Amarok 2H Back-up cam retrofit trouble
FranKeRS
Norway
C?ID=111403
Hello.
I did retrofit Back-Up cam and a Pioneer head-unit to my Amarok. To do this I ordered a retrofit-kit for the camera similar to the one Kufatec sells (intended for the RCD-510). Then I ordered a conversion cable kit for the Pioneer head-unit. And another conversion-kit to connect "original" back-up camera to the Pioneer.
I then activated module 6C in CAN gateway list. Did the coding for the module, and I the camera works somehow as expected. My problem is that I can't get the calibration to register.
I go in to module 6C. Choose Security-Access and enter the pin as stated in the pop-up. It is accepted, so I go in to Adaptation, and follow the steps ending in changing value from 0 to 1 in the last step. All steps are accepted. I clear the fault-code, and go back in to fault-codes. The same error comes back.
Anyone able to help me? Any steps I missed?
Autoscan:
Tuesday,14,January,2020,17:12:58:39202
VIN: WV1ZZZ2HZCA064485   License Plate: RK77259
Mileage: 23120km-14366mi   Repair Order: 03
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 18 19 22 25 32 56 69 6C 77
VIN: WV1ZZZ2HZCA064485   Mileage: 23120km-14366miles
56-Radio -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0011
Address 01: Engine (J623-CDCA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FA    HW: 03L 907 309 K
   Component: R4 2.0l BTD   X43 9978
   Revision: 26X43---    Serial number: 00000000000000
   Coding: 01194012232600080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
   ROD: EV_ECM20BTD01103L906019FA_004.rod
   VCID: 6FBBD41B57149E5F20D-803A
Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 G    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0106
   Revision: 00H44001
   Coding: B07324B6919A0D9924A689AB6F5510
   Shop #: WSC 07456 790 49164
   VCID: 34311B777E32FD871DF-8060
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 2H0 907 047 C    HW: 2H0 907 047 C
   Component: Climatic-T5   H19 0404
   Revision: 00001007
   Coding: 0000000002
   Shop #: WSC 07456 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 2809FF07B27A8967A17-807C
   Part No SW: 6R7 937 087 K    HW: 6R7 937 087 K
   Component: PQ25 BCM      H27 0532
   Revision: -1------    Serial number: 1009009900
   Coding: 2C0000380C01000000280C103C4B94D50080410E60020000300000000000
   VCID: 4CC1639706C2854765F-8018
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3321
   Coding: 100000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3321
   Coding: 100000
   Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Serial number: 0061349
   Coding: 020000
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00B H07 0013
   Revision: --------    Serial number: 003HN007CSEI
   Coding: 000000000000000000000000000000003042
   Shop #: WSC 07446 790 50316
   VCID: 3333186B7BBCFABF045-8066
   Serial number: 3495RRB40670VC0KO8TC
   Serial number: 3505RRB404V0VC0KK9A4
   Serial number: 3555YRB405B134DQHGDV
   Serial number: 3565YRB40650V8BO7PA7
   Part No SW: 2H0 920 861 B    HW: 2H0 920 861 B
   Component: KOMBI         H02 0505
   Coding: 150A00
   VCID: 2615F13FB86E9F1793B-8072
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0010031
   Shop #: WSC 07456 000 09999
   VCID: 2411EB37C2D26D078DF-8070
   Part No SW: 6N0 909 901     HW: 6R7 937 087 K
   Component: GW-K-CAN TP20 H27 0532
   Revision: -1------
   Coding: 742000
   Shop #: WSC 07462 790 50316
   VCID: 70B9D7674AAA81A7397-8024
   Part No SW: 2H0 927 755 B    HW: 2H0 927 755 B
   Component: SG offroad VTG      0153
   Revision: 00H06000    Serial number: T1IYC34413PZH3
   Coding: 0000013
   VCID: 2F3B141B9B14DE5F60D-807A
   Component: IMMO          H02 0505
   VCID: 6A8DC50F6CF67B77773-803E
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771 A    HW: 2H0 927 771
   Component: Quersperre    H04 0017
   Revision: 11001001    Serial number: 4DG 10.03.12 00
   Coding: 000001
   ASAM Dataset: EV_QuersUDSAAMVN817 A01606
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 2C010317A682A54745F-8078
Address 56: Radio
