Guyz I need your help please I bought a used Passat b6 comfort line 3 months ago , so far the car is going good except for two problems I would appreciate it if you can help me
1st when I first had the car a friend of mine came to me and messed with my tire pressure monitoring coding and its not working any more I tried following this guide
http://forums.ross-tech.com/showthr...ion-reset-and-disable-coding-with-VCDS-mk6-VW
but the long coding option does not appear in my abs controller only coding with the pop up +0002048 "as I understand I added 0002048 to current 0002362 resulted in 0004410" still not working it was working on the code 2362 when I first got the car and the system alerted me when a tire was a little under pressure and reseted using button
2nd is in the kessy system and I will explain the case in details : the car engine starts fine even if I used a dummy key (just a fob with no chip in it) and the original key is inside the vehicle ,if the car is locked and the remote is in range I can open the trunk with the handle when the key is in my pocket ,BUT I can not do it with the doors I tried many times with each door I noticed that the rear right door has a different handle not with a button like the other three doors (I guess the previous owner changed with a non kessy handle)
so does the door kessy unlock and lock function does not work unless all doors are fine and no errors so that's why I cant use it and if I bought another door handle with kessy and installed it for the rear right door will it work normally or it needs a special programming (I think its only an antenna no programming needed)
I hope someone can help me as I have no vw dealer is close to my city all I have is my vag cable and my tool set
PS I had a problem with the automatic dimming of the driver side mirror I fixed it (was just a loose wire from inside mirror) and its amazing while driving at night
Thanks in advance
Here is my vcds scan for reference
Thanks in advance
Monday,10,April,2017,13:19:55:25293
VCDS Version: 17.1.3.0 (x64)
VIN: WVWZZZ3CZBP002381 License Plate:
Mileage: 104450km-64902mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 53 55 56 5D
62 72 77
VIN: WVWZZZ3CZBP002381 Mileage: 104450km-64902miles
5D-Operations -- Status: OK 0000
Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
Part No SW: 03C 906 016 P HW: 03C 907 309 A
Component: MED17.5.5 G 9220
Revision: LCH09--- Serial number: VWZCZ000000000
Coding: 0000077
Shop #: WSC 29940 000 1048576
VCID: 2C573D7F8F69FA2165-8078
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 L HW: 0AM 927 769 D
Component: GSG DSG AG7 431 9059
Revision: 00043014 Serial number: 5ZV01405170628
Shop #: WSC 02411 360 36000
VCID: 3979142B703B5F89EE-806C
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000705758995
Coding: 0002362
Shop #: WSC 00028 790 00008
VCID: 62CB9347BD2D7C519F-8036
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
Shop #: WSC 00028 028 00021
VCID: 7EF3C737E195B8B19B-802A
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000006042168
Coding: E3868F0700041A00470A00000F000000000B5D435C000120000000000000
Shop #: WSC 00028 028 00001
VCID: 336526035257A5D924-8066
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 030510 006 0208
Coding: 00046997
Shop #: WSC 00028
Component: RLS 280510 054 0403
Coding: 00208936
Shop #: WSC 00028
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88591013488557
Coding: 300105
VCID: 408F79CFD3E10E41A9-8014
Part No SW: 5N0 959 655 N HW: 5N0 959 655 N
Component: J234__005 VW10 HI 1916
Revision: 21014000 Serial number: 003GHPAG7Y32
Coding: 0012341
VCID: 489F61EF3BD1360161-801C
Subsystem 1 - Serial number: 6332MTS663941260
Subsystem 2 - Serial number: 6342MTS616261270
Subsystem 3 - Serial number: 6351HTS602EH89KJ
Subsystem 4 - Serial number: 6361HTS6PTHC99KJ
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0135
Revision: FF010036 Serial number: 20100527301015
Coding: 099A270002
VCID: 6BD5FE6382E73D192C-803E
Component: E221__MFL-TK6 H06 0022
Coding: E30000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C0 920 872 F HW: 3C0 920 872 F
Component: KOMBI H03 0305
Coding: 160F00
VCID: 285FC16F5391D60181-807C
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P105260792
Coding: FDA1FF06002602001002
VCID: 2F6D2A73BE7F813940-807A
Part No SW: 3C0 959 799 H HW: 3C0 959 799 H
Component: IMMO 071 0383
Revision: 00071000 Serial number: VWZCZ000000000
VCID: 3E730737691578B1DB-806A
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0305
Revision: 12101005 Serial number: 0000973049
Coding: 0011B7
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2643CF575985C071B3-8072
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0402
Serial number: 00000001498411
Coding: 000090
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.204 0802
Revision: 1AH03728 Serial number: 00101370181201
Coding: 0000258
VCID: 3B750E237A076D99FC-806E
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Component: 01 KESSY PQ46 R 071 0231
Coding: 18910A0001C64E763400941570008F0E70780103242498
Subsystem 1 - Part No: 1K8 951 605 A
Component: LIN BACKUP HORN H11 9004
Reset counter: 169
Mileage: 104451 km
Date: 2011.09.01
Time: 13:11:58
02864 - Passenger's Door Handle Touch Sensor Incorrectly Installed
Reset counter: 169
Mileage: 104451 km
Date: 2011.09.01
Time: 13:11:58
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 A HW: 3C0 959 792 A
Component: TUER-SG BT 002 0305
Revision: 14101005 Serial number: 0000946337
Coding: 0011B6
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 275DC2535E8FD97988-8072
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0402
Serial number: 00000001500327
Coding: 000090
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 011 Serial number: 00000000292934
Coding: 0000057
Component: AFS-Steuergeraet 0142
Coding: 2311361
VCID: 3467251F5759A2E13D-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3528638
Coding: 0D00040004
VCID: 62CB93477D2D7C519F-8036
Address 5D: Operations Labels: 3C0-035-151.lbl
Part No SW: 3C0 035 151 C HW: 3C0 035 151 C
Component: J738 011 0019
Revision: 00011000
VCID: 183FF1AF2BF1668131-804C
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660205942
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 3561181B9423BBE90A-8060
End-------------------------(Elapsed Time: 02:44)--------------------------
