Retrofit 3Q0 ABS Pump
myounus
Northwest UK
C?ID=321059
Greetings
Please ignore all errors as the car has a flat battery and was involved in an accident and is being charged up. I'll post a proper scan when I've finished the body repairs.
It is a 2014 Golf MK7 that has Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H ABS pump which I'm pretty sure is not compatible with blind spot assist, unless someone can advise otherwise.
I think it'll need to be changed to a 3Q0 one. If so would there be any recommendations someone could make or wold any 3Q0 part number suffice? Would it be possible to recode a second hand ABS module or am I better avoiding this altogether??
VCDS Version: 18.9.1.0 (x64)
Dealer/Shop Name: VW UK
VIN: WVWZZZAUZEP074956   License Plate: BLUE
Mileage: 52284km-32487mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP074956   Mileage: 52284km-32487miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5520
   Revision: 83H22---
   Coding: 011D0012036505082000
   Shop #: WSC 00028 028 00072
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AFC4FC4FDD1809A93-802E
21605 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [175] - Malfunction
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 14:05:53
                    Coolant temperature: 35 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 12.540 V
                    Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 184.6 °C
                    Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: -0.0 °C
                    Particle filt.inlet temp.sens.1 bank 1: raw value: 38.9 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 25.3 °C
                    Shut-off timer: last engine shut-off time: 5 s
          U0428 00 [032] - -
                    Mileage: 52284 km
                    Date: 2018.12.04
                    Time: 00:00:12
                    Coolant temperature: 6 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 11.640 V
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:23
                    Engine speed: 2397.50 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 56 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 105 °C
                    Voltage terminal 30: 14.540 V
                    Limitation: accelerator pedal: 418.9 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 0
                    selected gear-Bits 0-7: 3
Readiness: 1 1 0 0 0
   Part No SW: 0D9 300 040 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4305
   Revision: 03252204    Serial number: TFK01401250588
   Shop #: WSC 00028 028 00066
   ROD: EV_TCMDQ250021.rod
   VCID: 224C57A435C1285AEB-8076
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6054400000042F
   Coding: 01FA8AA1242709700380060541C92980512490C0608294F3F8625078C202
   Shop #: WSC 00028 028 00241
   VCID: 7CF049DCF7E5BEAA81-8028
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 250
                    Mileage: 52284 km
                    Date: 2018.12.04
                    Time: 00:01:03
8192 - Databus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:23
8196 - Databus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:23
                    Reset counter: 210
                    Mileage: 52284 km
                    Date: 2018.12.04
                    Time: 00:01:03
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 35669CF8944FAFE23E-8060
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.29
                    Time: 08:55:58
                    Outside air temperature: 63.0 °C
                    Engine speed: 900 /min
                    Temperature after evaporator: 7.0 °C
                    System run time-Engine running time: 2 s
                    System run time-Terminal 15 on: 6 s
459527 - Databus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 14:05:54
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Fault Frequency: 20
                    Reset counter: 245
                    Mileage: 48603 km
                    Date: 2018.09.28
                    Time: 08:01:21
                    Voltage terminal 30: 11.4 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
                    Auxiliary heater: in stages-Act.val.: 1
          P1719 00 [008] - -
                    Fault Frequency: 76
                    Reset counter: 248
                    Mileage: 48249 km
                    Date: 2018.09.24
                    Time: 04:20:09
                    Voltage terminal 30: 13.9 V
                    Auxiliary heater: in stages-Act.val.: 3
          B10CD 00 [008] -  -
                    Reset counter: 250
                    Mileage: 52284 km
                    Date: 2018.12.04
                    Time: 01:14:56
                    Voltage terminal 30: 10.6 V
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011405501740
   Coding: 03001842C241027B0BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 79FE50C8F8D78B829A-802C
   Component: WWS    140216  042 0551
   Serial number:         140218200751
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M02D28H03M27S12S8
   Coding: 00A8DD
   Serial number: 000000000ZY140340CLY
   Serial number: 00000000000028780639
7 Faults Found:
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:23
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [009] - Open or Short to Plus
                    Reset counter: 210
                    Time: 00:00:00
8714 - Bulb for Left Fog Lamp
          B121F 15 [009] - Open or Short to Plus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.29
                    Time: 09:04:32
8970 - Bulb for Right Fog Lamp
          B1220 15 [009] - Open or Short to Plus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.29
                    Time: 09:04:25
137217 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Fault Frequency: 12
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 14:05:52
204546 - Remote key 2
                    Reset counter: 14
                    Mileage: 43719 km
                    Date: 2018.07.31
                    Time: 09:04:02
550420 - Databus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:23
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331403702212
   Coding: 0071151011
   VCID: 3E7483D4A1796CBAEF-806A
7 Faults Found:
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [008] - Open Circuit
                    Reset counter: 250
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:30
