C21003
VCID: 2142F4D3F82D6049C6-8074
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 39723CB370BD1889EE-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1124
Revision: 32008001 Serial number: 00000064469117
Coding: 0000693
VCID: 3B7E26BB7A812A99FC-806E
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.134 H07 1806
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 01910A0001860E763004941570085FCE107CA0
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1124
Revision: 32008001 Serial number: 00000500969110
Coding: 0000692
VCID: 3C7C25A77F8F2DA1F5-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0010000
VCID: 2648E7CF91038771B3-8072
000 - - - MIL ON
Fault Status: 11100000
Fault Frequency: 21
Reset counter: 77
Mileage: 119096 km
Time: 13:26:36
Voltage: 12.42 V
Count: 170
000 - - - MIL ON
Fault Frequency: 30
Reset counter: 76
Voltage: 11.49 V
Count: 171
Part No: 1K0 035 186 T
Component: Radio GR0 020 0023
Revision: 0002006S Serial number: VWZ2Z2F1310727
Coding: 0040400
VCID: 37763A8B46A90EF918-8062
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11005001 Serial number: 00000000883071
Coding: 0000144
VCID: 3D7A28A3649524A9C2-8068
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11005001 Serial number: 00000000904652
Coding: 0000144
VCID: 3E782FAF69933FB1DB-806A
End-------------------------(Elapsed Time: 02:17)--------------------------
