Results 11 to 20 of 36
Thread: Stage 2 Tune made my GTI 1.8T go bonkers! Please help
    New User 30secondgti's Avatar
    Jul 2014
    Vancouver, B.C
    Hey Jack,
    Did you see my pictures, did they post properly?
  2. #12
    Yes nice clean bay.
    I un-approve of your type hose clamps.....yuke! RULE! Only use Zebra/Norma screw type or crimp type for 360 degree clamp force!
    Okay that diverter you have is the spring maybe set to stiff? Please verify.
    Sorry had to find another ZPM to get back here to establish a wormhole.
  3. Likes jakematic liked this post
  4. #13
    Jul 2014
    Vancouver, B.C
    Where yah been?? usually its me that is MIA!
    Thanks, it came that way from previous owner. I've also used some meguiar's shine on various parts of the bay.
    Type hose clamps or tight hose clamps?
    The clamps came that way too, I haven't changed or added any. Aren't the ones currently installed stock? What's wrong with them, why would changing them be better? (i'm assuming these ones are too tight)?
    Diverter Valve came that way with the car... Another thing on the list to check (DV spring) when my mechanic is back from holidays (end of August)
    I also REALLY WANTED to Stress This: Our Tuner, My Landlord and myself all feel that the car is running rich. when the car idles on the driveway the exhaust is very strong. I can also smell it while the car is parked in the garage (not running). I suppose that could MEAN A NUMBER OF THINGS. Bad MAF or OXS are probably a cheap place to start? Interestingly enough, the car doesn't throw any faulty codes with a stock flash (like I've previously mentioned). Is this the case sometimes...running rich doesn't prompt any DTC's?
    Encounter any Goa'uld or Borg along the way?
  5. #14
    TYPE!
    Nope not stock.
    These type clamps you have, cause leaks by ripping boots and don't seal 360 degree of clamp force.
    Na saw a Wrathe hive ship, however, it was sleeping.......I am more concerned about Replicators recently crossing the Southern boarder of the USA here on Earth.
    I would take a good look at the injectors being correct part # and that the fuel PSI/regulator is not set to high.
  6. Likes jakematic liked this post
  7. #15
    Jul 2014
    Vancouver, B.C
    Well this is startling news I must say. I wonder why the previous owner put these no good clamps on...no wonder I could be running rich, perhaps a boost leak.
    Haha no comment on the Replicators..up here in Canada; we're far away from all the hype and logistics.
    I'm such a rookie. I have no idea where the fuel/ psi regulator is. I didn't even know that existed..
    Sounds like my list of things to do just became one item longer.
    Species 8472 has really been on my mind lately, run!
  8. #16
    NC USA
    Said clamps caused the leak in the power conduit - Jack knows of where he speaks, damn close call on the Hippaforalkus...
    I never let that junk on my ship. The Destiny is still on mission...
  9. #17
    Jul 2014
    Vancouver, B.C
    What about that double ground on the battery? That really seems like over kill...
    Orion is really stepping up..?
  10. #18
    Redundant rounds on hand or grounds are never a bad idea.
    In this thing a requirement, since history shows this to be a solution throughout VW-AUDI time travel.
    No matter what timeline I find myself in........... this problem never changes!
    Hey...........on another note I found the planet which manufactures the ZPM/DHD parts for the ancient races.
  11. Likes jakematic liked this post
  12. #19
    Jul 2014
    Vancouver, B.C
    I'll update after we do the aforementioned diagnostics and tests
  13. #20
    Jul 2014
    Vancouver, B.C
    So I just had a look under the hood since I had some free time today. Looks like some of the hose clamps are Eurojet...
    Car is revving all by itself, fluctuating from 1000 rpms to about 180. Have lost almost all of the gas predal/ throttle control.
    Ran yet another Auto-scan, and cleared all the DTC's, so the car is running semi normal (that is until I drive it around for a hour or two, all faults will come back)
    We're installing a new stock ECU tomorrow evening.
    Will update after its installed and adapted.
    For some personal info and if anyone is interested, here's the Auto-scan below that I did when the car lost almost complete throttle response with ghost revving.
    ABS fault code seems to be the new one (after things got worse and lost throttle response)
    interesting....
    Wednesday,20,August,2014,17:42:31:50875
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: 9BWDE21J7240xxxxx
    Mileage: 145080km-90148mi
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: 9BWDE21J7240xxxxx   Mileage: 145080km/90148miles
    Address 01: Engine        Labels: 06A-906-032-AWP.lbl
       Part No: 06A 906 032 HS
       Component: 1.8L R4/5VT     G   0008
       Coding: 07500
       VCID: 76EDE6CC520186AEB1B-513C
       3VWSE69M62M193142     VWZ7Z0B4932131
    17972 - Throttle Actuator (J338)
                P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
    17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
                P1171 - 35-10 -  - Intermittent
    Readiness: 0010 1001
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 K
       Component: ASR FRONT MK60      0103
       Coding: 0021505
       Shop #: WSC 00000 785 00200
       VCID: 32651ADCAEE9DA8E5D3-513C
       Part No: 1C0 909 605 A
       Component: 1M AIRBAG VW51 02   0004
       Coding: 12621
       VCID: 2245EA9CAE094A0EAD3-5120
    00591 - Seat Belt Switch; Driver (E24)
                32-10 - Resistance Too High - Intermittent
       Part No: 1J0 920 806 J
       Component: KOMBI+WEGFAHRSP VDO V07
       Coding: 07332
       VCID: 2E5D0EACEAD1FE6E39B-5120
       9BWDE21J7240xxxxx     VWZ7Z0B5281213
    01177 - Engine Control Unit
                64-10 - Not Currently Testable - Intermittent
       Part No: 6N0 909 901
       Coding: 00006
       VCID: F0E150D4B065289EEB7-5102
       Part No: 1C0 959 799 C
       Component: 1J Komfortgerát HLO 0003
       Coding: 00064
       VCID: 37732BC8158B3FA66AD-4B00
       Component: 1J Tőrsteuer.FS KLO 0002
       Component: 1J Tőrsteuer.BF KLO 0002
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 E
       Component:    Radio ZSW        0010
       Coding: 00031
    Last edited by Uwe; 08-20-2014 at 08:35 PM. Reason: Wrapped CODE tags around Auto-Scan
