chain drive 2.0T driving me up the wall
tdijetta99
C?ID=26025
ok here goes.. 2008 Passat 2.0TSI (chain driven). Car came to me setting a cam/crank correlation code 16400/P0016. idled choppy but drove fine otherwise. no chain noise whatsoever. has a little over 105k and zero history (local used car dealer got it from the auction).
To date I've done about 10-12 of the TSI chain replacements so I'm no stranger to these.
I pulled the upper cover and measured everything as outlined in this thread
http://forums.ross-tech.com/showthr...Chain-Drive-P0016-Cam-Crank-correlation-check
and my measurements indicated a stretched or improperly installed chain. The tensioner was also nearly all the way extended. The guides did not look to be excessively worn. I replaced the chain and tensioner and now the measurements are dead on (62.5mm/125mm). I verified the front cover marks with a TDC stop when I had it all apart and the balancer/front cover mark is also perfect. Also worth noting, there was zero sludge under the valve cover. oil pressure hovers just under 20psi hot (90C) idle, and 45-50psi at 2000rpm
unfortunately it's still setting the 16400/P0016 code. I pulled the cover again to double check the physical timing and it's still spot on. The spool valve doesn't appear to be sticky or contaminated, and the solenoid draws current and snaps out when power is provided.
The autoscan is from shortly after a warm restart after clearing the codes. it randomly will set a cam sensor signal code but I did have the opportunity to swap the cam sensor with a friend's GTI and no change in either car.
Thanks in advance,
Jason
Tuesday,23,May,2017,18:57:16:51340
VCDS Version: 17.1.3.0 (x64)
VIN: WVWJK73C88P116319   License Plate: ED
Mileage: 163550km-101625mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWJK73C88P116319   Mileage: 163550km-101625miles
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3319
   Revision: AAH03---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 00017 666 00413
   VCID: 6FE73C157E55803900-803A
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
               P0016 - 000 - Incorrect Correlation
                    Mileage: 163557 km
                    Date: 2017.05.16
                    Time: 04:56:24
                    RPM: 972 /min
                    Load: 38.4 %
                    Temperature: 98.0°C
                    Temperature: 53.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.589 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected
                    Mileage: 163557 km
                    Date: 2017.05.16
                    Time: 04:56:24
Readiness: 0110 0101
   Part No SW: 09G 927 750 HD    HW: 09G 927 750 HD
   Component: AQ 250 6F           1176
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 00028 028 00001
   VCID: 7AF11D413517D591A7-802E
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 K    HW: 3C0 614 109 K
   Component: J104    C4 440 V2   0005
   Revision: --020---    Serial number: 00000785432658
   Coding: 0000348
   VCID: 26491931912F8171B3-8072
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 7CFD1B593F23EBA1B5-8028
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 01000005612704
   Coding: 10848F0340041A00470000000F000000000859435C000100000000000000
   VCID: 71E33A6D686196C916-8024
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 150208 003  0205
   Coding: 00046997
   Shop #: WSC 00028
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__01F VW10 HI   1815
   Revision: 19013000    Serial number: 0039BP4G6RW4
   Coding: 0012614
   Subsystem 1 - Part No: 3C0 959 339 D
   Component: BF-Gewichtsens. 001 0002
   Subsystem 2 - Serial number: 00000000000KPN
   Subsystem 3 - Serial number: 0018.02.080000100000640099ÿ†63
   Subsystem 4 - Serial number: 640099ÿ†6333FTS647180528 ÿ†63
   Subsystem 5 - Serial number: 80528 ÿ†6343FTS623750108 ÿ†63
   Subsystem 6 - Serial number: 50108 ÿ†6353ETS6Q6FPSVNH ÿ†63
   Subsystem 7 - Serial number: PSVNH ÿ†6363ETS624JPSVNH ÿ†63
   Subsystem 8 - Serial number: PSVNH ÿ†6374CTS6PM7NSVNP ÿ†63
   Subsystem 9 - Serial number: NSVNP ÿ†6384CTS69UFNSVNH ÿ
   Subsystem 10 - Serial number: NSVNH ÿ
   Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AP
   Coding: 0001013
   VCID: 6CDD2B194F437B2125-8038
   Part No SW: 3C0 920 971 F    HW: 3C0 920 971 F
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007205
   VCID: 285517099B3B970181-807C
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P08313055C
   Coding: FD807F070012021002
   VCID: 234F0025E21D7459D4-8076
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1166279TSAGR06
   VCID: 6DDB261D7459722932-8038
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 08151 444 54287
   VCID: 73EF3065127DA4D9E4-8026
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000577288316
   Coding: 0001205
   VCID: 3B7FD8457AAD2C99FC-806E
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   VCID: 356BCE7D5C89FAE90A-8060
   Component:    KSG PQ46 RDK 051 0221
   Coding: 13910F8001862E521004141FF08A0F0E085801
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000630388302
   Coding: 0001204
   VCID: 3C7DDB597FA32BA1F5-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000405302
   Coding: 0000057
   VCID: 2953120D8031AE099E-807C
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
   Component: Radio DE2       015 0019
   Revision: 00015000    Serial number: VWZ4Z7H6332079
   Coding: 0040401
   VCID: 1F470CD5CE7550B9F0-804A
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
   Component: J388   TUER-SG HL   0308
   Revision: 42004101    Serial number: 00000000283686
   Coding: 0001168
   VCID: 72E135616D67ADD1EF-8026
   Coding: 0100101
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
   Component: J389   TUER-SG HR   0308
   Revision: 42004101    Serial number: 00000000298081
   Coding: 0001168
End---------------------(Elapsed Time: 02:20, udsna)-----------------------
Oil PSI issue or the timing is out and based on the slack on wrong side of the tensioner when oil PSI is made to retard timing.