   Revision: 3A001001    Serial number: 00008030021836
   Coding: 0100000100000000
   VCID: 303917678A2AC1A7797-8064
   Part No SW: 2H0 907 441     HW: 2H0 907 441
   Component: J772__Rearview      0020
   Revision: 00H11000    Serial number: 525 PA8J2Z0169
   Coding: 0010717
   Shop #: WSC 98765 666 38384
   VCID: 6393A82B875C2A3FB45-8036
03006 - Back-up Camera System not calibrated
                    Reset counter: 25
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661841667
   Coding: 0F00010000010101
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BFC3BBF64861FA8D-8072
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Reset counter: 25
                    Mileage: 23120 km
                    Date: 2020.01.14
                    Time: 17:07:44
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 25
                    Mileage: 23120 km
                    Date: 2020.01.14
                    Time: 17:07:44
End----------(Elapsed Time: 01:06, VBatt start/end: 14.3V/14.3V)-----------
Admin note: Please don't use FONT tags in your scan.
FranKeRS
Norway
C?ID=111403
I'm sorry. What is FONT tags? I just copy-pasted my Autoscan from notepad.
Edit: I can see what they are. But I have no idea how they got there, or how to remove them. When I edit the post, I only see the plain text in my autoscan.
Well, it's full of stuff like this:
[FONT=Verdana]
[/FONT]
I'm scratching my head wondering how you managed to do that. Notepad normally just leaves text alone.
FranKeRS
Norway
C?ID=111403
I did misunderstand what FONT tags are. I tought they were the green words you can hover over to see their explanations.
Like i wrote earlier. There are no FONT tags in the autoscan part of the post when I click "Edit Post" to look for them. Should be easy enough to find after you showed me exactly where to look..
I will post the autoscan again here. Just to see if it happens again. This is again direct copy paste from my autoscan.txt named "[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]Log-RK77259-WV1ZZZ2HZCA064485-23120km-14366mi-03.txt" [/FONT](opened in Notepad. Ctrl+A. Ctrl+C, Then Ctrl+V between CODE and /Code brackets)..
   Revision: 00H44001
   Revision: 00001007
   Coding: 0000000002
   Coding: 100000
   Coding: 100000
   Coding: 020000
   Coding: 150A00
   Coding: 0010031
   Revision: -1------
   Coding: 742000
   Coding: 0000013
   Coding: 000001
Address 56: Radio
   Coding: 0010717
                    Reset counter: 25
   ROD: UHVNA.rod
                    Reset counter: 25
                    Mileage: 23120 km
                    Date: 2020.01.14
                    Time: 17:07:44
                    Reset counter: 25
                    Mileage: 23120 km
                    Date: 2020.01.14
                    Time: 17:07:44
Well there is certainly something strange going on there, that doesn't seem to happen for anyone else, because the FONT tags are still there, even in your new post. I'm at a loss to explain it.
obedlink
Guatemala
C?ID=346572
I understand that you have a Pioneer aftermarket radio and an OEM style camera with the black 21-pin connector.
I think you also bought the RCA camera conversion kit, since the camera is RGB type and the radio has RCA video input.
1. Activate 6C on the can gateway is only for the camera with module (high version camera)
2. The error in the telephone module is because the bluetooth module will not work with the radio aftermarket.
3. When you use an aftermarket radio there is nothing that can be done with coding.
the error about the camera calibration, I think is not important, since it is assumed that the camera is directly connected to the pioneer radio, the camera is no longer part of the car system.
That is what I understand with what you say.
FranKeRS
Norway
C?ID=111403
Sorry for late reply.
This is the OEM camera with module (RVC High), and the calibration is to get the helping lines (both static, and moving) to line up correctly.
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb Part No SW: 2H0 907 441 HW: 2H0 907 441
Coding: 0010717
Reset counter: 25