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [009] - Open or Short to Ground
                    Reset counter: 210
                    Mileage: 52284 km
                    Date: 2018.12.13
                    Time: 03:18:25
1112084 - Front Left Center Parking Aid Sensor
          B10F8 14 [009] - Open or Short to Ground
                    Reset counter: 210
                    Mileage: 52284 km
                    Date: 2018.12.13
                    Time: 03:18:25
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [009] - Open or Short to Ground
                    Reset counter: 210
                    Mileage: 52284 km
                    Date: 2018.12.13
                    Time: 03:18:26
1111826 - Front Left Parking Aid Sensor
          B10F7 12 [009] - Short to Plus
                    Reset counter: 210
                    Mileage: 52284 km
                    Date: 2018.12.13
                    Time: 03:18:52
13637426 - Databus
                    Reset counter: 250
                    Mileage: 52284 km
                    Date: 2018.12.04
                    Time: 00:01:03
13637888 - Databus
                    Fault Frequency: 9
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 14:05:52
Address 13: Auto Dist. Reg
   Component: AirbagVW20    014 0386
   Serial number: 003MLR03W5K4
   Shop #: WSC 00028 028 00061
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F0ABED0E6F3A5B2A4-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169677B28021450347
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169676B27021450365
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 402 14
   Serial number: 35767000000705E00F0Q
   Subsystem 4 - Part No SW: -----------    HW: 480 002 702 14
   Serial number: 35867000000A4B251F0Y
   Subsystem 5 - Part No SW: -----------    HW: 480 402 502 14
   Serial number: 3516502BB142B1C08210
   Subsystem 6 - Part No SW: -----------    HW: 480 402 802 14
   Serial number: 3526502A312F6292D3FI
   Subsystem 7 - Part No SW: -----------    HW: 480 402 402 14
   Serial number: 3556502C112F62954096
1054981 - Databus
                    Fault Frequency: 9
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 14:05:56
1050117 - Databus
                    Reset counter: 250
                    Mileage: 52284 km
                    Date: 2018.12.04
                    Time: 00:01:03
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 03031404220519
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BF24AC0F2EBB99288-802E
   Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
   Component: KOMBI         252 2210
   Coding: 27A419082780260001886A01040000
   VCID: 2858458C53FDC20AB5-807C
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 250
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:26
16776960 - Databus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:22
16776961 - Databus
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:22
13639936 - Databus
                    Fault Frequency: 13
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 14:05:52
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 04031410800267
   Coding: 030100040B087300EF00005C1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3F8AFED0A67365B2E4-806A
   Component: E221__MFL-DC1  H15 0038
   Serial number: 29140000230530104075
   Coding: 2DFFFF
   Serial number: 5289432703
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Fault Frequency: 21
                    Reset counter: 210
                    Mileage: 52284 km
                    Date: 2018.12.04
                    Time: 00:01:04
                    Supply voltage: Terminal 30: 11.5 V
                    Terminal 15: On
66054 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
                    Fault Frequency: 17
                    Reset counter: 250
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:25
                    Supply voltage: Terminal 30: 14.6 V
                    Terminal 15: On
65798 - Extended CAN in One-Wire Mode
          U0054 00 [008] - -
                    Reset counter: 250
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:27
                    Terminal 15: On
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000093468588
   Coding: 003B0220D001048000001000
   VCID: 4480F13CCF95066AB9-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004375448
   Coding: 0D0000
65558 - Heated Exterior Mirror
          B11F8 14 [009] - Open or Short to Ground
                    Fault Frequency: 21
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:37
65650 - Turn Signal in Exterior Mirror
          B11FD 13 [009] - Open Circuit
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:23
65654 - Motor for mirror fold-in
          B11F6 13 [009] - Open Circuit
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 14:16:14
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 418EF828D087134292-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000093350543
   Coding: 003B0020DE01048000801000
   VCID: 4382F220CA9B015280-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000004391698
   Coding: 050000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    040 0430
   Serial number: V7F02202142644
   Coding: 02730001FF00000021111201002800001F0100160100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 67DA06B09E630D727C-8032
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9NJ9037N4
   Subsystem 2 - Part No SW: 5G0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
6917 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 250
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:27
                    Voltage terminal 30: 14.4 V
6939 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 250
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:26
          U1111 00 [009] - -
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:30
                    Voltage terminal 30: 14.5 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 210
                    Mileage: 52285 km
                    Date: 2018.11.24
                    Time: 13:46:29
downtime
C?ID=280813
You ABS block should be fine for blind spot assist. It already has ACC installed so BSM should be good to go as well. You have 30 byte block already. Byte 29 has Rear cross traffic alert coding which is the only thing you need to code to ABS block for BSM.
myounus
Northwest UK
C?ID=321059
That's good news then! I'll get on wiring it in (not looking forward to the mirrors wiring).
Thanks downtime :)
downtime
C?ID=280813
Thanks downtime :)
Good luck :) Mirror wiring is not that bad as it seems. There's not much room to play with the door connector on car side and pulling the wiring through the rubber protecting the wires to the door is not that nice, but it's not that bad.
RCTA bit is the only change required in ABS block. If that is not accepted, then no probs. You'll just don't enable it.
If you want to do the coding already, here's a new coding for your ABS block with RCTA bit enabled :
01FA8AA1242709700380060541C92980512490C0608294F3F8625078C282
myounus
Northwest UK
C?ID=321059
Thanks I'll try it tonight when I'm with the car. I think I'm going to swap the bcm also to a highline one to add in xenon and afs.
It currently has Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Would you say the best version for this car is 5Q0937084AJ?
darkchina811
ITALY
C?ID=333184
the mirror thing is the only thing which is holding me back from the BSM retrofit. I don't want to replace the mirrors' glasses because I already replaced them with aftermarket antiglare version, and I am totally in love.
then I thought: the BSM mirror LED must not be much different from a regular LED, so what if I installed just a round LED on the car doors?
downtime
C?ID=280813
It checks the current at startup and if it deviates enough it will disable the BSM system. If you get the resistance correct it should work.
There are videos in youtube where Leon owners have retrofitted BSM system and used leds in A pillars as indicators. Leon uses same 5Q0 modules.
Isn’t there anti-glare BSM mirror glasses available?
darkchina811
ITALY
C?ID=333184
that's exactly what I would like, do you maybe have any Leon forum links?
I was not able to find ANY antiglare glass for Golf, which is strange because Octavia has them.
darkchina811
ITALY
C?ID=333184
being italian I need little help to read spanish. thanks.
it looks like they used a stupid 12V LED, I will have to look into it.
myounus
Northwest UK
C?ID=321059
The ones I've got are fine, I don't get glare from them. The lights are the mirrors are yellow/orange are its quite cool how it works. They light up when a car is next to you in your blind spot and if you indicate the light starts to flash to warn you. If you then start to turn your steering the steering wheel shakes to warn you that you are likely to crash. The positioning of the lights are just perfect.
Anyway does anyone have any suggestions about the BCM?
I've also just come up with another problem, the dealers won't sell me the plug that goes into the glass, they're saying I have to purchase the entire mirror!! It's a really long and narrow section and I can't find it on ETKA either.
downtime
C?ID=280813
Look here, I wrote a small description about my Leon BSM retrofit. I have the connectors and pins there.
https://forums.ross-tech.com/showthread.php?12734-2013-Seat-Leon-5DR-1-2-TSI-DSG-Style-(MQB)&p=133971&viewfull=1#post133971
Copy paste, auto url does not work :)
The pins and connectors are JST, not VAG official components. You can find the parts easily from ebay.
myounus
Northwest UK
C?ID=321059
Thanks for that, great write up. I've just ordered the connectors and housing from RS Components here in the UK.
02R-JWPF-VSLE-S - waterproof housing for the mirror
SWPR-001T-P025 - female connectors.
The only trouble is minimum order for the housing is 5 so got a few spare but the connectors is 100! At 4p each it's not much but what a waste.
darkchina811
ITALY
C?ID=333184
I have a BCM AJ if you need it.
darkchina811
ITALY
C?ID=333184
do you think there is any chance to know the current involved?
downtime
C?ID=280813
Trial and error?
No seriously, there was a writeup somewhere (maybe here) in which a person measured the differences in Audi?
myounus
Northwest UK
C?ID=321059
Guys
I'm almost done with the install but I have an ABS pump that is too old. Ive got 5Q0 H31 0557 and the min to make this work is H31 0571 or a 3Q0 pump. Is it possible to upgrade the software or does it need replacing?
If replacing then will my ABS code still work??
downtime
C?ID=280813
if you’re able to find a newer software upgrade should be possible. Otherwise pump upgrade.
The 3Q0 AB pump though has everything. It’s the creme de la creme of abs pumpa :)
If you’re current pump is IPB the code should be easier to create.
myounus
Northwest UK
C?ID=321059
The obvious next question is where would I locate a software upgrade? Dealership???
I've never upgraded an ABS pump before.