tdijetta99
C?ID=26025
the timing according to the chain links and my digital caliper is dead on, unless the measurements in the thread I linked above are wrong, and/or the dark links on the new (from VW) chain were in the wrong spots.
As mentioned, oil pressure is a touch under 20psi hot idle (measured at the sender under the oil filter), and 45-50psi at 2000rpm. well over 60psi on a cold start so I doubt it's a pressure issue unless it simply isn't getting to the camshaft adjuster for whatever reason
Could always be a bad adjuster...........however, I refer to what I aforementioned.
Can't even count the number of times the OP or tech said that it was in time and when I observed it was not!
I have to ask why are you not using the repair manual to setup the timing?
Jef
HQ
The issue with oil pressure testing.... there isn't a test port where the cam adjuster is. So while the oil filter may be getting good oil pressure, there could be issues on the top side of the engine.
Run the engine up to temp, let idle, go into 01-08-093.3, what is the value? Do a WOT snap, what does the 3rd field go to?
tdijetta99
C?ID=26025
The timing chain was installed according to the service manual procedure. It's very simple with the cam chain especially when replacing it. the colored links align with the marks on the sprockets. After running the engine obviously the colored links aren't going to correspond anymore hence the measurements outlined in the other thread. The links will realign every 166 engine revolutions according to VW's EA888 study guide..
The thread I linked in my original post. Does it outline incorrect measurements?
As I mentioned before, this is not my first time doing one of these.
tdijetta99
C?ID=26025
I'll check that after work today.. I don't remember if it was group 93 or 94, but one of them i believe was stuck at 28KW.
It did something weird once though. I held rpm up near 4k (limiter in park) for about 20 seconds and when it came back down it idled smooth. revved it a little (1500) and it immediately got choppy again. I'll try to get it to do it again this evening and log 93 and 94
Sounds like oil PSI/Volume related to me and maybe the sump is part plugged at the screen or sludge is congregating during operation with floaters.
Drop the pan to inspect the sump.......
The screen should be removed & observed with a flashlight in reverse direction & to see the path is clear.
Apparently you need your basics rechecked........
If the sump screen is part blocked it will be like you installed a small volume pump and maintained PSI.
PSI is not a good indicator for a volume test.
tdijetta99
C?ID=26025
Yeah I probably will pull the pan. There was no evidence of sludge up top but I know that doesn't necessarily mean there isn't anything in the pan. It's easy enough to pull, but I have a feeling there won't be anything in there especially since it malfunctions immediately on a cold start.
Than maybe you have a stuck closed PSI valve raising PSI to the point of uncontrolled effect with thick fluids as a result.
That's why we JPPSG to get to the bottom of things.........:rolleyes:
RULE :
Never ever do timing chains or adjusters without inspecting a sump and all control + changing the filter.
NostraJackAss Has Spoken!
tdijetta99
C?ID=26025
Yeah I know about JPPSG lol..
This one initially seemed like just another routine TSI chain job.. Not this time.. I know y'all don't really know me from a hole in the wall but I'm not one to ever throw parts at a problem without testing things first. I can't count how many I see come in that someone emptied the parts cannon trying to sort out something that ends up being a $50 fix at the end of the day
ivagp
C?ID=95551
If you can rev it and make it idle differently I would say it's definitely oil volume. Change the oil filter and see how it behaves if it's still misbehaving dropped oil pan check the pickup. If everything checks out okay pressurize the system and check for leaks. Don't let the engine warm up in the bay and then check oil pressure go out and drive it for 10 miles and then come back and check for oil pressure
ivagp
C?ID=95551
I forgot to mention check cam correlation before it warms up and then check can correlation after it warms up. If Cam correlation while engine is cold is good and it only falters after it warms up then you know you have the chain on right and you have oil volume issues
The hole in the wall just isn't going to do it for me.......
Let me follow up on my reiteration.........to proper lubrication guidelines.
It's important to check oil beforehand & to get things fired up properly!
It's further more important that it be flowing with oil not just an occasional drip! :rolleyes:
Someone gets an A+ today!
He says cold but yeah can be inverse on temp if a sticky issue causing too much PSI too.
tdijetta99
C?ID=26025
The cam correlation is off right from a cold start since it's choppy as soon as the idle starts to settle down (also sets codes imediately), and still off when at operating temperature. The more I think about it, the more I think it has to be a volume issue to the actuator itself. I know it takes a certain amount of oil pressure inside the actuator (8psi IIRC) to release the pin so it can adjust away from the fully retarded position. It's acting like it's physically stuck in the retarded position most of the time.
oil and filter are fresh.. Liquimoly 5w40 is the oil that is in it, and a Mann filter.
Unfortunately I cannot drive the car out on the road since it's a dealer's car and is not registered. There is a dead end road by my shop that's about a mile long that I can get away with driving on but that's about it. I can get the oil temperature up to near coolant temperature just holding the rpm up for a few minutes. The pan was reading 185F surface temperature when I checked the pressure before.
My first step this evening is going to be pulling the pan to inspect for debris/clogged screen etc.
DrPeter
16.4905° S, 151.7375° W
- The values found in the Audi Volkswagen - 2.0L Chain Drive - P0016 Cam/Crank correlation check are correct, the values are from some of my old dealer training material and have been verified by my self several times, most recently last month on a 2011 Passat CC engine job.
Silly question I need to ask, because I see no mention of it, but did you happen to look at the 'Camshaft Bridge' as mentioned in the correlation check forum post? See image ref below again....
The screen must not be missing, damaged, etc... if so I would check the camshaft/head for wear and replace worn/damaged parts as needed.
Hope that helps,
drpeter
OMFG..........
Timing starts out at the FULL advanced position....... not the retarded for the retarded that think this.
Second it seeks a retarded target based on oil permitted to change it by the solenoid.......:p
The pin locks it in the advanced position to aid in cold start because cars start better cold with advanced timing not retarded.
That is why when no oil PSI is exhibited the adjuster will display and over advanced DTC!
Nice Post Peter............When will we make them understand?
tdijetta99
C?ID=26025
I think the screen was previously removed. the check ball is still in there but the screen and plastic surround are completely gone. I didn't see any evidence of leftover screen or plastic bits anywhere.
I'll pull the bridge back off and double check for wear at the camshaft interface. Are there specs for the inside diameter of the bridge or outside diameter of the camshaft?
This thing came from the auction so at this point I wouldn't be surprised if someone took the vanes out of the actuator.
tdijetta99
C?ID=26025
OMFG..........
There's absolutely ZERO need to be condescending or to sit there and call me retarded.
According to the self study guide, the cam locks in the retarded position. Is VW wrong?
Jef
HQ
Kind of what my MVB 093.3 question is leading up to.
All hail Tech Tip 01-15-08
2008 - 2015 with those damn chain drive engines. P0011, P0016, P000A, P0341, and or P052A
MVB 093.3 should not go over +/- 5 degrees. If so, suspect that the screen located in the camshaft adjuster bridge has come apart and lodged itself within the camshaft adjuster spool and the intake camshaft adjuster.
blah blah blah... more stuff I'm glossing over now... ah, the last part of this Tech Tip...
Despite the failure found, the repair should include replacement of the camshaft adjuster bridge, intake camshaft and the spool valve adjuster
Poop just got expensive if not covered under some kind of extended warranty. :( At any rate, see if you can get yourself a copy of Tech Tip 01-15-08 (November 13, 2015) from your local dealer. I'd gladly give you a copy of mine, but legal reasons prevent it. :banghead:
